Are FXTH87 and FXTH87E codes(.s19 file) compatible
1,226件の閲覧回数
jack_wang
Respected Administrator:
    Hello.
    Are FXTH87 and FXTH87E codes(.s19 file) compatible?
    If I can't use FXTH87 code(.s19 file) directly on FXTH87E, where do I need to change it?
                                                Jack Wang
1,113件の閲覧回数
lisettelozano
Hello LiuKai,
The FXTH87 and FXTH87E are different mainly in the pressure range depending on the part number; here you can see it clearly https://www.nxp.com/docs/en/product-selector-guide/FXTH87A4FS.pdf
We recommend you to check the documentation available regarding the Embedded Firmware in order to know what is inside each TPMS sensor; in this way you can see what should need to be changed:
https://www.nxp.com/docs/en/user-guide/FXTH87xx1XFWUG.pdf
https://www.nxp.com/docs/en/user-guide/FXTH87xx22FWUG.pdf
https://www.nxp.com/docs/en/user-guide/FXTH87xx02FWUG.pdf
https://www.nxp.com/docs/en/application-note/AN12523.pdf
Paulina
