Buy mcu with programmed Code
1,928件の閲覧回数
lamatrice
Hi, I want to know if it is possible to buy mcu with programmed code (our code). The mcu is MC9S08PA4AVTG and I planned to buy 1k to 10k qty to start.
3 返答(返信)
1,815件の閲覧回数
lamatrice
Awesome thanks for the advice. I will keep some identifier!
1,815件の閲覧回数
scottm
Senior Contributor II
Lots of distributors will do that.  The service can include laser marking and re-reeling, too.  Watch out on the laser marking - I went a little overboard on the part number the first time I did that, and it overwrote the whole surface of the device and was totally unreadable. I kept it to a 2-letter identifier after that.
Scott
1,815件の閲覧回数
vicentegomez
You need to contact your local distributor (Arrow,Avnet)to check if they have this service.
Vicente Gomez
