Can JTAG on NXP ARM MCUs be used for programming?
3,024件の閲覧回数
phirung
I'm evaluating the LPC11U6x family for a low-volume hobbyist project, but will automate PCBA production. A common approach is to use JTAG to verify the PCBA and upload code. JTAG is briefly described in the family datasheet.
However, there's no mention of the ability to use JTAG to upload code. If this is not possible, can code be uploaded as a final production step via an external hardware interface rather than using the internal bootloader?
タグ(1)
2,988件の閲覧回数
gusarambula
Hello Phirun Ng,
You may use JTAG to upload the code to your device. You may find more details on how to connect using JTAG on the following Community Document.
https://community.nxp.com/thread/388998
I hope that this helps!
Gustavo
2,988件の閲覧回数
phirung
Thanks for the advice and the link. Am still working through initial docn and finding my way around the site. All looking very promising.
