Compile L2.6.35_1.1.0_130130 for i.MX28 on Ubuntu 13.10 64bit OS
This is the procedure and patch to set up Ubuntu 13.10 64bit Linux Host PC and building i.MX28 L2.6.35_1.1.0_130130. It has been tested to build GNOME profile and with FSL Standard MM codec.
A) Basic Requirement:
  • Set up the Linux Host PC using ubuntu-13.10-desktop-amd64.iso
  • Make sure the previous LTIB installation and the /opt/freescale have been removed
B) Installed the needed packages to the Linux Host PC
$ sudo apt-get update
$ sudo apt-get install gettext libgtk2.0-dev rpm bison m4 libfreetype6-dev
$ sudo apt-get install libdbus-glib-1-dev liborbit2-dev intltool
$ sudo apt-get install ccache ncurses-dev zlib1g zlib1g-dev gcc g++ libtool
$ sudo apt-get install uuid-dev liblzo2-dev
$ sudo apt-get install tcl dpkg
$ sudo apt-get install asciidoc texlive-latex-base dblatex xutils-dev
$ sudo apt-get install texlive texinfo
$ sudo apt-get install lib32z1 lib32ncurses5 lib32bz2-1.0
$ sudo apt-get install libc6-dev-i386
$ sudo apt-get install u-boot-tools
$ sudo apt-get install scrollkeeper
$ sudo apt-get install gparted
$ sudo apt-get install nfs-common nfs-kernel-server
$ sudo apt-get install git-core git-doc git-email git-gui gitk
$ sudo apt-get install meld atftpd
$ sudo ln -s /usr/lib/x86_64-linux-gnu/librt.so   /usr/lib/librt.so
C) Unpack and install the LTIB source package and assume done on the home directory:
$ cd ~
$ tar -zxvf L2.6.35_1.1.0_130130_source.tar.gz
$ ./L2.6.35_1.1.0_130130_source/install
After that, you will find ~/ltib directory created
D) Apply the patch to make L2.6.35_1.1.0_130130 could be installed and compiled on Ubuntu 13.10 64bit OS
$ cd ~/ltib
$ git apply 0001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_13.10_64bit_OS.patch
What the patch is doing:
a) The patch modifies the following files:
    • dist/lfs-5.1/base_libs/base_libs.spec
    • dist/lfs-5.1/elftosb/elftosb.spec
    • dist/lfs-5.1/lkc/lkc.spec
    • dist/lfs-5.1/mux_server/mux_server.spec
    • dist/lfs-5.1/ncurses/ncurses.spec
b) Add the following files to the pkgs directory:
    • pkgs/elftosb-2.6.35.3-1385779630.patch
    • pkgs/elftosb-2.6.35.3-1385779630.patch.md5
    • pkgs/lkc-1.4-lib.patch
    • pkgs/lkc-1.4-lib.patch.md5
E) Then, it is ready to proceed the rest of the LTIB env setup process:
$ cd ~/ltib
$ ./ltib -m config
$ ./ltib
Reference:
NOTE:
When compiling gstreamer, this warning was pop up.  Just ignore it seems okay.
Labels (2)
Comments
useful patch
before build this should do many tips.
e.g.
pkgs/elftosb-2.6.35.3-1.1.0.tar.gz need modify Makefile
channge LIBS = -lstdc++ to LIBS = -lstdc++ -lm
now just add patch,
%3CLINGO-SUB%20id%3D%22lingo-sub-1099678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECompile%20L2.6.35_1.1.0_130130%20for%20i.MX28%20on%20Ubuntu%2013.10%2064bit%20OS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20is%20the%20procedure%20and%20patch%20to%20set%20up%20Ubuntu%2013.10%2064bit%20Linux%20Host%20PC%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Eand%20building%20i.MX28%20L2.6.35_1.1.0_130130.%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EIt%20has%20been%20tested%20to%20build%20GNOME%20profile%20and%20with%20FSL%20Standard%20MM%20codec.%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3EA)%20Basic%20Requirement%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3ESet%20up%20the%20Linux%20Host%20PC%20using%20ubuntu-13.10-desktop-amd64.iso%3C%2FLI%3E%3CLI%3EMake%20sure%20the%20previous%20LTIB%20installation%20and%20the%20%2Fopt%2Ffreescale%20have%20been%20removed%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3EB)%20Installed%20the%20needed%20packages%20to%20the%20Linux%20Host%20PC%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20update%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20gettext%20libgtk2.0-dev%20rpm%20bison%20m4%20libfreetype6-dev%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20libdbus-glib-1-dev%20liborbit2-dev%20intltool%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20ccache%20ncurses-dev%20zlib1g%20zlib1g-dev%20gcc%20g%2B%2B%20libtool%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20uuid-dev%20liblzo2-dev%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20tcl%20dpkg%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%24%20sudo%20apt-get%20install%20asciidoc%20texlive-latex-base%20dblatex%20xutils-dev%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20texlive%20texinfo%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20lib32z1%20lib32ncurses5%20lib32bz2-1.0%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20libc6-dev-i386%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20u-boot-tools%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20scrollkeeper%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20gparted%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20nfs-common%20nfs-kernel-server%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20git-core%20git-doc%20git-email%20git-gui%20gitk%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20apt-get%20install%20meld%20atftpd%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20sudo%20ln%20-s%20%2Fusr%2Flib%2Fx86_64-linux-gnu%2Flibrt.so%26nbsp%3B%26nbsp%3B%20%2Fusr%2Flib%2Flibrt.so%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3EC)%20Unpack%20and%20install%20the%20LTIB%20source%20package%20and%20assume%20done%20on%20the%20home%20directory%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20cd%20~%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20tar%20-zxvf%20L2.6.35_1.1.0_130130_source.tar.gz%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20.%2FL2.6.35_1.1.0_130130_source%2Finstall%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3EAfter%20that%2C%20you%20will%20find%20~%2Fltib%20directory%20created%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3ED)%20Apply%20the%20patch%20to%20make%20L2.6.35_1.1.0_130130%20could%20be%20installed%20and%20compiled%20on%20Ubuntu%2013.10%2064bit%20OS%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20cd%20~%2Fltib%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20git%20apply%200001_make_L2.6.35_1.1.0_130130_compile_on_ubuntu_13.10_64bit_OS.patch%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3EWhat%20the%20patch%20is%20doing%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSTRONG%3Ea)%20The%20patch%20modifies%20the%20following%20files%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3Edist%2Flfs-5.1%2Fbase_libs%2Fbase_libs.spec%3C%2FLI%3E%3CLI%3Edist%2Flfs-5.1%2Felftosb%2Felftosb.spec%3C%2FLI%3E%3CLI%3Edist%2Flfs-5.1%2Flkc%2Flkc.spec%3C%2FLI%3E%3CLI%3Edist%2Flfs-5.1%2Fmux_server%2Fmux_server.spec%3C%2FLI%3E%3CLI%3Edist%2Flfs-5.1%2Fncurses%2Fncurses.spec%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3CSTRONG%3Eb)%20Add%20the%20following%20files%20to%20the%20pkgs%20directory%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CUL%3E%3CLI%3Epkgs%2Felftosb-2.6.35.3-1385779630.patch%3C%2FLI%3E%3CLI%3Epkgs%2Felftosb-2.6.35.3-1385779630.patch.md5%3C%2FLI%3E%3CLI%3Epkgs%2Flkc-1.4-lib.patch%3C%2FLI%3E%3CLI%3Epkgs%2Flkc-1.4-lib.patch.md5%3C%2FLI%3E%3C%2FUL%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3EE)%20Then%2C%20it%20is%20ready%20to%20proceed%20the%20rest%20of%20the%20LTIB%20env%20setup%20process%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20cd%20~%2Fltib%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20.%2Fltib%20-m%20config%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%24%20.%2Fltib%3C%2FP%3E%3CP%20style%3D%22padding-left%3A%2030px%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012pt%3B%22%3E%3CSTRONG%3EReference%3A%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3EL2.6.35_1.1.0_130130_docs%2Fdoc%2Fmx28%2FSetting_Up_LTIB_Host_on_Ubuntu_9_04.pdf%3C%2FLI%3E%3CLI%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-93394%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-93394%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F332385%23332385%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F332385%23332385%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F271675%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fthread%2F271675%3C%2FA%3E%3C%2FLI%3E%3CLI%3E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fmessage%2F360556%23360556%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fmessage%2F360556%23360556%3C%2FA%3E%3C%2FLI%3E%3CLI%3Escrollkeeper%20is%20for%20the%20gnome-desktop%20compilation%3C%2FLI%3E%3CLI%3Eelftosb%20compilation%20issue%20fixed%20by%20added%20-lm%20to%20LIBS%20in%20the%20%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Eelftosb-2.6.35.3-1.1.0%2Fmakefile.rules%20%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ENOTE%3A%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EWhen%20compiling%20gstreamer%2C%20this%20warning%20was%20pop%20up.%26nbsp%3B%20Just%20ignore%20it%20seems%20okay.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22panel.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22panel.jpg%22%20style%3D%22width%3A%20563px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F42466i04B8FCF7DEB8E150%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22panel.jpg%22%20alt%3D%22panel.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22panel2.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22panel2.jpg%22%20style%3D%22width%3A%20535px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F41361i8533BF8D7C9DE780%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22panel2.jpg%22%20alt%3D%22panel2.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1099678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX2x%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Compile%20L2.6.35_1.1.0_130130%20for%20i.MX28%20on%20Ubuntu%2013.10%2064bit%20OS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Euseful%20patch%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Ebefore%20build%20this%20should%20do%20many%20tips.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Ee.g.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Epkgs%2Felftosb-2.6.35.3-1.1.0.%3CSPAN%20class%3D%22skimlinks-unlinked%22%20style%3D%22font-family%3A%20inherit%3B%20font-style%3A%20inherit%3B%20font-weight%3A%20inherit%3B%22%3Etar.gz%20%3C%2FSPAN%3Eneed%20modify%20Makefile%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Echannge%20LIBS%20%3D%20-lstdc%2B%2B%20to%20LIBS%20%3D%20-lstdc%2B%2B%20-lm%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Enow%20just%20add%20patch%2C%3C%2FP%3E%3CP%3Epkgs%2Felftosb-2.6.35.3-1385779630.patch%3C%2FP%3E%3CP%3Epkgs%2Felftosb-2.6.35.3-1385779630.patch.md5%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎12-09-2013 03:57 AM
Updated by:
