MK10 Bootloader.
MK10 Bootloader.
john71
Senior Contributor I
I've opened a IAR project that resides in AN2295sw. The project has some configuration files
AN2295_TWR_K60_cfg.h
AN2295_TWR_KL25_cfg.h
But if want to use MK10 chip - what file should I use? Or how should I alter the existing file?
Hui_Ma
Please try with attached AN2295 software.
In IAR project, please select the [Kinetis K 120MHz Release] target:
Wish it helps.
Ma Hui
john71
I configured the project for my chip MK10DN512. But when I connect with Universal Bootloader utility it returns
Waiting for HC(S)08 reset ACK (timeout: 10s)...received 0xfc (good).
Calibration break pulse sent. Count: 3
Can't read MCU info. Could be protocol error.
(Or forgot to set single wire mode?)
So I set checkbox - Single Wire and I get
Waiting for HC(S)08/ColdFire/Kinetis reset ACK (timeout: 0s)...
Error receiving reset ACK - TIMEOUT.
How can I debug the problem?
Hui_Ma
Please use <AN2295_TWR_K60_cfg.h > for MK10 chip.
The chapter 7.7 Correct setting of configuration file provides more detailed info about Kinetis configuration file.
Wish it helps.
Ma Hui
john71
I see. Thank you.
I created AN2295_TWR_K10_cfg.h file and included it. But now I have some errors like
Error[Pe020]: identifier "SIM_SCGC6_FTFL_MASK" is undefined. I found the definition SIM_SCGC6_FTFL_MASK only in MKxxDZ10.h headers. For K10F12 there is no such definition.
Regards.
Hui_Ma
There with some modules register difference with MK10 120MHz product vs. MK60 100MHz product.
The project header file need change to use "MK10F12.h" at <main.h>.
Ma Hui
john71
So I should manually add missing definitions? Or there is no such registers in MK10F? In this case - it's a lot of changing, I should dig deep to adapt the chip for the bootloader.
Well...I did some digging around - there is no FTFL for KxxF series, only for KxxD. I don't know what developers do to make K60 work in demo project. May be they could share? Or should I go crazy chasing things that should be obvious and explained?
Hui_Ma
Wish it helps.
Ma Hui
john71
Thanks a lot my friend! Awesome!
