I checked datasheet and reference manual (kl25p80m48sf0rm.pdf, kl25p80m48sf.pdf, klqrug.pdf) of Kinetis L series, but I can not find the description for systick, including register map and definitions.
I can find its definition from source code, but I still need the document. Have I missed some important documents?
Yours sincerely
Allan K Liu
解決済! 解決策の投稿を見る。
The SysTick is an optional part of the ARM Cortex architecture (but most vendors have it implemented).
You find information on SysTick and other ARM core parts on the ARM web site:
I hope this helps,
Erich
I hope this helps,
Erich
Hi, Erich,
Nice to see your reply again. I got the information. Thanks.
