Adeneo Embedded: Building Qt 5.1 for Freescale i.MX6 – A white paper by Cuong Chou
Introduction
Currently there is not an easy procedure to build Qt 5.1 with hardware acceleration support for Freescale i.MX6 platform. This document describes the steps necessary to download all the prerequisite oftware, build Qt 5.1 code and examples, and verify the hardware acceleration support status.
Required Software
1.     To start building, we need some development tools. This build is verified on LTIB (L3.0.35_4.0.0_130424_source.tar.gz downloaded from FreeScale website) and cross-compiled on a Ubuntu 12.04 64-bit PC. Verify that gpu-viv-bin-mx6q option is enabled in the LTIB configuration.
                   $ mkdir -p ~/BSP
                   $ cd ~/BSP
                   $ tar -xzvf L3.0.35_4.0.0_130424_source.tar.gz
2.     Download Qt 5.1.1 source code from the Qt-project website. Create a build directory and extract the content in it.
                   $ mkdir -p ~/Qt5
                   $ cd ~/Qt5
                   $ tar -xJvf qtbase-opensource-src-5.1.1.tar.xz
Build procedure:
1.     Enter the Qt5 build directory and create a configuration script as follows:
                  $ cd ~/Qt5/qt-everywhere-opensource-src-5.1.1/qtbase
                  $ vi config.imx6
                  #!/bin/sh
                  ./configure -opensource -confirm-license -make libs -device imx6 \
                  -device-option CROSS_COMPILE=\
                  /opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-fsl-linux-gnueabi- \
                 -no-pch -no-opengl -no-icu
                 -no-c++11 \
                 -opengl es2 \
                 -eglfs \
                 -compile-examples \
2.     Edit the device configuration to specify the root file system of the BSP. Make sure the config file contains lines that match with what lists below
                   $ cd ~/Qt5/qt-everywhere-opensource-src-5.1.1/qtbase/mkspecs/devices/linux-imx6-g++
                   $ vi qmake.conf
                   ROOTFS=/home/trainee/BSP/L3.0.35_4.0.0_130424_source/ltib/rootfs
                   QMAKE_INCDIR           += $$ROOTFS/usr/include
                   QMAKE_LIBDIR           += $$ROOTFS/usr/lib
                   QMAKE_LFLAGS           += -Wl,-rpath-link,$$ROOTFS/usr/lib
3.     Run the configuration script and make sure that Qt5 has openGL ES 2.0 support when it is complete. Note that you must run 'make confclean' to remove the previous configuration when any hanges are made to the script.
                $ ./config.imx6
                          This is the Qt Open Source Edition.
                          You are licensed to use this software under the terms of  the Lesser GNU General Public License (LGPL) versions 2.1.
                          You have already accepted the terms of the  license.
                          Creating qmake...
                           Support enabled for:
                           Accessibility  .......... yes
                           OpenGL .................. yes (OpenGL ES 2.x)
                           Qt is now configured for building. Just run 'make'.
            Once everything is built, you must run 'make install'.
            Qt will be installed into             /home/trainee/BSP/L3.0.35_4.0.0_130424_source/ltib/rootfs/usr/local/Qt5.1.1
            Prior to reconfiguration, make sure you remove any leftovers from
            the previous build.
4.     Do a build. Note that all the libraries are copied to the appropriate directories in the root file system.
                   $ make all -j8
                   $INSTALL_ROOT=/home/trainee/BSP/L3.0.35_4.0.0_130424_source/ltib/rootfs/ sudo
                   make install
       5.     Build the examples
               $ cd examples
               $ make
6.     Copy an example (hellogl_es2) used to demonstrate openGL ES to the root file system.
               $ sudo cp opengl/hellogl_es2/hellogl_es2
   Verify h/w acceleration support:
1.     Boot the board and verify that the galcore module is installed
              $ cat /proc/devices | grep galcore
              $ ls /dev/galcore
2.     Set up the required Qt environment
              $ export QT_PLUGIN_PATH=/usr/local/Qt-5.1.1/plugins/
       3.     Run the example. You shall see a rotating Qt logo on the display.
              $ cd /
              $ ./hellogl_es
      4.     Run top command and it shows the application running with a very low (0 – 1 %) cpu usage.
              $ top
                PID PPID USER     STAT   VSZ %VSZ CPU       %CPU COMMAND
                2820 2809  root         S         188m 21.5   0              0.7       ./hellogl_es2
About Adeneo Embedded
Adeneo Embedded provides system integration, design, support and training services to companies seeking world-class expertise in embedded solutions using high-performance architectures. For over
10 years, Adeneo Embedded has helped clients, in all stages of development; create profitable, feature-rich products that incorporate software and hardware solutions based on Android, Embedded Linux, Windows Embedded or Windows Mobile operating systems. Close working partnerships with industry-leading silicon and software vendors allow Adeneo Embedded to apply its experience to a wide range
of embedded solutions for the automotive, industrial, medical,  multi-media, navigation,  networking, mobile and wireless markets. Adeneo Embedded has a global sales and support network backed by engineering offices in North America and Europe.
Further information
For more information about Adeneo Embedded competences, products and services around Windows Embedded technologies:
Ä  visit Adeneo Embedded dedicated web site               www.adeneo-embedded.com
Ä  Adeneo Embedded General sales contact                 [email protected]
For a local contact in
Ä  Europe, please contact Jeremy Delicato                   [email protected]
Ä  America, please contact Mike Ruiz                            [email protected]
コメント
Hello:
     thanks for your share ,but follow your steps above,there is no error ,but when I run the demo
   $ ./hellogl_es
it appear
QIconvCodec::convertFromUnicode: using Latin-1 for conversion, iconv_open failed
QIconvCodec::convertToUnicode: using Latin-1 for conversion, iconv_open failed
Segmentation fault
i don't know why ,can u help me
Thanks for looking at the paper.
I could see there are 2 potential causes to the problem you're seeing:
1. The galcore module is not installed or not installed properly.
2. The version of your kernel doesn't match the version of the Vivante GPU libraries. For example, if you are using a Linux 3.0.35 4.1.0, you need to have the Vivante GPU libraries 4.1.0 and not the version 4.0.0.
Hope this helps.
thanks for you replay,and last week ,I used 4.00 ltib ,and have no error!
Hello all,
Can you provide me LTIB 4.0.0 for imx6 Sabre?
I'm interesting to following this tutorial, but freescale only have available the latest version on your website.
Cheers
%3CLINGO-SUB%20id%3D%22lingo-sub-1117215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAdeneo%20Embedded%3A%20Freescale%20i.MX6%20%E7%94%A8%E3%81%AE%20Qt%205.1%20%E3%81%AE%E6%A7%8B%E7%AF%89%20%E2%80%93%20Cuong%20Chou%20%E3%81%AB%E3%82%88%E3%82%8B%E3%83%9B%E3%83%AF%E3%82%A4%E3%83%88%E3%83%9A%E3%83%BC%E3%83%91%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CH1%20id%3D%22toc-hId-381618991%22%20id%3D%22toc-hId-1304245458%22%3E%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%3C%2FH1%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%3E%E7%8F%BE%E5%9C%A8%E3%80%81Freescale%20i.MX6%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8BQt%205.1%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E7%B0%A1%E5%8D%98%E3%81%AA%E6%89%8B%E9%A0%86%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E5%89%8D%E6%8F%90%E6%9D%A1%E4%BB%B6%E3%81%A7%E3%81%82%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81Qt%205.1%20%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E4%BE%8B%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CH1%20id%3D%22toc-hId--1425835472%22%20id%3D%22toc-hId--503209005%22%3E%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%3C%2FH1%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%20style%3D%22text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Liberation%20Serif'%3B%20mso-bidi-font-family%3A%20'Liberation%20Serif'%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E1.%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%E6%A7%8B%E7%AF%89%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E9%96%8B%E7%99%BA%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%81%AFLTIB(L3.0.35_4.0.0_130424_source.tar.gz%20FreeScale%E3%81%AEWeb%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89)%E3%81%A7%E6%A4%9C%E8%A8%BC%E3%81%95%E3%82%8C%E3%80%81Ubuntu%2012.04%2064%E3%83%93%E3%83%83%E3%83%88PC%E3%81%A7%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82LTIB%20%E8%A8%AD%E5%AE%9A%E3%81%A7%20gpu-viv-bin-mx6q%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%24%20mkdir%20-p%20~%2FBSP%3C%2FDIV%3E%3CDIV%3E%24%20cd%20~%2FBSP%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20tar%20-xzvf%20L3.0.35_4.0.0_130424_source.tar.gz%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%20style%3D%22text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Liberation%20Serif'%3B%20mso-bidi-font-family%3A%20'Liberation%20Serif'%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E2.%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3EQt-project%E3%81%AEWeb%E3%82%B5%E3%82%A4%E3%83%88%E3%81%8B%E3%82%89Qt%205.1.1%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E4%B8%AD%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%82%92%E6%8A%BD%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20mkdir%20-p%20~%2FQt5%3C%2FDIV%3E%3CDIV%3E%24%20cd%20~%2FQt5%3C%2FDIV%3E%3CDIV%3E%24%20tar%20-xJvf%20qtbase-opensource-src-5.1.1.tar.xz%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CH2%20id%3D%22toc-hId--735273998%22%20id%3D%22toc-hId-187352469%22%3E%E3%83%93%E3%83%AB%E3%83%89%E6%89%8B%E9%A0%86%3A%3C%2FH2%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%20style%3D%22text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Liberation%20Serif'%3B%20mso-bidi-font-family%3A%20'Liberation%20Serif'%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E1.%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3EQt5%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E5%85%A5%E3%82%8A%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%24%20cd%20~%2FQt5%2Fqt-everywhere-opensource-src-5.1.1%2Fqtbase%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20vi%20config.imx6%3C%2FDIV%3E%3CDIV%3E%23!%2Fbin%2Fsh%3C%2FDIV%3E%3CDIV%3E.%2Fconfigure%20-opensource%20-%E7%A2%BA%E8%AA%8D-%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%20-make%20libs%20-device%20imx6%20%5C%3C%2FDIV%3E%3CDIV%3E-device-option%20CROSS_COMPILE%3D%5C%3C%2FDIV%3E%3CDIV%3E%2Fopt%2Ffreescale%2Fusr%2Flocal%2Fgcc-4.6.2-glibc-2.13-linaro-multilib-2011.12%2Ffsl-linaro-toolchain%2Fbin%2Farm-fsl-linux-gnueabi-%20%5C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-no-pch%20-no-opengl%20-no-icu%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-no-c%2B%2B11%20%5C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-opengl%20es2%20%5C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-eglfs%20%5C%3C%2FDIV%3E%3CDIV%3E-compile-examples%20%5C%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%20style%3D%22text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Liberation%20Serif'%3B%20mso-bidi-font-family%3A%20'Liberation%20Serif'%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E2.%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%81%A6%E3%80%81BSP%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AA%E3%82%B9%E3%83%88%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E8%A1%8C%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%24%20cd%20~%2FQt5%2Fqt-everywhere-opensource-src-5.1.1%2Fqtbase%2Fmkspecs%2Fdevices%2Flinux-imx6-g%2B%2B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20vi%20qmake.conf%3C%2FDIV%3E%3CDIV%3EROOTFS%3D%2Fhome%2F%E7%A0%94%E4%BF%AE%E7%94%9F%2FBSP%2FL3.0.35_4.0.0_130424_source%2Fltib%2Frootfs%3C%2FDIV%3E%3CDIV%3EQMAKE_INCDIR%20%2B%3D%20%24%24ROOTFS%2Fusr%2Finclude%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20QMAKE_LIBDIR%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2B%3D%20%24%24ROOTFS%2Fusr%2Flib%3C%2FDIV%3E%3CDIV%3EQMAKE_LFLAGS%20%2B%3D%20-Wl%2C-rpath-link%2C%24%24ROOTFS%2Fusr%2Flib%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%20style%3D%22text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Liberation%20Serif'%3B%20mso-bidi-font-family%3A%20'Liberation%20Serif'%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E3.%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%E8%A8%AD%E5%AE%9A%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81Qt5%E3%81%8C%E5%AE%8C%E6%88%90%E3%81%97%E3%81%9F%E3%82%89OpenGL%20ES%202.0%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AB%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E5%8A%A0%E3%81%88%E3%82%89%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E4%BB%A5%E5%89%8D%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%89%8A%E9%99%A4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%20'make%20confclean'%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20.%2Fconfig.imx6%3C%2FDIV%3E%3CDIV%3E%E3%81%93%E3%82%8C%E3%81%8CQt%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%E7%89%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E3%81%93%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81Lesser%20GNU%20General%20Public%20License(LGPL)%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.1%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%8C%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AB%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3Eqmake%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%80%A6.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%80%A6.%3C%2FDIV%3E%3CDIV%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E6%9C%89%E5%8A%B9%E5%8C%96%3A%3C%2FDIV%3E%3CDIV%3E%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B7%E3%83%93%E3%83%AA%E3%83%86%E3%82%A3%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%80%82%E3%81%AF%E3%81%84%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%80%A6.%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22background%3A%20yellow%3B%22%3EOpenGL%20..................%20yes%20(OpenGL%20ES%202.x)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E2%80%A6.%3C%2FDIV%3E%3CDIV%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81Qt%E3%81%8C%E3%83%93%E3%83%AB%E3%83%89%E7%94%A8%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82'make'%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%20style%3D%22padding%3A%201pt%3B%22%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%82%89%E3%80%81'make%20install'%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3EQt%20%E3%81%AF%20%2Fhome%2Ftrainee%2FBSP%2FL3.0.35_4.0.0_130424_source%2Fltib%2Frootfs%2Fusr%2Flocal%2FQt5.1.1%20%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E5%86%8D%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E6%AE%8B%E3%82%8A%E7%89%A9%E3%82%92%E3%81%99%E3%81%B9%E3%81%A6%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FDIV%3E%3CDIV%3E%E5%89%8D%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%20style%3D%22text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Liberation%20Serif'%3B%20mso-bidi-font-family%3A%20'Liberation%20Serif'%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E4.%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%83%93%E3%83%AB%E3%83%89%E3%82%92%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AF%E3%80%81%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E9%81%A9%E5%88%87%E3%81%AA%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%95%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%24%20make%20all%20-j8%3C%2FDIV%3E%3CDIV%3E%24INSTALL_ROOT%3D%2Fhome%2Ftrainee%2FBSP%2FL3.0.35_4.0.0_130424_source%2Fltib%2Frootfs%2F%20sudo%3CBR%20%2F%3Emake%20install%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Liberation%20Serif'%3B%20mso-bidi-font-family%3A%20'Liberation%20Serif'%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E5.%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%E4%BE%8B%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%24%20cd%20%E3%81%AE%E4%BE%8B%3C%2FDIV%3E%3CDIV%3E%24%E4%BD%9C%E3%82%8B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%20style%3D%22text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Liberation%20Serif'%3B%20mso-bidi-font-family%3A%20'Liberation%20Serif'%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E6.%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3EopenGL%20ES%E3%81%AE%E3%83%87%E3%83%A2%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E4%BE%8B(hellogl_es2)%E3%82%92%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20sudo%20cp%20opengl%2Fhellogl_es2%2Fhellogl_es2%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2Fhome%2Ftrainee%2FBSP%2FL3.0.35_4.0.0_130424_source%2Fltib%2Frootfs%2F%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3Eh%2Fw%20%E3%82%A2%E3%82%AF%E3%82%BB%E3%83%A9%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%20style%3D%22text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Liberation%20Serif'%3B%20mso-bidi-font-family%3A%20'Liberation%20Serif'%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E1.%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81galcore%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%24%20cat%20%2Fproc%2Fdevices%20%7Cgrep%20%E3%82%AC%E3%83%AB%E3%82%B3%E3%82%A2%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20ls%20%2Fdev%2Fgalcore%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%20style%3D%22text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Liberation%20Serif'%3B%20mso-bidi-font-family%3A%20'Liberation%20Serif'%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E2.%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%E5%BF%85%E8%A6%81%E3%81%AAQt%E7%92%B0%E5%A2%83%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%24%20export%20QT_PLUGIN_PATH%3D%2Fusr%2Flocal%2FQt-5.1.1%2Fplugins%2F%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Liberation%20Serif'%3B%20mso-bidi-font-family%3A%20'Liberation%20Serif'%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E3.%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3E%E4%BE%8B%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E5%9B%9E%E8%BB%A2%E3%81%99%E3%82%8BQt%E3%81%AE%E3%83%AD%E3%82%B4%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%24cd%20%2F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%24%20.%2Fhellogl_es%3C%2FDIV%3E%3CDIV%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Qtimage.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Qtimage.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F40776iF113C31C3F6186C5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Qtimage.jpg%22%20alt%3D%22Qtimage.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EQtimage.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%3E%20%3C%2FDIV%3E%3CDIV%20class%3D%22Standard%22%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CSPAN%20style%3D%22mso-fareast-font-family%3A%20'Liberation%20Serif'%3B%20mso-bidi-font-family%3A%20'Liberation%20Serif'%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E4.%3CSPAN%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FSPAN%3Etop%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%BD%8E%E3%81%84(0%20%E2%80%93%201%20%25)CPU%E4%BD%BF%E7%94%A8%E7%8E%87%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%24%E3%83%88%E3%83%83%E3%83%97%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PID%20PPID%20USER%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STAT%26nbsp%3B%26nbsp%3B%20VSZ%20%25VSZ%20CPU%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%25CPU%20COMMAND%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FDIV%3E%3CDIV%3E2820%202809%20%E3%83%AB%E3%83%BC%E3%83%88%20S%20188m%2021.5%200%200.7.%2Fhellogl_es2%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3EAdeneo%20Embedded%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3EAdeneo%20Embedded%E3%81%AF%E3%80%81%E9%AB%98%E6%80%A7%E8%83%BD%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E4%B8%96%E7%95%8C%E3%82%AF%E3%83%A9%E3%82%B9%E3%81%AE%E5%B0%82%E9%96%80%E7%9F%A5%E8%AD%98%E3%82%92%E6%B1%82%E3%82%81%E3%82%8B%E4%BC%81%E6%A5%AD%E3%81%AB%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E7%B5%B1%E5%90%88%E3%80%81%E8%A8%AD%E8%A8%88%E3%80%81%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BB%A5%E4%B8%8A%3CBR%20%2F%3E10%E5%B9%B4%E9%96%93%E3%80%81Adeneo%20Embedded%E3%81%AF%E9%96%8B%E7%99%BA%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%AE%B5%E9%9A%8E%E3%81%A7%E3%82%AF%E3%83%A9%E3%82%A4%E3%82%A2%E3%83%B3%E3%83%88%E3%82%92%E6%94%AF%E6%8F%B4%E3%81%97%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Android%E3%80%81Embedded%20Linux%E3%80%81Windows%20Embedded%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AFWindows%20Mobile%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%8F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8A%E3%82%88%E3%81%B3%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%B5%84%E3%81%BF%E8%BE%BC%E3%82%93%E3%81%A0%E3%80%81%E5%8F%8E%E7%9B%8A%E6%80%A7%E3%81%AE%E9%AB%98%E3%81%84%E6%A9%9F%E8%83%BD%E8%B1%8A%E5%AF%8C%E3%81%AA%E8%A3%BD%E5%93%81%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%A5%AD%E7%95%8C%E3%82%92%E3%83%AA%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%82%B7%E3%83%AA%E3%82%B3%E3%83%B3%E3%81%8A%E3%82%88%E3%81%B3%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%E3%81%A8%E3%81%AE%E7%B7%8A%E5%AF%86%E3%81%AA%E5%8D%94%E5%8A%9B%E9%96%A2%E4%BF%82%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81Adeneo%20Embedded%E3%81%AF%E3%81%9D%E3%81%AE%E7%B5%8C%E9%A8%93%E3%82%92%E5%B9%85%E5%BA%83%E3%81%84%E5%88%86%E9%87%8E%E3%81%AB%E5%BF%9C%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E8%87%AA%E5%8B%95%E8%BB%8A%E3%80%81%E7%94%A3%E6%A5%AD%E3%80%81%E5%8C%BB%E7%99%82%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%80%81%E3%83%8A%E3%83%93%E3%82%B2%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AD%E3%83%B3%E3%82%B0%E3%80%81%E3%83%A2%E3%83%90%E3%82%A4%E3%83%AB%E3%80%81%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%AC%E3%82%B9%E5%B8%82%E5%A0%B4%E5%90%91%E3%81%91%E3%81%AE%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%82Adeneo%20Embedded%E3%81%AF%E3%80%81%E5%8C%97%E7%B1%B3%E3%81%A8%E3%83%A8%E3%83%BC%E3%83%AD%E3%83%83%E3%83%91%E3%81%AE%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%AA%E3%83%95%E3%82%A3%E3%82%B9%E3%81%AB%E6%94%AF%E3%81%88%E3%82%89%E3%82%8C%E3%81%9F%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E3%81%AA%E8%B2%A9%E5%A3%B2%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-language%3A%20EN-US%3B%20mso-fareast-language%3A%20EN-US%3B%20line-height%3A%20115%25%3B%20font-size%3A%2011pt%3B%20mso-hansi-theme-font%3A%20minor-latin%3B%20mso-ansi-language%3A%20EN-US%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20mso-ascii-theme-font%3A%20minor-latin%3B%20mso-fareast-theme-font%3A%20minor-fareast%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-theme-font%3A%20minor-bidi%3B%22%3E%3CSTRONG%20style%3D%22mso-fareast-language%3A%20FR%3B%20mso-bidi-language%3A%20AR-SA%3B%20mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20line-height%3A%20150%25%3B%20mso-bidi-font-size%3A%2010.0pt%3B%20font-size%3A%2011pt%3B%20mso-ansi-language%3A%20EN-US%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CDIV%3E%3CSTRONG%3E%E3%81%95%E3%82%89%E3%81%AB%E8%A9%B3%E3%81%97%E3%81%84%E6%83%85%E5%A0%B1%3C%2FSTRONG%3E%3C%2FDIV%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-language%3A%20EN-US%3B%20mso-fareast-language%3A%20EN-US%3B%20line-height%3A%20115%25%3B%20font-size%3A%2011pt%3B%20mso-hansi-theme-font%3A%20minor-latin%3B%20mso-ansi-language%3A%20EN-US%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20mso-ascii-theme-font%3A%20minor-latin%3B%20mso-fareast-theme-font%3A%20minor-fareast%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-theme-font%3A%20minor-bidi%3B%22%3E%3CSTRONG%20style%3D%22mso-fareast-language%3A%20FR%3B%20mso-bidi-language%3A%20AR-SA%3B%20mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20line-height%3A%20150%25%3B%20mso-bidi-font-size%3A%2010.0pt%3B%20font-size%3A%2011pt%3B%20mso-ansi-language%3A%20EN-US%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3EAdeneo%20Embedded%20%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%94%E3%83%86%E3%83%B3%E3%82%B7%E3%83%BC%E3%80%81Windows%20Embedded%20%E3%83%86%E3%82%AF%E3%83%8E%E3%83%AD%E3%82%B8%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E8%A3%BD%E5%93%81%E3%80%81%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-language%3A%20EN-US%3B%20mso-fareast-language%3A%20EN-US%3B%20line-height%3A%20115%25%3B%20font-size%3A%2011pt%3B%20mso-hansi-theme-font%3A%20minor-latin%3B%20mso-ansi-language%3A%20EN-US%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20mso-ascii-theme-font%3A%20minor-latin%3B%20mso-fareast-theme-font%3A%20minor-fareast%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-theme-font%3A%20minor-bidi%3B%22%3E%3CSTRONG%20style%3D%22mso-fareast-language%3A%20FR%3B%20mso-bidi-language%3A%20AR-SA%3B%20mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20line-height%3A%20150%25%3B%20mso-bidi-font-size%3A%2010.0pt%3B%20font-size%3A%2011pt%3B%20mso-ansi-language%3A%20EN-US%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CDIV%20style%3D%22text-align%3A%20justify%3B%20text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Wingdings%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3EAdeneo%20%3C%2FSPAN%3E%3C%2FSPAN%3EEmbedded%E5%B0%82%E7%94%A8Web%E3%82%B5%E3%82%A4%E3%83%88%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3CA%20href%3D%22http%3A%2F%2Fwww.adeneo-embedded.com%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20lang%3D%22EN-GB%22%20style%3D%22-ms-layout-grid-mode%3A%20line%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-theme-font%3A%20major-fareast%3B%20mso-fareast-language%3A%20DE%3B%20mso-ansi-language%3A%20EN-GB%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.adeneo-embedded.com%22%20target%3D%22test_blank%22%3Ewww.adeneo-embedded.com%3C%2FA%3E%3C%2FDIV%3E%3CDIV%20style%3D%22text-align%3A%20justify%3B%20text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Wingdings%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E%C3%A4%20%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%82%A2%E3%83%87%E3%83%8D%E3%82%AA%E3%83%BB%E3%82%A8%E3%83%B3%E3%83%99%E3%83%87%E3%83%83%E3%83%89%E3%83%BB%E3%82%BC%E3%83%8D%E3%83%A9%E3%83%AB%20%E5%96%B6%E6%A5%AD%E6%8B%85%E5%BD%93%20%3CA%20href%3D%22mailto%3Asales%40adeneo-embedded.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20lang%3D%22EN-GB%22%20style%3D%22-ms-layout-grid-mode%3A%20line%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-theme-font%3A%20major-fareast%3B%20mso-fareast-language%3A%20DE%3B%20mso-ansi-language%3A%20EN-GB%3B%22%3Esales%40adeneo-embedded.com%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-language%3A%20EN-US%3B%20mso-fareast-language%3A%20EN-US%3B%20line-height%3A%20115%25%3B%20font-size%3A%2011pt%3B%20mso-hansi-theme-font%3A%20minor-latin%3B%20mso-ansi-language%3A%20EN-US%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20mso-ascii-theme-font%3A%20minor-latin%3B%20mso-fareast-theme-font%3A%20minor-fareast%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-theme-font%3A%20minor-bidi%3B%22%3E%3CSTRONG%20style%3D%22mso-fareast-language%3A%20FR%3B%20mso-bidi-language%3A%20AR-SA%3B%20mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20line-height%3A%20150%25%3B%20mso-bidi-font-size%3A%2010.0pt%3B%20font-size%3A%2011pt%3B%20mso-ansi-language%3A%20EN-US%3B%20font-family%3A%20'Arial'%2C'sans-serif'%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%22%3E%3CSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22text-align%3A%20justify%3B%22%3E%E5%9C%B0%E5%9F%9F%E3%81%AE%E9%80%A3%E7%B5%A1%E5%85%88%3C%2FDIV%3E%3CDIV%20style%3D%22text-align%3A%20justify%3B%20text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20lang%3D%22EN-GB%22%20style%3D%22font-family%3A%20Wingdings%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E%C3%84%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E3%83%A8%E3%83%BC%E3%83%AD%E3%83%83%E3%83%91%3C%2FSPAN%3E%E3%80%81Jeremy%20Delicato%20%3CA%20href%3D%22mailto%3Ajdelicato%40adeneo-embedded.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20lang%3D%22EN-GB%22%20style%3D%22-ms-layout-grid-mode%3A%20line%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-theme-font%3A%20major-fareast%3B%20mso-fareast-language%3A%20DE%3B%20mso-ansi-language%3A%20EN-GB%3B%22%3E%E3%81%AB%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20jdelicato%40adeneo-embedded.com%3C%2FSPAN%3E%3C%2FA%3E%3C%2FDIV%3E%3CDIV%20style%3D%22text-align%3A%20justify%3B%20text-indent%3A%20-0.25in%3B%20margin-left%3A%200.5in%3B%22%3E%3CSPAN%20lang%3D%22EN-GB%22%20style%3D%22font-family%3A%20Wingdings%3B%22%3E%3CSPAN%20class%3D%22pasted-list-info%22%3E%C3%84%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3E%E3%82%A2%E3%83%A1%E3%83%AA%E3%82%AB%3C%2FSPAN%3E%E3%80%81%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%BB%E3%83%AB%E3%82%A4%E3%82%B9%E3%81%AB%E9%80%A3%E7%B5%A1%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3CA%20href%3D%22mailto%3Amruiz%40adeneo-embedded.com%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20lang%3D%22EN-GB%22%20style%3D%22-ms-layout-grid-mode%3A%20line%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-theme-font%3A%20major-fareast%3B%20mso-fareast-language%3A%20DE%3B%20mso-ansi-language%3A%20EN-GB%3B%22%3Emruiz%40adeneo-embedded.com%3C%2FSPAN%3E%3C%2FA%3E%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CSPAN%20style%3D%22mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-language%3A%20EN-US%3B%20mso-fareast-language%3A%20EN-US%3B%20line-height%3A%20115%25%3B%20font-size%3A%2011pt%3B%20mso-hansi-theme-font%3A%20minor-latin%3B%20mso-ansi-language%3A%20EN-US%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20mso-ascii-theme-font%3A%20minor-latin%3B%20mso-fareast-theme-font%3A%20minor-fareast%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-theme-font%3A%20minor-bidi%3B%22%3E%3CSTRONG%20style%3D%22%3A%20%3B%20mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-language%3A%20EN-US%3B%20mso-fareast-language%3A%20EN-US%3B%20mso-ascii-theme-font%3A%20minor-latin%3B%20line-height%3A%20115%25%3B%20mso-bidi-font-size%3A%2010.0pt%3B%20color%3A%20%231f497d%3B%20font-size%3A%2011pt%3B%20mso-hansi-theme-font%3A%20minor-latin%3B%20mso-ansi-language%3A%20EN-US%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20mso-fareast-theme-font%3A%20minor-fareast%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-theme-font%3A%20minor-bidi%3B%22%3E%3CSTRONG%3E%3CSTRONG%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%231f497d%3B%20line-height%3A%20115%25%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20font-size%3A%2011pt%3B%20mso-ascii-theme-font%3A%20minor-latin%3B%20mso-fareast-font-family%3A%20'Times%20New%20Roman'%3B%20mso-fareast-theme-font%3A%20minor-fareast%3B%20mso-hansi-theme-font%3A%20minor-latin%3B%20mso-bidi-font-family%3A%20'Times%20New%20Roman'%3B%20mso-bidi-theme-font%3A%20minor-bidi%3B%20mso-bidi-language%3A%20EN-US%3B%20mso-fareast-language%3A%20EN-US%3B%20mso-ansi-language%3A%20EN-US%3B%22%3E%3CBR%20clear%3D%22all%22%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CDIV%3E%20%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1117215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Adeneo%20Embedded%3A%20Building%20Qt%205.1%20for%20Freescale%20i.MX6%20%E2%80%93%20Cuong%20Chou%E3%81%AB%E3%82%88%E3%82%8B%E3%83%9B%E3%83%AF%E3%82%A4%E3%83%88%E3%83%9A%E3%83%BC%E3%83%91%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117219%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eimx6%20Sabre%20%E3%81%AE%20LTIB%204.0.0%20%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%81%E3%83%A5%E3%83%BC%E3%83%88%E3%83%AA%E3%82%A2%E3%83%AB%E3%81%AB%E5%BE%93%E3%81%86%E3%81%AE%E3%81%AF%E8%88%88%E5%91%B3%E6%B7%B1%E3%81%84%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AEWeb%E3%82%B5%E3%82%A4%E3%83%88%E3%81%A7%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%97%E3%81%8B%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B9%BE%E6%9D%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Adeneo%20Embedded%3A%20Building%20Qt%205.1%20for%20Freescale%20i.MX6%20%E2%80%93%20Cuong%20Chou%E3%81%AB%E3%82%88%E3%82%8B%E3%83%9B%E3%83%AF%E3%82%A4%E3%83%88%E3%83%9A%E3%83%BC%E3%83%91%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%AA%E3%83%97%E3%83%AC%E3%82%A4%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E5%85%88%E9%80%B1%E3%80%81%E7%A7%81%E3%81%AF4.00%20LTIB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Adeneo%20Embedded%3A%20Building%20Qt%205.1%20for%20Freescale%20i.MX6%20%E2%80%93%20Cuong%20Chou%E3%81%AB%E3%82%88%E3%82%8B%E3%83%9B%E3%83%AF%E3%82%A4%E3%83%88%E3%83%9A%E3%83%BC%E3%83%91%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117217%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AB%96%E6%96%87%E3%82%92%E3%81%94%E8%A6%A7%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A6%8B%E3%81%A6%E3%81%84%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%AF2%E3%81%A4%E3%81%AE%E6%BD%9C%E5%9C%A8%E7%9A%84%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.galcore%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%8C%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%8B%E3%80%81%E6%AD%A3%E3%81%97%E3%81%8F%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E2.%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%8C%20Vivante%20GPU%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81Linux%203.0.35%3CSTRONG%3E4.1.0%3C%2FSTRONG%3E%E3%80%81Vivante%20GPU%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%3CSTRONG%3E4.1.0%3C%2FSTRONG%3E%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.0.0%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1117216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Adeneo%20Embedded%3A%20Building%20Qt%205.1%20for%20Freescale%20i.MX6%20%E2%80%93%20Cuong%20Chou%E3%81%AB%E3%82%88%E3%82%8B%E3%83%9B%E3%83%AF%E3%82%A4%E3%83%88%E3%83%9A%E3%83%BC%E3%83%91%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1117216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%82%B7%E3%82%A7%E3%82%A2%E3%81%AB%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%83%87%E3%83%A2%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%3C%2FP%3E%3CTABLE%3E%3CTBODY%3E%3CTR%3E%3CTD%3E%26nbsp%3B%26nbsp%3B%20%3C%2FTD%3E%3CTD%3E%24%20.%2Fhellogl_es%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%AF%E7%8F%BE%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EQIconvCodec%3A%3AconvertFromUnicode%3A%E5%A4%89%E6%8F%9B%E3%81%ABLatin-1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81iconv_open%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EQIconvCodec%3A%3AconvertToUnicode%3A%E5%A4%89%E6%8F%9B%E3%81%ABLatin-1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81iconv_open%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%BB%E3%82%B0%E3%83%A1%E3%83%B3%E3%83%86%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E9%9A%9C%E5%AE%B3%3C%2FP%3E%3CP%3E%E3%81%AA%E3%81%9C%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E5%8A%A9%E3%81%91%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-23-2013 06:39 PM
更新者:
