Can not install SMAC 4.1/4.2
1,339 次查看
niket_304
I have downloaded and installed SMAC 4.1c and SMAC 4.2. but i can not use it directly from beekit. It gives error while i select codebase from beekit. How to use it????
635 次查看
Alban
Senior Contributor II
May be if you were describing the error... people could think about helping you.
Unfortunately, the only answer that comes to my head is: Have you read the user guide ?
There is one thing that needs to be remembered on Forums:
- People are helping during the free time,
- The more qualified people are, the less free time they have,
- If you don't have time, you answer clear questions first,
This leads to the following:
"You shall not lose too much of your time trying to get more information to try and solve the problem of someone who may not even thank you at the end."
In a nutshell, the more detailed the question is, the more luck you can have that someone will answer it.
This is not especially for you, but I am certain that everyone who reads this post is likely to agree. We already had the conversation in the past in this same forum.
Cheers,
Alban.
