Set up NFS Environment and Boot up Board
Platform: Ubuntu 12.04
Board: Freescale MCIMX6Q-SDP  and  MCIMX-LVDS1 Screen
BSP: L3.0.35_4.1.0_ER_SOURCE_BSP
Other device: PC , One Router, 3 Network Cable and 2 usb-otg lines
The  platform is as follow:
Boot form NFS is very convenient in porting and debugging, and will value us much time. If the customers have modified the kernel and rebuild the kernel to generate the uImage running on board, he can directly download the uImage to the board by TFTP network. It is fast and can avoid the normal operation ,  first customers need to copy the images to the mfgtool specified directory and download the u-boot, uImage and file sytem again to the flash device in board, and then change to boot up mode to boot up the board. If customers are doing debug this operation will waste lot of time. So use the NFS is vey convenient. Beyond this, in the target board customers can also read the files and content in host machine. In a word, use NFS it will help save much time and also convenient. So the follows is introduce and show how to set NFS and then boot up the board.
1 Preparation
(1)Build the BSP
Build up the L3.0.35_4.1.0_ER_SOURCE_BSP use LTIB on the Ubuntu12.04, you can refer to our user guide document here no details. The u-boot, uImage and file system are all under the directory of litb. Boot up from NFS, so when build uImage some items are needed, here you can see the build details in the section of  Setting Target Linux Image to use NFS in this articel.
(2)Download the u-boot to the target board
Use the mfgtool Mfgtools-Rel-4.1.0_130816_MX6Q_UPDATER to download the u-boot to the SD card of MCIMX6Q-SDP board or use dd command to write the u-boot to SD card.( By the way, writing to the EMMC is also OK)
2 Setting the NFS Environment
Set host machine
1 - Install NFS Service on host typing:
$sudo apt-get install nfs-kernel-server
2 - Create symbolic link to ltib/rootfs
$sudo ln -s <ltib instalation folder>/rootfs /tftpboot/rootfs
3 - Setup exports typing:
$sudo gedit /etc/exports
and add the following line:
/tftpboot/rootfs/ *(rw,no_root_squash,no_subtree_check,async)
4 - Restart the NFS server:
$sudo /etc/init.d/nfs-kernel-server restart
Now the host is ready to use NFS
1. Run LTIB configuration by typing:
$cd <ltib instalation folder>
$./ltib -c
2. On first page menu, go to "Target Image Generation -> Options"
3. Select the option NFS only and exit LTIB configuration to compile with the new configuration.
4. LTIB should start new compiling and create a new Linux image on /<ltib instalation folder>/rootfs/boot/uImage
5. Copy the created image on /<ltib instalation folder>/rootfs/boot/uImage to /tftpboot/uImage
6. The system is ready to run with NFS. The root file system on target will be located on host on /<ltib instalation folder>/rootfs/
3 Setting the u-boot command line
(1)Download the u-boot to the target board fist according to the section 1 (2) Download the u-boot to the target board. Then give the power to the board, boot up board, u-boot boot up.
(2)Configuration the Network
Configure the Network and IP , to make the target board and the host machine IP are in the local area network of Router.
(3)Set the u-boot command line
As follow is my setting for you to refer to :
4 Boot up the board
Running the “run bootcmd” after setting the u-boot parameters then boot up the kernel and file system. We can see that the board download the uImage by the TFTP from host machine, then boot up the kernel and finally mount the NFS in the kernel. As follows is the details:
Downloading the uImage success and boot up kernel:
Input root and access the system.
Test: Create a new file in the host machine directory, you can see in the next picture:
Then open the target board, in the terminal go to the same directory  in the unit_test we can see the same name. So as we can see in the above operation we can see it is very convenient and fast use the NFS. It will help save time and speed the development time.
ラベル(2)
%3CLINGO-SUB%20id%3D%22lingo-sub-1103568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENFS%E7%92%B0%E5%A2%83%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%A8%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3EPlatform%3A%20Ubuntu%2012.04%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E3%83%9C%E3%83%BC%E3%83%89%3A%20%E3%83%95%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%ABMCIMX6Q-SDP%E3%81%8A%E3%82%88%E3%81%B3%20%3C%2FSPAN%3E%3CSPAN%20class%3D%22ng-scope%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3DIMX53QSB%26amp%3Bcof%3D0%26amp%3Bam%3D0%26amp%3Btab%3DBuy_Parametric_Tab%26amp%3BfromSearch%3Dfalse%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%22%3EMCIMX-LVDS1%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20times%20new%20roman%2Ctimes%3B%22%3E%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3EBSP%3A%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3Di.MX6Q%26amp%3Bfpsp%3D1%26amp%3Btab%3DDesign_Tools_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%20color%3A%20windowtext%3B%22%3EL3.0.35_4.1.0_ER_SOURCE_BSP%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3APC%E3%80%81%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC1%E6%9C%AC%E3%80%81%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB3%3C%2FSPAN%3E%E6%9C%AC%E3%80%81%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3EUSB-OTG%E3%83%A9%E3%82%A4%E3%83%B3%3C%2FSPAN%3E2%E6%9C%AC%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B9%B3%E5%8F%B0%E6%90%AD%E5%BB%BA.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B9%B3%E5%8F%B0%E6%90%AD%E5%BB%BA.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F54876iDA18CE6138F7082F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B9%B3%E5%8F%B0%E6%90%AD%E5%BB%BA.jpg%22%20alt%3D%22%E5%B9%B3%E5%8F%B0%E6%90%AD%E5%BB%BA.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B9%B3%E5%8F%B0%E6%90%AD%E5%BB%BA.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20times%20new%20roman%2Ctimes%3B%22%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0NFS%E3%81%AF%E3%80%81%E7%A7%BB%E6%A4%8D%E3%81%A8%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%AB%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%BE%BF%E5%88%A9%E3%81%A7%E3%80%81%E5%A4%9A%E3%81%8F%E3%81%AE%E6%99%82%E9%96%93%E3%82%92%E5%A4%A7%E5%88%87%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E5%86%8D%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%A6%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8BuImage%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81TFTP%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6uImage%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E7%9B%B4%E6%8E%A5%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%82%8C%E3%81%AF%E9%80%9F%E3%81%8F%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AE%E6%93%8D%E4%BD%9C%E3%82%92%E9%81%BF%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%E9%A1%A7%E5%AE%A2%E3%81%AF%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92mfgtool%E6%8C%87%E5%AE%9A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81u-boot%E3%80%81uImage%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%9C%E3%83%BC%E3%83%89%E5%86%85%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E5%86%8D%E5%BA%A6%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E8%B5%B7%E5%8B%95%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%8C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%92%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E6%93%8D%E4%BD%9C%E3%81%AF%E5%A4%9A%E3%81%8F%E3%81%AE%E6%99%82%E9%96%93%E3%82%92%E7%84%A1%E9%A7%84%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81NFS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%BE%BF%E5%88%A9%E3%81%A7%E3%81%99%E3%80%82%E3%81%95%E3%82%89%E3%81%AB%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%84%E3%82%B3%E3%83%B3%E3%83%86%E3%83%B3%E3%83%84%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E8%A8%80%E3%81%A7%E8%A8%80%E3%81%88%E3%81%B0%E3%80%81NFS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%A4%9A%E3%81%8F%E3%81%AE%E6%99%82%E9%96%93%E3%82%92%E7%AF%80%E7%B4%84%E3%81%97%E3%80%81%E4%BE%BF%E5%88%A9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%A7%E3%81%AF%E3%80%81NFS%E3%81%AE%E8%A8%AD%E5%AE%9A%E6%96%B9%E6%B3%95%E3%81%A8%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E8%B5%B7%E5%8B%95%E6%96%B9%E6%B3%95%E3%82%92%E7%B4%B9%E4%BB%8B%E3%81%97%E3%80%81%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E1%20%E4%BA%8B%E5%89%8D%E6%BA%96%E5%82%99%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20times%20new%20roman%2Ctimes%3B%22%3E(1)BSP%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20times%20new%20roman%2Ctimes%3B%22%3E%3CA%20href%3D%22http%3A%2F%2Fwww.freescale.com%2Fwebapp%2Fsps%2Fsite%2Fprod_summary.jsp%3Fcode%3Di.MX6Q%26amp%3Bfpsp%3D1%26amp%3Btab%3DDesign_Tools_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%22%3EL3.0.35_4.1.0_ER_SOURCE_BSP%3C%2FSPAN%3E%20%E3%81%AE%E6%A7%8B%E7%AF%89%3C%2FA%3EUbuntu12.04%E3%81%A7LTIB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%80%81%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82u-boot%E3%80%81uImage%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A6litb%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82NFS%E3%81%8B%E3%82%89%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81uImage%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A2%E3%82%A4%E3%83%86%E3%83%A0%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%AE%20%3CSTRONG%3ENFS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88Linux%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E8%A8%AD%E5%AE%9A%20%3C%2FSTRONG%3E%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20times%20new%20roman%2Ctimes%3B%22%3E(2)u-boot%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20times%20new%20roman%2Ctimes%3B%22%3EUse%20the%20mfgtool%20Mfgtools-Rel-4.1.0_130816_MX6Q_UPDATERu-boot%E3%82%92MCIMX6Q-SDP%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AESD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81dd%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6u-boot%E3%82%92SD%E3%82%AB%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82(%E3%81%A1%E3%81%AA%E3%81%BF%E3%81%AB%E3%80%81EMMC%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%82OK%E3%81%A7%E3%81%99)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E2%20NFS%E7%92%B0%E5%A2%83%E3%81%AE%E8%A8%AD%E5%AE%9A%20%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AE%E8%A8%AD%E5%AE%9A%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E1%20-%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%ABNFS%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%24sudo%20apt-get%20nfs-kernel-server%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E2%20-%20ltib%2Frootfs%20%E3%81%B8%E3%81%AE%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AA%E3%83%83%E3%82%AF%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E4%BD%9C%E6%88%90%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%24sudo%20ln%20-s%20%3CLTIB%20instalation%3D%22%22%20folder%3D%22%22%3E%2Frootfs%20%2Ftftpboot%2Frootfs%20%3C%2FLTIB%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E3%20-%20%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E5%85%A5%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%24sudo%20gedit%20%2Fetc%2Fexports%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E8%A1%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%2Ftftpboot%2Frootfs%2F%20*(rw%2Cno_root_squash%2Cno_subtree_check%2Casync)%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222export.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222export.PNG%22%20style%3D%22width%3A%20843px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F54929iDF412D46A481954B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222export.PNG%22%20alt%3D%222export.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2export.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E4%20-%20NFS%20%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%24sudo%20%2Fetc%2Finit.d%2Fnfs-kernel-server%E5%86%8D%E8%B5%B7%E5%8B%95%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E3%81%93%E3%82%8C%E3%81%A7%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A7NFS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E6%BA%96%E5%82%99%E3%81%8C%E6%95%B4%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3ENFS%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20Linux%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E1.%20%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%A6%20LTIB%20%E8%A8%AD%E5%AE%9A%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%24cd%3CLTIB%20instalation%3D%22%22%20folder%3D%22%22%3E%3C%2FLTIB%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%24.%2Fltib%20-c%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E2.%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%9A%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%A1%E3%83%8B%E3%83%A5%E3%83%BC%E3%81%A7%E3%80%81%E3%80%8C%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E7%94%BB%E5%83%8F%E3%81%AE%E7%94%9F%E6%88%90-%26gt%3B%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8D%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E3.%20%E3%80%8CNFS%20only%E3%80%8D%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%80%81%E3%80%8CExit%20LTIB%20configuration%E3%80%8D%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221target%20image%20NFS%20ONLY.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221target%20image%20NFS%20ONLY.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F54981i97C427169D952B05%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221target%20image%20NFS%20ONLY.PNG%22%20alt%3D%221target%20image%20NFS%20ONLY.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1target%20image%20NFS%20ONLY.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E4.%20LTIB%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%80%81%2F%3CLTIB%20instalation%3D%22%22%20folder%3D%22%22%3E%20%2Frootfs%2Fboot%2FuImage%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84Linux%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FLTIB%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E5.%20%2F%3CLTIB%20instalation%3D%22%22%20folder%3D%22%22%3E%20%2Frootfs%2Fboot%2FuImage%E3%81%AB%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%2Ftftpboot%2FuImage%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FLTIB%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223tftpboot.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223tftpboot.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55017i5296F3B3BC85CB27%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223tftpboot.PNG%22%20alt%3D%223tftpboot.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E3tftpboot.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E6.%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%20NFS%20%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E6%BA%96%E5%82%99%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E4%B8%8A%E3%81%AE%E3%83%AB%E3%83%BC%E3%83%88%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%BB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%80%81%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%2F%3CLTIB%20instalation%3D%22%22%20folder%3D%22%22%3E%20%2Frootfs%2F%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FLTIB%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E3%20u-boot%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E(1)u-boot%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E6%8B%B3%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B31%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6(2)%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%20u-boot%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81u-boot%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E(2)%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AE%E8%A8%AD%E5%AE%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%A8IP%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E3%82%92%E6%A7%8B%E6%88%90%E3%81%97%3C%2FSPAN%3E%E3%81%A6%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AEIP%E3%81%8C%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%82%A8%E3%83%AA%E3%82%A2%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%81%AB%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E(3)u-boot%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E7%A7%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%99%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22u-boot%20command.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22u-boot%20command.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55045iF594411190070659%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22u-boot%20command.PNG%22%20alt%3D%22u-boot%20command.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Eu-boot%20command.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E4%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20times%20new%20roman%2Ctimes%3B%22%3Eu-boot%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E3%80%8Crun%20bootcmd%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%8B%E3%82%89TFTP%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6uImage%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E6%9C%80%E5%BE%8C%E3%81%ABNFS%E3%82%92%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%AB%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22download%20and%20boot%20up.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22download%20and%20boot%20up.PNG%22%20style%3D%22width%3A%20657px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55097iF9B5C8600C66D065%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22download%20and%20boot%20up.PNG%22%20alt%3D%22download%20and%20boot%20up.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Edownload%20and%20boot%20up.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3EuImage%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22logoin.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22logoin.PNG%22%20style%3D%22width%3A%20943px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55128i4ABA151AB178E65B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22logoin.PNG%22%20alt%3D%22logoin.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Elogoin.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3Eroot%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Times%20New%20Roman'%2C'serif'%3B%22%3E%3CSTRONG%3E%E8%A9%A6%E9%A8%93%EF%BC%9A%3C%2FSTRONG%3E%20%E3%83%9B%E3%82%B9%E3%83%88%E3%83%9E%E3%82%B7%E3%83%B3%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%99(%E6%AC%A1%E3%81%AE%E5%9B%B3%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99)%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22host%20make%20dir%20atest.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22host%20make%20dir%20atest.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55156i50EF302E83339974%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22host%20make%20dir%20atest.PNG%22%20alt%3D%22host%20make%20dir%20atest.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ehost%20make%20dir%20atest.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%20text-align%3A%20justify%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20times%20new%20roman%2Ctimes%3B%22%3E%E6%AC%A1%E3%81%AB%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%81%A7%E5%90%8C%E3%81%98%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E5%90%8C%E3%81%98%E5%90%8D%E5%89%8D%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99unit_test%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E6%93%8D%E4%BD%9C%E3%81%A7%E3%82%8F%E3%81%8B%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81NFS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E9%9D%9E%E5%B8%B8%E3%81%AB%E4%BE%BF%E5%88%A9%E3%81%A7%E9%AB%98%E9%80%9F%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E6%99%82%E9%96%93%E3%82%92%E7%AF%80%E7%B4%84%E3%81%97%E3%80%81%E9%96%8B%E7%99%BA%E6%99%82%E9%96%93%E3%82%92%E7%9F%AD%E7%B8%AE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22target.PNG%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22target.PNG%22%20style%3D%22width%3A%20584px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F55193i8BB19C481B0C9C9F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22target.PNG%22%20alt%3D%22target.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Etarget.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1103568%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6Quad%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎07-15-2015 01:39 AM
更新者:
