Excel MPC5744P Clock Configurator
Document created by Petr Stancik Employee on Sep 17, 2015Last modified by Petr Stancik Employee on Mar 31, 2020
Version 4Show Document
  • View in full screen mode
This config tool simplifies PLL setting calculation and clock configuration for MPC5744P device.
Follow these steps
Note: Macros have to be enabled!
  1. 1. Enter frequency of used XOSC and desired PLL0 and PLL1 output.
                - put values into cells B11, Q10 and Q17 of the "Clocks" sheet
                - check if it is Valid or Invalid
                - "PLLconfig" sheet shows possible PLLs configurations
  1. 2. Configure System and AUX clock selectors and its Dividers
                - check calculated frequency of System/Peripheral clocks
                - if Invalid change source clock and Divider value to keep Max freq
  3. Copy generated code by pressing "Copy Code" button
14 people found this helpful
Outcomes
