Qt 5.3.0 release on i.MX6 using fsl-community-bsp and meta-qt5
These are my notes for compiling Qt 5.3.0 release using the fsl-community-bsp and the meta-qt5 layer graciously provided by the much lauded Otavio and Martin Jansa.  My test board is the wandboard solo.  My original procedure was based on this document: Compiling Qt5.3.0-beta1 on Yocto which was in turn based on this tutorial: Building Qt5 using yocto on Wandboard - Wandboard Wiki
Steps to build:
repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b daisy; repo sync
cd sources; git clone https://github.com/cetola/meta-qt5.git
**as of this commit:
https://github.com/meta-qt5/meta-qt5/commit/e9ad98bbed6065989ef4648e724f27275b35b838
the meta-qt5 official repo is now using qt 5.3.  I won't be updating my layer, and I suggesting using theirs.
add to bblayers.conf:
  ${BSPDIR}/sources/meta-openembedded/meta-ruby \
  ${BSPDIR}/sources/meta-qt5 \
add to local.conf:
DISTRO_FEATURES_remove = "x11 wayland"
PACKAGECONFIG_append_pn-qtmultimedia = " gstreamer010 "
bitbake wandboard-image-qt5
I will do my best to keep this working with the latest in daisy. Current functionality includes playing hardware accellerated video in QML.  However, examples such as multimediawidgets/player,  multimediawidgets/videowidget do not play video. Also qtwebkit/browser, qtwebkit/youtubeview qtwebkit/fanicybrowser do not support HTML5 video.
Comments welcome.
Cheers,
Stephano
Comments
Bob, I am stuck on the same problem "GStreamer; Unable to play - "" / Error: "No URI set"... have you found a solution for that?
Ok, solution found. It is enough to use a "complete path" when referencing the video file from my QRC-embedded QML file; so I have to do something like:
MediaPlayer {
        source: "file:///home/user/bigbuck1080.mov"
        autoPlay: true
instead of:
MediaPlayer {
        source: "/home/user/bigbuck1080.mov"
        autoPlay: true
I've built an image (for the BoundaryDevices Nitrogen6x board). Verified that Qt5 works, set up the toolchain on a Ubuntu host with cross compile and can deploy my Qt5 applications via ssh. However I need to use the map component in the qtlocation package with the geoservices plugins (I use both nokia and osm) for geocoding and routing. However it seems that these plugins are not built by the Yocto meta-qt5 recepie - there is no /usr/lib/qt5/plugins/geoservices folder in the output image. I'm building a core-image-base image with qtlocation, qtlocation-examples, qtlocation-plugins and qtlocation-qmlplugins added to the IMAGE_INSTALL_append from the dizzy branch.
Has anyone successfully built the qtlocation's geoservices plugins?
Qt has resolved the EGL configuration mismatch issue that prevents hardware acceleration working. Most imx6 and yocto builds end up hardcoding the returned configuration ID, but the Qt patch resolving the issue can be grabbed here:
[QTBUG-44290] IMX6 - Failure to match EGLConfig and X Visual buffer depth crashes app - Qt Bug Track...
The bug fix is targeted for Qt 5.5.
Hi!  Stephano,
I just followed your note and try to recreate the image with QT5.3 on fsl-community-bsp with imx6solosabresd based on Yocto 3.14.28.  Unfortunately I obtained the following error and stopped.
| make: *** [sub-src-make_first] Error 2
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /home/radiant/fsl-community-bsp/solo/tmp/work/cortexa9hf-vfp-neon-poky-linux-gnueabi/qtmultimedia/5.3.2-r0/temp/log.do_compile.11611)
ERROR: Task 793 (/home/radiant/fsl-community-bsp/sources/meta-qt5/recipes-qt/qt5/qtmultimedia_5.3.2.bb, do_compile) failed with exit code '1'
Do I have to modify the bb or inc file for qtmultimedia to correct this issue?
Vincent
When i try to build rocko with meta-qt layer I am getting below error,
ERROR: qtbase-5.9.2+gitAUTOINC+ec16ba393b-r0 do_prepare_recipe_sysroot: The file /usr/lib/pkgconfig/wayland-egl.pc is installed by both mesa and imx-gpu-viv, aborting
ERROR: qtbase-5.9.2+gitAUTOINC+ec16ba393b-r0 do_prepare_recipe_sysroot: Function failed: extend_recipe_sysroot
ERROR: Logfile of failure stored in: /home/sandeep/fsl-community-bsp/build/tmp/work/cortexa9hf-neon-mx6qdl-poky-linux-gnueabi/qtbase/5.9.2+gitAUTOINC+ec16ba393b-r0/temp/log.do_prepare_recipe_sysroot.14279
ERROR: Task (/home/sandeep/fsl-community-bsp/sources/meta-qt5/recipes-qt/qt5/qtbase_git.bb:do_prepare_recipe_sysroot) failed with exit code '1'
add to local.conf:
trying to build toolchain by
bitbake meta-toolchain-qt
due to the above error its not generating sysroot and unable to configure qt, any help?
I'm using yocto project 2.0 which is based on QT 5.5 library.
And now I'm trying to update QT version to 5.8.
How to do it?
Can anyone give me suggestion?
Not at such a high level. We use Qt 5.8/5.11/5.12 with our IMX6 on a frame buffer stack, but getting Qt to properly build was an effort in itself, let alone to modify Yocto. Personally, I would drop Yocto. It is a big effort to get Qt to build properly, another effort to get it to build with the proper HW acceleration, and another to keep multimedia working with Vivante.
%3CLINGO-SUB%20id%3D%22lingo-sub-1099303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EThese%20are%20my%20notes%20for%20compiling%20Qt%205.3.0%20release%20using%20the%20fsl-community-bsp%20and%20the%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Emeta-qt5%3C%2FA%3E%20layer%20graciously%20provided%20by%20the%20much%20lauded%20Otavio%20and%20Martin%20Jansa.%26nbsp%3B%20My%20test%20board%20is%20the%20%3CA%20href%3D%22http%3A%2F%2Fwww.wandboard.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ewandboard%20solo%3C%2FA%3E.%26nbsp%3B%20My%20original%20procedure%20was%20based%20on%20this%20document%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100419%22%20target%3D%22_blank%22%3ECompiling%20Qt5.3.0-beta1%20on%20Yocto%3C%2FA%3E%20which%20was%20in%20turn%20based%20on%20this%20tutorial%3A%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22http%3A%2F%2Fwiki.wandboard.org%2Findex.php%2FBuilding_Qt5_using_yocto_on_Wandboard%22%20style%3D%22font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20color%3A%20%236a737b%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EBuilding%20Qt5%20using%20yocto%20on%20Wandboard%20-%20Wandboard%20Wiki%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESteps%20to%20build%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Erepo%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20style%3D%22color%3A%20%234183c4%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%20-b%20daisy%3B%20repo%20sync%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ecd%20sources%3B%20git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fcetola%2Fmeta-qt5.git%22%20style%3D%22color%3A%20%234183c4%3B%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fcetola%2Fmeta-qt5.git%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E**as%20of%20this%20commit%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fcommit%2Fe9ad98bbed6065989ef4648e724f27275b35b838%22%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fcommit%2Fe9ad98bbed6065989ef4648e724f27275b35b838%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fcommit%2Fe9ad98bbed6065989ef4648e724f27275b35b838%3C%2FA%3E%3C%2FP%3E%3CP%3Ethe%20meta-qt5%20official%20repo%20is%20now%20using%20qt%205.3.%26nbsp%3B%20I%20won't%20be%20updating%20my%20layer%2C%20and%20I%20suggesting%20using%20theirs.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eadd%20to%20bblayers.conf%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%24%7BBSPDIR%7D%2Fsources%2Fmeta-openembedded%2Fmeta-ruby%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%20%24%7BBSPDIR%7D%2Fsources%2Fmeta-qt5%20%5C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eadd%20to%20local.conf%3A%3C%2FP%3E%3CP%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20wayland%22%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-qtmultimedia%20%3D%20%22%20gstreamer010%20%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ebitbake%20wandboard-image-qt5%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20will%20do%20my%20best%20to%20keep%20this%20working%20with%20the%20latest%20in%20daisy.%20Current%20functionality%20includes%20playing%20hardware%20accellerated%20video%20in%20QML.%26nbsp%3B%20However%2C%20examples%20such%20as%20multimediawidgets%2Fplayer%2C%26nbsp%3B%20multimediawidgets%2Fvideowidget%20do%20not%20play%20video.%20Also%20qtwebkit%2Fbrowser%2C%20qtwebkit%2Fyoutubeview%20qtwebkit%2Ffanicybrowser%20do%20not%20support%20HTML5%20video.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EComments%20welcome.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ECheers%2C%3C%2FP%3E%3CP%3EStephano%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENot%20at%20such%20a%20high%20level.%20We%20use%20Qt%205.8%2F5.11%2F5.12%20with%20our%20IMX6%20on%20a%20frame%20buffer%20stack%2C%20but%20getting%20Qt%20to%20properly%20build%20was%20an%20effort%20in%20itself%2C%20let%20alone%20to%20modify%20Yocto.%20Personally%2C%20I%20would%20drop%20Yocto.%20It%20is%20a%20big%20effort%20to%20get%20Qt%20to%20build%20properly%2C%20another%20effort%20to%20get%20it%20to%20build%20with%20the%20proper%20HW%20acceleration%2C%20and%20another%20to%20keep%20multimedia%20working%20with%20Vivante.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099360%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI'm%20using%20yocto%20project%202.0%20which%20is%20based%20on%20QT%205.5%20library.%3C%2FP%3E%3CP%3EAnd%20now%20I'm%20trying%20to%20update%20QT%20version%20to%205.8.%3C%2FP%3E%3CP%3EHow%20to%20do%20it%3F%3C%2FP%3E%3CP%3ECan%20anyone%20give%20me%20suggestion%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWhen%20i%20try%20to%20build%20rocko%20with%20meta-qt%20layer%20I%20am%20getting%20below%20error%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CDIV%20class%3D%22%22%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%20margin%3A%205px%2015px%200px%200px%3B%20padding-bottom%3A%205px%3B%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20dir%3D%22ltr%22%3E%3CDIV%3E%3CEM%3EERROR%3A%20qtbase-5.9.2%2BgitAUTOINC%2Bec16ba393b-r0%20do_prepare_recipe_sysroot%3A%20The%20file%20%2Fusr%2Flib%2Fpkgconfig%2Fwayland-egl.pc%20is%20installed%20by%20both%20mesa%20and%20imx-gpu-viv%2C%20aborting%3C%2FEM%3E%3C%2FDIV%3E%3CDIV%3E%3CEM%3EERROR%3A%20qtbase-5.9.2%2BgitAUTOINC%2Bec16ba393b-r0%20do_prepare_recipe_sysroot%3A%20Function%20failed%3A%20extend_recipe_sysroot%3C%2FEM%3E%3C%2FDIV%3E%3CDIV%3E%3CEM%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Fsandeep%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-neon-mx6qdl-poky-linux-gnueabi%2Fqtbase%2F5.9.2%2BgitAUTOINC%2Bec16ba393b-r0%2Ftemp%2Flog.do_prepare_recipe_sysroot.14279%3C%2FEM%3E%3C%2FDIV%3E%3CDIV%3E%3CEM%3EERROR%3A%20Task%20(%2Fhome%2Fsandeep%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtbase_git.bb%3Ado_prepare_recipe_sysroot)%20failed%20with%20exit%20code%20'1'%3C%2FEM%3E%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3Eadd%20to%20bblayers.conf%3A%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%26nbsp%3B%20%24%7BBSPDIR%7D%2Fsources%2Fmeta-openembedded%2Fmeta-ruby%20%5C%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%26nbsp%3B%20%24%7BBSPDIR%7D%2Fsources%2Fmeta-qt5%20%5C%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3Eadd%20to%20local.conf%3A%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20wayland%22%3C%2FP%3E%3CP%20style%3D%22color%3A%20%2351626f%3B%20background-color%3A%20%23ffffff%3B%20border%3A%200px%3B%20font-size%3A%2015px%3B%22%3EPACKAGECONFIG_append_pn-qtmultimedia%20%3D%20%22%20gstreamer010%20%22%3C%2FP%3E%3C%2FDIV%3E%3CDIV%3Etrying%20to%20build%20toolchain%20by%3C%2FDIV%3E%3CDIV%3Ebitbake%20meta-toolchain-qt%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3E%20%3C%2FDIV%3E%3CDIV%3Edue%20to%20the%20above%20error%20its%20not%20generating%20sysroot%20and%20unable%20to%20configure%20qt%2C%20any%20help%3F%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099358%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi!%26nbsp%3B%20Stephano%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20just%20followed%20your%20note%20and%20try%20to%20recreate%20the%20image%20with%20QT5.3%20on%20fsl-community-bsp%20with%20imx6solosabresd%20based%20on%20Yocto%203.14.28.%26nbsp%3B%20Unfortunately%20I%20obtained%20the%20following%20error%20and%20stopped.%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3E%7C%20make%3A%20***%20%5Bsub-src-make_first%5D%20Error%202%3C%2FP%3E%3CP%3E%7C%20ERROR%3A%20oe_runmake%20failed%3C%2FP%3E%3CP%3E%7C%20WARNING%3A%20exit%20code%201%20from%20a%20shell%20command.%3C%2FP%3E%3CP%3E%7C%20ERROR%3A%20Function%20failed%3A%20do_compile%20(log%20file%20is%20located%20at%20%2Fhome%2Fradiant%2Ffsl-community-bsp%2Fsolo%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fqtmultimedia%2F5.3.2-r0%2Ftemp%2Flog.do_compile.11611)%3C%2FP%3E%3CP%3EERROR%3A%20Task%20793%20(%2Fhome%2Fradiant%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtmultimedia_5.3.2.bb%2C%20do_compile)%20failed%20with%20exit%20code%20'1'%3C%2FP%3E%3CP%3E%3D%3D%3D%3D%3D%3C%2FP%3E%3CP%3EDo%20I%20have%20to%20modify%20the%20bb%20or%20inc%20file%20for%20qtmultimedia%20to%20correct%20this%20issue%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EVincent%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099357%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EQt%20has%20resolved%20the%20EGL%20configuration%20mismatch%20issue%20that%20prevents%20hardware%20acceleration%20working.%20Most%20imx6%20and%20yocto%20builds%20end%20up%20hardcoding%20the%20returned%20configuration%20ID%2C%20but%20the%20Qt%20patch%20resolving%20the%20issue%20can%20be%20grabbed%20here%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fbugreports.qt.io%2Fbrowse%2FQTBUG-44290%22%20title%3D%22https%3A%2F%2Fbugreports.qt.io%2Fbrowse%2FQTBUG-44290%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%5BQTBUG-44290%5D%20IMX6%20-%20Failure%20to%20match%20EGLConfig%20and%20X%20Visual%20buffer%20depth%20crashes%20app%20-%20Qt%20Bug%20Tracker%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThe%20bug%20fix%20is%20targeted%20for%20Qt%205.5.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099356%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20built%20an%20image%20(for%20the%20BoundaryDevices%20Nitrogen6x%20board).%20Verified%20that%20Qt5%20works%2C%20set%20up%20the%20toolchain%20on%20a%20Ubuntu%20host%20with%20cross%20compile%20and%20can%20deploy%20my%20Qt5%20applications%20via%20ssh.%20However%20I%20need%20to%20use%20the%20map%20component%20in%20the%20qtlocation%20package%20with%20the%20geoservices%20plugins%20(I%20use%20both%20nokia%20and%20osm)%20for%20geocoding%20and%20routing.%20However%20it%20seems%20that%20these%20plugins%20are%20not%20built%20by%20the%20Yocto%20meta-qt5%20recepie%20-%20there%20is%20no%20%2Fusr%2Flib%2Fqt5%2Fplugins%2Fgeoservices%20folder%20in%20the%20output%20image.%20I'm%20building%20a%20core-image-base%20image%20with%20qtlocation%2C%20qtlocation-examples%2C%20qtlocation-plugins%20and%20qtlocation-qmlplugins%20added%20to%20the%20IMAGE_INSTALL_append%20from%20the%20dizzy%20branch.%3C%2FP%3E%3CP%3EHas%20anyone%20successfully%20built%20the%20qtlocation's%20geoservices%20plugins%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099355%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOk%2C%20solution%20found.%20It%20is%20enough%20to%20use%20a%20%22complete%20path%22%20when%20referencing%20the%20video%20file%20from%20my%20QRC-embedded%20QML%20file%3B%20so%20I%20have%20to%20do%20something%20like%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMediaPlayer%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20id%3A%20mediaPlayer2%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20source%3A%20%22file%3A%2F%2F%2Fhome%2Fuser%2Fbigbuck1080.mov%22%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20autoPlay%3A%20true%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Einstead%20of%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMediaPlayer%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20id%3A%20mediaPlayer2%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20source%3A%20%22%2Fhome%2Fuser%2Fbigbuck1080.mov%22%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20autoPlay%3A%20true%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099354%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBob%2C%20I%20am%20stuck%20on%20the%20same%20problem%20%22GStreamer%3B%20Unable%20to%20play%20-%20%22%22%20%2F%20Error%3A%20%22No%20URI%20set%22...%20have%20you%20found%20a%20solution%20for%20that%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099353%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIf%20I%20use%20stop()%20or%20seek()%20method%2C%20everything%20hangs%20though%20audio%20is%20being%20heard%20with%20Play().%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099352%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENo%20I%20didnot%20experience%20these%20problems.%20Play()%2C%20Pause()%20or%20Seek()%20works%20fine%20but%20audio%20is%20not%20heard%20while%20playing%20video.%3C%2FP%3E%3CP%3EAny%20reasons%20for%20this%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099351%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAs%20I%20found%20that%20udisks%20service%20is%20not%20available%2C%20Please%20let%20me%20know%20how%20can%20I%20add%20udisks%20and%20their%20dependent%20packages%20in%20local.conf.%3C%2FP%3E%3CP%3Ewhat%20would%20be%20the%20entry%20for%20udisks%20in%20local.conf%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWhen%20I%20tried%20to%20play%20audio%2C%20it%20throws%20error%20%22Unable%20to%20create%20connection%20to%20pulse%20audio%20context%22.%20If%20I%20use%20dbus%20service%20UDisks%2C%20it%20gives%20error%20%3C%2FP%3E%3CDIV%20class%3D%22rpHighlightAllClass%20_rp_O3%20rpHighlightBodyClass%22%3E%3CDIV%3E%3CDIV%3E%3CDIV%20style%3D%22background-color%3A%20white%3B%22%3E%3CDIV%20style%3D%22text-indent%3A%200%3B%20margin%3A%200%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23be1414%3B%20font-size%3A%209pt%3B%20font-family%3A%20monospace%3B%22%3Eresponse%20is%3A%20QDBusMessage(type%3DError%2C%20service%3D%22%22%2C%20error%20name%3D%22org.freedesktop.DBus.Error.ServiceUnknown%22%2C%20error%20message%3D%22%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23be1414%3B%20font-size%3A%209pt%3B%20font-family%3A%20monospace%3B%22%3E%3CSTRONG%3EThe%20name%20org.freedesktop.UDisks%20was%20not%20provided%20by%20any%20.service%20files%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23be1414%3B%20font-size%3A%209pt%3B%20font-family%3A%20monospace%3B%22%3E%22%2C%20signature%3D%22%22%2C%20contents%3D()%20)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%20style%3D%22text-indent%3A%200%3B%20margin%3A%200%3B%22%3E%3CBR%20%2F%3EWhen%20I%20tried%20to%20play%20audio%2CPlease%20let%20me%20know%20if%20anyone%20has%20experienced%20these%20issues%20with%20latest%20Qt5.3.%3C%2FDIV%3E%3CDIV%20style%3D%22text-indent%3A%200%3B%20margin%3A%200%3B%22%3E%20%3C%2FDIV%3E%3CDIV%20style%3D%22text-indent%3A%200%3B%20margin%3A%200%3B%22%3E%20%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20figured%20out%20that%20one%20has%20to%20add%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtgraphicaleffects-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%20to%20local.conf%20in%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EIMAGE_INSTALL_append%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Eto%20get%20the%20qtgraphicaleffects%20added%20to%20the%20image.%20Thanks%20%3CSTRONG%3E%3CEM%3EGunnar%20Roth%3C%2FEM%3E%3C%2FSTRONG%3E%20for%20the%20hint.%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099348%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAm%20sorry%20for%20the%20delayed%20reply.%3C%2FP%3E%3CP%3EIam%20unable%20to%20make%20my%20application%20work%20due%20to%20dependencies%20on%20graphicaleffects%20and%20qtquickcontrols.%3C%2FP%3E%3CP%3EIf%20add%20entries%20of%20qtgraphicaleffects%20and%20qtquickcontrols%20in%20local.conf%2C%20it%20throws%20error.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eqtgraphicaleffects%20and%20qtquickcontrols%20are%20not%20found%20in%20base%20feeds.%3C%2FP%3E%3CP%3EDid%20anyone%20face%20these%20issues%3F%20Please%20let%20me%20know%20how%20to%20overcome%20the%20same.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099347%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EFor%20Qt5.2%20and%20Qt5.3%20i%20have%20problem%20when%20playing%20video.%20I%20use%20Video%2C%20MediaPlayer%20items%20in%20Qml.%20Video%20file%20played%20without%20problem.%20but%20if%20i%20use%20stop()%20or%20seek%20method%20everything%20hangs.%20Pause()%20method%20works%20fine.%20did%20you%20have%20problems%20like%20that%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAdding%20%3CSTRONG%3Egstreamer1.0%3C%2FSTRONG%3E%20support%20break%20qtmultimedia%20recipe.%20If%20you%20don't%20use%20%3CSTRONG%3Egstreamer1.0%3C%2FSTRONG%3E%20you%20must%20replace%20your%20%3CSTRONG%3Emeta-qt5%2Frecipes-qt%2Fqt5%2Fqtmultimedia.inc%3C%2FSTRONG%3E%20by%20this%20code%20(and%20rebuild)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Erequire%20qt5.inc%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDEPENDS%20%2B%3D%20%22qtdeclarative%20alsa-lib%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPACKAGECONFIG%20%3F%3F%3D%20%22%22%3C%2FP%3E%3CP%3EPACKAGECONFIG%5Bopenal%5D%20%3D%20%22%2C%2Copenal-soft%22%3C%2FP%3E%3CP%3EPACKAGECONFIG%5Bgstreamer010%5D%20%3D%20%22%2C%2Cgstreamer%20gst-plugins-base%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edo_configure_prepend()%20%7B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%23%20disable%20openal%20test%20if%20it%20isn't%20enabled%20by%20PACKAGECONFIG%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3Esed%20-i%20's%2F%5EqtCompileTest(openal)%2FOE_OPENAL_ENABLED%3AqtCompileTest(openal)%2Fg'%20%24%7BS%7D%2Fqtmultimedia.pro%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%23%20disable%20gstreamer-0.10%20test%20if%20it%20isn't%20enabled%20by%20PACKAGECONFIG%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3Esed%20-i%20's%2F%5E%5C(%20*%5C)qtCompileTest(gstreamer)%20%7B%2F%5C1OE_GSTREAMER010_ENABLED%3AqtCompileTest(gstreamer)%20%7B%2Fg'%20%24%7BS%7D%2Fqtmultimedia.pro%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EEXTRA_QMAKEVARS_PRE%20%2B%3D%20%22%24%7B%40base_contains('PACKAGECONFIG'%2C%20'openal'%2C%20'CONFIG%2B%3DOE_OPENAL_ENABLED'%2C%20''%2C%20d)%7D%22%3C%2FP%3E%3CP%3EEXTRA_QMAKEVARS_PRE%20%2B%3D%20%22%24%7B%40base_contains('PACKAGECONFIG'%2C%20'gstreamer010'%2C%20'CONFIG%2B%3DOE_GSTREAMER010_ENABLED'%2C%20''%2C%20d)%7D%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%20older%20copyright%20year%20than%20what%20e.g.%20qtbase%20is%20using%20now%3C%2FP%3E%3CP%3ELIC_FILES_CHKSUM%20%3D%20%22file%3A%2F%2FLICENSE.LGPL%3Bmd5%3D4193e7f1d47a858f6b7c0f1ee66161de%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20file%3A%2F%2FLICENSE.GPL%3Bmd5%3Dd32239bcb673463ab874e80d47fae504%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20file%3A%2F%2FLGPL_EXCEPTION.txt%3Bmd5%3D0145c4d1b6f96a661c2c139dfb268fb6%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20file%3A%2F%2FLICENSE.FDL%3Bmd5%3D6d9f2a9af4c8b8c3c769f6cc1b6aaf7e%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELooks%20like%20GST_CHECK_VERSION(1%2C0%2C0)%20working%20wrong.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099344%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20tried%20to%20switch%20from%205.3.0%20beta%20to%205.3.0%20using%20master%20branch.%20But%20when%20I%20bitbake%20core-image-minimal%2C%20it%20gives%20below%20error%20in%20qtmultimedia.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%2Fhome%2Framakanth%2FYocto%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fqtmultimedia%2F5.3.0%2BgitAUTOINC%2Bb99a4b3025-r0%2Fgit%2Fsrc%2Fgsttools%2Fgstvideoconnector.c%3A467%3A32%3A%20error%3A%20'GST_PAD_PROBE_DROP'%20undeclared%20(first%20use%20in%20this%20function)%3C%2FP%3E%3CP%3EAm%20I%20missing%20anything%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20and%20Regards%2C%3C%2FP%3E%3CP%3ERamakanth%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099343%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAs%20i%20wrote%20i%20my%20config%20at%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-100419%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fdocs%2FDOC-100419%3C%2FA%3E%20I%20figured%20out%20that%20one%20has%20to%20add%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtquickcontrols-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eto%20local.conf%20in%20%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3EIMAGE_INSTALL_append%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%22%3Eto%20get%20the%20QuickControls%20added%20to%20the%20image.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CBR%20%2F%3EPlease%20let%20me%20know%20if%20we%20need%20to%20build%20QtQuickcontrols%20only%20through%20source%20but%20not%20through%20bitbake%20to%20resolve%20the%20issue%3C%2FP%3E%3CP%3E%22QtQuickcontrols%20not%20found%20in%20base%20feeds%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPlease%20let%20me%20know%20if%20there%20is%20a%20solution%20for%20the%20above%20QtQuickcontrols%20error.%3C%2FP%3E%3CP%3EI%20tried%20with%20PACKAGECONFIG_append_pn-qtbase%20%3D%20%22%20accessibility%22%20a%20suggested%20in%20other%20forum%20but%20still%20the%20problem%20exists.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20got%20the%20vpu_fw_imx6d.bin%20to%20build%20and%20install%20into%20the%20correct%20directory!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EJust%20needed%20to%20add%20these%20lines%20to%20my%20local.conf%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3EIMAGE_INSTALL_append%20%3D%20%22%20%5C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20firmware-imx-vpu-imx6d%20%5C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%22%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI've%20been%20working%20with%20core-image-minimal.....%20I%20guess%20that%20file%20doesn't%20get%20built%20unless%20specified.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI'm%20back%20to%20battling%20QML%20video......%20as%20far%20as%20I%20can%20tell%2C%20I'll%20need%20to%20write%20my%20own%20C%2B%2B%20wrapper%20to%20play%20video%20in%20QML.%20I%20keep%20getting%20the%20following%20error...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3EGStreamer%3B%20Unable%20to%20play%20-%20%22%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-indent%3A%200px%3B%22%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3EError%3A%20%22No%20URI%20set%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIt's%20like%20Qt%20QML%20doesn't%20want%20to%20pass%20the%20filename%20and%20path%20to%20gstreamer.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20again%20for%20the%20help!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20found%20a%20disconnect%20here.....%3C%2FP%3E%3CP%3EThe%20problem%20I've%20been%20having%20with%20videos%20is%20because%20I%20didn't%20have%20vpu_fw_imx6d.bin%20in%20the%20%2Flib%2Ffirmware%2Fvpu%20directory......%20I%20didn't%20even%20have%20a%20%2Flib%2Ffiirmware%2Fvpu%20directory%20in%20my%20Yocto%20system.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20found%20vpu_fw_imx6d.bin%20in%20one%20of%20my%20android%20build%20directories%20that%20I%20was%20able%20to%20use%20and%20then%20I%20was%20able%20to%20play%20Big%20Buck%20Bunny.%3C%2FP%3E%3CP%3EDigging%20into%20this.....%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EStephano%2C%3C%2FP%3E%3CP%3ENow%20I'm%20stuck%20again.%3C%2FP%3E%3CP%3EBeen%20trying%20to%20debug%20qml%20video%20and%20neither%20of%20the%20two%20videos%20I%20have%20want%20to%20play!%20I%20decided%20to%20just%20use%20gstreamer%20directly%20to%20debug%20this.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhenever%20I%20try%20to%20play%20Big%20Buck%20Bunny%2C%20I%20get%20the%20following%20error...%3C%2FP%3E%3CP%3E'%3CSTRONG%3EMissing%20element%3A%20AC-3%20(ATSC%20A%2F52)%20decoder%3C%2FSTRONG%3E'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20launch%20it%20with%20the%20following%20command...%3C%2FP%3E%3CP%3E%3CSTRONG%3Egst-launch%20playbin2%20uri%3Dfile%3A%2F%2F%2Fhome%2Froot%2Fbig_buck_bunny_720p_surround.avi%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EI%20can%20see%20that%20the%20decoder%20for%20that%20is%20available%20in%20the%20gst-plugins-ugly%20plugin.....%20when%20I%20try%20to%20add%20gst-plugins-ugly%20to%20my%20local.conf%20I%20get%20an%20error%20saying%20that%20nothing%20provides%20for%20it....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAny%20ideas%20on%20what%20I%20should%20do%20next%3F%3C%2FP%3E%3CP%3EThanks!%3C%2FP%3E%3CP%3E-Bob%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099337%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20tried%20with%20below%20but%20still%20getting%20ERROR%3A%20qtquickcontrols%20not%20found%20in%20the%20base%20feeds.%20Is%20there%20any%20solution%20for%20the%20same%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Erepo%20init%20-u%20%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%20-b%20master%3B%20repo%20sync%3C%2FP%3E%3CP%3E%20cd%20sources%3B%20git%20clone%20-b%20master%20%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAdded%20even%20PACKAGECONFIG_append_pn-qtbase%20%3D%20%22accessibility%20gles2%20openssl%22%20but%20no%20luck.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20Todor!%3C%2FP%3E%3CP%3EWhat's%20weird%20is%2C%20I%20swear%2C%20it%20seems%20like%20it%20builds%20just%20fine%20sometimes%20and%20other%20times%20it%20decides%20to%20generate%20this%20alsa%20error.%3C%2FP%3E%3CP%3EIt%20looks%20like%20I'm%20past%20this%20error%20now.%3C%2FP%3E%3CP%3EThank%20you%20very%20much%20for%20the%20tip.%3C%2FP%3E%3CP%3EThis%20combination%20of%20bitbake%20commands%26nbsp%3B%20(appears)%20to%20have%20gotten%20me%20past%20this%20point.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ebitbake%20-c%20cleanall%20ncurses%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ebitbake%20-c%20cleanall%20alsa-utils%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ebitbake%20-c%20build%20ncurses%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ebitbake%20-c%20build%20alsa-utils%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ethen%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3Ebitbake%20%3CYOUR%20target%3D%22%22%3E%3C%2FYOUR%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EThanks%20again%20sir!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%231f497d%3B%22%3EI%20had%20the%20same%20issue.%20I%20could%20not%20figure%20out%20the%20cause%2C%20but%20I%20know%20how%20to%20go%20past%20it%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%231f497d%3B%22%3EThe%20alsa-utils%20use%20ncurses%20for%20the%20mixer%20and%20some%20such%2C%20and%20ncurses%20is%20built%20before%20that%2C%20but%20for%20some%20reason%20the%20libs%20are%20overwritten%20later%20with%20the%20SDK%20version%20from%20the%20host%20(which%20is%20Intel%20and%20not%20ARM)%20so%20the%20configure%20script%20cannot%20link%20against%20them%20anymore.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2011.0pt%3B%20font-family%3A%20'Calibri'%2C'sans-serif'%3B%20color%3A%20%231f497d%3B%22%3EWhen%20the%20bitbake%20command%20fails%2C%20just%20do%20a%20%E2%80%9Cbitbake%20%E2%80%93c%20build%20ncurses%E2%80%9D%20again%2C%20and%20when%20that%20is%20done%20repeat%20%E2%80%9Cbitbake%20%3CYOUR-TARGET%3E%E2%80%9D%20or%20%E2%80%9Cbitbake%20%E2%80%93c%20cleanall%20alsa-utils%20%26amp%3B%26amp%3B%20bitbake%20%E2%80%93c%20build%20alsa-utils%3B%20bitbake%20%3CYOUR-TARGET%3E%E2%80%9D%20and%20it%20will%20continue%20from%20where%20it%20stopped%20before.%3C%2FYOUR-TARGET%3E%3C%2FYOUR-TARGET%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099334%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHip%2C%20hip%20hooray!%20For%20big%20buck%20bunny!%3C%2FP%3E%3CP%3ENow%20I'm%20battling%20THIS%20error....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EError%3A%20%2Ffsl-community-bsp%2Fsources%2Fpoky%2Fmeta%2Frecipes-multimedia%2Falsa%2Falsa-utils_1.0.27.2.bb%2C%20do_configure)%20failed%20with%20exit%20code%20'1'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAm%20I%20missing%20a%20package%3F%20Is%20this%20just%20a%20bug%20with%20the%20'master'%20branch%3F%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099333%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eplease%20change%20QT_MODULE_BRANCH%20in%20file%20%3CSPAN%20class%3D%22js-repo-root%20repo-root%22%3E%3CSPAN%3E%3CA%20data-branch%3D%22qt5-5.3.0%22%20data-direction%3D%22back%22%20data-pjax%3D%22true%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fcetola%2Fmeta-qt5%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%3Emeta-qt5%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22separator%22%3E%20%2F%20%3C%2FSPAN%3E%3CSPAN%3E%3CA%20data-branch%3D%22qt5-5.3.0%22%20data-direction%3D%22back%22%20data-pjax%3D%22true%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fcetola%2Fmeta-qt5%2Ftree%2Fqt5-5.3.0%2Frecipes-qt%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%3Erecipes-qt%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22separator%22%3E%20%2F%20%3C%2FSPAN%3E%3CSPAN%3E%3CA%20data-branch%3D%22qt5-5.3.0%22%20data-direction%3D%22back%22%20data-pjax%3D%22true%22%20href%3D%22https%3A%2F%2Fgithub.com%2Fcetola%2Fmeta-qt5%2Ftree%2Fqt5-5.3.0%2Frecipes-qt%2Fqt5%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%3Eqt5%3C%2FSPAN%3E%3C%2FA%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22separator%22%3E%20%2F%20%3C%2FSPAN%3E%3CSTRONG%20class%3D%22final-path%22%3Eqt5-5.3.0.inc%3C%2FSTRONG%3E%20from%205.3.0%20to%205.3%2C%20because%20it%20changed%20in%20Qt%20repository.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099332%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20added%20CHKSUM%20explicitly%20and%20got%20way%20with%20the%20above%20error.%20However%2C%20not%20able%20to%20get%20away%20with%20Qtquickcontrols%20not%20found%20in%20base%20feeds%20error.%20Perhaps%2C%20I%20need%20to%20try%20with%20master%20branch%20as%20Qt5.3%20is%20officially%20integrated%20in%20main%20respository.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EProbably%20the%20below%20should%20do%20the%20trick%20instead%20of%20cloning%20to%20specific%20branch.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Erepo%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FFreescale%2Ffsl-community-bsp-platform%3C%2FA%3E%20-b%20master%3B%20repo%20sync%3C%2FP%3E%3CP%3E%20cd%20sources%3B%20git%20clone%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIam%20still%20getting%20the%20below%20error%20in%20qtbase%20when%20I%20did%20bitbake%20core-image-minimal.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EERROR%3A%20qtbase-native%3A%20md5%20data%20is%20not%20matching%20for%20file%3A%2F%2FLICENSE.LGPL%3Bmd5%3D4193e7f1d47a858f6b7c0f1ee66161de%3C%2FP%3E%3CP%3EERROR%3A%20qtbase-native%3A%20The%20new%20md5%20checksum%20is%202abca611d56c23eb99943bde21c80a0d%3C%2FP%3E%3CP%3EERROR%3A%20qtbase-native%3A%20Check%20if%20the%20license%20information%20has%20changed%20in%20%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fi686-linux%2Fqtbase-native%2F5.3.0-r0%2Fgit%2FLICENSE.LGPL%20to%20verify%20that%20the%20LICENSE%20value%20%22GFDL-1.3%20%26amp%3B%20LGPL-2.1%20%7C%20GPL-3.0%22%20remains%20valid%3C%2FP%3E%3CP%3EERROR%3A%20Licensing%20Error%3A%20LIC_FILES_CHKSUM%20does%20not%20match%2C%20please%20fix%3C%2FP%3E%3CP%3EERROR%3A%20Function%20failed%3A%20do_qa_configure%3C%2FP%3E%3CP%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fi686-linux%2Fqtbase-native%2F5.3.0-r0%2Ftemp%2Flog.do_configure.7527%3C%2FP%3E%3CP%3EERROR%3A%20Task%201651%20(%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtbase-native_5.3.0.bb%2C%20do_configure)%20failed%20with%20exit%20code%20'1'%3C%2FP%3E%3CP%3ENOTE%3A%20Tasks%20Summary%3A%20Attempted%203371%20tasks%20of%20which%203000%20didn't%20need%20to%20be%20rerun%20and%201%20failed.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20seen%20that%20error%20before%20and%20have%20resolved%20it%20in%20the%20past%20by%20adding%20this%20line%20to%20my%20local.conf%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EPACKAGECONFIG_append_pn-qtmultimedia%20%3D%20%22%20gstreamer010%20%22%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3EDo%20you%20already%20have%20that%20line%3F%20If%20not%20give%20that%20a%20try%20and%20let%20me%20know%20if%20it%20helps.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%233d3d3d%3B%20font-family%3A%20'Helvetica%20Neue'%2C%20Helvetica%2C%20Arial%2C%20'Lucida%20Grande'%2C%20sans-serif%3B%20font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3Ep.s.%20Three%20cheers%20for%20Big%20Buck%20Bunny!%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099329%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099329%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20tested%20this%20now%20and%2C%20for%20the%20most%20part%2C%20I'm%20pleased%20to%20see%20that%20it%20compiled%20just%20fine.%3C%2FP%3E%3CP%3EOne%20problem%20I'm%20having%20is%20with%20Qt%20Multimedia....%3C%2FP%3E%3CP%3EWhenever%20I%20run%20this%20code%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3ERectangle%20%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20width%3A%201280%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20height%3A%20800%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20color%3A%20%22black%22%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MediaPlayer%20%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20id%3A%20player%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20source%3A%20%22%2Fhome%2Froot%2Fbig_buck_bunny_720p_surround.avi%22%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20autoPlay%3A%20true%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20VideoOutput%20%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20id%3A%20videoOutput%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20source%3A%20player%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20anchors.fill%3A%20parent%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EI%20get%20the%20following%20error.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3Ed%3CSTRONG%3EefaultServiceProvider%3A%3ArequestService()%3A%20no%20service%20found%20for%20-%20%22org.qt-project.qt.mediaplayer%22%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3E%3CSTRONG%3EAnybody%20else%20encounter%20this%20and%20have%20a%20workaround%3F%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20'Monospace'%3B%20font-size%3A%209pt%3B%20color%3A%20%23be1414%3B%22%3E%3CSTRONG%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EWell...it%20will%20be%20a%20couple%20of%20hours%20before%20it's%20done%20but%20it's%20already%20gotten%20further%20than%20it%20has%20before.%20I'm%20optimisitc%20now.%3C%2FP%3E%3CP%3Ethank%20you%20Todor%20and%20Stephano!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThat's%20good%20info!%20Thanks!%20I'll%20remove%20that%20and%20rebuild%20and%20see%20what%20happens.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBob%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20believe%20you%20forgot%20to%20remove%20the%20file%20sources%2Fmeta-fsl-arm%2Fqt5-layer%2Frecipes-qt%2Fqt5%2Fqtmultimedia_%25.bbappend%20prior%20to%20bitbaking%20the%20image.%20It%20tries%20to%20apply%20exactly%20the%20patch%20that%20is%20failing%20your%20build.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETodor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYup.%20Same%20errors....%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3EERROR%3A%20Command%20Error%3A%20exit%20status%3A%201%26nbsp%3B%20Output%3A%3C%2FP%3E%3CP%3EApplying%20patch%20add-imx6-support.patch%3C%2FP%3E%3CP%3Epatching%20file%20src%2Fplugins%2Fplugins.pro%3C%2FP%3E%3CP%3EHunk%20%231%20FAILED%20at%206.%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20rejects%20in%20file%20src%2Fplugins%2Fplugins.pro%3C%2FP%3E%3CP%3EThe%20next%20patch%20would%20create%20the%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fimx6.json%2C%3C%2FP%3E%3CP%3Ewhich%20already%20exists!%26nbsp%3B%20Applying%20it%20anyway.%3C%2FP%3E%3CP%3Epatching%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fimx6.json%3C%2FP%3E%3CP%3EHunk%20%231%20FAILED%20at%201.%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20rejects%20in%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fimx6.json%3C%2FP%3E%3CP%3EThe%20next%20patch%20would%20create%20the%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fimx6.pro%2C%3C%2FP%3E%3CP%3Ewhich%20already%20exists!%26nbsp%3B%20Applying%20it%20anyway.%3C%2FP%3E%3CP%3Epatching%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fimx6.pro%3C%2FP%3E%3CP%3EHunk%20%231%20FAILED%20at%201.%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20rejects%20in%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fimx6.pro%3C%2FP%3E%3CP%3EThe%20next%20patch%20would%20create%20the%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterial.cpp%2C%3C%2FP%3E%3CP%3Ewhich%20already%20exists!%26nbsp%3B%20Applying%20it%20anyway.%3C%2FP%3E%3CP%3Epatching%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterial.cpp%3C%2FP%3E%3CP%3EHunk%20%231%20FAILED%20at%201.%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20rejects%20in%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterial.cpp%3C%2FP%3E%3CP%3EThe%20next%20patch%20would%20create%20the%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterial.h%2C%3C%2FP%3E%3CP%3Ewhich%20already%20exists!%26nbsp%3B%20Applying%20it%20anyway.%3C%2FP%3E%3CP%3Epatching%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterial.h%3C%2FP%3E%3CP%3EHunk%20%231%20FAILED%20at%201.%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20rejects%20in%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterial.h%3C%2FP%3E%3CP%3EThe%20next%20patch%20would%20create%20the%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterialshader.cpp%2C%3C%2FP%3E%3CP%3Ewhich%20already%20exists!%26nbsp%3B%20Applying%20it%20anyway.%3C%2FP%3E%3CP%3Epatching%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterialshader.cpp%3C%2FP%3E%3CP%3EHunk%20%231%20FAILED%20at%201.%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20rejects%20in%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterialshader.cpp%3C%2FP%3E%3CP%3EThe%20next%20patch%20would%20create%20the%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterialshader.h%2C%3C%2FP%3E%3CP%3Ewhich%20already%20exists!%26nbsp%3B%20Applying%20it%20anyway.%3C%2FP%3E%3CP%3Epatching%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterialshader.h%3C%2FP%3E%3CP%3EHunk%20%231%20FAILED%20at%201.%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20rejects%20in%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideomaterialshader.h%3C%2FP%3E%3CP%3EThe%20next%20patch%20would%20create%20the%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonode.cpp%2C%3C%2FP%3E%3CP%3Ewhich%20already%20exists!%26nbsp%3B%20Applying%20it%20anyway.%3C%2FP%3E%3CP%3Epatching%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonode.cpp%3C%2FP%3E%3CP%3EHunk%20%231%20FAILED%20at%201.%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20rejects%20in%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonode.cpp%3C%2FP%3E%3CP%3EThe%20next%20patch%20would%20create%20the%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonode.h%2C%3C%2FP%3E%3CP%3Ewhich%20already%20exists!%26nbsp%3B%20Applying%20it%20anyway.%3C%2FP%3E%3CP%3Epatching%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonode.h%3C%2FP%3E%3CP%3EHunk%20%231%20FAILED%20at%201.%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20rejects%20in%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonode.h%3C%2FP%3E%3CP%3EThe%20next%20patch%20would%20create%20the%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonodefactory.cpp%2C%3C%2FP%3E%3CP%3Ewhich%20already%20exists!%26nbsp%3B%20Applying%20it%20anyway.%3C%2FP%3E%3CP%3Epatching%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonodefactory.cpp%3C%2FP%3E%3CP%3EHunk%20%231%20FAILED%20at%201.%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20rejects%20in%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonodefactory.cpp%3C%2FP%3E%3CP%3EThe%20next%20patch%20would%20create%20the%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonodefactory.h%2C%3C%2FP%3E%3CP%3Ewhich%20already%20exists!%26nbsp%3B%20Applying%20it%20anyway.%3C%2FP%3E%3CP%3Epatching%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonodefactory.h%3C%2FP%3E%3CP%3EHunk%20%231%20FAILED%20at%201.%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20rejects%20in%20file%20src%2Fplugins%2Fvideonode%2Fimx6%2Fqsgvivantevideonodefactory.h%3C%2FP%3E%3CP%3EThe%20next%20patch%20would%20create%20the%20file%20src%2Fplugins%2Fvideonode%2Fvideonode.pro%2C%3C%2FP%3E%3CP%3Ewhich%20already%20exists!%26nbsp%3B%20Applying%20it%20anyway.%3C%2FP%3E%3CP%3Epatching%20file%20src%2Fplugins%2Fvideonode%2Fvideonode.pro%3C%2FP%3E%3CP%3EHunk%20%231%20FAILED%20at%201.%3C%2FP%3E%3CP%3E1%20out%20of%201%20hunk%20FAILED%20--%20rejects%20in%20file%20src%2Fplugins%2Fvideonode%2Fvideonode.pro%3C%2FP%3E%3CP%3EPatch%20add-imx6-support.patch%20does%20not%20apply%20(enforce%20with%20-f)%3C%2FP%3E%3CP%3EERROR%3A%20Function%20failed%3A%20patch_do_patch%3C%2FP%3E%3CP%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Fbob%2FProjects%2FM821%2FYocto%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-mx6-poky-linux-gnueabi%2Fqtmultimedia%2F5.3.0-r0%2Ftemp%2Flog.do_patch.6597%3C%2FP%3E%3CP%3EERROR%3A%20Task%20759%20(%2Fhome%2Fbob%2FProjects%2FM821%2FYocto%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtmultimedia_5.3.0.bb%2C%20do_patch)%20failed%20with%20exit%20code%20'1'%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20Todor.%20I%20did%20that.%3C%2FP%3E%3CP%3EI%20followed%20the%20Wandboard%20Wiki%20for%20building%20Yocto%2FQt5.%3C%2FP%3E%3CP%3EInstead%20of%20checking%20out%20the%20version%20specified%20in%20the%20wiki%2C%20I%20got%20the%20master%20repo.%3C%2FP%3E%3CP%3EI%20had%20also%20added%20a%20few%20more%20packages%20than%20the%20ones%20specified%20in%20the%20Wandboard%20wiki%20(local.conf)....%20perhaps%20that's%20why%20I%20couldn't%20successfully%20run%20'bitbake%20meta-toolchain-qt5'.%3C%2FP%3E%3CP%3EI've%20removed%20a%20bunch%20of%20the%20things%20that%20I've%20added%20in%20my%20local.conf%20so%20that%20it%20matches%20what's%20specified%20in%20the%20wiki.%20As%20soon%20as%20the%20image%20is%20built%2C%20I'll%20try%20to%20build%20the%20toolchain%20again%20and%20post%20my%20results.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EJust%20a%20shot%20note%20for%20people%2C%20who%20want%20to%20try%20the%20master%20repo.%20When%20I%20cloned%20it%20locally%2C%20I%20did%20not%20checkout%20a%20specific%20branch%20as%20suggested%20by%20multiple%20websites%2C%20so%20no%20-b%205.3.0%20or%20-b%20daisy%20when%20you%20are%20cloning%20meta-qt5!%20The%20other%20branches%20will%20not%20fit%20with%20yocto%201.6.1%2C%20I%20believe.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%2C%20but%20yours%20is%20the%20more%20important%20contribution!%20%3CLI-EMOJI%20id%3D%22lia_winking-face%22%20title%3D%22%3Awinking_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBTW%2C%20while%20I%20was%20trying%20to%20fix%20my%20build%20using%20your%20meta-qt5%20layer%20repo%2C%20I%20think%20I%20figured%20where%20the%20cause%20of%20the%20build%20failure%20is.%20In%20your%20sources%2C%20for%20the%20package%20that%20errors%20our%2C%20there%20are%20both%20%3CFOLDER_BASENAME%3E%20and%20%3CFOLDER_BASENAME-5.3.0%3E%20directories%3A%20e.g.%20sources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqttools%20and%20sources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqttools-5.3.0.%20When%20I%20compared%20the%20included%20patches%2C%20they%20are%20mostly%201-to-1%20the%20same%2C%20but%20the%20build%20system%20seems%20to%20prefer%20the%20folder%20with%20the%20version%20over%20the%20generic%20name.%20Unfortunately%20these%20did%20not%20fit%20the%20source%20code%2C%20so%20the%20build%20failed.%20My%20guess%20is%20that%20the%20folders%20names%20with%20the%20version%20string%20are%20older%20and%20were%20the%20only%20one%20when%20you%20tested%20out%20your%20repository.%20At%20a%20later%20point%20the%20other%20ones%20were%20added%20to%20the%20source%20tree%2C%20when%20you%20synced%20with%20the%20master%20repo...%20Too%20bad%20I%20am%20too%20new%20and%20inexperienced%20with%20bitbake%2C%20so%20I%20could%20not%20find%20a%20fix%20on%20my%20own.%20Hence%20my%20(fortunately%20successful)%20try%20to%20use%20the%20master%20repository%20again.%3C%2FFOLDER_BASENAME-5.3.0%3E%3C%2FFOLDER_BASENAME%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENicely%20done!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20just%20saw%20the%20commit%20on%20the%20official%20repo%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fcommit%2Fe9ad98bbed6065989ef4648e724f27275b35b838%22%20title%3D%22https%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fcommit%2Fe9ad98bbed6065989ef4648e724f27275b35b838%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5%2Fcommit%2Fe9ad98bbed6065989ef4648e724f27275b35b838%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThat's%20awesome.%20I%20should%20look%20and%20see%20how%20the%20pros%20did%20it%20%3CIMG%20id%3D%22smileywink%22%20class%3D%22emoticon%20emoticon-smileywink%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-wink.png%22%20alt%3D%22Smiley%20Wink%22%20title%3D%22Smiley%20Wink%22%20%2F%3E%20.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20also%20successfully%20built%20Qt%205.3.0%20from%20the%20main%20repo%20(github.com%2Fmeta-qt5%2Fmeta-qt5.git)%20with%20yocto%201.6.1%20for%20imx53qsb%2C%20but%20haven't%20tested%20it%20out%20yet%20-%20I%20am%20currently%20at%20work%20and%20my%20board%20is%20at%20home...%20Just%20FYI.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EBob%20(and%20everyone%20else%20interested)%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20progressed%20past%20the%20errors...%20Both%20QT%205.3.0%20and%20the%20Toolchain%20SDK%20were%20built%20without%20problems.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBecause%20Qt%205.3.0%20was%20officially%20released%20and%20merged%20into%20the%20main%20repo%2C%20what%20I%20did%20was%20to%20download%20the%20fsl-community-bsp%20using%20repo%2C%20then%20I%20got%20Qt%20meta%20sources%20from%20the%20official%20repository%20on%20GitHub%2C%20instead%20of%20Stephano's%3A%20%5Bgit%7Chttps%5D%3A%2F%2Fgithub.com%2Fmeta-qt5%2Fmeta-qt5.git.%20I%20did%20remove%20the%20sources%2Fmeta-fsl-arm%2Fqt5-layer%2Frecepies-qt%2Fqt5%2Fqtmultimedia_%25.bbappend%20file%2C%20then%20loosly%20followed%20the%20intstuctions%20on%20building%20Qt5%20from%20the%20Wandboard.org%20WIKI%20(%3CA%20href%3D%22http%3A%2F%2Fwiki.wandboard.org%2Findex.php%2FBuilding_Qt5_using_yocto_on_Wandboard%22%20title%3D%22http%3A%2F%2Fwiki.wandboard.org%2Findex.php%2FBuilding_Qt5_using_yocto_on_Wandboard%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EBuilding%20Qt5%20using%20yocto%20on%20Wandboard%20-%20Wandboard%20Wiki%3C%2FA%3E).%20I%20added%20both%20the%20ruby%20and%20meta-qt5%20layers%20to%20bblayers.conf%3B%20skipped%20the%20openssh%20from%20the%20extra%20image%20features%3B%20added%20the%20whole%20of%20install_append%20as%20suggested%3B%20added%20the%20remove%20features%20line%20to%20the%20local.conf.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESince%20this%20was%20not%20the%20repo%20from%20Stephano%2C%20I%20did%20not%20have%20his%20wandboard-image-qt5%20recipe%2C%20but%20building%20the%20minimal%20image%20worked%20for%20testing%20purposes.%20Maybe%20one%20day%20soon%20I%20will%20clone%20his%20repository%20and%2For%20make%20my%20own%20wandboard%20image...%20After%20the%20minimal%20image%20was%20built%2C%20I%20had%20no%20problem%20with%20meta-toolchain-qt5%20from%20the%20main%20repository%20either%20-%20it%20builds%20everything.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETodor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099318%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099318%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20currently%20working%20on%20other%20projects%2C%20so%20I%20have%20not%20had%20time%20to%20look%20at%20the%20meta-toolchain-qt5.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYou%20will%20need%20this%20Qt%20toolchain%20to%20compile%20Qt5%20apps%2C%20as%20the%20fsl-toolchain%20lacks%20the%20Qt%20libraries%20needed%20(and%20qmake).%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYou%20could%20cross%20compile%20Qt%205.3.0%20outside%20of%20Yocto%20and%20use%20those%20libraries%20%2F%20qmake%20to%20compile%20your%20app.%20However%2C%20I%20am%20not%20sure%20which%20would%20be%20easier%2C%20fixing%20meta-toolchain-qt5%20or%20cross%20compilling%20Qt%205.3.0%20from%20source.%26nbsp%3B%20%3CIMG%20id%3D%22smileyhappy%22%20class%3D%22emoticon%20emoticon-smileyhappy%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fi%2Fsmilies%2F16x16_smiley-happy.png%22%20alt%3D%22Smiley%20Happy%22%20title%3D%22Smiley%20Happy%22%20%2F%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20sharing%20your%20work%20and%20the%20reply.%3C%2FP%3E%3CP%3EI'll%20check%20back%20some%20other%20time%20to%20see%20if%20you've%20made%20any%20progress.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20haven't%20had%20any%20luck%20with%20the%20toolchain%20either%2C%20however%20I'm%20currently%20working%20on%20other%20projects.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI'll%20post%20when%20I%20get%20back%20to%20this%2C%20though%20for%20now%20we're%20using%205.2.1.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099315%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20been%20able%20to%20get%20Yocto%20to%20build%20with%20Qt5.3%20following%20your%20instructions%20but%20'bitbake%20meta-toolchain-qt5'%20is%20giving%20me%20a%20small%20mountain%20of%20errors.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20haven't%20been%20able%20to%20cross-compile%20any%20version%20of%20Qt5.X%20using%20poky%201.6.1%20either.%3C%2FP%3E%3CP%3EI%20think%20I'm%20going%20to%20be%20stuck%20with%20Qt5.2.1%20for%20a%20while.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20your%20great%20work!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20have%20a%20problem%20with%20compiling%20the%20sdk%20from%20your%20source.%20%3CSTRONG%3Ebitbake%20wandboard-image-qt5%3C%2FSTRONG%3E%20worked%20as%20expected%2C%20but%20%3CSTRONG%3Ebitbake%20meta-toolchain-qt5%3C%2FSTRONG%3E%20errored%20out%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWARNING%3A%20Failed%20to%20fetch%20URL%20git%3A%2F%2Fqt.gitorious.org%2Fqt%2Fqtbase.git%3Bbranch%3D5.3.0%2C%20attempting%20MIRRORS%20if%20available%3C%2FP%3E%3CP%3EERROR%3A%20Fetcher%20failure%3A%20Unable%20to%20find%20revision%20207598fd8e69be34e8ba2c9db7720cb6003ea114%20in%20branch%205.3.0%20even%20from%20upstream%3C%2FP%3E%3CP%3EERROR%3A%20Function%20failed%3A%20Fetcher%20failure%20for%20URL%3A%20'git%3A%2F%2Fqt.gitorious.org%2Fqt%2Fqtbase.git%3Bbranch%3D5.3.0'.%20Unable%20to%20fetch%20URL%20from%20any%20source.%3C%2FP%3E%3CP%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Fttodorov%2FWork%2Fyocto%2Ffsl-community-bsp-image%2Fbuild%2Ftmp%2Fwork%2Fx86_64-nativesdk-pokysdk-linux%2Fnativesdk-qtbase%2F5.3.0-r1%2Ftemp%2Flog.do_fetch.7617%3C%2FP%3E%3CP%3EERROR%3A%20Task%201024%20(%2Fhome%2Fttodorov%2FWork%2Fyocto%2Ffsl-community-bsp-image%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fnativesdk-qtbase_5.3.0.bb%2C%20do_fetch)%20failed%20with%20exit%20code%20'1'%3C%2FP%3E%3CP%3ENOTE%3A%20Tasks%20Summary%3A%20Attempted%201473%20tasks%20of%20which%201350%20didn't%20need%20to%20be%20rerun%20and%201%20failed.%3C%2FP%3E%3CP%3EWaiting%20for%200%20running%20tasks%20to%20finish%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESummary%3A%201%20task%20failed%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%2Fhome%2Fttodorov%2FWork%2Fyocto%2Ffsl-community-bsp-image%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fnativesdk-qtbase_5.3.0.bb%2C%20do_fetch%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EI%20also%20have%20similar%20problems%20with%20qttools%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWARNING%3A%20Failed%20to%20fetch%20URL%20git%3A%2F%2Fqt.gitorious.org%2Fqt%2Fqttools.git%3Bbranch%3D5.3.0%2C%20attempting%20MIRRORS%20if%20available%3C%2FP%3E%3CP%3EERROR%3A%20Fetcher%20failure%3A%20Unable%20to%20find%20revision%20e7b791c8bb5e64a4c786bf370b10366815af704f%20in%20branch%205.3.0%20even%20from%20upstream%3C%2FP%3E%3CP%3EERROR%3A%20Function%20failed%3A%20Fetcher%20failure%20for%20URL%3A%20'git%3A%2F%2Fqt.gitorious.org%2Fqt%2Fqttools.git%3Bbranch%3D5.3.0'.%20Unable%20to%20fetch%20URL%20from%20any%20source.%3C%2FP%3E%3CP%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Fttodorov%2FWork%2Fyocto%2Ffsl-community-bsp-image%2Fbuild%2Ftmp%2Fwork%2Fx86_64-nativesdk-pokysdk-linux%2Fnativesdk-qttools%2F5.3.0-r0%2Ftemp%2Flog.do_fetch.31774%3C%2FP%3E%3CP%3EERROR%3A%20Task%201037%20(%2Fhome%2Fttodorov%2FWork%2Fyocto%2Ffsl-community-bsp-image%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fnativesdk-qttools_5.3.0.bb%2C%20do_fetch)%20failed%20with%20exit%20code%20'1'%3C%2FP%3E%3CP%3ENOTE%3A%20Tasks%20Summary%3A%20Attempted%201634%20tasks%20of%20which%201583%20didn't%20need%20to%20be%20rerun%20and%201%20failed.%3C%2FP%3E%3CP%3EWaiting%20for%200%20running%20tasks%20to%20finish%3A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESummary%3A%201%20task%20failed%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%2Fhome%2Fttodorov%2FWork%2Fyocto%2Ffsl-community-bsp-image%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fnativesdk-qttools_5.3.0.bb%2C%20do_fetch%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EWhat%20I%20did%20try%2C%20is%20to%20clone%20the%205.3.0%20branches%20of%20qtbase%20and%20qttools%20in%20a%20temp%20directory%20and%20get%20the%20hashes%20of%20the%20last%20commits%20for%20the%20SRCREVs%2C%20which%20produced%20errors.%20It%20did%20pass%20the%20previous%20errors%2C%20but%20produced%20quite%20a%20few%20patching%20and%20compiling%20errors.%20Could%20you%20please%20help%20resolve%20that%3F%20Or%20is%20the%20standard%20fsl%20toolchain%20enough%20to%20compile%20Qt%205.3.0%20apps%20without%20the%20need%20to%20build%20the%20meta-toolchain-qt5%20target%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EThanks%20in%20advance%20for%20everyone's%20help%20and%20input!%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETodor%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099313%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECould%20you%20please%20check%20as%20am%20getting%20same%20error%20after%20git%20pull%20in%20meta-qt5%20and%20bitbake%20core-image-minimal.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EERROR%3A%20qtbase-native%3A%20md5%20data%20is%20not%20matching%20for%20file%3A%2F%2FLICENSE.LGPL%3Bmd5%3D4193e7f1d47a858f6b7c0f1ee66161de%3C%2FP%3E%3CP%3EERROR%3A%20qtbase-native%3A%20The%20new%20md5%20checksum%20is%202abca611d56c23eb99943bde21c80a0d%3C%2FP%3E%3CP%3EERROR%3A%20qtbase-native%3A%20Check%20if%20the%20license%20information%20has%20changed%20in%20%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fi686-linux%2Fqtbase-native%2F5.3.0-r0%2Fgit%2FLICENSE.LGPL%20to%20verify%20that%20the%20LICENSE%20value%20%22GFDL-1.3%20%26amp%3B%20LGPL-2.1%20%7C%20GPL-3.0%22%20remains%20valid%3C%2FP%3E%3CP%3EERROR%3A%20Licensing%20Error%3A%20LIC_FILES_CHKSUM%20does%20not%20match%2C%20please%20fix%3C%2FP%3E%3CP%3EERROR%3A%20Function%20failed%3A%20do_qa_configure%3C%2FP%3E%3CP%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fi686-linux%2Fqtbase-native%2F5.3.0-r0%2Ftemp%2Flog.do_configure.25371%3C%2FP%3E%3CP%3EERROR%3A%20Task%201651%20(%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtbase-native_5.3.0.bb%2C%20do_configure)%20failed%20with%20exit%20code%20'1'%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eok%20thanks..%3C%2FP%3E%3CP%3Eam%20using%20below%20local.conf.Does%20it%20creates%20any%20issues%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3F%3D%20%22%24%7B%40oe.utils.cpu_count()%7D%22%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3F%3D%20%22-j%20%24%7B%40oe.utils.cpu_count()%7D%22%3C%2FP%3E%3CP%3EMACHINE%20%3F%3F%3D%20'imx6qsabreauto'%3C%2FP%3E%3CP%3EDISTRO%20%3F%3D%20'poky'%3C%2FP%3E%3CP%3EPACKAGE_CLASSES%20%3F%3D%20%22package_rpm%22%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%20%22debug-tweaks%22%3C%2FP%3E%3CP%3EUSER_CLASSES%20%3F%3D%20%22buildstats%20image-mklibs%20image-prelink%22%3C%2FP%3E%3CP%3EPATCHRESOLVE%20%3D%20%22noop%22%3C%2FP%3E%3CP%3EBB_DISKMON_DIRS%20%3D%20%22%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BTMPDIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BDL_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20STOPTASKS%2C%24%7BSSTATE_DIR%7D%2C1G%2C100K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BTMPDIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BDL_DIR%7D%2C100M%2C1K%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20ABORT%2C%24%7BSSTATE_DIR%7D%2C100M%2C1K%22%20%3C%2FP%3E%3CP%3EPACKAGECONFIG_pn-qemu-native%20%3D%20%22sdl%22%3C%2FP%3E%3CP%3EASSUME_PROVIDED%20%2B%3D%20%22libsdl-native%22%3C%2FP%3E%3CP%3ECONF_VERSION%20%3D%20%221%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EBB_NUMBER_THREADS%20%3D%20'2'%3C%2FP%3E%3CP%3EPARALLEL_MAKE%20%3D%20'-j%202'%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDL_DIR%20%3F%3D%20%22%24%7BBSPDIR%7D%2Fdownloads%2F%22%3C%2FP%3E%3CP%3EACCEPT_FSL_EULA%20%3D%20%22%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20wayland%22%3C%2FP%3E%3CP%3EEXTRA_IMAGE_FEATURES%20%3D%20%22debug-tweaks%20ssh-server-openssh%20tools-profile%20dbg-pkgs%20tools-debug%22%3C%2FP%3E%3CP%3EIMAGE_INSTALL_append%20%3D%20%22%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20firmware-imx-vpu-imx6q%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20firmware-imx-vpu-imx6d%20%5C%3C%2FP%3E%3CP%3E%22%3C%2FP%3E%3CP%3EIMAGE_INSTALL_append%20%3D%20%22%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cpufrequtils%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20binutils%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20nano%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gdb%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20openssh-sftp-server%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20packagegroup-fsl-gstreamer%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20packagegroup-fsl-tools-testapps%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20packagegroup-fsl-tools-benchmark%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gstreamer%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gst-plugins-base-app%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gst-plugins-base%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gst-plugins-good%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gst-plugins-good-rtsp%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gst-plugins-good-udp%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gst-plugins-good-rtpmanager%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gst-plugins-good-rtp%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gst-plugins-good-video4linux2%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtbase-fonts%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtbase-plugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtbase-tools%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtbase-examples%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtdeclarative%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtdeclarative-plugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtdeclarative-tools%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtdeclarative-examples%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtdeclarative-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtmultimedia%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtmultimedia-plugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtmultimedia-examples%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtmultimedia-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtlocation%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtlocation-plugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtlocation-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtlocation-examples%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsvg%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsvg-plugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsensors%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsensors-plugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsensors-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtimageformats-plugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsystems%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsystems-tools%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsystems-examples%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtsystems-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtscript%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtquick1%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qt3d%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qt3d-examples%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qt3d-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qt3d-tools%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtconnectivity%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtconnectivity-examples%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtconnectivity-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtserialport%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtquickcontrols%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20qtquickcontrols-qmlplugins%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cinematicexperience%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20cairo%20pango%20fontconfig%20freetype%20pulseaudio%20dbus%20taglib%20zlib%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20alsa-lib%20alsa-tools%20alsa-state%20alsa-utils-alsaconf%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20tslib%20evtest%20tslib-conf%20tslib-tests%20tslib-calibrate%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20gcc%20g%2B%2B%20libgcc%20libgcc-dev%20libstdc%2B%2B%20libstdc%2B%2B-dev%20libstdc%2B%2B-staticdev%20%5C%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%22%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-qtbase%20%3D%20%22%20accessibility%20gles2%20openssl%22%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-qtmultimedia%20%3D%20%22%20gstreamer010%20%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESeems%20like%20the%20license%20CHKSUM%20values%20are%20different%20for%20qtbase%20and%20qtconnectivity.%20I%20have%20rolled%20back%20the%20change%20I%20made.%20You%20may%20have%20to%20add%20a%20CHKSUM%20value%20explicitly%20for%20qtconnectivity.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099310%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EERROR%3A%20qtbase-native%3A%20md5%20data%20is%20not%20matching%20for%20file%3A%2F%2FLICENSE.LGPL%3Bmd5%3D4193e7f1d47a858f6b7c0f1ee66161de%3C%2FP%3E%3CP%3EERROR%3A%20qtbase-native%3A%20The%20new%20md5%20checksum%20is%202abca611d56c23eb99943bde21c80a0d%3C%2FP%3E%3CP%3Eam%20getting%20this%20error%20after%20git%20pull%20in%20meta-qt5%20and%20bitbake%20core-image-minimal.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EERROR%3A%20qtbase-native%3A%20Check%20if%20the%20license%20information%20has%20changed%20in%20%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fi686-linux%2Fqtbase-native%2F5.3.0-r0%2Fgit%2FLICENSE.LGPL%20to%20verify%20that%20the%20LICENSE%20value%20%22GFDL-1.3%20%26amp%3B%20LGPL-2.1%20%7C%20GPL-3.0%22%20remains%20valid%3C%2FP%3E%3CP%3EERROR%3A%20Licensing%20Error%3A%20LIC_FILES_CHKSUM%20does%20not%20match%2C%20please%20fix%3C%2FP%3E%3CP%3EERROR%3A%20Function%20failed%3A%20do_qa_configure%3C%2FP%3E%3CP%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fi686-linux%2Fqtbase-native%2F5.3.0-r0%2Ftemp%2Flog.do_configure.22997%3C%2FP%3E%3CP%3EERROR%3A%20Task%201651%20(%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtbase-native_5.3.0.bb%2C%20do_configure)%20failed%20with%20exit%20code%20'1'%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099309%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099309%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI've%20updated%20the%20license%20hash%20in%20my%20qt5.3%20repo.%20Do%20a%20'git%20pull'%20inside%20meta-qt5%20and%20you%20should%20be%20fine%20now.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099308%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eam%20getting%20below%20error.%20Please%20let%20me%20know%20how%20to%20resolve%20this.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EERROR%3A%20qtconnectivity%3A%20md5%20data%20is%20not%20matching%20for%20file%3A%2F%2FLICENSE.LGPL%3Bmd5%3D2abca611d56c23eb99943bde21c80a0d%3C%2FP%3E%3CP%3EERROR%3A%20qtconnectivity%3A%20The%20new%20md5%20checksum%20is%204193e7f1d47a858f6b7c0f1ee66161de%3C%2FP%3E%3CP%3EERROR%3A%20qtconnectivity%3A%20Check%20if%20the%20license%20information%20has%20changed%20in%20%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fqtconnectivity%2F5.3.0-r0%2Fgit%2FLICENSE.LGPL%20to%20verify%20that%20the%20LICENSE%20value%20%22GFDL-1.3%20%26amp%3B%20LGPL-2.1%20%7C%20GPL-3.0%22%20remains%20valid%3C%2FP%3E%3CP%3EERROR%3A%20Licensing%20Error%3A%20LIC_FILES_CHKSUM%20does%20not%20match%2C%20please%20fix%3C%2FP%3E%3CP%3EERROR%3A%20Function%20failed%3A%20do_qa_configure%3C%2FP%3E%3CP%3EERROR%3A%20Logfile%20of%20failure%20stored%20in%3A%20%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fbuild%2Ftmp%2Fwork%2Fcortexa9hf-vfp-neon-poky-linux-gnueabi%2Fqtconnectivity%2F5.3.0-r0%2Ftemp%2Flog.do_configure.21742%3C%2FP%3E%3CP%3EERROR%3A%20Task%20582%20(%2Fhome%2Framakanth%2Ffsl-community-bsp%2Fsources%2Fmeta-qt5%2Frecipes-qt%2Fqt5%2Fqtconnectivity_5.3.0.bb%2C%20do_configure)%20failed%20with%20exit%20code%20'1'%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099307%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099307%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20need%20qtconnectivity%2Cqtlocation%20and%20qtquickcontrols%20apart%20from%20qtmultimedia.%3C%2FP%3E%3CP%3EIf%20I%20add%20below%20to%20local.conf%2C%20whether%20the%20qtmodules%20including%20above%20be%20part%20of%20final%20image%20using%20bitbake%20core-image-minimal%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20wayland%22%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-qtmultimedia%20%3D%20%22%20gstreamer010%20%22%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099306%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20updated%20meta-qt5%20today.%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EYou%20must%20delete%20this%20file%20from%20meta-fsl-arm%3A%3C%2FP%3E%3CP%3Emeta-fsl-arm%2Fqt5-layer%2Frecipes-qt%2Fqt5%2Fqtmultimedia_%25.bbappend%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFreescale%20is%20backporting%20features%20from%20qt%205.3.0%20that%20already%20exist%20if%20using%20this%20layer.%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%20line-height%3A%201.5em%3B%22%3ELet%20me%20know%20if%20you%20see%20any%20more%20issues.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099305%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099305%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eadd%20to%20local.conf%3A%3C%2FP%3E%3CP%3EDISTRO_FEATURES_remove%20%3D%20%22x11%20wayland%22%3C%2FP%3E%3CP%3EPACKAGECONFIG_append_pn-qtmultimedia%20%3D%20%22%20gstreamer010%20%22%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Ecore-image-minimal%20builds%20fine%20for%20me..%3C%2FP%3E%3CP%3EBut%20without%20adding%20qtmodules%20in%20local.conf%2C%20am%20wondering%20whether%20if%20it%20would%20appear%20in%20image.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1099304%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Qt%205.3.0%20release%20on%20i.MX6%20using%20fsl-community-bsp%20and%20meta-qt5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1099304%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20sharing%20this!%3C%2FP%3E%3CP%3EI'm%20in%20the%20process%20of%20switching%20back%20to%20Yocto%20after%20a%20brief%20stint%20working%20with%20LTIB.....%20I'll%20let%20you%20know%20how%20this%20works%20on%20my%20system.%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎06-05-2014 08:25 AM
Updated by:
