i.MX51 Ubuntu USB TS
Using a USB Touchscreen on Ubuntu
  This example uses a XENARC 706TSA monitor http://www.xenarc.com/product/706tsa.html
To use a USB touchscreen on i.MX51 EVK, disable all touchscreen drivers on menuconfig and build the kernel:
Device Drivers  --->
       Input device support  --->
       [ ]   Touchscreens  --->
Download xserver-xorg-input-evtouch (0.8.8-ubuntu3 version) from http://launchpadlibrarian.net/24760784/xserver-xorg-input-evtouch_0.8.8-0ubuntu3_armel.deb.
X crash is found if using latest 0.8.8-ubuntu6.1 version. For the details. See https://bugs.launchpad.net/ubuntu/+source/xf86-inputevtouch/+bug/511491
On MX51 EVK board, run “sudo dpkg –i xserver-xorg-input-evtouch_0.8.8-0ubuntu3_armel.deb” to install debian package.
Add fdi file by "sudo vi ./usr/share/hal/fdi/policy/20thirdparty/50-eGalax.fdi":
<?xml version="1.0" encoding="UTF-8"?>
<deviceinfo version="0.2">
   <device>
      <match key="info.product" contains="eGalax">
         <match key="info.capabilities" contains="input">
            <merge key="input.x11_driver" type="string">evtouch</merge>
            <merge key="input.x11_options.minx" type="string">130</merge>
            <merge key="input.x11_options.miny" type="string">197</merge>
            <merge key="input.x11_options.maxx" type="string">3945</merge>
            <merge key="input.x11_options.maxy" type="string">3894</merge>
            <merge key="input.x11_options.Rotate" type="string">CCW</merge>
            <merge key="input.x11_options.Swapy" type="string">true</merge>
            <merge key="input.x11_options.taptimer" type="string">30</merge>
            <merge key="input.x11_options.longtouchtimer" type="string">750</merge>
            <merge key="input.x11_options.longtouched_action" type="string">click</merge>
            <merge key="input.x11_options.longtouched_button" type="string">3</merge>
            <merge key="input.x11_options.oneandhalftap_button" type="string">2</merge>
            <merge key="input.x11_options.movelimit" type="string">10</merge>
            <merge key="input.x11_options.touched_drag" type="string">1</merge>
            <merge key="input.x11_options.maybetapped_action" type="string">click</merge>
            <merge key="input.x11_options.maybetapped_button" type="string">1</merge>
         </match>
      </match>
   </device>
</deviceinfo>
Save above configuration.
Calibrating
Calibration in made by clicking on System -> Administration -> Calibrate Touchscreen
Follow the on screen instructions and reboot the system.
Calibrating using Xinput Calibrator
Xinput_calibrator is another option to calibrate touchscreen. It can be downloaded at: http://www.freedesktop.org/wiki/Software/xinput_calibrator
On i.MX5x Ubuntu, unpack the source code:
tar -xzvf xinput_calibrator-0.7.5.tar.gz
Install xorg-dev, it's required to build xinput_calibrator
sudo apt-get install xorg-dev
Configure, build and install xinput_calibrator
./configure
./make
./make install
Execute xinput_calibrator. A four-point calibration screen will be shown. Follow the instructions on screen and after complete xinput_calibrator will return the calibration parameters.
Replace the given calibration parameters on file /usr/share/hal/fdi/policy/20thirdparty/50-eGalax.fdi and reboot the system.
ラベル(2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1100919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX51%20Ubuntu%20USB%20TS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-380493664%22%20id%3D%22toc-hId-380493664%22%20id%3D%22toc-hId-1304162744%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EUbuntu%E3%81%A7USB%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%20style%3D%22background-color%3A%20%23eeeeff%3B%20padding-left%3A%2030px%3B%20width%3A%2060%25%3B%20margin-left%3A%2020%25%3B%22%3E%3CP%20class%3D%22note%22%3E%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81XENARC%20706TSA%20%E3%83%A2%E3%83%8B%E3%82%BF%E3%83%BC%20%3CA%20class%3D%22free%20external%22%20href%3D%22http%3A%2F%2Fwww.xenarc.com%2Fproduct%2F706tsa.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.xenarc.com%2Fproduct%2F706tsa.html%3C%2FA%3E%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX51%20EVK%E3%81%A7USB%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81menuconfig%E3%81%A7%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%3CSTRONG%3E%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%3C%2FSTRONG%3E%20%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC---%26gt%3B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E5%85%A5%E5%8A%9B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88---%26gt%3B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B%20%5D%20%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%20---%26gt%3B%0A%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ts_usb_menuconfig.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Ts_usb_menuconfig.jpg%22%20style%3D%22width%3A%20600px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F37848iE966C7765E05877B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Ts_usb_menuconfig.jpg%22%20alt%3D%22Ts_usb_menuconfig.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CA%20class%3D%22free%20external%22%20href%3D%22http%3A%2F%2Flaunchpadlibrarian.net%2F24760784%2Fxserver-xorg-input-evtouch_0.8.8-0ubuntu3_armel.deb%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Flaunchpadlibrarian.net%2F24760784%2Fxserver-xorg-input-evtouch_0.8.8-0ubuntu3_armel.deb%3C%2FA%3E%20%E3%81%8B%E3%82%89%20xserver-xorg-input-evtouch%20(0.8.8-ubuntu3%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3)%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E6%96%B0%E3%81%AE0.8.8-ubuntu6.1%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81X%E3%81%AE%E3%82%AF%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%82%3CA%20class%3D%22free%20external%22%20href%3D%22https%3A%2F%2Fbugs.launchpad.net%2Fubuntu%2F%2Bsource%2Fxf86-inputevtouch%2F%2Bbug%2F511491%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fbugs.launchpad.net%2Fubuntu%2F%2Bsource%2Fxf86-inputevtouch%2F%2Bbug%2F511491%3C%2FA%3E%20%E3%82%92%E8%A6%8B%E3%82%8B%3C%2FP%3E%3CP%3EMX51%20EVK%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%80%81%E3%80%8Csudo%20dpkg%20%E2%80%93i%20xserver-xorg-input-evtouch_0.8.8-0ubuntu3_armel.deb%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6debian%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%22sudo%20vi%20.%2Fusr%2Fshare%2Fhal%2Ffdi%2Fpolicy%2F20thirdparty%2F50-eGalax.fdi%22%20%E3%81%A7%20fdi%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%0A%3CDEVICEINFO%20version%3D%220.2%22%3E%3CDEVICE%3E%3CMATCH%20key%3D%22info.product%22%20contains%3D%22eGalax%22%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMATCH%20key%3D%22info.capabilities%22%20contains%3D%22input%22%20%E3%81%A7%E3%81%99%3D%22%22%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_driver%22%20type%3D%22string%22%3Eevtouch%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_options.minx%22%20type%3D%22string%22%3E130%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_options.miny%22%20type%3D%22string%22%3E197%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_options.maxx%22%20type%3D%22string%22%3E3945%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_options.maxy%22%20type%3D%22string%22%3E3894%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_options.%E5%9B%9E%E8%BB%A2%22%20type%3D%22string%22%3ECCW%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_options.Swapy%22%20type%3D%22string%22%3Etrue%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_options.taptimer%22%20type%3D%22string%22%3E30%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_options.longtouchtimer%22%20type%3D%22string%22%3E750%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_options.longtouched_action%22%20type%3D%22string%22%3E%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%20%3CMERGE%20key%3D%22input.x11_options.longtouched_button%22%3E%3C%2FMERGE%3Etype%3D%22string%22%26gt%3B3%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B%E3%83%9E%E3%83%BC%E3%82%B8%E3%82%AD%E3%83%BC%3D%22input.x11_options.oneandhalftap_button%22type%3D%22string%22%26gt%3B2%3C%2FMATCH%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_options.movelimit%22%20type%3D%22string%22%3E10%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_options.touched_drag%22%20type%3D%22string%22%3E1%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3CMERGE%20key%3D%22input.x11_options.maybetapped_action%22%20type%3D%22string%22%3E%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%20%3CMERGE%20key%3D%22input.x11_options.maybetapped_button%22%3E%3C%2FMERGE%3Etype%3D%22string%22%26gt%3B1%3C%2FMERGE%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FMATCH%3E%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FDEVICE%3E%0A%26nbsp%3B%26nbsp%3B%20%3C%2FDEVICEINFO%3E%0A%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%0A%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1071055138%22%20id%3D%22toc-hId-1071055138%22%20id%3D%22toc-hId-1994724218%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81%5B%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%5D%20-%26gt%3B%20%5B%E7%AE%A1%E7%90%86%5D%20-%26gt%3B%20%5B%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%AE%E8%AA%BF%E6%95%B4%5D%20%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%BB%E9%9D%A2%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--736399325%22%20id%3D%22toc-hId--736399325%22%20id%3D%22toc-hId-187269755%22%3E%3CSPAN%20class%3D%22mw-headline%22%3EXinput%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3EXinput_calibrator%E3%82%BF%E3%83%83%E3%83%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%92%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E5%88%A5%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%99%E3%80%82%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E5%85%88%3A%20%3CA%20class%3D%22free%20external%22%20href%3D%22http%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSoftware%2Fxinput_calibrator%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.freedesktop.org%2Fwiki%2FSoftware%2Fxinput_calibrator%3C%2FA%3E%3C%2FP%3E%3CP%3Ei.MX5x%20Ubuntu%E3%81%A7%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A7%A3%E5%87%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Etar%20-xzvf%20xinput_calibrator-0.7.5.tar.gz%20%3C%2FPRE%3E%3CP%3Exorg-dev%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%20xinput_calibrator%20%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Esudo%20apt-get%20install%20xorg-dev%20%3C%2FPRE%3E%3CP%3Exinput_calibrator%E3%81%AE%E6%A7%8B%E6%88%90%E3%80%81%E3%83%93%E3%83%AB%E3%83%89%E3%80%81%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%E3%80%82%2F%E6%A7%8B%E6%88%90%0A%E3%80%82%2F%E4%BD%9C%E3%82%8B%E3%80%82%2F%E4%BD%9C%E3%82%8B%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%82%8B%0A%3C%2FPRE%3E%3CP%3Exinput_calibrator%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%824%E7%82%B9%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E7%94%BB%E9%9D%A2%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E7%94%BB%E9%9D%A2%E3%81%AE%E6%8C%87%E7%A4%BA%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E5%AE%8C%E4%BA%86%E5%BE%8C%E3%80%81xinput_calibrator%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%2Fusr%2Fshare%2Fhal%2Ffdi%2Fpolicy%2F20thirdparty%2F50-eGalax.fdi%20%E3%81%AB%E3%81%82%E3%82%8B%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1100919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX51%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 01:40 AM
更新者:
