Access variables in a C program from inline asm
3,148件の閲覧回数
rasmusnygaard
How do I access variables in a C program from inline asm. Now I access the variable by writing direct to the RAMadress from asm.
What do I write instead of XXX when I want to increment the testvar?
void main()
   char testvar;
   asm
      inc XXX
Rasmus L. Nygaard, Denmark
2 返答(返信)
1,848件の閲覧回数
rasmusnygaard
Thanks - it works. I did not even try this straight forward method, because of my experience from other compilers.
1,848件の閲覧回数
CrasyCat
Specialist III
Hello
I assume you are using CodeWarriot for HC08. AM I right?
You just use the variable name as defined.
void foo(void)
   char testvar;
   __asm
      inc  testvar
CrasyCat
