Brief Introduction to LwIP stack in MCUXpresso SDK
LwIP is a small independent implementations of the TCP/IP protocol suite that has been initially developed by Adam Dunkels . The focus of the lwIP TCP/IP implementation is to reduce resource usage while still having a full scale TCP. This makes lwIP suitable for use in embedded systems with tens of kilobytes of free RAM and room for around 40 kilobytes of code ROM.
Currently LwIP 2.1.2 is ported to Kinetis and I.MX RT families in MCUXpresso SDK 2.6 .
Features:
LwIP comes with the following protocols:
IPv4 and IPv6, including packet forwarding over multiple network interfaces.
ICMP for network maintenance and debugging
IGMP for multicast traffic management
MLD (Multicast listener discovery for IPv6).
ND (Neighbor discovery and stateless address autoconfiguration for IPv6)
DHCP and DHCPv6.
UDP (User Datagram Protocol)
TCP (Transmission Control Protocol)
Raw/native API for enhanced performance
Optional Berkeley -  like socket API.
TLS: optional layered TCP for nearly transparent TLS for any TCP-based protocol
PPPoS and PPPoE
DNS (Domain name resolver incl. mDNS)
6LoWPAN
Organization of the LwIP stack
Let’s take SDK_2.6.1_EVKB-IMXRT1050 for example,
LwIP code in under SDK_2.6.1_EVKB-IMXRT1050\middleware\lwip
Port: This folder includes the adapter code which can make the LwIP stack run on the bare metal and FreeRTOS.
Enet_ethernetif.c/h: Adapt the LwIP stack to the underlying MCUXpresso SDK ethernet driver, provides ethernet interfaces , like  phy init and  ethernetif_input.
cc.c/h: provide typedefs, compiler hints for packing and platform specific diagnostic output.
Perf.h: architecture specific performance measurement, current the definitions is NULL, reserve for future use.
Src: This folder includes the latest stable LwIP 2.1.2 source code which can be downloaded from below link download.savannah.gnu.org/releases/lwip/
--api: netconn and socket API files
--core: LwIP core files
--include: LwIP include files
--netif:  network interface files
LwIP APIs overview
LwIP provides three application programming interfaces (API) for programmers to use for communication with the TCP/IP code:
Raw APIs:   Non thread-safe APIs, callback style for maximum performance and minimum memory footprint. Program execution is driven by callbacks functions, which are then invoked by the lwIP core when activity related to that application occurs. A particular application may register to be notified via a callback function for events such as incoming data available, outgoing data sent, error notifications, poll timer expiration, connection closed, etc. An application can provide a callback function to perform processing for any or all of these events.
Sequential-style APIs:    blocking functions. More overhead, but can be called from any thread except TCPIP thread. The sequential API provides a way for ordinary, sequential, programs to use the lwIP stack. It is quite similar to the BSD socket API. The model of execution is based on the blocking open-read-write-close paradigm. Since the TCP/IP stack is event based by nature, the TCP/IP code and the application program must reside in different execution contexts (threads).
Socket API: BSD-style socket API.  The socket API is a compatibility API for existing applications, currently it is built on top of the sequential API. It is meant to provide all functions needed to run socket API applications running on other platforms.
TCP Raw API
API function
Description
TCP connection setup
tcp_new()
Creates a new TCP PCB
tcp_bind()
Binds a TCP PCB to a local IP address and port
tcp_listen()
Starts the listening process on the TCP PCB.
tcp_accept()
Assigns a callback function that will be called when a
new TCP connection arrives.
tcp_connect()
Used to connect to a remote TCP host.
Sending TCP data
tcp_write()
Queues up data to be sent.
tcp_output()
Forces queued data to be sent
tcp_sent()
Assigns a callback function that will be called when sent
data is acknowledged by the remote host.
Receiving TCP data
tcp_recv()
Sets the callback function that will be called when new
data arrives.
tcp_recved()
Must be called when the application has processed the
incoming data packet (for TCP window management).
Application polling
tcp_poll()
Assigns a callback functions that will be called
periodically. It can be used by the application to check if
there is remaining application data that needs to be sent
or if there are connections that need to be closed.
Closing and aborting connections
tcp_close()
Closes a TCP connection with a remote host.
tcp_abort()
Aborts a TCP connection.
tcp_err()
Assigns a callback function for handling connections
aborted by the lwIP due to errors (such as memory
shortage errors).
UDP Raw API
API
Description
udp_bind
Binds a UDP PCB with a local IP address and port.
udp_new
Creates a new UDP PCB.
udp_send
Sends UDP data.
udp_recv
Specifies a callback function which is called when a datagram is received
udp_remove
Removes and de-allocates a UDP PCB.
udp_connect
Sets up a UDP PCB remote IP address and port
udp_disconnect
Removes a UDP PCB remote IP and port.
Netconn API
netconn_new
Creates a new connection
netconn_listen
Sets a TCP connection into a listening mode
netconn_write
Sends data on a connected TCP netconn
netconn_accept
Accepts an incoming connection on a listening TCP connection
netconn_close
Closes a TCP connection without deleting it.
netconn_send
Sends data to the currently connected remote IP/port (not applicable for
TCP connections).
netconn_bind
Binds a connection to a local IP address and port.
netconn_recv
Receives data from a netconn.
netconn_connect
Connects to a remote IP address and port.
Socket API
Macro
API
description
accept
lwip_accept
Accepts a new connection on a socket
bind
 lwip_bind
Binds a socket to an IP address and port
shutdown
 lwip_shutdown
getpeername
 lwip_getpeername
getsockname
lwip_getsockname
setsockopt
lwip_setsockopt
closesocket
 lwip_close
connect
lwip_connect
Connects a socket to a remote host IP address and port.
listen
 lwip_listen
Listens for socket connections
recv
 lwip_recv
recvmsg
lwip_recvmsg
recvfrom
 lwip_recvfrom
send
 lwip_send
sendmsg
 lwip_sendmsg
sendto
lwip_sendto
socket
 lwip_socket
Creates an new socket.
poll
lwip_poll
ioctlsocket
lwip_ioctl
inet_ntop
 lwip_inet_ntop
inet_pton
 lwip_inet_pton
read
 lwip_read
Reads data from a socket
readv
lwip_readv
write
lwip_write
Writes data on a socket
writev
lwip_writev
close
 lwip_close
Closes a socket (socket is deleted).
fcntl
 lwip_fcntl
ioctl
lwip_ioctl
LwIP Configure
Configuration file is placed in application source folder: Lwipopts.h:
Lwipopts.h is a user file that you can use to fully configure LwIP and all of it’s modules. You do not need to define every option that LwIP provides; if you do not define an option, a default value will be used. Therefore, your lwipopts.h provides a way to override much of the behavior of LwIP.
LwIP Demos in MCUXpresso SDK
MCUXpresso SDK comes with lots of demos that use different API sets.
Name
Description
Lwip_tcpecho
a TCP echo demo on the lwIP TCP/IP stack with bare metal KSDK or FreeRTOS. The demo uses the TCP protocol and acts as an echo server
Lwip_udpecho
a UDP echo demo on the lwIP TCP/IP stack with bare metal KSDK or FreeRTOS, which uses the UDP protocol and acts as an echo server.
Lwip_ping
a Ping Demo on the lwIP TCP/IP stack which using the ICMP protocol
lwip_nghttp2cli_mbedTLS
an NGHTTP2 client set up on lwIP TCP/IP and the MbedTLS stack with
FreeRTOS
lwip_mqtt
MQTT client connecting to MQTT broker via unsecured socket
lwip_iperf
check your bandwidth using the network performance measurement IPerf application on a PC as a client or a server
lwip_httpsrv
an HTTPServer on the lwIP TCP/IP stack with bare metal SDK or FreeRTOS
lwip_httpscli_mbedTLS
an HTTPS client set up on lwIP TCP/IP and the MbedTLS stack with
FreeRTOS
lwip_dhcp_usb
a DHCP and ping demo on the lwIP TCP/IP and USB stack
lwip_dhcp
a DHCP client and prints the status as it is progressing
No ratings
Version history
Last update:
‎11-04-2019 08:09 AM
Updated by:
