BDM interface design
5,529 次查看
RChapman
This message contains an entire topic ported from a separate forum. The original message and all replies are in this single message. We have seeded this new forum with selected information that we expect will be of value to you as you search for answers to your questions.
Fri Sep 24, 2004 7:45 pm
Is there a published circuit design anywhere showing how to design your own PC to BDM interface?
Posted: Thu Nov 04, 2004 10:42 am
Hi!
I was looking for other info on FSL website and found that:
http://www.freescale.com/files/microcontrollers/doc/app_note/AN1230.pdf
That's a reference design to build BDM to parallel interface.
There's also a reference to files, but it's through a BBS Confused ....
How old can it be ? Very Happy
May be if you search for 'AN1230 software' there will be something.
A BBS.... I was young when I was using them Wink
Posted: Sat Dec 25, 2004 4:34 pm
FYI,
http://www.allactivex.com
has USB pod base on PIC MCU.
this site give the schematic and PCB layout but firmware for PIC must buy from him for 47 USD (include MCU). i think this cheaper then pemicro USB pod 199 USD.
i already buy usb pod from pemicro but stuck on code warrior software since i already familiar with pemicro IDE on hc08. pemicro (you know) don't give it's hcs08 IDE for free.
i may be will buy pemicro ICD but i'm not sure it's support non intrusive command.
Posted: Sat Dec 25, 2004 6:56 pm
Thanks for the info on this solution, after looking around for a while we decided to design our own. We couldn't bear to use one based on a PIC or AVR
Message Edited by RChapman on 01-19-2006 02:43 PM
Message Edited by RChapman on 01-19-2006 02:47 PM
0 回复数
