Where is detail description for Systick for KL?
kai_liu
Senior Contributor I
I checked datasheet and reference manual (kl25p80m48sf0rm.pdf, kl25p80m48sf.pdf, klqrug.pdf) of Kinetis L series, but I can not find the description for systick, including register map and definitions.
I can find its definition from source code, but I still need the document. Have I missed some important documents?
Yours sincerely
Allan K Liu
BlackNight
The SysTick is an optional part of the ARM Cortex architecture (but most vendors have it implemented).
You find information on SysTick and other ARM core parts on the ARM web site:
ARM Information Center
I hope this helps,
Erich
BlackNight
I hope this helps,
Erich
kai_liu
Hi, Erich,
Nice to see your reply again. I got the information. Thanks.
