'908AB32 Power Supplies
1,667 次查看
J_Gordon
I am interested in understanding if there is any compelling reason to provide power to the analog section of the Clock Generator Module (CGM) or Analog-to-Digital Converter (ADC) section of the HC908AB32 if my application does not make use of the PLL or the ADC? If it is not necessary to power the unused modules, should the associated power, reference and ground pins be left all unterminated, all terminated to Vss or some combination?
Additionally - Is there any reason to provide the external filter capacitor for the CGM PLL (pin CGMXFC) if the PLL is unused and off?
I look forward to knowledgable replies and thank you in advance.
790 次查看
J_Gordon
Thanks for your insight.
790 次查看
bigmac
Specialist III
I think it would be safer to connect the various Vdd and Vss pins according to the data sheet.  I can't see that there is anything to be gained by not doing so, and this may avoid side effects that may not be immediately apparent.  We don't know what intrinsic diodes may be present between the internal modules.  The power required by the CGM PLL and the ADC should already be reduced when not enabled.
You can probably omit the CGMXFC filter capacitor when the PLL is not used.
Mac
