Running DES-ECB with mmCAU on MKM34Z256VLL7 controller generates HardFault upon executing 'cau_des_encrypt' API.
shaiknisar
Fresh Out Contributor
Hey Hi all,.
I'm working with MKM34Z256VLL7 controller. I have referred to the example code provided by the NXP for the mmCAU module, and i'm trying to replicate the same.
   => I'm trying to use the TDES API provided in the example code. For this i've created a new IAR Build and tried to replicate the way it is done in the example code.
   => The problem here i face is that the moment i try to execute the 'cau_des_encrypt' API it triggers 'Hard Fault'. Can someone please help me resolve this issue. I have been trying to resolve this since a week.
NOTE: I have added the IAR Build.
Tags (3)
shaiknisar
Resolved the Hard fault issue.
The clock for the mmCAU module wasn't getting enabled.
