32bit additon on the HC08
1,551 次查看
Bloodhound
Hi all,
I am assuming this is possible?
I need to be able to increment a number by 254 until it reaches
$06000000.
Can anybody please demonstrate in assembler how this might be done?
Ross
725 次查看
Bloodhound
Thanks Peg, makes perfect sense, much appreciated.
Cheers,
Ross
725 次查看
peg
Senior Contributor IV
Hi Ross,
Anything can be done, it just a matter of how much code is required.
here is a full programme that will run in GP32 simulator.
Code:
 org $40num rmb 4  ;4 bytes of storage org $8000start clr num  ;clear storage clr num+1 clr num+2 clr num+3 loop lda num+3 sta $FFFF  ;reset COP add #$FE  ;add 254 sta num+3 bcc loop inc num+2 bne loop inc num+1 bne loop inc num lda num  ;test MSByte cmp #6  ;for $06 bne loop  ;loop back if not equalend sta $FFFF  ;reset COP bra end  ;loop here when finished org $FFFE  ;reset vector dw start
