ADC FIFO conversion speed
1,105 次查看
jason_zhang
I am using the ADC FIFO mode to get 3 anolog channels results.
When continuous conversion and interrupt are enabled, the interval time is about 300uS that can jump to ADC Interrupt.
I want to change the interval time into 1mS by the below method:
1. ADC Interrupt enable per 1mS in the timer interrupt.  // ADC_SC1 |= ADC_SC1_AIEN_MASK;
2. ADC Interrupt disable when get out of  the  adc interrupt. //// ADC_SC1 &= ~ADC_SC1_AIEN_MASK;
But the interval time is 3mS, could you kindly explain why the speed has been down.
MCU:MC9S08PA60
ADC setting: ADC FIFO mode/12-bit conversion/Long sample time/3-level FIFO is enabled
Thank you!
Jason
0 回复数
