Porting WM8960 to Android jb4.2.2
The document will introduce all steps for poring WM8960 audio codec to freescale android4.2.2 BSP.
Attachments include :
(1)Document for porting
(2)Codec driver : wm8960.c
(3)Machine driver: imx-wm8960.c
(4)wm8960 schematic for reference
(5)Android Audio HAL: config_wm8960.h
(6)schematic: MX6QDL-PIANO-CNFV1.DSN
(7)i.MX6DL BSP files
mx6dl_piano.c
mx6dl_piano.h
mx6dl_piano_pmic_pfuse100.c
(8)i.MX6Q BSP files
mx6q_piano.c
mx6q_piano.h
mx6q_piano_pmic_pfuse100.c
Freescale TICS Team
Weidong.sun
ラベル(5)
添付
コメント
This document is so wonderful!But Can you write a document introduce how to port the driver to android4.4.3?
OK, thank you for your high praise!
porting to android4.4.3 wil be arranged to be next work.
weidong
looking forward to your new document!
Thandks
hi sun,
I port the wm8960 code to android4.4.2, the wm8960 driver is ok,I can found the wm8960 sound card  and can found the
controlC0
pcmC0D0c
pcmC0D0p
timer
in /dev/snd dir.
but that has some problem,the logcat is:
W/audio_hw_primary( 2281): card -1, port 0 device 0x400
W/audio_hw_primary( 2281): rate 44100, channel 2 period_size 0xc0
E/audio_hw_primary( 2281): cannot open pcm_out driver 1: cannot open device '/dev/snd/pcmC4294967295D0p': No such file or directory
and can't hear anything on the headphone.
all are base on the document's guide.
can you give me some advise?
hi,sun!
Can you write a document introduce how to port the driver to android4.4.3/android5.0/yocto1.6.2?
Is there a plan?
Hi Wilson,
            I am using WM8960 for my project, I added above modules(config_wm8960.h,wm8960.c,wm8960.h,imx-wm8960.c) , Working Fine.I can able to hear the audio. Thanks Weidong.sun.
Hi Zidan,
          I want small info from you.I took sabresd reference, Audio COdec working fine( I can able to record & Listen audio),As per imx-wm8960(Machine drivers) routed Audio Codec(WM8960) to MIC(input1 ADC to store audio in Process) & Head_phone(Processor's DAC to output channel).
But As per my requirements i need to play Auxillory audio stream which connected to 2nd input channel & FM in 3rd input channel(Like below pic).
So how i can route(switch one input channel to other input channel) it in imx-wm8960.c file like below.
static const struct snd_soc_dapm_route imx6_audio_map[] = {
    { "Headphone Jack",         NULL,           "HP_L"      },
    { "Headphone Jack",         NULL,           "HP_R"      },
    { "Speaker_L",              NULL,           "SPK_LP"    },
    { "Speaker_L",              NULL,           "SPK_LN"    },
    { "Speaker_R",              NULL,           "SPK_RP"    },
    { "Speaker_R",              NULL,           "SPK_RN"    },
    { "LINPUT1",                NULL,           "MICB"      },
    { "MICB",                   NULL,           "Mic Jack"  },
//    { "LINPUT3",                "LINPUT3 Switch",       "HP_L"   },
//    { "RINPUT3",                "RINPUT3 Switch",       "HP_R"   },
I am waiting for your reply. Thank you.
It's not working on my platform. The only diffenent is i2c channel, othere are same.. does I lost something ?
------------------------------ parital log --------------------------------
usbcore: registered new interface driver snd-usb-audio
wm8960 i2C probe
wm8960 i2C probe sucessful
imx-hdmi-soc-dai: probe of imx-hdmi-soc-dai.0 failed with error -12
imx_wm8960_probe successful,MCLK is 24000000
wm8960 machine device add
ALSA device list:
  No soundcards found.
oprofile: using arm/armv7-ca9
GACT probability NOT on
Mirror/redirect action on
Please help me to check ... Thanks!
David5ICP
Hi wilson,
     In our new BSP , wm8960 was supported. you can find it on i.MX6UL evk board.
Weidong
请问,您的问题解决了吗?我也遇到了类似问题,ALSA device list:里找不到wm8960。若已经解决,介意告诉我解决方法吗?
Hi Jiang,
 我當初的問題是 I2C channel 設定的問題, 因我的 i2c 與參考設計不同, 除在  board file 裡定義外, 在  driver 也須調整, 請見下述斜體字部分::
static struct snd_soc_dai_link imx_dai[] = {
.name = "HiFi",
.stream_name = "HiFi",
.codec_dai_name = "wm8960-hifi",
.codec_name = "wm8960.1-001a",
/* wm8960.1-001a代表的是用I2C1来控制codec,其I2C地址为0x1a;I2CX, X代表的是0,1,2,开始 */
.cpu_dai_name = "imx-ssi.1",
* 代表的是同一个声卡中的第一个设备与SSI1相连;I2SX X代表0,1,2;ssi.1代表SSI1。
* IMX6中的SSI接口有3对可以接着路I2S;三路SSI可以每路SSI 单独作为一个声卡,
* 也可以是一个声卡包含多个设备;
.platform_name = "imx-pcm-audio.1",
/* 代表的连接接口与SSI来对应,用哪路SSI,其后面的数字就是几。 */
.init = imx_wm8960_init,
.ops = &imx_hifi_ops,
出處 詳細可參考這篇 :: http://www.bkjia.com/Androidjc/972723.html
BR.
David Wu
非常感谢!在您的帮助下,wm8960终于被识别了。
只是似乎和hdmi有些冲突,在设置-》声音-》音量中修改音量时,偶尔会导致黑屏(hdmi接口的显示器)。而且声音播放也不正常。不知您是否遇到了类似问题?
你好,在David Wu的帮助下,wm8960终于被识别了。但是似乎和hdmi有些冲突,在设置-》声音-》音量中修改音量时,偶尔会导致黑屏(hdmi接口的显示器)。而且声音播放也不正常。这大概是哪里的问题?有解决的办法吗?
Hi Jiang,
 我是沒有碰到你說的現象.. 但有發生開機時 HDMI 異常而造成 I2C 無法讀取 (我的 HDMI 與 Wm8960 接同一組 i2c).. .. 因為 我量了 i2c 發現是被  HDMI 拉到 low .. 以致同一 i2c channel 上的 devices 都不能用.. 我沒有繼續追查... 因我預計這是解不了了 (HDMI 本身造成)... 最後我把他們兩組分開了 ~
BR.
David Wu
hi sun,
new BSP ,the wm8960 for the i.MX6UL board is the sai interface,but the imx6q/dl/solo must use the ssi interface.
so the wm8960 is not supported in imx6q/dl/solo.
Do you have the plan to port the wm8960 to the imx6q/dl/solo in the new kernel bsp?
thanks
%3CLINGO-SUB%20id%3D%22lingo-sub-1107622%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWM8960%20%E3%81%8B%E3%82%89%20Android%20jb4.2.2%20%E3%81%B8%E3%81%AE%E7%A7%BB%E6%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107622%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81WM8960%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%82%92%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%AB%E3%81%AEandroid4.2.2%20BSP%E3%81%AB%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%82%E3%81%AE%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E(1)%E7%A7%BB%E6%A4%8D%E7%94%A8%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E(2)%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3Awm8960.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E(3)%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3A%20imx-wm8960.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E(4)WM8960%E3%81%AE%E5%8F%82%E8%80%83%E5%9B%9E%E8%B7%AF%E5%9B%B3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E(5)Android%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AAHAL%3Aconfig_wm8960.h%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E(6)schematic%3A%20%3CSPAN%20class%3D%22%22%3EMX6QDL-PIANO-CNFV1.DSN%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22%22%3E(7)i.MX6DL%20BSP%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22%22%3Emx6dl_piano.c%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22%22%3Emx6dl_piano.h%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22%22%3Emx6dl_piano_pmic_pfuse100.c%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22%22%3E(8)i.MX6Q%20BSP%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22%22%3Emx6q_piano.c%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22%22%3Emx6q_piano.h%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22%22%3Emx6q_piano_pmic_pfuse100.c%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABTIS%E3%83%81%E3%83%BC%E3%83%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3EWeidong.sun%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1107622%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6DL%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Dual%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3Ei.MX6S%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AWM8960%E3%82%92Android%20jb4.2.2%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20sun%2C%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84BSP%E3%80%81i.MX6UL%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AEwm8960%E3%81%AF%3CSTRONG%3E%20sai%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FSTRONG%3E%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81imx6q%20%2F%20dl%20%2F%20solo%E3%81%AF%20%3CSTRONG%3Essi%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81WM8960%20%E3%81%AF%20IMX6Q%2FDL%2FSOLO%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%20bsp%20%E3%81%A7%20wm8960%20%E3%82%92%20imx6q%2Fdl%2Fsolo%20%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%AC%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107636%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Porting%20WM8960%20to%20Android%20jb4.2.2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107636%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Jiang%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%8A%E3%81%A3%E3%81%97%E3%82%83%E3%82%8B%E7%8F%BE%E8%B1%A1%E3%81%AB%E3%81%AF%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E8%B5%B7%E5%8B%95%E6%99%82%E3%81%ABHDMI%E3%81%AB%E7%95%B0%E5%B8%B8%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81I2C%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%81%E3%81%AA%E3%81%84%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%E7%A7%81%E3%81%AEHDMI%E3%81%A8Wm8960%E3%81%AF%E5%90%8C%E3%81%98i2c%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82i2c%E3%82%92%E8%A8%88%E6%B8%AC%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81HDMI%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%AD%E3%83%BC%E3%81%AB%E3%83%97%E3%83%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%82%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E5%90%8C%E3%81%98i2c%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AB%E3%81%82%E3%82%8B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E8%AA%BF%E6%9F%BB%E3%82%92%E7%B6%9A%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%EF%BC%88HDMI%E8%87%AA%E4%BD%93%E3%81%8C%E5%8E%9F%E5%9B%A0%EF%BC%89%E3%81%A8%E4%BA%88%E6%83%B3%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%E3%80%82%E7%B5%90%E5%B1%80%E3%80%812%E3%81%A4%E3%81%AE%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%97%E3%81%AB%E5%88%86%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%EF%BD%9E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR.%3C%2FP%3E%3CP%3EDavid%20Wu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107635%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Porting%20WM8960%20to%20Android%20jb4.2.2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107635%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82David%20%3CA%20_jive_internal%3D%22true%22%20data-userid%3D%22216065%22%20data-username%3D%22david5icp%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fdavid5icp%22%20style%3D%22color%3A%20%235e89c1%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-weight%3A%20200%3B%20font-size%3A%201.286rem%3B%22%20target%3D%22_blank%22%3EWu%3C%2FA%3E%E3%81%95%E3%82%93%E3%81%AE%E5%8A%A9%E3%81%91%E3%81%AE%E3%81%8A%E3%81%8B%E3%81%92%E3%81%A7%E3%80%81wm8960%E3%81%8C%E3%82%88%E3%81%86%E3%82%84%E3%81%8F%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3EHDMI%E3%81%A8%E3%81%AE%E7%AB%B6%E5%90%88%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%80%8C%E8%A8%AD%E5%AE%9A%E3%80%8D%E2%86%92%E3%80%8C%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%80%8D%E2%86%92%E3%80%8C%E9%9F%B3%E9%87%8F%E3%80%8D%E3%81%A7%E9%9F%B3%E9%87%8F%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%99%82%E3%80%85%E9%BB%92%E3%81%84%E7%94%BB%E9%9D%A2%EF%BC%88HDMI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E7%94%BB%E9%9D%A2%EF%BC%89%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%81%AE%E5%86%8D%E7%94%9F%E3%82%82%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BD%95%E3%81%8C%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107634%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Porting%20WM8960%20to%20Android%20jb4.2.2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107634%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%AC%E5%BD%93%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%E7%9A%86%E3%81%95%E3%82%93%E3%81%AE%E3%81%8A%E5%8A%9B%E6%B7%BB%E3%81%88%E3%81%AE%E3%81%8A%E3%81%8B%E3%81%92%E3%81%A7%E3%80%81wm8960%20%E3%81%8C%E3%82%88%E3%81%86%E3%82%84%E3%81%8F%E8%AA%8D%E8%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3EHDMI%E3%81%A8%E3%81%AE%E7%AB%B6%E5%90%88%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E8%A8%AD%E5%AE%9A%E2%86%92%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E2%86%92%E9%9F%B3%E9%87%8F%E3%81%A7%E9%9F%B3%E9%87%8F%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%99%82%E3%80%85%E7%94%BB%E9%9D%A2%E3%81%8C%E7%9C%9F%E3%81%A3%E9%BB%92%E3%81%AB%E3%81%AA%E3%82%8A%EF%BC%88HDMI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E7%94%BB%E9%9D%A2%EF%BC%89%E3%80%81%E9%9F%B3%E5%A3%B0%E3%81%AE%E5%86%8D%E7%94%9F%E3%82%82%E6%AD%A3%E5%B8%B8%E3%81%AB%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AA%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%95%E3%82%8C%E3%81%9F%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107633%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Porting%20WM8960%20to%20Android%20jb4.2.2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107633%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Jiang%2C%3C%2FP%3E%3CP%3E%E5%BD%93%E5%88%9D%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AFI2C%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AEI2C%E3%81%AF%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%A8%E7%95%B0%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%81%AB%E5%8A%A0%E3%81%88%E3%81%A6%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E5%81%B4%E3%81%A7%E3%82%82%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A4%E3%82%BF%E3%83%AA%E3%83%83%E3%82%AF%E4%BD%93%E3%81%AE%E9%83%A8%E5%88%86%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%9D%99%E7%9A%84%E6%A7%8B%E9%80%A0%E4%BD%93%20snd_soc_dai_link%20imx_dai%5B%5D%20%3D%20%7B%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20%E3%80%82%E5%90%8D%E5%89%8D%3D%20%22HiFi%22%2C%3CBR%20%2F%3E%20.%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E5%90%8D%3D%20%22HiFi%22%2C%3CBR%20%2F%3E%20.codec_dai_name%3D%20%22wm8960-hifi%22%2C%3CBR%20%2F%3E%20%3CSTRONG%3E%3CEM%3E.codec_name%20%3D%20%22wm8960.1-001a%22%2C%3C%2FEM%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CEM%3E%3CSTRONG%3E%2F*%20wm8960.1-001a%E3%81%AFI2C1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%80%81%E3%81%9D%E3%81%AEI2C%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF0x1a%E3%81%A7%E3%81%99%E3%80%82I2CX%E3%80%81X%E3%81%AF0%E3%80%811%E3%80%812%E3%80%81%E9%96%8B%E5%A7%8B%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99*%2F%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3E.cpu_dai_name%20%3D%20%22imx-ssi.1%22%2C%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20%3CEM%3E%3CSTRONG%3E%2F*%3C%2FSTRONG%3E%3C%2FEM%3E%3CBR%20%2F%3E%20*%20%E3%81%AF%20SSI1%20%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%90%8C%E3%81%98%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AE%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82I2SX%20X%20%E3%81%AF%200%E3%80%811%E3%80%812%20%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82ssi.1%20%E3%81%AF%20SSI1%20%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20IMX6%E3%81%AB%E3%81%AFI2S%E6%8E%A5%E7%B6%9A%E5%8F%AF%E8%83%BD%E3%81%AASSI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%8C3%E7%B5%84%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%823%E7%B5%84%E3%81%AESSI%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%82%AB%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20*%20%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%20%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E8%A4%87%E6%95%B0%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%82%82%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20*%2F%3CBR%20%2F%3E%20.%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E5%90%8D%3D%20%22imx-pcm-audio.1%22%2C%3CBR%20%2F%3E%2F*%20SSI%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E6%8E%A5%E7%B6%9A%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E8%A1%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%81%AE%E6%95%B0%E5%AD%97%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8BSSI%E3%81%A7%E3%81%99%E3%80%82%20*%2F%3CBR%20%2F%3E%20.init%3D%20imx_wm8960_init%E3%80%81%3CBR%20%2F%3E%20.ops%3D%20%26amp%3Bimx_hifi_ops%2C%3CBR%20%2F%3E%20%7D%2C%3CBR%20%2F%3E%20%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%AE%E8%A8%98%E4%BA%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CA%20href%3D%22http%3A%2F%2Fwww.bkjia.com%2FAndroidjc%2F972723.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20%230066cc%3B%20text-decoration%3A%20underline%3B%22%3E%3C%2FSPAN%3E%3C%2FA%3E%20%3CA%20href%3D%22http%3A%2F%2Fwww.bkjia.com%2FAndroidjc%2F972723.html%22%20target%3D%22test_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.bkjia.com%2FAndroidjc%2F972723.html%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBR.%3C%2FP%3E%3CP%3EDavid%20Wu%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107632%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20Porting%20WM8960%20to%20Android%20jb4.2.2%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107632%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E7%A7%81%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82ALSA%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%AA%E3%82%B9%E3%83%88%E3%81%ABwm8960%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%82%E3%81%97%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%82%88%E3%81%86%E3%81%A7%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AWM8960%E3%82%92Android%20jb4.2.2%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%A6%E3%82%A3%E3%83%AB%E3%82%BD%E3%83%B3%E3%80%81%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84BSP%E3%81%A7%E3%81%AF%E3%80%81wm8960%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82i.MX6UL%20evk%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EWeidong%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AWM8960%E3%82%92Android%20jb4.2.2%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107630%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%20%E7%A7%81%E3%81%AE%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E5%94%AF%E4%B8%80%E3%81%AE%E9%81%95%E3%81%84%E3%81%AFi2c%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E3%81%A7%E3%81%99%E3%80%82%E4%BD%95%E3%81%8B%E3%82%92%E5%A4%B1%E3%81%8F%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E------------------------------%20parital%20log%20--------------------------------%3C%2FP%3E%3CP%3Eusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BCsnd-usb-audio%E3%82%92%E7%99%BB%E9%8C%B2%3C%2FP%3E%3CP%3Ewm8960%20i2C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FP%3E%3CP%3Ewm8960%20i2C%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E6%88%90%E5%8A%9F%3C%2FP%3E%3CP%3Eimx-hdmi-soc-dai%3A%20imx-hdmi-soc-dai.0%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-12%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Eimx_wm8960_probe%E6%88%90%E5%8A%9F%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81MCLK%E3%81%AF24000000%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EWM8960%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3EALSA%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%B8%80%E8%A6%A7%3A%3C%2FP%3E%3CP%3E%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3Eoprofile%3Aarm%2Farmv7-CA9%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3EGACT%E3%81%AE%E7%A2%BA%E7%8E%87%E3%81%8C%E3%82%AA%E3%83%B3%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%3E%E3%83%9F%E3%83%A9%E3%83%BC%2F%E3%83%AA%E3%83%80%E3%82%A4%E3%83%AC%E3%82%AF%E3%83%88%E3%82%A2%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FP%3E%3CP%3E--------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%E7%A2%BA%E8%AA%8D%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84...%E6%84%9F%E8%AC%9D%EF%BC%81%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%93%E3%83%83%E3%83%895ICP%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AWM8960%E3%82%92Android%20jb4.2.2%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%20color%3A%20%230b5394%3B%22%3EHi%20Zidan%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8B%E3%82%89%E5%B0%8F%E3%81%95%E3%81%AA%E6%83%85%E5%A0%B1%E3%81%8C%E6%AC%B2%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E7%A7%81%E3%81%AF%E3%82%BB%E3%82%A4%E3%83%90%E3%83%BC%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%82%92%E5%8F%96%E3%81%A3%E3%81%9F%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AACOdec%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B(%E7%A7%81%E3%81%AF%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%92%E9%8C%B2%E9%9F%B3%E3%81%97%E3%81%A6%E8%81%9E%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B)%E3%81%8C%E3%80%81imx-wm8960(%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90)%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B3%E3%83%BC%E3%83%87%E3%83%83%E3%82%AF(WM8960)%E3%82%92MIC(%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AEinput1%20ADC)%E3%81%A8Head_phone(%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AEDAC%E3%82%92%E5%87%BA%E5%8A%9B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AB)%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E7%A7%81%E3%81%AE%E8%A6%81%E4%BB%B6%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%812%E7%95%AA%E7%9B%AE%E3%81%AE%E5%85%A5%E5%8A%9B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%A83%E7%95%AA%E7%9B%AE%E3%81%AE%E5%85%A5%E5%8A%9B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AEFM%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E8%A3%9C%E5%8A%A9%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%82%B9%E3%83%88%E3%83%AA%E3%83%BC%E3%83%A0%E3%82%92%E5%86%8D%E7%94%9F%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%EF%BC%88%E4%B8%8B%E3%81%AE%E5%86%99%E7%9C%9F%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB)%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6imx-wm8960.c%E3%81%A7%E3%81%9D%E3%82%8C%E3%82%92%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%99%E3%82%8B(1%E3%81%A4%E3%81%AE%E5%85%A5%E5%8A%9B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%92%E4%BB%96%E3%81%AE%E5%85%A5%E5%8A%9B%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%82%8B)%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3C%2FP%3E%3CDIV%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%E9%9D%99%E7%9A%84%20const%20struct%20snd_soc_dapm_route%20imx6_audio_map%5B%5D%20%3D%20%7B%3C%2FSPAN%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%7B%20%22%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%22%2C%20NULL%2C%20%22HP_L%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%7B%20%22%E3%83%98%E3%83%83%E3%83%89%E3%83%95%E3%82%A9%E3%83%B3%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%22%2C%20NULL%2C%20%22HP_R%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%7B%20%22Speaker_L%22%2C%20NULL%2C%20%22SPK_LP%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%7B%20%22Speaker_L%22%2C%20NULL%2C%20%22SPK_LN%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%7B%20%22Speaker_R%22%2C%20NULL%2C%20%22SPK_RP%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%7B%20%22Speaker_R%22%2C%20NULL%2C%20%22SPK_RN%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7B%20%22LINPUT1%22%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20NULL%2C%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22MICB%22%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%7B%20%22MICB%22%2C%20NULL%2C%20%22%E3%83%9E%E3%82%A4%E3%82%AF%E3%82%B8%E3%83%A3%E3%83%83%E3%82%AF%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%7B%20%22LINPUT3%22%2C%20%22LINPUT3%20%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%22%2C%20%22HP_L%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%7B%20%22RINPUT3%22%2C%20%22RINPUT3%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%22%2C%20%22HP_R%22%20%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%20%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23222222%3B%20font-family%3A%20arial%2C%20sans-serif%3B%20font-size%3A%2012.7272720336914px%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%230b5394%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202016-02-16%2011_33_32.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Screenshot%20from%202016-02-16%2011_33_32.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F53541i7A2A45253876A7CC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Screenshot%20from%202016-02-16%2011_33_32.png%22%20alt%3D%22Screenshot%20from%202016-02-16%2011_33_32.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EScreenshot%20from%202016-02-16%2011_33_32.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AWM8960%E3%82%92Android%20jb4.2.2%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107627%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%2Csun!%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23434343%3B%20font-family%3A%20Tahoma%2C%20Arial%3B%20font-size%3A%2012px%3B%20background-color%3A%20%23f2f2f2%3B%22%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92android4.4.3%20%2F%20android5.0%20%2F%20yocto1.6.2%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%B4%B9%E4%BB%8B%E3%81%99%E3%82%8B%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E6%9B%B8%E3%81%84%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22background-color%3A%20%23ffff00%3B%20color%3A%20%23333333%3B%20font-size%3A%2016px%3B%20font-family%3A%20arial%3B%22%3E%E3%83%97%E3%83%A9%E3%83%B3%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AWM8960%E3%82%92Android%20jb4.2.2%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ehi%20sun%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFwm8960%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92android4.4.2%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%97%E3%80%81wm8960%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E5%95%8F%E9%A1%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E7%A7%81%E3%81%AFwm8960%E3%82%B5%E3%82%A6%E3%83%B3%E3%83%89%E3%82%AB%E3%83%BC%E3%83%89%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%20%3C%2FP%3E%3CP%3E%E5%88%B6%E5%BE%A1C0%3C%2FP%3E%3CP%3EpcmC0D0c%3C%2FP%3E%3CP%3EpcmC0D0p%3C%2FP%3E%3CP%3E%E3%82%BF%E3%82%A4%E3%83%9E%3C%2FP%3E%3CP%3E%2Fdev%2Fsnd%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AB%E3%81%AF%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%81logcat%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EW%20%2Faudio_hw_primary(%202281)%3A%20%E3%82%AB%E3%83%BC%E3%83%89%20-1%E3%80%81%E3%83%9D%E3%83%BC%E3%83%88%200%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200x400%3C%2FP%3E%3CP%3EW%20%2F%20audio_hw_primary(2281)%3A%E3%83%AC%E3%83%BC%E3%83%8844100%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB2%20period_size%200xc0%3C%2FP%3E%3CP%3EE%20%2F%20audio_hw_primary(2281)%3Apcm_out%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC1%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%3CSTRONG%3E%E3%80%8C%2F%20dev%20%2F%20snd%20%2F%20pcmC4294967295D0p%3C%2FSTRONG%3E%E3%80%8D%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3EW%20%2Faudio_hw_primary(%202281)%3A%20%E3%82%AB%E3%83%BC%E3%83%89%20-1%E3%80%81%E3%83%9D%E3%83%BC%E3%83%88%200%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%200x400%3C%2FP%3E%3CP%3EW%20%2F%20audio_hw_primary(2281)%3A%E3%83%AC%E3%83%BC%E3%83%8844100%E3%80%81%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB2%20period_size%200xc0%3C%2FP%3E%3CP%3EE%20%2F%20audio_hw_primary(2281)%3Apcm_out%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC1%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%3CSTRONG%3E%E3%80%8C%2F%20dev%20%2F%20snd%20%2F%20pcmC4294967295D0p%3C%2FSTRONG%3E%E3%80%8D%E3%82%92%E9%96%8B%E3%81%8F%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%98%E3%83%83%E3%83%89%E3%83%9B%E3%83%B3%E3%81%A7%E3%81%AF%E4%BD%95%E3%82%82%E8%81%9E%E3%81%93%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AF%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1107624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AWM8960%E3%82%92Android%20jb4.2.2%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1107624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E9%AB%98%E3%81%84%E8%A9%95%E4%BE%A1%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3EAndroid4.4.3%E3%81%B8%E3%81%AE%E7%A7%BB%E6%A4%8D%E3%81%AF%E6%AC%A1%E3%81%AE%E4%BD%9C%E6%A5%AD%E3%81%AB%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E4%BA%88%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eweidong%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎08-12-2015 11:14 PM
更新者:
