Simulink Freezes With Build Command
ali_terro
Hello everyone,
i am having a Problem with the build command from Simulink. i am using the S32K144 Motor Control development kit and i followed the Installation procedure writen in the eviroment Setup of the PMSM Control Course but when i build the model to verify the Software and Hardware Installation Simulink just freezes without giving any error or something.
has anyone encoutered this Problem? if so please provide some Information on how to fix.
i am using matlab 2018b and 2018 R1 Toolbox.
Best Regards
Ali Terro
sparkee
Contributor V
As luck would have it, I bricked the board today.  It would not come out of bootloader mode.  It wouldn't take new bootloader firmware.  It wouldn't respond to the Mutlilink Universal programmer.  It wouldn't respond to the Kinetis software to fix the bricking.  12V power, USB power, didn't matter.  I messed with it for 3 hours, pouring over every post about a bricked device.  I was finally able to get the BOOTUPDATEAPP to take, then it took the 1.19 bootloader firmware, now everything is working great on USB power and OpenSDA is programming from Simulink.  Like it's fresh out of the box again.  I'm so happy slash worn out.
constantinrazva
Hello sparkee,
So are you finally able to program the EVB directly from Simulink? That would be great news to hear, knowing for how long this issue has persisted.
Kind regards,
Razvan.
sparkee
Contributor V
I'm back to a bricked unit.  It worked so well all day.  I left my computer for a while and it went to sleep.  When I came back, the board was no longer communicating.  I unplugged and replugged and it would no longer recognize the device.  I immediately started in boot mode and dragged over the BOOTUPDATEAPP file.  When I cycle the plug it isn't recognized by my computer and I get 2 green LEDs and 1 red LED.  No SDA drive on my computer at all.  I've tried it 3 times just to be sure.
sparkee
Contributor V
Yes everything seems to be working great on this board.  I didn't do anything that we had not tried previously so I'm not sure why it works well now but I'm happy that it is.  I may try again with the second board to see if I get the same results.  Thank you for your support!
ali_terro
search
Verify_SW_HW_Setup
 Build
4 5
08:36 AM Elapsed: 1:02 min
### Starting build procedure for model: Verify_SW_HW_Setup
### Generating code and artifacts to 'Model specific' folder structure
 Code Generation
2 5
Elapsed: 55 sec
### Generating code into build folder: C:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw
### Invoking Target Language Compiler on Verify_SW_HW_Setup.rtw
### Using System Target File: C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\mbdtbx_s32k14x\mbdtbx_s32k14x\mbd_s32k14.tlc
### Using Model-Based Design Toolbox for S32K1xx Series 2018.R1 (R2016b-R2018a) 23-Jul-2018
Warning: Directory already exists. [5 similar]
### Loading TLC function libraries
### Initial pass through model to cache user defined code
### Caching model source code
### Writing header file Verify_SW_HW_Setup_types.h
### Writing header file Verify_SW_HW_Setup.h
### Writing header file freemaster_cfg.h
### Writing header file freemaster_interface_init.h
### Writing source file freemaster_interface_init.c
### Writing header file rtwtypes.h
### Writing source file Verify_SW_HW_Setup.c
### Writing header file Verify_SW_HW_Setup_private.h
### Writing source file mbd_main.c
### TLC code generation complete.
CGIR assertion 'begin != 0' failed in 'b:\matlab\toolbox\coder\trace\src\trace\traceutil.cpp:302'
[  0] 0x000000010ba9eabf                           bin\win64\libmwtrace.dll+00191167 mwboost::archive::codecvt_null<wchar_t>::codecvt_null<wchar_t>+00002783
[  1] 0x000000010bb4761b                           bin\win64\libmwtrace.dll+00882203 coder::trace::TraceInfoBuilder::setTraceDelim+00088731
[  2] 0x000000010bb3d8c0                           bin\win64\libmwtrace.dll+00841920 coder::trace::TraceInfoBuilder::setTraceDelim+00048448
[  3] 0x000000010bb1fbf7                           bin\win64\libmwtrace.dll+00719863 coder::trace::TraceInfoBuilder::extractTraceInfo+00000263
[  4] 0x000000010bb66706                           bin\win64\libmwtrace.dll+01009414 coder::trace::TraceInfoBuilder::setTraceDelim+00215942
[  5] 0x0000000023af3c60                        bin\win64\pgo\mcos_impl.dll+00408672
[  6] 0x0000000023af3232                        bin\win64\pgo\mcos_impl.dll+00406066
[  7] 0x0000000023af234b                        bin\win64\pgo\mcos_impl.dll+00402251
[  8] 0x0000000023af0d12                        bin\win64\pgo\mcos_impl.dll+00396562
[  9] 0x0000000023b46f30                        bin\win64\pgo\mcos_impl.dll+00749360
[ 10] 0x0000000023d43585                        bin\win64\pgo\mcos_impl.dll+02831749 mwboost::serialization::singleton_module::unlock+01534417
[ 11] 0x0000000023d4cf01                        bin\win64\pgo\mcos_impl.dll+02871041 mwboost::serialization::singleton_module::unlock+01573709
[ 12] 0x0000000016993655                                 bin\win64\mcos.dll+00144981 omDirectCallMethod+00000069
[ 13] 0x000000001cef75c2                 bin\win64\pgo\libmwlxeindexing.dll+00357826 MathWorks::lxe::MatrixModuleImplementation::SetHeterogeneousArray+00014702
[ 14] 0x000000001cf78936                 bin\win64\pgo\libmwlxeindexing.dll+00887094 MathWorks::lxe::assign_paren_shared_xvalue_ptr_uninitialized_to_struct+00006890
[ 15] 0x000000001ceac70f                 bin\win64\pgo\libmwlxeindexing.dll+00050959 MathWorks::lxe::at_rbrace_nargout+00006831
### Processing Template Makefile: C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\mbdtbx_s32k14x\mbdtbx_s32k14x\mbd_s32k14.tmf
### Verify_SW_HW_Setup.mk which is generated from C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\mbdtbx_s32k14x\mbdtbx_s32k14x\mbd_s32k14.tmf is up to date
### Building Verify_SW_HW_Setup: .\Verify_SW_HW_Setup.bat
C:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw>set MATLAB=C:\KBApps\MATLAB\R2018b
C:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw>"C:\KBApps\MATLAB\R2018b\bin\win64\gmake" -f Verify_SW_HW_Setup.mk COPY_MDLREF_INCLUDES=0 GENERATE_ERT_S_FUNCTION=0 INCLUDE_MDL_TERMINATE_FCN=1 COMBINE_OUTPUT_UPDATE_FCNS=1 MULTI_INSTANCE_CODE=0 INTEGER_CODE=0 ISPROTECTINGMODEL=NOTPROTECTING
Cleaning...
RELATIVE_PATH_TO_ANCHOR is ..
==== Removing object files from build directory ====
Copying necessary files to build directory...
Compiler details : "C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o SetupFiles -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"
Assembler details : "C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -g -x assembler-with-cpp -o SetupFiles
Product: Verify_SW_HW_Setup.mot
Build product type: executable
Building file startup_S32K144.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -g -x assembler-with-cpp -o startup_S32K144.o startup_S32K144.s
Building file Verify_SW_HW_Setup.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o Verify_SW_HW_Setup.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    Verify_SW_HW_Setup.c
Building file clock_S32K1xx.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o clock_S32K1xx.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    clock_S32K1xx.c
Building file clock_manager.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o clock_manager.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    clock_manager.c
Building file edma_driver.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o edma_driver.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    edma_driver.c
Building file edma_hw_access.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o edma_hw_access.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    edma_hw_access.c
Building file edma_irq.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o edma_irq.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    edma_irq.c
Building file freemaster_S32K14x.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o freemaster_S32K14x.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    freemaster_S32K14x.c
Building file freemaster_appcmd.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o freemaster_appcmd.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    freemaster_appcmd.c
Building file freemaster_interface_init.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o freemaster_interface_init.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    freemaster_interface_init.c
Building file freemaster_protocol.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o freemaster_protocol.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    freemaster_protocol.c
Building file freemaster_rec.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o freemaster_rec.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    freemaster_rec.c
Building file freemaster_scope.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o freemaster_scope.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    freemaster_scope.c
Building file freemaster_serial.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o freemaster_serial.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    freemaster_serial.c
Building file freemaster_sfio.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o freemaster_sfio.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    freemaster_sfio.c
Building file freemaster_tsa.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o freemaster_tsa.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    freemaster_tsa.c
Building file interrupt_manager.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o interrupt_manager.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    interrupt_manager.c
Building file lpit_driver.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o lpit_driver.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    lpit_driver.c
Building file lpuart_driver.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o lpuart_driver.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    lpuart_driver.c
Building file lpuart_hw_access.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o lpuart_hw_access.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    lpuart_hw_access.c
Building file lpuart_irq.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o lpuart_irq.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    lpuart_irq.c
Building file mbd_main.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o mbd_main.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    mbd_main.c
Building file osif_baremetal.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o osif_baremetal.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    osif_baremetal.c
Building file pins_driver.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o pins_driver.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    pins_driver.c
Building file pins_port_hw_access.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o pins_port_hw_access.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    pins_port_hw_access.c
Building file power_manager.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o power_manager.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    power_manager.c
Building file power_manager_S32K1xx.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o power_manager_S32K1xx.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    power_manager_S32K1xx.c
Building file power_smc_hw_access.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o power_smc_hw_access.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    power_smc_hw_access.c
Building file s32k_clock_init.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o s32k_clock_init.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    s32k_clock_init.c
Building file startup.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o startup.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    startup.c
Building file system_S32K144.o...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -c -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O1 -g -gstrict-dwarf -DARM_MATH_CM4 -D__FPU_PRESENT=1 -D__FPU_USED=1 -D__NVIC_PRIO_BITS=FEATURE_NVIC_PRIO_BITS -o system_S32K144.o -DCPU_S32K144HFT0VLLT -I. -I.. -I.. -I"C:\KBApps\MATLAB\R2018b\simulink\include" -I"C:\KBApps\MATLAB\R2018b\extern\include" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src" -I"C:\KBApps\MATLAB\R2018b\rtw\c\libsrc" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\tcpip" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\serial" -I"C:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\custom" -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1 -IC:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw -IC:\KBApps\MATLAB\R2018b\extern\include -IC:\KBApps\MATLAB\R2018b\simulink\include -IC:\KBApps\MATLAB\R2018b\rtw\c\src -IC:\KBApps\MATLAB\R2018b\rtw\c\src\ext_mode\common -IC:\KBApps\MATLAB\R2018b\rtw\c\ert  -I"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/include"    -I"./common" -I"./inc" -I"./src/clock/S32K1xx" -I"./src/sim/S32K144" -I"./src/power/S32K1xx" -I"./S32K144/include" -I"../common" -I"../inc" -I"../src/clock/S32K1xx" -I"../src/sim/S32K144" -I"../src/power/S32K1xx" -I"../S32K144/include"    system_S32K144.c
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -Xlinker --gc-sections -Xlinker --defsym=__ram_vector_table__=1 -TS32K14x.ld startup_S32K144.o Verify_SW_HW_Setup.o clock_S32K1xx.o clock_manager.o edma_driver.o edma_hw_access.o edma_irq.o freemaster_S32K14x.o freemaster_appcmd.o freemaster_interface_init.o freemaster_protocol.o freemaster_rec.o freemaster_scope.o freemaster_serial.o freemaster_sfio.o freemaster_tsa.o interrupt_manager.o lpit_driver.o lpuart_driver.o lpuart_hw_access.o lpuart_irq.o mbd_main.o osif_baremetal.o pins_driver.o pins_port_hw_access.o power_manager.o power_manager_S32K1xx.o power_smc_hw_access.o s32k_clock_init.o startup.o system_S32K144.o    -specs=nosys.specs --sysroot=C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/arm-none-eabi/newlib -lm "S32K14x_AMMCLIB.a" -Wl,-Map,Verify_SW_HW_Setup.map -o Verify_SW_HW_Setup.elf
### Created executable: Verify_SW_HW_Setup.mot
Generating S-record...
"C:\Users\terroa\Documents\MATLAB\Add-Ons\Toolboxes\NXP_MBDToolbox_S32K1xx\tools\gcc-6.3-arm32-eabi/bin/arm-none-eabi-objcopy" -O srec Verify_SW_HW_Setup.elf Verify_SW_HW_Setup.mot
Created S-record: Verify_SW_HW_Setup.mot
Building target all
*** Created executable: Verify_SW_HW_Setup.mot
### Successful completion of build procedure for model: Verify_SW_HW_Setup
COPY CATCH: The system cannot find the file specified.
: >> C:\Users\terroa\Documents\MATLAB\M1_2018.R1\Verify_SW_HW_Setup_mbd_rtw\Verify_SW_HW_Setup.mot
COPY CATCH: The specified network resource or device is no longer available.
Can't download the file to the board.
Daniel_Popa
Hi [email protected]‌,
Your model builds correctly since the *.mot file is getting generated.
Your problem is when Simulink tries to download the  *.mot file to the actual target (S32K14x EVB).
I do not know how your system is configured, but please try to copy manually the *.mot file into Mass Storage Drive mapped when you plug it the board.
ali_terro
I tried coppying the .mot file but it didn't work. It requires permission to edit the mass storage.
How can i solve that?
Best Regards
Ali
Daniel_Popa
That seems to be an issue with your PC/System Admin.
Perhaps, your company policies prevent you from using USB connected devices on company PCs.
The best approach your be to talk with your System Administrator about this, and ask him to grant you rights to use the USB connected devices.
You can refer to: https://www.isumsoft.com/windows-10/how-to-disable-use-of-usb-storage-devices-in-windows-10.html
Hope this helps to resolve your issue.
The alternative would be to download the application over the UART, using BootLoader. This requires you to program a Boot Loader Flash Image into the MCU over JTAG first. There a couple of examples showing the procedure in the ..\S32_Examples\s32k14x\flash_bam
sparkee
Contributor V
I have a similar issue but I am able to drag the mot file over and program.  When I first got the board I was able to use use the download code after build option.  After a few days it started working sporadically.  Sometimes I could unplug and restart Simulink and get it working and sometimes I had to plug in after Simulink had started.  Nothing solid would fix it though.  After reflashing the bootloader multiple times and jumping through a few other hoops I was able to get the board to take a mot file manually every time but still doesn't allow me to download code after build.
My error message is the same.  Simulink locks up at the successful build line until I unplug the board.  After unplug, I get the same error message and Simulink is no longer locked up.
mariuslucianand
Hello sparkee‌,
If you try to uncheck the Download Code after Build option from the Config Block, the Simulink still freezes? I am trying to understand if the problem is related with the code generation, building or code deployment.
Marius
sparkee
Contributor V
No, everything runs as expected when unchecked.  After successful build I can drag the mot file into the EVB drive and it programs.
mariuslucianand
Hi sparkee‌,
So the problem is related with the deployment, when the toolbox copies the .mot file on the selected Open SDA Drive Name. Have you selected the right Open SDA Drive Name?
Marius
sparkee
Contributor V
I know you have to ask the dummy questions first to make sure the computer is plugged in etc but I've already been through the easy stuff in a previous thread https://community.nxp.com/thread/511465.
At one point after multiple bootloader flashes I did have a jumper that didn't make it back to the right place.  I think that was what caused the 4099 error although sometimes it would still work.
If I have my EVB drive folder open, I can watch the mot file populate.  No other files change.  LASTSTAT says "READY”.  The board has a flashing green LED (D2) but, strangely, after 5 flashes, the red LED (D1) and the RGB (D11) flash twice very quickly at the same time, then the pattern repeats.
Map,adc_pdb_trigger_s32k14x.map -o adc_pdb_trigger_s32k14x.elf ### Created executable: adc_pdb_trigger_s32k14x.mot Generating S-record... "C:\MATLAB\gcc-6.3-arm32-eabi/bin/arm-none-eabi-objcopy" -O srec adc_pdb_trigger_s32k14x.elf adc_pdb_trigger_s32k14x.mot Created S-record: adc_pdb_trigger_s32k14x.mot Building target all *** Created executable: adc_pdb_trigger_s32k14x.mot ### Successful completion of build procedure for model: adc_pdb_trigger_s32k14x
mariuslucianand
Hello sparkee‌,
On the S32K144EVB there are four jumpers, that have the following functionalities. Probably the one you are referring here is the J104.
The led D2 is the Led Status Indicator for the OpenSDA. The actual states of the led patterns are described in the Table 2 (page 8) of this file https://www.nxp.com/docs/en/user-guide/OPENSDAUG.pdf .
I would suggest to reflash the OpenSDA Applicationas explained by the section 2.2 from the referenced document.
Hope this helps,
Marius
sparkee
Contributor V
Nothing in the LED Status Indicator Table is similar to my LED flash so that doesn't help me.  I'm attempting to reflash the bootloader despite that action having no results previously.  Before attempting the reflash I was running version 1.19 firmware according to the SDAINFO.htm file.  I'm using the info here since the OPENSDAUG.pdf file you referenced does not contain adequate directions to reflash.
Unfortunately, when I download the latest firmware here and program the board, I get the exact same behavior I described previously, which is not covered in the LED Table you provided.
In past efforts to fix this issue, I have attempted to flash version 1.18 firmware but that also did not fix the issue.
Error with either firmware:
: >> C:\MATLAB\Projects\Power Control Module\adc_pdb_trigger_s32k14x_mbd_rtw\adc_pdb_trigger_s32k14x.mot
LASTSTAT.TXT says "READY"
