i.MX35 PDK Linux Booting SD
Document created by jesseg Employee on Jul 30, 2012Last modified by Jodi Paul on May 9, 2013
Version 4Show Document
  • View in full screen mode
Booting Linux Directly from SD/MMC Card
You can create a self-bootable SD or MMC card with Linux.
This tutorial describes how to create a complete Linux system (bootloader + Linux kernel + root file system) that boots from SD/MMC card.
This is very useful for people willing to demonstrate several Linux images that can be self-contained in SD/MMC cards.
Flashing RedBoot on MMC using ATK
To boot Linux from a SD card, the first thing to do is to program the bootloader to the card. For this, click on the link below:
I.MX35 PDK Board Flashing SDCard
Flashing RedBoot on MMC using DD
You can also use dd on any linux system to load redboot:
$ sudo dd if=./Desktop/mx35_3stack_redboot_mmc.bin of=/dev/sdd bs=512 skip=2 seek=2
Configuring Kernel to Boot From SD/MMC
Creating a Linux bootable MMC/SD Card.
Execute LTIB:
$ ./ltib -c
Choose configure the kernel:
[*] Configure the kernel
Change image generation to NFS:
Target Image Generation
Options --->
(X) NFS only
Compile Linux kernel with built-in support to MMC/SD and ext3:
Follow that sequence:
Device Drivers --->
<*> MMC/SD card support --->
<*> UniFi SDIO glue for Freescale MMC/SDIO
<*> Freescale i.MX Secure Digital Host Controller Interface support
File systems --->
<*> Ext3 journalling file system support
After the compilation copy the file ~/ltib/rootfs/boot/zImage to tftpboot directory:
$ cp ~/ltib/rootfs/boot/zImage /tftpboot
Creating RedBoot Kernel Partition
Create RedBoot partitions and copy Linux kernel to it:
Turn MMC active:
RedBoot> factive MMC
Initialize flash partitions:
RedBoot> fis init
RedBoot> fis list
... Read from 0x07ee0000-0x07eff000 at 0x00060000: .
Name FLASH addr Mem addr Length Entry point
RedBoot 0x00000000 0x00000000 0x00040000 0x00000000
FIS directory 0x00060000 0x00060000 0x0001F000 0x00000000
RedBoot config 0x0007F000 0x0007F000 0x00001000 0x00000000
Load kernel to RAM:
RedBoot> load -r -b 0x100000 /tftpboot/zImage
Using default protocol (TFTP)
Raw file loaded 0x00100000-0x002c31b7, assumed entry at 0x00100000
Create a kernel partition with content of kernel image loaded to RAM:
RedBoot> fis create -f 0x200000 kernel
RedBoot> fis list
kernel 0x00200000 0x00100000 0x001E0000 0x00100000
If you reset your board you need to see:
Booting from [SD card, CSD Version 1.0]
If instead you see this message:
Booting from [unknown version card ]
This means your card is not support, please replace it with other card.
Creating the Root File System
After storing the kernel image in the SD card, remove the card from the target board and insert it in your computer (running Linux).
In this example, Linux detected the SD card as /dev/sdb.
Now we need to create two partitions. The first partition will not be used, this is just reserved to RedBoot and kernel. The second partition will be used to store Linux Root File System.
# fdisk /dev/sdb
Device contains neither a valid DOS partition table, nor Sun, SGI or OSF disklabel
Building a new DOS disklabel with disk identifier 0x526c22da.
Changes will remain in memory only, until you decide to write them.
After that, of course, the previous content won't be recoverable.
Warning: invalid flag 0x0000 of partition table 4 will be corrected by w(rite)
Command (m for help): p
Disk /dev/sdb: 1023 MB, 1023934464 bytes
32 heads, 62 sectors/track, 1008 cylinders
Units = cylinders of 1984 * 512 = 1015808 bytes
Disk identifier: 0x526c22da
  Device Boot Start End Blocks Id System
Create the first partition with 8 MB; it already contains RedBoot and the kernel, as we stored previously:
Command (m for help): n
Command action
  e extended
  p primary partition (1-4)
p
Partition number (1-4): 1
First cylinder (1-1008, default 1):
Using default value 1
Last cylinder, +cylinders or +size{K,M,G} (1-1008, default 1008): +8M
Now, create the second partition using all remaining space on SD card:
Command action
  e extended
p
Partition number (1-4): 2
First cylinder (10-1008, default 10):
Using default value 10
Last cylinder, +cylinders or +size{K,M,G} (10-1008, default 1008):
Using default value 1008
/dev/sdb1 1 9 8897 83 Linux
/dev/sdb2 10 1008 991008 83 Linux
Command (m for help): w
Now format the second partition as EXT3:
# mkfs.ext3 /dev/sdb2
Remove the SD card from your computer and insert again. Probably your Linux distribution will dectect it and will mount automatically.
On Ubuntu 8.10 it was mounted on /dev/media:
# mount
/dev/sdb2 on /media/disk type ext3 (rw,nosuid,nodev,uhelper=hal)
If your Linux didn't mount it, then you can mount it manually:
# mkdir -p /media/disk
# mount /dev/sdb2 -t ext3 /media/disk
Enter in your LTIB directory and copy the rootfs content to SD card:
# cd /home/alan/ltib-imx35/rootfs/
# cp -a * /media/disk/
Verify if it was copied correctly:
# ls -l /media/disk/
total 80
drwxr-xr-x 2 root root 4096 2009-03-12 09:55 bin
drwxr-xr-x 2 root root 4096 2009-03-12 09:53 boot
drwxr-xr-x 2 root root 4096 2009-03-12 09:55 dev
drwxr-xr-x 6 root root 4096 2009-03-12 14:41 etc
drwxr-xr-x 3 root root 4096 2009-03-12 09:53 home
drwxr-xr-x 4 root root 4096 2009-03-12 09:55 lib
lrwxrwxrwx 1 root root 11 2009-03-12 14:47 linuxrc -> bin/busybox
drwx------ 2 root root 16384 2009-03-12 14:37 lost+found
drwxr-xr-x 7 root root 4096 2009-03-12 09:53 mnt
drwxr-xr-x 2 root root 4096 2009-03-12 09:53 opt
drwxr-xr-x 2 root root 4096 2009-03-12 09:53 proc
drwxr-xr-x 2 root root 4096 2009-03-12 10:10 root
drwxr-xr-x 2 root root 4096 2009-03-12 09:55 sbin
drwxr-xr-x 2 root root 4096 2009-03-12 09:53 sys
drwxrwxrwt 3 root root 4096 2009-03-12 09:53 tmp
drwxr-xr-x 2 root root 4096 2009-03-12 09:55 unit_tests
drwxr-xr-x 9 root root 4096 2009-03-12 09:55 usr
drwxr-xr-x 11 root root 4096 2009-03-12 09:55 var
root@urubu:~/ltib-imx25/rootfs#
Now umount the SD card:
# umount /media/disk
Configuring RedBoot to Load Kernel and Rootfs from SD/MMC Card
Remove the SD card from your computer and place again in the board.
Configure RedBoot to load the kernel from SD/MMC card and set up the kernel command parameter "root" to load the root file system from second SD/MMC card partition (/dev/mmcblk0p2)
RedBoot> fc
Run script at boot: true
Boot script:
Enter script, terminate with empty line
>> fis load kernel
>> exec -b 0x100000 -l 0x200000 -c "noinitrd console=ttymxc0,115200 root=/dev/mmcblk0p2 init=/linuxrc ip=none"
Boot script timeout (1000ms resolution): 1
Use BOOTP for network configuration: false
Gateway IP address: 10.29.244.254
Local IP address: 10.29.244.135
Local IP address mask: 255.255.0.0
Default server IP address: 10.29.240.182
Board specifics: 0
Console baud rate: 115200
Set eth0 network hardware address [MAC]: false
Set FEC network hardware address [MAC]: false
GDB connection port: 9000
Force console for special debug messages: false
Network debug at boot time: false
Default network device: lan92xx_eth0
Update RedBoot non-volatile configuration - continue (y/n)? y
... Erase from 0x00060000-0x00080000: .
... Program from 0x07ee0000-0x07f00000 at 0x00060000: .
Now just reset the board and it will boot directly from SD/MMC card.
    Outcomes
