アクセスしようとしている記事は完全に削除されました。
The following file contains example code for usage of ADC, UART, DAC, GPIO, I2C, interrupts, MCG and timers for the k53 platform.
Regards.
Hello!!
Excuse me, Could you please tell me how can the example code be compiled?
Thanks a lot!
Hi Sandra,
You simply import the example code into your CodeWarrior environment and compile it.
This might help you to get familiarized with the environment Freescale Kinetis K20 50Mhz Getting started with Codewarrior (V10.2) - Bareboard - YouTube
Manuel
