Booting from QSPI on LS102xA
LS1021xA series product starts to support QSPI flash booting.
But booting from QSPI flash isn't the same as booting from SPI flash.
QSPI booting use XIP(Execute in place) method just like NOR Flash booting.
The memory map start address assigned to QSPI flash is 0x4000000.
You need to put your code at the right location.
And another key point you should be noted is data endian format between QSPI controller and ARM AMBA AXI bus.2.gif
Any binary file burned into QSPI Flash should be done Byte-Swap process first.
Our Ls1021xA Bsp has provided this function at Tcl script file named “byte_swap.tcl”.
Follow the below command to finish this process .
tclsh ./byte_swap.tcl ./<original file name>.bin ./<Byte-swap file name>.bin 8
Then Boot up system from SD/MMC media.
Burn the image file into QSPI Flash by following commands.
=>tftp 0x81000000 rcw_qspiboot_swap.bin
(Measure this binary file contains PBI command: 0xee0200, 0x40010000
This is  the Workaround for u-boot address )
=> sf probe
=> sf erase 0 0x10000
=> sf write 0x81000000 0 0x100
=> tftp 0x82000000 u-boot-qspiboot_swap.bin
=> sf erase 0x10000 0x90000
=> sf write 0x82000000 0x10000 0x80000
コメント
I'm working on booting a customized LS1021A board from QSPI flash and I have one question:
What's the file rcw_qspiboot_swap.bin?
While I compile the u-boot, I can only get the u-boot.bin.
Is that file necessary to boot up a board?
You may use script "byte_swap.tcl" to swap your rcw.bin to rcw_qspiboot_swap.bin.
you could use QorIQ Configuration suite"pre-boot loader tool" to generate specific RCW binary file for your customized board.
Yes,it is a pre-boot loader code and you need to modify it carefully.
Thanks Ming-Che,
Is the RCW binary file always needed no matter how I boot my LS1021A board?
Are those configurations already included in u-boot like imx6?
Yes, RCW binary file is necessary for T series ,LS series and part of P series QorIQ product.
Our SDK will help you insert RCW Data into U-boot binary file automatically after code-build process.
But LS SDK hasn't completed all feature yet.
%3CLINGO-SUB%20id%3D%22lingo-sub-1099418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS102xA%20%E3%81%A7%E3%81%AE%20QSPI%20%E3%81%8B%E3%82%89%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099418%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ELS1021xA%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E8%A3%BD%E5%93%81%E3%81%8CQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%96%E3%83%BC%E3%83%88%E3%81%AE%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81QSPI%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AF%E3%80%81SPI%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%A8%E5%90%8C%E3%81%98%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EQSPI%E3%83%96%E3%83%BC%E3%83%88%E3%81%AF%E3%80%81NOR%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%96%E3%83%BC%E3%83%88%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%ABXIP(Execute%20in%20place)%E6%96%B9%E5%BC%8F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EQSPI%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%9F%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9E%E3%83%83%E3%83%97%E9%96%8B%E5%A7%8B%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AF%200x4000000%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E9%81%A9%E5%88%87%E3%81%AA%E5%A0%B4%E6%89%80%E3%81%AB%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-size%3A%2012pt%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.gif%22%20style%3D%22width%3A%20900px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F43535iF2C9732027C57D17%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.gif%22%20alt%3D%221.gif%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-size%3A%2012pt%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E3%81%BE%E3%81%9F%E3%80%81QSPI%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A8ARM%20AMBA%20AXI%E3%83%90%E3%82%B9%E9%96%93%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E5%BD%A2%E5%BC%8F%E3%81%AB%E3%82%82%E6%B3%A8%E6%84%8F%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CEM%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.gif%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.gif%22%20style%3D%22width%3A%20704px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F43586i411332BE8AFB80E2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.gif%22%20alt%3D%222.gif%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EQSPI%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%E3%83%90%E3%82%A4%E3%83%88%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ELs1021xA%20Bsp%E3%81%A7%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E3%80%8Cbyte_swap.tcl%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86Tcl%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3Etclsh%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%20.%2Fbyte_swap.tcl%20.%2F%3CORIGINAL%20file%3D%22%22%20name%3D%22%22%3E.bin%20.%2F%3CBYTE-SWAP%20file%3D%22%22%20name%3D%22%22%3E.bin%208%3C%2FBYTE-SWAP%3E%3C%2FORIGINAL%3E%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%E6%AC%A1%E3%81%AB%E3%80%81SD%20%2F%20MMC%E3%83%A1%E3%83%87%E3%82%A3%E3%82%A2%E3%81%8B%E3%82%89%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92QSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23575757%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3ETFTP%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%20%E3%81%AE0x81000000%20rcw_qspiboot_swap.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%233366ff%3B%22%3E(%E3%81%93%E3%81%AE%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%20PBI%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%3A%200xee0200%E3%80%810x40010000%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%20color%3A%20%233366ff%3B%22%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81u-boot%20address%20%E3%81%AE%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%A7%E3%81%99)%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3ESF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%20%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3ESF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%20%E6%B6%88%E5%8E%BB%200%200x10000%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3Esf%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%20write%200x81000000%200%200x100%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3Etftp%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%200x82000000%20u-boot-qspiboot_swap.bin%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3ESF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%20%E6%B6%88%E5%8E%BB0x10000%200x90000%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%20margin-top%3A%205.75pt%3B%20text-indent%3A%20-0.26in%3B%20padding-left%3A%2023px%3B%20margin-bottom%3A%200.75pt%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%3D%26gt%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3ESF%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF0x82000000%200x10000%200x80000%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS102xA%20%E3%81%A7%E3%81%AE%20QSPI%20%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099422%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81RCW%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AFT%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%80%81LS%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3P%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BAQorIQ%E8%A3%BD%E5%93%81%E3%81%AE%E4%B8%80%E9%83%A8%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E7%A4%BE%E3%81%AESDK%E3%81%AF%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%83%93%E3%83%AB%E3%83%89%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E5%BE%8C%E3%81%ABRCW%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92U-boot%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E6%8C%BF%E5%85%A5%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81LS%20SDK%E3%81%AF%E3%81%BE%E3%81%A0%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS102xA%20%E3%81%A7%E3%81%AE%20QSPI%20%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099421%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22n%20fn%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E3%83%9F%E3%83%B3%E3%83%81%E3%82%A7%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22n%20fn%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22n%20fn%22%3ERCW%20%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%80%81%20%3CSPAN%20class%3D%22n%20fn%22%3ELS1021A%20%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%82%82%3C%2FSPAN%3E%E5%B8%B8%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22n%20fn%22%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%80%81imx6%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABu-boot%E3%81%AB%E3%81%99%E3%81%A7%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS102xA%20%E3%81%A7%E3%81%AE%20QSPI%20%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSTRONG%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3Ercw_qspiboot_swap.bin%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%20%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%20style%3D%22%3A%20%3B%20color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3E%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%80%8C%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%20style%3D%22%3A%20%3B%20color%3A%20%23575757%3B%20font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%20style%3D%22%3A%20%3B%20color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3Ebyte_swap.tcl%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81rcw.bin%E3%82%92rcw_qspiboot_swap.bin%E3%81%AB%E4%BA%A4%E6%8F%9B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3Etclsh%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20Arial%3B%22%3E%20.%2Fbyte_swap.tcl%20.%2F%3CORIGINAL%20file%3D%22%22%20name%3D%22%22%3E.bin%20.%2F%3CBYTE-SWAP%20file%3D%22%22%20name%3D%22%22%3E.bin%208%3C%2FBYTE-SWAP%3E%3C%2FORIGINAL%3E%3C%2FSPAN%3E%20%3C%2FSPAN%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-style%3A%20normal%3B%20font-family%3A%20Arial%3B%20color%3A%20%23575757%3B%20font-weight%3A%20normal%3B%22%3E%3CSPAN%20class%3D%22st%22%3E%3CEM%20style%3D%22color%3A%20%233366ff%3B%22%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Eu-boot%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E9%96%93%E3%80%81u-boot.bin%E3%81%97%E3%81%8B%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EQorIQ%E8%A8%AD%E5%AE%9A%E3%82%B9%E3%82%A4%E3%83%BC%E3%83%88%E3%81%AE%E3%80%8C%E3%83%97%E3%83%AA%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%83%84%E3%83%BC%E3%83%AB%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%97%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AERCW%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E3%81%9D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%83%97%E3%83%AA%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E6%85%8E%E9%87%8D%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20LS102xA%20%E3%81%A7%E3%81%AE%20QSPI%20%E3%81%8B%E3%82%89%E3%81%AE%E8%B5%B7%E5%8B%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099419%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8B%E3%82%89%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%82%A4%E3%82%BA%E3%81%95%E3%82%8C%E3%81%9FLS1021A%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%811%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3CSPAN%20style%3D%22color%3A%20%233366ff%3B%20font-family%3A%20Arial%3B%22%3Ercw_qspiboot_swap.bin%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eu-boot%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E9%96%93%E3%80%81u-boot.bin%E3%81%97%E3%81%8B%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎08-24-2014 10:52 PM
更新者:
