Hi Ritesh
please verify that nand was programmed with mfg tool
using steps described on
How-To use NAND boot on i.MX6UL EVK board
for debugging one can use procedure given on
https://community.freescale.com/thread/307723
with difference that ROM address 0x000001e0 contains pointer
to internal RAM location where boot log buffer is stored.
After fail, one can connect jtag and check boot data at 0x907400.
