Help, NEW to Codewarrior IDE S12 V5.0 and KIT33812ECUEVME
MBEMotorsportsi
Hi am I new to forums, codewarrior and Freescale. I bought the reference design KIT33812ECUEVME a few weeks ago and still havn't been able to do anything with it. How or where do I start. I made all the connections but don't know if I the software has been uploaded or not in the ECU.
I read all the documents but seems to be missing details. Does anyone have detailed step by step instructions on how to get started with the small engine software example?
Thanks for all you help
usmanjavaid
u must start with the spin bench setup
after u r certain that the reluctance sensor is giving output u desired than make the wiring connections
then edit the software example inn the CD
Edit the application definition file to define your engine specs and the size of the lookup tables
then edit application map accordin to the specs of your fuel pump and fuel injector you are willing to use
u may Contact me via email
[email protected]
i am working on the same thing nowadays
sammaxel
Hi Usman,
I have just started this KIT33812ECUEVME project.
I have problems: no output signals on Injection and coil output.
are you really ever successfully using this kit on any motorcycle?
thanks in advance
jorge_plascencia
Hi Alex,
in this link you may find all the getting started documents and software that you may need for this kit. KIT33812ECUEVME: Small Engine Control Reference Design featuring the 33812 and the S12P Product Summ...
in this page you will find a section called Jump Start Your Design in this section you will find the following data:
Let me know if you need more information reading this kit.
J2MEJediMaster
Specialist I
Usually the kits come with a Quick Start guide that goes through the set up, stey-by-step. They also (but not always), tell you how the cable the gear up. Did you not find a Quick Start Guide?
---Tom
usmanjavaid
hi !
can u tell what might be the problem
i am using KIT33812ECUEVME with 8m1 toothed flywheel
the output pulses for fuel injector are comming in millivolts there are no high side pullup resistors with these output pins
is this pulse whose amplitude is in millivots capable of turning the fuel injector "ON" ---????????????????
regards:
Usman
[email protected]
