i.MX35 PDK NAND Creating and Flashing UBIFS image
Quick Steps
Four quick steps to build and flash a UBIFS image on i.MX35 NAND (K9LBG08U0D-PCB0), for information on how to you another memory, please see next section.
  1. Enable MTD_UBI and UBIFS_FS on kernel
  2. Create UBI image from rootfs (used for NFS) - ON PC
    1. mkfs.ubifs -v -r rootfs -m 2048 -e 258048 -c 966 -o ubifs.img
    2. ubinize -o ubi.img -m 2048 -p 256KiB -s 2048 ubinize.cfg
  3. Format NAND using UBI image - ON TARGET
    1. ubiformat -f ubi.img /dev/mtd8
  4. Load UBI file system
    1. load -r -b 0x100000 zImage
    2. fis create -f 0x300000 kernel
      1. fis load kernel
      2. exec -c "noinitrd console=ttymxc0 115200 ubi.mtd=8 root=ubi0:rootfs rw rootfstype=ubifs ip=none"
How To
First of all, install mtd-utils on both target and host:
Target:
./ltib -c
Package list
[*] mtd-utils
Host
sudo aptget install mtd-utils
MTD_UBI
-> Device Drivers
    -> Memory Technology Device (MTD) support (MTD [=y])
          -> UBI - Unsorted block images
                  <*> Enable UBI
                   (4096) UBI wear-leveling threshold (NEW)
                   (1) Percentage of reserved eraseblocks for bad eraseblocks handling (NEW)
                < > MTD devices emulation driver (gluebi) (NEW)
                   ** UBI debugging options **
                   [ ] UBI debugging (NEW)
UBIFS_FS
-> File systems
        ->Miscellaneous filesystems
            <*> UBIFS file system support
                [ ] Extended attributes support (NEW)
                [ ] Advanced compression options (NEW)
                [ ] Enable debugging (NEW)
2. Create UBI image
On TARGET Collect some information needed in order to create the UBI image according to your NAND device
root@freescale \~$ cat /proc/mtd
dev:   size   erasesize name
mtd0: 00080000 00020000 "Bootloader"
mtd1: 00400000 00020000 "nor.Kernel"
mtd2: 01e00000 00020000 "nor.userfs"
mtd3: 01c00000 00020000 "nor.rootfs"
mtd4: 00003000 00020000 "FIS directory"
mtd5: 02001000 00020000 "Redboot config"
mtd6: 00300000 00040000 "nand.bootloader"
mtd7: 00500000 00040000 "nand.kernel"
mtd8: 10000000 00040000 "nand.rootfs"
mtd9: 00800000 00040000 "nand.configure"
mtd10: 6f000000 00040000 "nand.userfs"
I will use mtd8, because I want the NAND rootfs MTD partition.
More on [1]
root@freescale ~$ ubiattach /dev/ubi_ctrl -m 8
UBI: attaching mtd8 to ubi0
UBI: physical eraseblock size:   262144 bytes (256 KiB)
UBI: logical eraseblock size:    258048 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
UBI: empty MTD device detected
UBI: create volume table (copy #1)
UBI: create volume table (copy #2)
UBI: attached mtd8 to ubi0
UBI: MTD device name:            "nand.rootfs"
UBI: MTD device size:            256 MiB
UBI: number of good PEBs:        979
UBI: number of bad PEBs:         45
UBI: max. allowed volumes:       128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:     0
UBI: available PEBs:             966
UBI: total number of reserved PEBs: 13
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 0/0
UBI: image sequence number: 0
UBI: background thread "ubi_bgt0d" started, PID 2098
UBI device number
You will need:
  • -p = physical eraseblock size = 256KiB
  • -e = logical eraseblock size = 258048
  • -m = smallest flash I/O unit = 2048
  • -s = VID header offset = 2048
  • -c = available PEB = 966
Values only for iMX35 PDK NAND - K9LBG08U0D-PCB0
3. ON HOST - Now, create the images (two steps)
You need to create ubinize.cfg file!
ubinize.cfg
[ubifs]
mode=ubi
image=ubifs.img
vol_id=0
vol_size=237MiB
vol_type=dynamic
vol_name=rootfs
vol_flags=autoresize
$ mkfs.ubifs -v -r rootfs -m 2048 -e 258048 -c 966 -o ubifs.img
mkfs.ubifs
     root:                rootfs/
     min_io_size:    2048
     leb_size:         258048
     max_leb_cnt:   966
     output:            ubifs.img
     jrn_size:          8388608
     reserved:         0
     compr:            lzo
     keyhash:         r5
     fanout:            8
     orph_lebs:       1
     super lebs:      1
     master lebs:    2
     log_lebs:         4
     lpt_lebs:          2
     orph_lebs:       1
     main_lebs:       132
     gc lebs:           1
     index lebs:       2
     leb_cnt:           142
     UUID:              CC2057F9-B20F-46D1-A399-1FCA95DCAFF7
Success\!
$ ubinize -o ubi.img -m 2048 -p 256KiB -s 2048 ubinize.cfg
$ ls -lh u*
-rw-r--r-- 1 daiane daiane 35M 2010-11-26 15:21 ubifs.img
-rw-r--r-- 1 daiane daiane 36M 2010-11-26 15:22 ubi.img
-rw-r--r-- 1 daiane daiane 113 2010-11-26 15:22 ubinize.cfg
$ sudo cp ubi.img rootfs/home/
4. Format NAND using UBI image - ON TARGET
Turn on target (or reset it) and format MTD partition
$ cd /home
$ ubiformat -f ubi.img /dev/mtd8
5. Load UBI file system
Reset and change redboot script:
.. fis load kernel
.. exec -c "noinitrd console=ttymxc0 115200 ubi.mtd=8 root=ubi0:rootfs rw rootfstype=ubifs ip=none"
タグ(2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1125145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX35%20PDK%20NAND%3AUBIFS%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E4%BD%9C%E6%88%90%E3%81%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20id%3D%22toc-hId-382482062%22%20id%3D%22toc-hId-382482062%22%20id%3D%22toc-hId-1304009976%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E3%82%AF%E3%82%A4%E3%83%83%E3%82%AF%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3Ei.MX35%20NAND(K9LBG08U0D-PCB0)%E3%81%A7UBIFS%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE4%E3%81%A4%E3%81%AE%E7%B0%A1%E5%8D%98%E3%81%AA%E6%89%8B%E9%A0%86%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7MTD_UBI%E3%81%A8UBIFS_FS%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3C%2FLI%3E%3CLI%3Erootfs%E3%81%8B%E3%82%89UBI%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B(NFS%E3%81%AB%E4%BD%BF%E7%94%A8)%20-%20ON%20PC%3COL%3E%3CLI%3Emkfs.ubifs%20-v%20-r%20rootfs%20-m%202048%20-e%20258048%20-c%20966%20-o%20ubifs.img%3C%2FLI%3E%3CLI%3Eubinize%20-o%20ubi.img%20-m%202048%20-p%20256KiB%20-s%202048%20ubinize.cfg%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%3CLI%3EUBI%E7%94%BB%E5%83%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FNAND%E3%81%AE%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%20-%20ON%20TARGET%3COL%3E%3CLI%3Eubiformat%20-f%20ubi.img%20%2Fdev%2Fmtd8%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%3CLI%3EUBI%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3COL%3E%3CLI%3Eload%20-r%20-b%200x100000%20zImage%3C%2FLI%3E%3CLI%3Efis%20create%20-f%200x300000%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%3COL%3E%3CLI%3Efis%20load%20kernel%3C%2FLI%3E%3CLI%3Eexec%20-c%20%22noinitrd%20console%3Dttymxc0%20115200%20%3CSTRONG%3Eubi.mtd%3D8%20root%3Dubi0%3Arootfs%20rw%20rootfstype%3Dubifs%3C%2FSTRONG%3E%20ip%3Dnone%22%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%3C%2FOL%3E%3C%2FLI%3E%3C%2FOL%3E%3CH1%20id%3D%22toc-hId--1424972401%22%20id%3D%22toc-hId--1424972401%22%20id%3D%22toc-hId--503444487%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH1%3E%3CH1%20id%3D%22toc-hId-1062540432%22%20id%3D%22toc-hId-1062540432%22%20id%3D%22toc-hId-1984068346%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%E6%93%8D%E4%BD%9C%E6%96%B9%E6%B3%95%3C%2FSPAN%3E%3C%2FH1%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%A8%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%ABmtd-utils%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E.%2Fltib%20-c%20%3C%2FPRE%3E%3CP%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E4%B8%80%E8%A6%A7%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%5B*%5D%20mtd-utils%20%3C%2FPRE%3E%3CP%3E%3CSTRONG%3E%E3%83%9B%E3%82%B9%E3%83%88%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Esudo%20aptget%20install%20mtd-utils%20%3C%2FPRE%3E%3CH2%20id%3D%22toc-hId-1753101906%22%20id%3D%22toc-hId-1753101906%22%20id%3D%22toc-hId--1620337476%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FH2%3E%3CH3%20id%3D%22toc-hId--1851303916%22%20id%3D%22toc-hId--1851303916%22%20id%3D%22toc-hId--929776002%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E1.%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A7MTD_UBI%E3%81%A8UBIFS_FS%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EMTD_UBI%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E-%26gt%3B%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%BB%26gt%3B%20MTD(Memory%20Technology%20Device)%E5%AF%BE%E5%BF%9C(MTD%5B%3Dy%5D)%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%26gt%3B%20UBI%20-%20%E6%9C%AA%E5%88%86%E9%A1%9E%E3%81%AE%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E7%94%BB%E5%83%8F%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3B%20UBI%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20(4096)%20UBI%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E9%96%BE%E5%80%A4(NEW)%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20(1)%20%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%E6%B6%88%E5%8E%BB%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E3%81%86%E3%81%A1%E3%80%81%E4%B8%8D%E8%89%AF%E6%B6%88%E5%8E%BB%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E5%87%A6%E7%90%86%E3%81%AE%E5%89%B2%E5%90%88%20(NEW)%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B%20%26gt%3B%20MTD%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%BB%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20(gluebi)%20(NEW)%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20**%20UBI%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20**%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B%20%5D%20UBI%E3%83%87%E3%83%90%E3%83%83%E3%82%B0(%E6%96%B0%E6%A9%9F%E8%83%BD)%0A%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%20%3CSTRONG%3EUBIFS_FS%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E-%26gt%3B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20-%26gt%3B%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26lt%3B*%26gt%3B%20UBIFS%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B%20%5D%20%E6%8B%A1%E5%BC%B5%E5%B1%9E%E6%80%A7%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%20(NEW)%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B%20%5D%20%E9%AB%98%E5%BA%A6%E3%81%AA%E5%9C%A7%E7%B8%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20(NEW)%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%5B%20%5D%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%20(NEW)%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-636208917%22%20id%3D%22toc-hId-636208917%22%20id%3D%22toc-hId-1557736831%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E2.UBI%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3CSPAN%20class%3D%22mw-headline%22%3ETARGET%E3%81%A7%E3%80%81NAND%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6UBI%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%83%85%E5%A0%B1%E3%82%92%E5%8F%8E%E9%9B%86%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Eroot%40freescale%20%5C~%24%20cat%20%2Fproc%2Fmtd%0Adev%3A%20size%20erasesize%20name%20(%E3%82%B5%E3%82%A4%E3%82%BA%E6%B6%88%E5%8E%BB%E3%82%B5%E3%82%A4%E3%82%BA%E5%90%8D)%0Amtd0%3A%2000080000%2000020000%20%22%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%22%0Amtd1%3A%2000400000%2000020000%20%22nor.%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%80%8D%0Amtd2%3A%2001e00000%2000020000%20%22nor.userfs%22mtd3%3A%2001c00000%2000020000%20%22nor.rootfs%22mtd4%3A%2000003000%2000020000%20%22FIS%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%22%0Amtd5%3A%2002001000%2000020000%20%22Redboot%20config%22%0Amtd6%3A%2000300000%2000040000%20%22nand.bootloader%22mtd7%3A%2000500000%2000040000%20%22nand.kernel%22%3CSTRONG%3Emtd8%3A%2010000000%2000040000%20%22nand.rootfs%22%3C%2FSTRONG%3Emtd9%3A%2000800000%2000040000%20%22nand.configure%22mtd10%3A%206f000000%2000040000%20%22nand.userfs%22%0A%3C%2FPRE%3E%3CP%3ENAND%20rootfs%20MTD%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81mtd8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%A9%B3%E7%B4%B0%20%3CA%20class%3D%22autonumber%20external%22%20href%3D%22http%3A%2F%2Fwww.linux-mtd.infradead.org%2Ffaq%2Fubifs.html%23L_mkfubifs%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3A%20%5B1%5D%3C%2FA%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3Eroot%40freescale%20~%24%20ubiattach%20%2Fdev%2Fubi_ctrl%20-m%208%0AUBI%3A%20mtd8%20%E3%82%92%20ubi0%20%E3%81%AB%E3%82%A2%E3%82%BF%E3%83%83%E3%83%81%E3%81%99%E3%82%8B%0AUBI%3A%20%E7%89%A9%E7%90%86%E6%B6%88%E5%8E%BB%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%B5%E3%82%A4%E3%82%BA%3A%20262144%20%E3%83%90%E3%82%A4%E3%83%88%20(256%20KiB)%0AUBI%3A%20%E8%AB%96%E7%90%86%E6%B6%88%E5%8E%BB%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%BA%3A%20258048%E3%83%90%E3%82%A4%E3%83%88%0AUBI%3A%E6%9C%80%E5%B0%8F%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5I%20%2F%20O%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%3A2048%0AUBI%3AVID%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3A2048(2048%E6%8F%83%E3%81%88)%0AUBI%3A%E3%83%87%E3%83%BC%E3%82%BF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3A4096%0AUBI%3A%20%E7%A9%BA%E3%81%AE%20MTD%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%0AUBI%3A%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90(%E3%82%B3%E3%83%94%E3%83%BC%231)%0AUBI%3A%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90(%E3%82%B3%E3%83%94%E3%83%BC%232)%0AUBI%3Aubi0%E3%81%ABmtd8%E3%82%92%E6%B7%BB%E4%BB%98%0AUBI%3A%20MTD%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E5%90%8D%3A%20%22nand.rootfs%22%0AUBI%3A%20MTD%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%B5%E3%82%A4%E3%82%BA%3A%20256%20MiB%0AUBI%3A%E8%89%AF%E5%A5%BD%E3%81%AAPEB%E3%81%AE%E6%95%B0%3A979%0AUBI%3A%E4%B8%8D%E8%89%AFPEB%E3%81%AE%E6%95%B0%3A45%0AUBI%3A%E6%9C%80%E5%A4%A7%E3%80%82%E8%A8%B1%E5%AE%B9%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%3A128%0AUBI%3A%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%AC%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4%3A4096%0AUBI%3A%E5%86%85%E9%83%A8%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E3%81%AE%E6%95%B0%3A1%0AUBI%3A%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%AA%E3%83%A5%E3%83%BC%E3%83%A0%E6%95%B0%3A0%0AUBI%3A%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AAPEB%3A966%0AUBI%3A%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BFPEB%E3%81%AE%E7%B7%8F%E6%95%B0%3A13%0AUBI%3A%20%E4%B8%8D%E9%81%A9%E5%88%87%E3%81%AA%20PEB%20%E5%87%A6%E7%90%86%E7%94%A8%E3%81%AB%E4%BA%88%E7%B4%84%E3%81%95%E3%82%8C%E3%81%9F%20PEB%20%E3%81%AE%E6%95%B0%3A%209%0AUBI%3A%E6%9C%80%E5%A4%A7%2F%E5%B9%B3%E5%9D%87%E6%B6%88%E5%8E%BB%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%83%BC%3A0%2F0%0AUBI%3A%E7%94%BB%E5%83%8F%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E7%95%AA%E5%8F%B7%3A0%0AUBI%3A%20%E3%83%90%E3%83%83%E3%82%AF%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%80%8Cubi_bgt0d%E3%80%8D%E9%96%8B%E5%A7%8B%E3%80%81PID%202098%0AUBI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E7%95%AA%E5%8F%B7%0A%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%20%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%82%E3%81%AE%3A%3C%2FP%3E%3CUL%3E%3CLI%3E-p%20%3D%20%E7%89%A9%E7%90%86%E6%B6%88%E5%8E%BB%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%20256KiB%3C%2FLI%3E%3CLI%3E-e%20%3D%20%E8%AB%96%E7%90%86%E6%B6%88%E5%8E%BB%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%83%BB%E3%82%B5%E3%82%A4%E3%82%BA%20%3D%20258048%3C%2FLI%3E%3CLI%3E-m%20%3D%20%E6%9C%80%E5%B0%8F%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5I%2FO%E3%83%A6%E3%83%8B%E3%83%83%E3%83%88%20%3D%202048%3C%2FLI%3E%3CLI%3E-s%20%3D%20VID%20%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%20%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%20%3D%202048%3C%2FLI%3E%3CLI%3E-c%20%3D%20%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%20PEB%20%3D%20966%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%20style%3D%22background-color%3A%20%23ffdddd%3B%20padding-left%3A%2030px%3B%20width%3A%2060%25%3B%20margin-left%3A%2020%25%3B%22%3E%3CP%20class%3D%22warning%22%3EValues%20only%20for%20iMX35%20PDK%20NAND%20-%20K9LBG08U0D-PCB0%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--1171245546%22%20id%3D%22toc-hId--1171245546%22%20id%3D%22toc-hId--249717632%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E3.%20%E3%83%9B%E3%82%B9%E3%83%88%E4%B8%8A%20-%20%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%20(2%20%E3%81%A4%E3%81%AE%E6%89%8B%E9%A0%86)%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%20style%3D%22background-color%3A%20%23ffffcc%3B%20padding-left%3A%2030px%3B%20width%3A%2060%25%3B%20margin-left%3A%2020%25%3B%22%3E%3CP%20class%3D%22important%22%3Eubinize.cfg%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eubinize.cfg%3C%2FSTRONG%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%5BUBIFs%5D%0A%E3%83%A2%E3%83%BC%E3%83%89%3DUBI%0A%E7%94%BB%E5%83%8F%3Dubifs.img%0Avol_id%3D0%0Avol_size%3D237MiB%0Avol_type%3D%E3%83%80%E3%82%A4%E3%83%8A%E3%83%9F%E3%83%83%E3%82%AF%0Avol_name%3Drootfs%E3%81%AE%0Avol_flags%3D%E8%87%AA%E5%8B%95%E3%82%B5%E3%82%A4%E3%82%BA%E5%A4%89%E6%9B%B4%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20mkfs.ubifs%20-v%20-r%20rootfs%20-m%202048%20-e%20258048%20-c%20966%20-o%20ubifs.img%0Amkfs.ubifs%20%E3%81%95%E3%82%93%E3%83%AB%E3%83%BC%E3%83%88%3A%20rootfs%2F%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20min_io_size%3A2048%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20leb_size%3A258048%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20max_leb_cnt%3A966%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E5%87%BA%E5%8A%9B%E7%B5%90%E6%9E%9C%3A%20ubifs.imgjrn_size%3A8388608%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E4%BA%88%E7%B4%84%E6%B8%88%E3%81%BF%3A0%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20compr%3A%20lzo%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%82%AD%E3%83%BC%E3%83%8F%E3%83%83%E3%82%B7%E3%83%A5%3AR5%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%95%E3%82%A1%E3%83%B3%E3%82%A2%E3%82%A6%E3%83%88%3A8%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20orph_lebs%3A1%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%82%B9%E3%83%BC%E3%83%91%E3%83%BC%E3%83%AC%E3%83%96%E3%82%B9%3A1%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%AC%E3%83%96%E3%82%B9%3A2%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20log_lebs%3A4%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20lpt_lebs%3A2%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20orph_lebs%3A1%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20main_lebs%3A132%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20GC%E3%83%AC%E3%83%96%3A1%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9LEBS%3A2%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20leb_cnt%3A142%0A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20UUID%3ACC2057F9-B20F-46D1-A399-1FCA95DCAFF7%0A%E6%88%90%E5%8A%9F%5C%EF%BC%81%24%20ubinize%20-o%20ubi.img%20-m%202048%20-p%20256KiB%20-s%202048%20ubinize.cfg%0A%24%20ls%20-lh%20u*%0A-rw-r--r--%201%20daiane%20daiane%2035M%202010-11-26%2015%3A21%20ubifs.img%0A-rw-r--r--%201%20daiane%20daiane%2036M%202010-11-26%2015%3A22%20ubi.img%0A-rw-r--r--%201%20daiane%20daiane%20113%202010-11-26%2015%3A22%20ubinize.cfg%0A%24%20sudo%20cp%20ubi.img%20rootfs%2Fhome%2F%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-1316267287%22%20id%3D%22toc-hId-1316267287%22%20id%3D%22toc-hId--2057172095%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E4.%20UBI%E7%94%BB%E5%83%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6NAND%E3%82%92%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99-ON%20TARGET%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E3%82%AA%E3%83%B3(%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88)%E3%81%97%E3%80%81MTD%E3%83%91%E3%83%BC%E3%83%86%E3%82%A3%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%95%E3%82%A9%E3%83%BC%E3%83%9E%E3%83%83%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E%24%20cd%20%2Fhome%20%0A%24%20ubiformat%20-f%20ubi.img%20%2Fdev%2Fmtd8%0A%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--491187176%22%20id%3D%22toc-hId--491187176%22%20id%3D%22toc-hId-430340738%22%3E%3CSPAN%20class%3D%22mw-headline%22%3E5.%20UBI%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3C%2FP%3E%3CP%3Eredboot%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%8A%E3%82%88%E3%81%B3%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22jive-pre%22%3E..FIS%E3%83%AD%E3%83%BC%E3%83%89%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%0A..exec%20-c%20%22noinitrd%20console%3Dttymxc0%20115200%20ubi.mtd%3D8%20root%3Dubi0%3Arootfs%20rw%20rootfstype%3Dubifs%20ip%3Dnone%22%0A%3C%2FPRE%3E%3CP%3E%3CSPAN%20class%3D%22mce_paste_marker%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 03:05 AM
更新者:
