Communication Driver - Application Configuration
This article is meant to show you the minimal setup required to allow your embedded application to start talking to FreeMASTER host application.
It is part of the FreeMASTER Tutorial series:
  1. Communication Driver (current article)
  2. Connecting to the Board
  3. Target Side Address Translation
Communication Driver & S32 Design Studio
Prerequisites:
See example application source code in attachments.
(view in My Videos)
If you read Communication Driver article you may have noticed that the the stand-alone package available on the FreeMASTER download page implements version 2.0 of the communication protocol.
  • Why this video still uses an older version ?
The host application is fully backward compatible and supports both versions of the communication protocol.
No ratings
Version history
Last update:
‎11-11-2020 04:37 AM
Updated by:
