Example MPC5744P eTimer frequency measurement GHS614
* Detailed Description:
* Example gives possible implementation of input signal period/freq measurement.
* eTimer channel capture 1 and 2 features are used. CAPT1/CAPT2 capture counter
* value on rising/falling edge of input signal. The FIFO is set to 2 entries
* and ICF2 is monitored. Free-running mode is used here.
* eTimer channel 0-1 are cascaded to achieve 1sec/1Hz measuring with 32bit counter.
* EVB connection:
*   P8.2  - A[1]  .. eTimer0 channel1 input signal
*   P8.1  - A[0]  .. GPIO output, used to show measurement period
*   Route LINFlexD_0 TXD/RXD (PB2/PB3) signals to the main board RS-232 transceiver
*   Daughtercard:
*   J17.11–12 ON  .. Connect LINFlexD_0 TXD (PB2) to main board.
*   J17.8–9 ON .. Connect LINFlexD_0 RXD (PB3) to main board.
*   Motherboard
*   J14 - SCI_RX ON
*   J13 - SCI_TX ON
*   J25 - SCI_PWR ON
* connect pulse signal to the P8.2.
* See results on PC terminal (19200, 8N1, None).
* Change freq/duty of input signal.
* Test HW:  MPC57xx
* Maskset:  1N65H
* Target :  internal_FLASH
* Fsys:     200 MHz PLL with 40 MHz crystal reference
* Terminal: 19200, 8N1, None
附件
评论
Pat
Hi Petr,
Is it possible to have the same using DMA ?
PetrS
Pat
Pat
Hi Petr,
Thank you very much for your help and your support.
Pat
Hi Petr,
could you compile this with S32DS? I see loads of samples using GHS, but as you know GHS is access is expensive. Beside startup code, would it be possible to take sources and integrate them into S32DS demo project? (Note: I haven't tried yet)
Kind regards
%3CLINGO-SUB%20id%3D%22lingo-sub-1121335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A4%BA%E4%BE%8B%20MPC5744P%20eTimer%20%E9%A2%91%E7%8E%87%E6%B5%8B%E9%87%8F%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E7%A4%BA%E4%BE%8B%E7%BB%99%E5%87%BA%E4%BA%86%E8%BE%93%E5%85%A5%E4%BF%A1%E5%8F%B7%E5%91%A8%E6%9C%9F%2F%E9%A2%91%E7%8E%87%E6%B5%8B%E9%87%8F%E7%9A%84%E5%8F%AF%E8%83%BD%E5%AE%9E%E7%8E%B0%E6%96%B9%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%3E*%20%E4%BD%BF%E7%94%A8%20eTimer%20%E9%80%9A%E9%81%93%E6%8D%95%E8%8E%B7%201%20%E5%92%8C%202%20%E5%8A%9F%E8%83%BD%E3%80%82CAPT1%2FCAPT2%E6%8D%95%E8%8E%B7%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FP%3E%3CP%3E*%20%E8%BE%93%E5%85%A5%E4%BF%A1%E5%8F%B7%E4%B8%8A%E5%8D%87%2F%E4%B8%8B%E9%99%8D%E6%B2%BF%E7%9A%84%E5%80%BC%E3%80%82FIFO%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%202%20%E4%B8%AA%E6%9D%A1%E7%9B%AE%3C%2FP%3E%3CP%3E*%20%E5%B9%B6%E4%B8%94%20ICF2%20%E5%8F%97%E5%88%B0%E7%9B%91%E6%8E%A7%E3%80%82%E8%BF%99%E9%87%8C%E9%87%87%E7%94%A8%E7%9A%84%E6%98%AF%E8%87%AA%E7%94%B1%E8%BF%90%E8%A1%8C%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20eTimer%20%E9%80%9A%E9%81%93%200-1%20%E7%BA%A7%E8%81%94%E4%BB%A5%E5%AE%9E%E7%8E%B0%2032%20%E4%BD%8D%E8%AE%A1%E6%95%B0%E5%99%A8%E7%9A%84%201%20%E7%A7%92%2F1Hz%20%E6%B5%8B%E9%87%8F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E*%20EVB%E8%BF%9E%E6%8E%A5%EF%BC%9A%3C%2FP%3E%3CP%3E*%20P8.2-%20A%5B1%5D%20..%20eTimer0%20%E9%80%9A%E9%81%93%201%20%E8%BE%93%E5%85%A5%E4%BF%A1%E5%8F%B7%3C%2FP%3E%3CP%3E*%20P8.1-%20A%5B0%5D%20..%20GPIO%20%E8%BE%93%E5%87%BA%EF%BC%8C%E7%94%A8%E4%BA%8E%E6%98%BE%E7%A4%BA%E6%B5%8B%E9%87%8F%E5%91%A8%E6%9C%9F%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E5%B0%86%20LINFlexD_0%20TXD%2FRXD%EF%BC%88PB2%2FPB3%EF%BC%89%E4%BF%A1%E5%8F%B7%E8%B7%AF%E7%94%B1%E8%87%B3%E4%B8%BB%E6%9D%BF%20RS-232%20%E6%94%B6%E5%8F%91%E5%99%A8%3C%2FP%3E%3CP%3E*%20%E5%AD%90%E5%8D%A1%EF%BC%9A%3C%2FP%3E%3CP%3E*%20J17.11%E2%80%9312ON%20..%20%E5%B0%86%20LINFlexD_0%20TXD%20(PB2)%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%BB%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%3E*%20J17.8%E2%80%939%E5%BC%80%E5%90%AF..%E5%B0%86%20LINFlexD_0%20RXD%20(PB3)%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%BB%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%20%E6%AF%8D%E6%9D%BF%3C%2FP%3E%3CP%3E*%20J14%E2%80%94%E2%80%94SCI_RX%E5%BC%80%E5%90%AF%3C%2FP%3E%3CP%3E*%20J13-SCI_TX%E5%BC%80%E5%90%AF%3C%2FP%3E%3CP%3E*%20J25%E2%80%94%E2%80%94SCI_PWR%E5%BC%80%E5%90%AF%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E5%B0%86%E8%84%89%E5%86%B2%E4%BF%A1%E5%8F%B7%E8%BF%9E%E6%8E%A5%E5%88%B0P8.2%E3%80%82%3C%2FP%3E%3CP%3E*%20%E6%9F%A5%E7%9C%8B%20PC%20%E7%BB%88%E7%AB%AF%E4%B8%8A%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%8819200%E3%80%818N1%E3%80%81%E6%97%A0%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E*%20%E6%94%B9%E5%8F%98%E8%BE%93%E5%85%A5%E4%BF%A1%E5%8F%B7%E7%9A%84%E9%A2%91%E7%8E%87%2F%E5%8D%A0%E7%A9%BA%E6%AF%94%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AMPC57xx%3C%2FP%3E%3CP%3E*%20Maskset%3A%26nbsp%3B%201N65H%3C%2FP%3E%3CP%3E*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH%3C%2FP%3E%3CP%3E*%20Fsys%3A%20200%20MHz%20PLL%EF%BC%8C%E5%B8%A6%2040%20MHz%20%E6%99%B6%E6%8C%AF%E5%8F%82%E8%80%83%3C%2FP%3E%3CP%3E*%20%E7%BB%88%E7%AB%AF%EF%BC%9A19200%E3%80%818N1%E3%80%81%E6%97%A0%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1121335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E7%A4%BA%E4%BE%8B%E7%BB%99%E5%87%BA%E4%BA%86%E8%BE%93%E5%85%A5%E4%BF%A1%E5%8F%B7%E5%91%A8%E6%9C%9F%2F%E9%A2%91%E7%8E%87%E6%B5%8B%E9%87%8F%E7%9A%84%E5%8F%AF%E8%83%BD%E5%AE%9E%E7%8E%B0%E6%96%B9%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%3E*%20%E4%BD%BF%E7%94%A8%20eTimer%20%E9%80%9A%E9%81%93%E6%8D%95%E8%8E%B7%201%20%E5%92%8C%202%20%E5%8A%9F%E8%83%BD%E3%80%82CAPT1%2FCAPT2%E6%8D%95%E8%8E%B7%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FP%3E%3CP%3E*%20%E8%BE%93%E5%85%A5%E4%BF%A1%E5%8F%B7%E4%B8%8A%E5%8D%87%2F%E4%B8%8B%E9%99%8D%E6%B2%BF%E7%9A%84%E5%80%BC%E3%80%82FIFO%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%202%20%E4%B8%AA%E6%9D%A1%E7%9B%AE%3C%2FP%3E%3CP%3E*%20%E5%B9%B6%E4%B8%94%20ICF2%20%E5%8F%97%E5%88%B0%E7%9B%91%E6%8E%A7%E3%80%82%E8%BF%99%E9%87%8C%E9%87%87%E7%94%A8%E7%9A%84%E6%98%AF%E8%87%AA%E7%94%B1%E8%BF%90%E8%A1%8C%E6%A8%A1%E5%BC%8F%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20eTimer%20%E9%80%9A%E9%81%93%200-1%20%E7%BA%A7%E8%81%94%E4%BB%A5%E5%AE%9E%E7%8E%B0%2032%20%E4%BD%8D%E8%AE%A1%E6%95%B0%E5%99%A8%E7%9A%84%201%20%E7%A7%92%2F1Hz%20%E6%B5%8B%E9%87%8F%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E*%20EVB%E8%BF%9E%E6%8E%A5%EF%BC%9A%3C%2FP%3E%3CP%3E*%20P8.2-%20A%5B1%5D%20..%20eTimer0%20%E9%80%9A%E9%81%93%201%20%E8%BE%93%E5%85%A5%E4%BF%A1%E5%8F%B7%3C%2FP%3E%3CP%3E*%20P8.1-%20A%5B0%5D%20..%20GPIO%20%E8%BE%93%E5%87%BA%EF%BC%8C%E7%94%A8%E4%BA%8E%E6%98%BE%E7%A4%BA%E6%B5%8B%E9%87%8F%E5%91%A8%E6%9C%9F%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E5%B0%86%20LINFlexD_0%20TXD%2FRXD%EF%BC%88PB2%2FPB3%EF%BC%89%E4%BF%A1%E5%8F%B7%E8%B7%AF%E7%94%B1%E8%87%B3%E4%B8%BB%E6%9D%BF%20RS-232%20%E6%94%B6%E5%8F%91%E5%99%A8%3C%2FP%3E%3CP%3E*%20%E5%AD%90%E5%8D%A1%EF%BC%9A%3C%2FP%3E%3CP%3E*%20J17.11%E2%80%9312ON%20..%20%E5%B0%86%20LINFlexD_0%20TXD%20(PB2)%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%BB%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%3E*%20J17.8%E2%80%939%E5%BC%80%E5%90%AF..%E5%B0%86%20LINFlexD_0%20RXD%20(PB3)%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%BB%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%20%E6%AF%8D%E6%9D%BF%3C%2FP%3E%3CP%3E*%20J14%E2%80%94%E2%80%94SCI_RX%E5%BC%80%E5%90%AF%3C%2FP%3E%3CP%3E*%20J13-SCI_TX%E5%BC%80%E5%90%AF%3C%2FP%3E%3CP%3E*%20J25%E2%80%94%E2%80%94SCI_PWR%E5%BC%80%E5%90%AF%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E5%B0%86%E8%84%89%E5%86%B2%E4%BF%A1%E5%8F%B7%E8%BF%9E%E6%8E%A5%E5%88%B0P8.2%E3%80%82%3C%2FP%3E%3CP%3E*%20%E6%9F%A5%E7%9C%8B%20PC%20%E7%BB%88%E7%AB%AF%E4%B8%8A%E7%9A%84%E7%BB%93%E6%9E%9C%EF%BC%8819200%E3%80%818N1%E3%80%81%E6%97%A0%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E*%20%E6%94%B9%E5%8F%98%E8%BE%93%E5%85%A5%E4%BF%A1%E5%8F%B7%E7%9A%84%E9%A2%91%E7%8E%87%2F%E5%8D%A0%E7%A9%BA%E6%AF%94%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AMPC57xx%3C%2FP%3E%3CP%3E*%20Maskset%3A%26nbsp%3B%201N65H%3C%2FP%3E%3CP%3E*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH%3C%2FP%3E%3CP%3E*%20Fsys%3A%20200%20MHz%20PLL%EF%BC%8C%E5%B8%A6%2040%20MHz%20%E6%99%B6%E6%8C%AF%E5%8F%82%E8%80%83%3C%2FP%3E%3CP%3E*%20%E7%BB%88%E7%AB%AF%EF%BC%9A19200%E3%80%818N1%E3%80%81%E6%97%A0%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1121335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPC5744P%20eTimer%20%E9%A2%91%E7%8E%87%E6%B5%8B%E9%87%8F%E7%A4%BA%E4%BE%8B%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Petr%2C%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E7%94%A8S32DS%E7%BC%96%E8%AF%91%E8%BF%99%E4%B8%AA%E5%90%97%EF%BC%9F%E6%88%91%E7%9C%8B%E5%88%B0%E5%A4%A7%E9%87%8F%E4%BD%BF%E7%94%A8%20GHS%20%E7%9A%84%E6%A0%B7%E6%9C%AC%EF%BC%8C%E4%BD%86%E6%AD%A3%E5%A6%82%E6%82%A8%E6%89%80%E7%9F%A5%EF%BC%8CGHS%20%E7%9A%84%E8%AE%BF%E9%97%AE%E6%88%90%E6%9C%AC%E5%BE%88%E9%AB%98%E3%80%82%E9%99%A4%E4%BA%86%E5%90%AF%E5%8A%A8%E4%BB%A3%E7%A0%81%E4%B9%8B%E5%A4%96%EF%BC%8C%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E8%8E%B7%E5%8F%96%E6%BA%90%E4%BB%A3%E7%A0%81%E5%B9%B6%E5%B0%86%E5%85%B6%E9%9B%86%E6%88%90%E5%88%B0%20S32DS%20%E6%BC%94%E7%A4%BA%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%9F%EF%BC%88%E6%B3%A8%EF%BC%9A%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E5%B0%9D%E8%AF%95%E8%BF%87%EF%BC%89%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPC5744P%20eTimer%20%E9%A2%91%E7%8E%87%E6%B5%8B%E9%87%8F%E7%A4%BA%E4%BE%8B%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Petr%2C%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E5%92%8C%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E6%8B%8D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AMPC5744P%20eTimer%20%E9%A2%91%E7%8E%87%E6%B5%8B%E9%87%8F%E7%A4%BA%E4%BE%8B%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Petr%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20DMA%20%E5%8F%AF%E4%BB%A5%E5%AE%9E%E7%8E%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E6%95%88%E6%9E%9C%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FPetrS%22%20target%3D%22_blank%22%3EPetrS%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E6%8B%8D%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎03-20-2015 04:34 AM
更新人:
