AN3942 source file is needed
white01
Hello, I am currently trying to program FLASH memory using MC9S08LH64, but I am failing
Some time ago I found the file AN3942.pdf, but nowhere in public sources I can not find the file with the code (AN3942SW.zip), only stumbled upon the posts as someone was sent it personally. Is there any way I can get this file? Thanks
Pablo_Ramos
You can use the following link in order to download the AN3942SW.
nxp.com/doc/AN3942SW
