What firmware does PN532 C6 chip have by default?
alexzdr_job
PN532 C6 has NFCIP1 compatible firmware.
Is this firmware factory default or should it be flashed separately?
IvanRuiz
This is an old reader which is not recommended for new designs, but as far as I can understand from the documentation, it shall be flashed what it is required from the NFC reader to perform.
BR,
Ivan.
