9s08AW FLL
9s08AW FLL
2,565 次查看
CCandido
Contributor V
Hello, my FLL 9s08AW no run.
Internal configuration = OK
Xtal = 4mhz (FLL 40mhz)= busclock=20mhz
NOTE:
/* PE initialization code after reset */
SOPT =0x52;
SPMSC1=0x1C;
SPMSC2=0x00;
SMCLK =0x17;
/* System clock initialization */
ICGC1=0x5C; // 38.....
ICGC2=0x30; // 32.....
ICGTRM = *(unsigned char*)0xFFBE;
while(!ICGS1_LOCK) { /* Wait */
thenks,
Edited by Carlos Candido from Brazil,
860 次查看
Andik
Section 8.5.3 "Example #2: External Crystal = 4 MHz, Bus Frequency = 20 MHz":
INITIALIZE ICG
ICGC1 = $7A
ICGC2 = $30 ...
I used FLL in FEI mode at 30MHz, and it worked (ICGC1=$28, ICGC2=$50).
Good luck.
860 次查看
CCandido
Contributor V
INITIALIZE ICG
ICGC1 = $7A
ICGC2 = $30 ...
goto RUN = OK
Andik Thenks,
