BeeStack Application Integration
1,838 次查看
toffer
hi,
   i have a problem regarding my own zigbee application. i've read through the several Beestack documents. i've also a copy of beekit. i am planning to use the beestack codebase but i am having a problem on how to integrate my application into the beestack layers. i am confused on how to add my application into the application object part of the application layer in the beestack. can someone help me solve this problem?also, are the codes in the beekit only intended for Home Automation usage?can i somewhat configure them in order to fit into my application?thanks ahead for the help!
regards,
toffer
1,186 次查看
addiyi
Hello Toffer,
If you don't need Home Automation, you can start you a application from GenericApp demo project.  The GenericApp measures and displays movement of a board (Accelerometer application). Try to undestand how this application work and then instead of Accelerometer app you should integrate your application.
Adrian
