PN7150 NFC Controller on i.MX8M mini evk running Android Pie
This documents describes how to add the NFC support to i.MX8M mini evk running Android Pie.
Hardware setup:
The i.MX8M mini evk (see i.MX 8M Mini Evaluation Kit | NXP) featuring Raspberry Pi compliant connector, the OM5578/RPI PN7150 demo kit can be used to perform this porting (see NFC Development Kits for Arduino and more|NXP). However a small modification must be done because some of the signals required by PN7150 are not mapped to i.MX8M mini expansion connector pins.
OM5578 IRQ signal must be mapped to Raspberry Pi connector pin #19 and OM5578 VEN signal must be mapped to Raspberry Pi connector pin #21.
See below a picture of the modification:
Then, the two boards can fit together as shown in the picture below:
Quick start using demo image:
The demo image including support for PN7150, is based on Android P9.0.0 Pie (P9.0.0_1.0.0, 4.14 kernel) i.MX software release (see i.MX Software | NXP).
Related documentation can be downloaded from here: https://www.nxp.com/docs/en/supporting-information/android_p9.0.0_1.0.0-ga_docs.zip.
Just flash the demo image (downloaded from here:https://www.nxp.com/lgfiles/updates/NFC/ANDROID_P9-0-0_PN7150_IMAGE_8MMEVK.zip) following guidelines from i.MX_Android_Quick_Start document (part of Android P9.0.0_1.0.0 Documentation package mentioned above).
The NFC support is then included in the device settings, as shown in below screenshot of the device:
Approaching the NFC tag, provided as reference in the OM5578 demo kit, to the NFC Antenna will trigger a sound notification:
Unfortunately the Android demo image doesn't embed a web browser, so it won't be automatically open when the NFC tag content (an URL to the demo kit web page) is read. Otherwise (if a web browser is installed) you could see such page opening on the device:
Adding PN7150 support to imx-android-pie release:
If you wish to add PN7150 support to your imx-android-pie environment, just apply the patches (imx-p9.0.0_1.0.0-ga_pn7150_patches.tar.gz file attached) from the ${MY_ANDROID} source code root folder (refer to i.MX_Android_User_Guide document part of Android P9.0.0_1.0.0 Documentation package mentioned above).
 $ patch -p1 -d device/fsl/ <device_fsl.patch
 $ patch -p1 -d packages/apps/Nfc <packages_apps_Nfc.patch
 $ patch -p1 -d hardware/nxp/nfc <hardware_nxp_nfc.patch
 $ patch -p1 -d vendor/nxp <vendor_nxp.patch
 $ patch -p1 -d vendor/nxp-opensource/kernel_imx/ <vendor_nxp-opensource_kernel_imx.patch
When building, the PN7150 support will then be included to the android image, as shown in the demo image described above.
Reference:
This porting have been done (demo image and patches creation) following guidelines provided in AN11690_NXP-NCI_Android_Porting_Guidelines document.
添付
コメント
Hi Jeremy, this patch also fit with imx-p9.0.0_2.0.0-ga too?
Thank you!
Yes the imx-p9.0.0_1.0.0-ga_pn7150_patches should applies quietly to imx-p9.0.0_2.0.0-ga version.
Jeremy.
Thanks for reply,
After the patched, our PN7150 is working on our board with imx-p9.0.0_2.0.0-ga version!
%3CLINGO-SUB%20id%3D%22lingo-sub-1099285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAndroid%20Pie%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8Bi.MX8M%20mini%20evk%E4%B8%8A%E3%81%AEPN7150%20NFC%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-360437807%22%20id%3D%22toc-hId-1304160699%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81Android%20Pie%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8Bi.MX8M%20mini%20evk%E3%81%ABNFC%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1050999281%22%20id%3D%22toc-hId-1994722173%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%EF%BC%9A%3C%2FH2%3E%3CP%3Ei.MX8M%20mini%20evk%20(%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Fsoftware-development-tools%2Fi.mx-developer-resources%2Fevaluation-kit-for-the-i.mx-8m-mini-applications-processor%3A8MMINILPD4-EVK%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Fsoftware-development-tools%2Fi.mx-developer-resources%2Fevaluation-kit-for-the-i.mx-8m-mini-applications-processor%3A8MMINILPD4-EVK%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX%208M%20Mini%20%E8%A9%95%E4%BE%A1%E3%82%AD%E3%83%83%E3%83%88%20%7CNXP%3C%2FA%3E)%E3%81%AFRaspberry%20Pi%E6%BA%96%E6%8B%A0%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%82%92%E5%82%99%E3%81%88%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81OM5578%20%2F%20RPI%20PN7150%E3%83%87%E3%83%A2%E3%82%AD%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99(%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fidentification-and-security%2Fnfc%2Fnfc-reader-ics%2Fdevelopment-kits-for-pn7150-plugn-play-nfc-controller%3AOM5578%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fproducts%2Fidentification-and-security%2Fnfc%2Fnfc-reader-ics%2Fdevelopment-kits-for-pn7150-plugn-play-nfc-controller%3AOM5578%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EArduino%E7%94%A8%E3%81%AENFC%E9%96%8B%E7%99%BA%E3%82%AD%E3%83%83%E3%83%88%E3%81%AA%E3%81%A9%7CNXP)%E3%81%A7%E3%81%99%3C%2FA%3E%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81PN7150%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E4%BF%A1%E5%8F%B7%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%8Ci.MX8M%E3%83%9F%E3%83%8B%E6%8B%A1%E5%BC%B5%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%E3%83%94%E3%83%B3%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E5%B0%8F%E3%81%95%E3%81%AA%E5%A4%89%E6%9B%B4%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EOM5578%20IRQ%20%E4%BF%A1%E5%8F%B7%E3%81%AF%20Raspberry%20Pi%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20%E3%83%94%E3%83%B3%20%2319%20%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81OM5578%20VEN%20%E4%BF%A1%E5%8F%B7%E3%81%AF%20Raspberry%20Pi%20%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF%20%E3%83%94%E3%83%B3%20%2321%20%E3%81%AB%E3%83%9E%E3%83%83%E3%83%94%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AE%E5%86%99%E7%9C%9F%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_12.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64102i70D3EE6B3642F0D0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_12.jpg%22%20alt%3D%22pastedImage_12.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_12.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81%E4%B8%8B%E3%81%AE%E5%9B%B3%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%812%E3%81%A4%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%B8%80%E7%B7%92%E3%81%AB%E5%8F%8E%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_14.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64147iC77C287F51B620E2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_14.jpg%22%20alt%3D%22pastedImage_14.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_14.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--756455182%22%20id%3D%22toc-hId-187267710%22%3E%3CBR%20%2F%3E%3C%2FH2%3E%3CH2%20id%3D%22toc-hId-1731057651%22%20id%3D%22toc-hId--1620186753%22%3E%E3%83%87%E3%83%A2%E7%94%BB%E5%83%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%3A%3C%2FH2%3E%3CP%3EPN7150%20%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%90%AB%E3%82%80%E3%83%87%E3%83%A2%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E3%80%81Android%20P9.0.0%20Pie%20(P9.0.0_1.0.0%E3%80%814.14%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB)%20i.MX%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Fsoftware-development-tools%2Fi.mx-developer-resources%2Fi.mx-software-and-development-tool%3AIMX_SW%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Fsoftware-development-tools%2Fi.mx-developer-resources%2Fi.mx-software-and-development-tool%3AIMX_SW%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX%20Software%20%7CNXP%3C%2FA%3E%E3%81%AE)%E3%80%82%3C%2FP%3E%3CP%3E%E9%96%A2%E9%80%A3%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fsupporting-information%2Fandroid_p9.0.0_1.0.0-ga_docs.zip%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fsupporting-information%2Fandroid_p9.0.0_1.0.0-ga_docs.zip%3C%2FA%3E%20%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fsupporting-information%2Fandroid_p9.0.0_1.0.0-ga_docs.zip%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fsupporting-information%2Fandroid_p9.0.0_1.0.0-ga_docs.zip%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E3%80%82%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%A2%E7%94%BB%E5%83%8F%E3%82%92%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99(%E3%81%93%E3%81%93%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3A%3CSPAN%20style%3D%22font-size%3A%2010.0pt%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fupdates%2FNFC%2FANDROID_P9-0-0_PN7150_IMAGE_8MMEVK.zip%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Flgfiles%2Fupdates%2FNFC%2FANDROID_P9-0-0_PN7150_IMAGE_8MMEVK.zip%3C%2FA%3E%3C%2FSPAN%3E)i.MX_Android_Quick_Start%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88(%E4%B8%8A%E8%A8%98%E3%81%AEAndroid%20P9.0.0_1.0.0%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E4%B8%80%E9%83%A8)%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ENFC%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E8%A8%AD%E5%AE%9A%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F72954iD9F7B39A6F750D11%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EOM5578%E3%83%87%E3%83%A2%E3%82%AD%E3%83%83%E3%83%88%E3%81%A7%E5%8F%82%E7%85%A7%E3%81%A8%E3%81%97%E3%81%A6%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BNFC%E3%82%BF%E3%82%B0%E3%82%92NFC%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AB%E8%BF%91%E3%81%A5%E3%81%91%E3%82%8B%E3%81%A8%E3%80%81%E9%9F%B3%E5%A3%B0%E9%80%9A%E7%9F%A5%E3%81%8C%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F75193i357D4357DA7902D9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AE%8B%E5%BF%B5%E3%81%AA%E3%81%8C%E3%82%89%E3%80%81Android%E3%81%AE%E3%83%87%E3%83%A2%E7%94%BB%E5%83%8F%E3%81%AB%E3%81%AFWeb%E3%83%96%E3%83%A9%E3%82%A6%E3%82%B6%E3%81%8C%E5%9F%8B%E3%82%81%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81NFC%E3%82%BF%E3%82%B0%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84(%E3%83%87%E3%83%A2%E3%82%AD%E3%83%83%E3%83%88%E3%81%AEWeb%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%B8%E3%81%AEURL)%E3%81%8C%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%A6%E3%82%82%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E3%81%AF%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A0%B4%E5%90%88(Web%E3%83%96%E3%83%A9%E3%82%A6%E3%82%B6%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88)%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%8C%E9%96%8B%E3%81%84%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%82%92%E8%A6%8B%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F90477i13207E70237A84E0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--76396812%22%20id%3D%22toc-hId-867326080%22%3EIMX-android-pie%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%B8%E3%81%AE%20PN7150%20%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E8%BF%BD%E5%8A%A0%3A%3C%2FH2%3E%3CP%3EIMX-android-pie%E7%92%B0%E5%A2%83%E3%81%ABPN7150%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8B%E3%82%89%E3%83%91%E3%83%83%E3%83%81(%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%20%E6%B7%BB%E4%BB%98imx-p9.0.0_1.0.0-ga_pn7150_patches.tar.gz%3C%2FSPAN%3E%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB)%E3%82%92%E9%81%A9%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99(%E4%B8%8A%E8%A8%98%E3%81%AEAndroid%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%24%7BMY_ANDROID%7D%3C%2FSPAN%3E%20P9.0.0_1.0.0%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AEi.MX_Android_User_Guide%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E9%83%A8%E5%88%86%E3%82%92%E5%8F%82%E7%85%A7)%E3%80%82%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%24%20patch%20-p1%20-d%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2Ffsl%2F%20%3CDEVICE_FSL.PATCH%3E%3C%2FDEVICE_FSL.PATCH%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%24%20patch%20-p1%20-d%20%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%2F%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%2FNfc%20%3CPACKAGES_APPS_NFC.PATCH%3E%3C%2FPACKAGES_APPS_NFC.PATCH%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%24%20patch%20-p1%20-d%20hardware%2Fnxp%2Fnfc%20%3CHARDWARE_NXP_NFC.PATCH%3E%3C%2FHARDWARE_NXP_NFC.PATCH%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%26nbsp%3B%24%20patch%20-p1%20-d%20vendor%2Fnxp%20%3CVENDOR_NXP.PATCH%3E%3C%2FVENDOR_NXP.PATCH%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2C%20courier%2C%20monospace%3B%22%3E%24%20patch%20-p1%20-d%20vendor%2Fnxp-opensource%2Fkernel_imx%2F%20%3CVENDOR_NXP-OPENSOURCE_KERNEL_IMX.PATCH%3E%3C%2FVENDOR_NXP-OPENSOURCE_KERNEL_IMX.PATCH%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%87%E3%83%A2%E7%94%BB%E5%83%8F%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AB%E3%80%81PN7150%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8CAndroid%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--1883851275%22%20id%3D%22toc-hId--940128383%22%3E%E5%8F%82%E8%80%83%E6%83%85%E5%A0%B1%EF%BC%9A%3C%2FH2%3E%3CP%3E%E3%81%93%E3%81%AE%E7%A7%BB%E6%A4%8D%20(%E3%83%87%E3%83%A2%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A8%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E4%BD%9C%E6%88%90)%20%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN11690.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAN11690_NXP-NCI_Android_Porting_Guidelines%3C%2FA%3E%20%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%AC%E3%82%A4%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1099285%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAndroid%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%20Pie%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8Bi.MX8M%E3%83%9F%E3%83%8Bevk%E4%B8%8A%E3%81%AEPN7150%20NFC%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099288%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%81%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%81%E9%81%A9%E7%94%A8%E5%BE%8C%E3%80%81PN7150%E3%81%AFimx-p9.0.0_2.0.0-ga%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099287%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%20Pie%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8Bi.MX8M%E3%83%9F%E3%83%8Bevk%E4%B8%8A%E3%81%AEPN7150%20NFC%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099287%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%20%3CA%20_jive_internal%3D%22true%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fservlet%2FJiveServlet%2Fdownload%2F342420-2-450615%2Fimx-p9.0.0_1.0.0-ga_pn7150_patches.tar.gz%22%20target%3D%22_blank%22%3Eimx-p9.0.0_1.0.0-ga_pn7150_patches%3C%2FA%3E%20%E3%81%AF%20imx-p9.0.0_2.0.0-ga%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AB%E9%9D%99%E3%81%8B%E3%81%AB%E9%81%A9%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EJeremy.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099286%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AAndroid%20Pie%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8Bi.MX8M%E3%83%9F%E3%83%8Bevk%E4%B8%8A%E3%81%AEPN7150%20NFC%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099286%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%B8%E3%82%A7%E3%83%AC%E3%83%9F%E3%83%BC%E3%80%81%E3%81%93%E3%81%AE%E3%83%91%E3%83%83%E3%83%81%E3%81%AFimx-p9.0.0_2.0.0-ga%E3%81%AB%E3%82%82%E9%81%A9%E5%90%88%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎01-21-2019 08:10 AM
更新者:
