i.MX6 Q7 Development Kit by iWave Systems
No ratings
The Development Platform incorporates Q7 compatible i.MX6 SOM which is based on Freescale’s i.MX 6 Series 1.2GHz multimedia focused processor and Generic Q7 compatible Development Board. This platform can be used for quick prototyping of any high end applications in verticals like Automotive, Industrial  & Medical. Being a nano ITX form factor with 120mmx120mm size, the board is highly packed with all necessary onboard connectors to validate complete i.MX6 CPU features.
Benefits
  • Simple, low cost and yet rugged assembly thanks to the industrial temperature grade and compact (120 x 120 - Nano ITX) form factor
  • Simple and low-cost integration thanks to the on-board standard interfaces (uSD, USB and Memory)
  • Lowest power consumption. Typical power consumption
Highlights
  • Ideal for quick development
  • Shortens product development life cycle
  • Quick customization can be done in a very shorter period
  • Suitable for validation of any R1.20 Q7 compatible module
Features
  • Display: 7" 800x480 TFT LCD, VGA Port/ TV Out, HDMI Port*, LVDs Display connector*
  • Touch Panel: Resistive Touch Capacitive touch*
  • Video Input: Camera Interface*, TV IN*
  • Audio: External Audio Codec, Headphone/ Mic Jacks
  • PCIe: PCIe Mini Card*, PCIex1 Port*
  • USB: USB2.0 Device - Mini AB connector, USB2.0 Host 2 ports - Type A Connector
  • Serial: UART - DB9 connector
  • Storage:SATA Port1 - 7P Connector*, SATA Port2 - 22P Connector*, Standard SD Slot
  • Communication:10/100Mbps Ethernet - RJ45 Jack, 802.11b/g/n Wi-Fi Module*, CAN Port - DB9 connector*
  • Power: 12V DC Input, On-board RTC coin Battery
  • Form Factor: 120 x 120 - Nano ITX
  • Temperature supported: 0 to 60 oC
Target Applications
  • Industrial/Medical
  • Green Energy Controller
  • Panel PC, High-end PDAs, Secure Devices,
  • Industrial appliance Control, Automotive In Vehicle Infotainment Systems
  • Medical HMI, Kiosks, POS, General Embedded
Click here for more details on the i.MX 6 Q7 Development Kit by iWave
Version history
Last update:
‎09-10-2012 01:03 PM
Updated by:
