MCU Config Tool V6 "Communication Error" opening .MEX
larry_ciummo
Installed V6 of MCU Config tool and tried to open an existing MEX file. Got Communications Error. Check your internet connection and try again.
My internet is ok.  I heard this error may be related to an unsupported mcu, but we're using K65.
It may be that this mex was created with a V5 Mcu config tool.
LArry
larry_ciummo
I'll put V6 back later, but below is the data for V5.  You install your own Java with the tool install and provide the path to it?
I have a newer Java for Eclipse but I don't see it on the path, so I don't think you'd pick it up over yours.
:\nxp\MCUX_CFG_v5\bin\tools.exe
-name
Tools
--launcher.library
C:\nxp\MCUX_CFG_v5\bin\\plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.551.v20171108-1834\eclipse_1630.dll
-startup
C:\nxp\MCUX_CFG_v5\bin\\plugins/org.eclipse.equinox.launcher_1.4.0.v20161219-1356.jar
--launcher.overrideVmargs
-data
@user.home/.nxp/nxp_conf_workspace_v5.0
C:\Users\lciummo\Work Folders\Desktop\MK65FN2M0xxx18_MWIR_vA2.mex
-vm
C:\nxp\MCUX_CFG_v5\bin\jre\bin\server\jvm.dll
eclipse.home.location=file:/C:/nxp/MCUX_CFG_v5/bin/
eclipse.launcher=C:\nxp\MCUX_CFG_v5\bin\tools.exe
eclipse.launcher.name=Tools
[email protected]/../p2
eclipse.p2.profile=DefaultProfile
eclipse.product=com.nxp.swtools.framework.kinetis.product
eclipse.startTime=1562596658349
eclipse.stateSaveDelayInterval=30000
eclipse.vm=C:\nxp\MCUX_CFG_v5\bin\jre\bin\server\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.8
-Xms256m
-Xmx868m
-Djava.util.logging.config.file=configuration/logging.properties
-Djava.net.useSystemProxies=true
-Dcom.nxp.restapi.server=http://mcuxpresso.nxp.com
-Dcom.nxp.restapi.familyfilter=
-Dupdate.site=http://mcuxpresso.nxp.com/staticdata/updates/kex_5.0/
-Dcom.nxp.product.dirname=MCUX_Tools
-Dcom.nxp.product.name=MCUXpresso Configuration Tools
-Djava.class.path=C:\nxp\MCUX_CFG_v5\bin\\plugins/org.eclipse.equinox.launcher_1.4.0.v20161219-1356.jar
equinox.init.uuid=true
equinox.use.ds=true
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
gosh.args=--nointeractive
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.version=52.0
java.endorsed.dirs=C:\nxp\MCUX_CFG_v5\bin\jre\lib\endorsed
java.ext.dirs=C:\nxp\MCUX_CFG_v5\bin\jre\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\nxp\MCUX_CFG_v5\bin\jre
java.io.tmpdir=C:\Users\lciummo\AppData\Local\Temp\
java.library.path=C:\nxp\MCUX_CFG_v5\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:/nxp/MCUX_CFG_v5/bin/jre/bin/server;C:/nxp/MCUX_CFG_v5/bin/jre/bin;C:/nxp/MCUX_CFG_v5/bin/jre/lib/amd64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\SafeNet\Authentication\SAC\x64;C:\Program Files\SafeNet\Authentication\SAC\x32;C:\Program Files (x86)\CheckPoint\Endpoint Security\Endpoint Common\bin;C:\Program Files\Perforce\;C:\Program Files\PuTTY\;C:\Program Files\Git\cmd;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\bin;C:\Users\lciummo\AppData\Local\Microsoft\WindowsApps;;C:\Users\lciummo\Work Folders\Desktop;;.
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.8.0_181-b13
java.specification.name=Java Platform API Specification
java.specification.vendor=Oracle Corporation
java.specification.version=1.8
java.vendor=Oracle Corporation
java.vendor.url=http://java.oracle.com/
java.vendor.url.bug=http://bugreport.sun.com/bugreport/
java.version=1.8.0_181
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Oracle Corporation
java.vm.specification.version=1.8
java.vm.vendor=Oracle Corporation
java.vm.version=25.181-b13
line.separator=
liborukropec
Hello Larry,
yes, MEX from v5 should work in v6 (not always vice versa). In order to help, could you please share the log file from directory location I wrote in previous post? Otherwise I do not know how to help.
Also you can paste what exact processor it is, to double check it is supported by the latest V6? MK65FN2M0xxx18 or MK65FX1M0xxx18? If am I correct both are supported by V5 and V6.
Libor
larry_ciummo
This may be the last V6 log - the time looks right...
Jul 05, 2019 12:01:59 PM com.nxp.swtools.kex.api.internal.MfactApiClient listProcessors
SEVERE: [NETWORK] listProcessors - server not available or other error
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:316)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1639)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:965)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1564)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492)
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:347)
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpBinaryResponseWithRedirect(HttpHelper.java:156)
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpBinaryResponse(HttpHelper.java:100)
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpBinaryResponse(HttpHelper.java:193)
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpGetBinaryResponse(HttpHelper.java:207)
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpGetXmlResponse(HttpHelper.java:80)
at com.nxp.swtools.kex.api.internal.MfactApiClient.listProcessors(MfactApiClient.java:122)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.listProcessors(KExProcessorsProvider.java:287)
at com.nxp.swtools.provider.processors.OnlineDataInfo.lambda$0(OnlineDataInfo.java:42)
at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:184)
at java.util.Spliterators$ArraySpliterator.forEachRemaining(Spliterators.java:948)
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)
at java.util.stream.ForEachOps$ForEachTask.compute(ForEachOps.java:291)
at java.util.concurrent.CountedCompleter.exec(CountedCompleter.java:731)
at java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:289)
at java.util.concurrent.ForkJoinPool$WorkQueue.runTask(ForkJoinPool.java:1056)
at java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1692)
at java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:157)
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:397)
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:302)
at sun.security.validator.Validator.validate(Validator.java:262)
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:324)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:229)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:124)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1621)
... 30 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141)
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126)
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280)
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:392)
... 36 more
Jul 05, 2019 12:01:59 PM com.nxp.swtools.kex.api.internal.MfactApiClient listKits
SEVERE: [NETWORK] listKits - server not available or other error
at com.nxp.swtools.kex.api.internal.MfactApiClient.listKits(MfactApiClient.java:417)
at com.nxp.swtools.provider.processors.KExProcessorsProvider.listKits(KExProcessorsProvider.java:368)
at com.nxp.swtools.provider.processors.OnlineDataInfo.lambda$2(OnlineDataInfo.java:50)
... 30 more
... 36 more
Jul 05, 2019 12:16:52 PM com.nxp.swtools.kex.analytics.DesktopAnalytics uploadAnalytics
WARNING: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1334)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1309)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getOutputStream(HttpsURLConnectionImpl.java:259)
at com.nxp.swtools.kex.api.internal.HttpHelper.getHttpBinaryResponseWithRedirect(HttpHelper.java:150)
at com.nxp.swtools.kex.analytics.DesktopAnalytics.uploadAnalytics(DesktopAnalytics.java:249)
at com.nxp.swtools.rcp.analytics.RcpAnalyticsFactory.uploadAnalytics(RcpAnalyticsFactory.java:129)
at com.nxp.swtools.framework.Application.uploadAnalytics(Application.java:508)
at com.nxp.swtools.framework.ApplicationWorkbenchWindowAdvisor.postWindowClose(ApplicationWorkbenchWindowAdvisor.java:371)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowClosed(WorkbenchWindow.java:1728)
at org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:2051)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:1645)
at org.eclipse.ui.internal.WorkbenchWindow.lambda$2(WorkbenchWindow.java:1670)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:72)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1670)
at org.eclipse.ui.internal.Workbench$10.run(Workbench.java:1145)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1128)
at org.eclipse.ui.internal.Workbench.lambda$4(Workbench.java:1410)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1410)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:1383)
at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:1641)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1679)
at org.eclipse.ui.internal.WorkbenchWindow$4.close(WorkbenchWindow.java:535)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.lambda$4(WBWRenderer.java:577)
at org.eclipse.swt.events.ShellListener$2.shellClosed(ShellListener.java:102)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:102)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4131)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1055)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1064)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations.java:284)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.java:1574)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4770)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:348)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1502)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2153)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4770)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(Native Method)
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:508)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4867)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(Native Method)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3545)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:339)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:563)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:151)
at com.nxp.swtools.framework.Application.start(Application.java:335)
at com.nxp.swtools.framework.Application.start(Application.java:282)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:595)
at org.eclipse.equinox.launcher.Main.run(Main.java:1501)
... 91 more
... 97 more
Jul 05, 2019 12:37:49 PM com.nxp.swtools.configuration.PEConfiguration mkdirsWritable
WARNING: Cannot create data directory writable for everyone
Jul 05, 2019 12:39:16 PM com.nxp.swtools.clocks.data.parser.ClockSignalInterface <init>
WARNING: OSCERCLK_UNDIV: missing output group type. Peripheral will be used instead.
Jul 05, 2019 12:39:17 PM com.nxp.swtools.expert.processordb.DatabaseXmlLoader logProblem
WARNING: 'description' shall not be empty in register[ANACTRL].bit_field[EMPH_PULSE_CTRL].bit_field_value[ANACTRL_EMPH_PULSE_CTRL_0b01]
WARNING: 'description' shall not be empty in register[ANACTRL].bit_field[EMPH_PULSE_CTRL].bit_field_value[ANACTRL_EMPH_PULSE_CTRL_0b10]
WARNING: 'description' shall not be empty in register[ANACTRL_SET].bit_field[EMPH_PULSE_CTRL].bit_field_value[ANACTRL_SET_EMPH_PULSE_CTRL_0b01]
WARNING: 'description' shall not be empty in register[ANACTRL_SET].bit_field[EMPH_PULSE_CTRL].bit_field_value[ANACTRL_SET_EMPH_PULSE_CTRL_0b10]
WARNING: 'description' shall not be empty in register[ANACTRL_CLR].bit_field[EMPH_PULSE_CTRL].bit_field_value[ANACTRL_CLR_EMPH_PULSE_CTRL_0b01]
WARNING: 'description' shall not be empty in register[ANACTRL_CLR].bit_field[EMPH_PULSE_CTRL].bit_field_value[ANACTRL_CLR_EMPH_PULSE_CTRL_0b10]
WARNING: 'description' shall not be empty in register[ANACTRL_TOG].bit_field[EMPH_PULSE_CTRL].bit_field_value[ANACTRL_TOG_EMPH_PULSE_CTRL_0b01]
WARNING: 'description' shall not be empty in register[ANACTRL_TOG].bit_field[EMPH_PULSE_CTRL].bit_field_value[ANACTRL_TOG_EMPH_PULSE_CTRL_0b10]
Jul 05, 2019 12:39:18 PM com.nxp.swtools.clocks.data.model.SettingsConfig getSettingValue
WARNING: Setting value of "MCG::C2[RANGE].bitField" has not been initialized yet.
liborukropec
Hello Larry,
this is very strange. Could you please
1) Install MCUX Config Tools V6 and edit c:\nxp\MCUX_CFG_v6\bin\tools.ini and look for this line:
-Dcom.nxp.restapi.server=https://mcuxpresso.nxp.com
And change the https => http
Launch the application and test whether it is able to download data
2) If it works, either the wrong java is used, or there's MITM (Man in the middle attack) - e.g. company proxy/firewall.
To check that the correct java is used, launch the tools and use main menu  "Help | About". In the dialog click "Details" button and post here this part, where the used java VM is described:
Thank you,
Libor
larry_ciummo
Added V6 back to my system. Ran as it and confirmed still gets “communications error”.
Changed the tool.ini rest api server to not use https. Tool downloaded required components and started ok.
Here’s the about details… Looks like your Java.
To me this looks like some sort of cert trust validation failure.
      • Date: Tuesday, July 9, 2019 at 10:49:31 AM Eastern Daylight Time
      • About MCUXpresso Config Tools:
Version and Build id: 6.0.0.201905210938
Installed tools:
Project Cloner (2.0)
Pins (6.0)
Clocks (6.0)
Peripherals (6.0)
TEE (1.0)
Device Configuration (2.0)
Locally installed data:
C:\ProgramData\NXP\mcu_data_v6
Processors:
LPC55S66 (6.0.0) - LPC LPC5500
LPC55S69 (6.0.0) - LPC LPC5500
MIMXRT1052xxxxB (6.0.0) - i.MX RT
MK64FN1M0xxx12 (6.0.0) - Kinetis K
MK65FN2M0xxx18 (6.0.1) - Kinetis K
Boards:
FRDM-K64F (6.0.0)
IMXRT1050-EVKB (6.0.0)
LPCXpresso55S69 (6.0.0)
Components:
adc12_5324d28dd0212c08055a9d9cd4317082 (6.0.0)
adc12_582213dfbd3d6bcee209acc93ebafd79 (6.0.0)
adc16_7d827be2dc433dc756d94a7ce88cbcc5 (6.0.0)
adc_12b1msps_sar_6a490e886349a7b2b07bed10ce7b299b (6.0.0)
adc_etc_f54f0f22e1814a87101dbc3d3da0f030 (6.0.0)
aoi_5a2efbfd7a8a5208f8f552077e2b4ded (6.0.0)
cmp_306724f57b92dbe1771f1514089d2b18 (6.0.0)
cmt_4b415df0953c334612ffa4b1d9ce84dd (6.0.0)
cop_62effe547bc33f38e0c0666f7c5b3ba5 (6.0.0)
crc_9fd5aeb8f898a23808d5f975e5443f11 (6.0.0)
csi_3739ec1355c7b915be929f3b7e35095b (6.0.0)
csi_b2cf1faba8074e676ac4be93ec552c5a (6.0.0)
ctimer_c8b90232d8b6318ba1dac2cf08fb5f4a (6.0.0)
dac_a54f338a6fa6fd273bc89d61f5a3b85e (6.0.0)
dcp_95a1068fdf77eaec189146622e54f5e0 (6.0.0)
dcp_972afb0e5bdd98ba89e5860deaf0bf5c (6.0.0)
dma_cb8220597343022981727d8655725baf (6.0.0)
dmic_409d8a3828da008fe0c747329e3bf6f9 (6.0.0)
dmic_61c72b586a16e9c1db868b8108e5db02 (6.0.0)
dspi_305e5b03c593d065f61ded8061d15797 (6.0.0)
edma_a23fca76a894e1bcdf9d01a687505ff9 (6.0.1)
eeprom_900c1d52ed631f61118a245f4c5f8277 (6.0.0)
eeprom_fade05ae71ed62ec5506b51976e7a854 (6.0.0)
elcdif_1c39bcb43ed1a24bc8980672c7378576 (6.0.0)
enc_a31ae546b0cbfc3aa2c35851e1fcb3b8 (6.0.0)
ewm_4792127f422c23cc3392826dba86b9fd (6.0.0)
flexbus_701bf8bb8d697a7ef61170eed6ff2742 (6.0.0)
flexbus_c0f98ce230f06c38b26b546b16ee96cc (6.0.0)
flexcan_10d80efac19b25dcd240244aae88dca0 (6.0.0)
flexcan_ba45456ec815807245205237e2bf425b (6.0.0)
flexcan_d4764a197c0db35c88f36862312557e4 (6.0.0)
flexcomm_i2c_567d1a9d97c12e5d39b00259c3436dc4 (6.0.0)
flexcomm_i2s_1c5c11aa8e597614e0f70b372f33ba24 (6.0.0)
flexcomm_i2s_58c65abc2443943ac0fcda85b0d62d5f (6.0.0)
flexcomm_spi_fa73bcfbc0a2fd3b8c6ba5b0b1f1446f (6.0.0)
flexcomm_usart_c0a0c6d3d3ef57701b439b00070052a8 (6.0.0)
flexcomm_usart_fcc110cc6b16332e9dfd9e0df675e21f (6.0.0)
flexio_i2c_master_b1c6d75a13c223349acb4bdd6d771f21 (6.0.0)
flexio_i2s_a594b82e98584b93cd0e9c6b6e73df7f (6.0.0)
flexio_spi_d67d6584d62b130dba246fa5abb61949 (6.0.0)
flexio_uart_fc94dc0ace2887e1e4712084856919fa (6.0.0)
ftm_04a15ae4af2b404bf2ae403c3dbe98b3 (6.0.0)
ftm_5e037045c21cf6f361184c371dbbbab2 (6.0.0)
gint_f9751e057606760f4d52cb811c360fa8 (6.0.0)
gpio_be9de87e5addb6b0f416d9acbab34797 (6.0.0)
gpio_f970a92e447fa4793838db25a2947ed7 (6.0.0)
gpt_e92a0cbd07e389b82a1d19b05eb9fdda (6.0.0)
i2c_2566d7363e7e9aaedabb432110e372d7 (6.0.0)
igpio_b1c1fa279aa7069dca167502b8589cb7 (6.0.0)
kpp_42e527b886eb45655f11a320d8e4317a (6.0.0)
llwu_3300b573fd6e3303f27cdce526747338 (6.0.0)
lpadc_57a565c57fc5153b5212eadd052e3232 (6.0.0)
lpadc_c195ce2aea82996d53ed5cc4bb152217 (6.0.0)
lpc_adc_872b702fe80978eb853f71d267ac6cdd (6.0.0)
lpc_adc_d4840b616722dd9291a911597277144f (6.0.0)
lpc_crc_5f5f079056dd2a843b86fbb64c18c8cd (6.0.0)
lpc_dma_073e226789af4d91fdf79312787d777b (6.0.0)
lpc_dma_77c87b8df0796f4146842e3f11ac40fe (6.0.0)
lpc_gpio_8c9ab9b3668a514c1f4609fe43001865 (6.0.0)
lpc_i2c_f5051a0134792729f1007113ec6ddccd (6.0.0)
lpc_lcdc_6c2fed5b01722a6698c5f0d783d6b9f2 (6.0.0)
lpc_rtc_9080ace5f35f667bc4d544a142838bd9 (6.0.0)
lpi2c_540b08a1d4a23952ca7a6ac43c82d1e6 (6.0.0)
lpi2c_db68d4f4f06a22e25ab51fe9bd6db4d2 (6.0.0)
lpsci_6cb860df0090aefbbd9e197ba914a87c (6.0.0)
lpsci_d7d643c7d665ff9a7a181303138bb697 (6.0.0)
lpspi_2e4230bc6f188eb74b5476d1b09fc7bf (6.0.0)
lpspi_6e21a1e0a09f0a012d683c4f91752db8 (6.0.0)
lptmr_2eeab91a1a42f8238f9ac768f18c65ae (6.0.0)
lpuart_bebe3e12b6ec22bbd14199038f2bf459 (6.0.0)
mcan_2d100a4872f8271ba5289791a0db8987 (6.0.0)
mrt_ec4ff9f008b2eee803e5f398b3b3325f (6.0.0)
msg_6e2baaf3b97dbeef01c0043275f9a0e7 (6.0.0)
pdb_32eb8756416d042c4a30e2cf9bd8fca4 (6.0.0)
pint_5316dad711c8755e87dc7f941ce932b0 (6.0.0)
pint_cf4a806bb2a6c1ffced58ae2ed7b43af (6.0.0)
pit_a4782ba5223c8a2527ba91aeb2bc4159 (6.0.0)
qtmr_460dd7aa3f3371843c2548acd54252b0 (6.0.0)
rit_b722f95e53018d6f73a2b67d43c4ab32 (6.0.0)
rit_f03000c154de1ddc9acd4ea71856f5ae (6.0.0)
rnga_e3462b71d05dedbc6eec554b71e8aafc (6.0.0)
rtc_5a0edd77b33c110032c2a0f5e3d1bd2f (6.0.0)
rtc_603f70732a5387a85b5715615cba9e65 (6.0.0)
rtwdog_04d8f6604a79500facf56c1a1d0a7215 (6.0.0)
rtwdog_67fd785e8bb4ab28416270fb114d2253 (6.0.0)
sai_930e9b093093df3f492b3fa05284d81f (6.0.0)
sai_e171ee1d4e17db4b5b234f946b59a148 (6.0.1)
sai_e7c250a6f9f5ec36ac5d0ffad0941743 (6.0.1)
sctimer_11116c58643bd290f0e74db0acbc9466 (6.0.0)
sctimer_90afed1589e477b2ea2e4716f6f2b403 (6.0.0)
semc_d3a530ecfc3f527ce59c92b1deb0f7ea (6.0.0)
sha_ba2d3f72a89bf425920285094446a1de (6.0.0)
sha_e896408e6953d6c2d23452f8bd0fa07a (6.0.0)
snvs_hp_5fc0a925779e7e5f8b9bedf272c8d94e (6.0.0)
snvs_hp_8aa1d6897a8f71c776216caab5be8259 (6.0.0)
snvs_lp_214d2a8e2ab7b1cb98af7868b3016bee (6.0.0)
snvs_lp_3b9e952b0ef37d4c4fffea74821e74e2 (6.0.0)
spdif_040614b5288766ad77a1a386b39d0a3c (6.0.0)
spi_672b694426b0a10a1d774659ee8f8435 (6.0.0)
system_54b53072540eeeb8f8e9343e71f28176 (6.0.0)
tempmon_c966e400757748d37785414258f2801c (6.0.0)
tpm_e7472ea12d53461b8d293488f3ed72ec (6.0.0)
trng_dd5b2a6f14d45ca091cf6c9a38560d5e (6.0.0)
uart_c6ca9befff8c3e28c85e70f512c4576e (6.0.0)
uart_cd31a12aa8c79051fda42cc851a27c37 (6.0.0)
usb_5cc0ab6dff459aca35db264e9de4f664 (6.0.1)
usb_ee653dbc854ad587d0b0d9450b290322 (6.0.1)
utick_58a3a3f691b03a130cd9419552f8327d (6.0.0)
vref_62f8e6ca39d44fd8d933f98728e18183 (6.0.0)
vspi_9007ef7a0da73373c0cea4288e9d1bd8 (6.0.0)
vusart_5aaee6363fed76927f762537b5faef95 (6.0.0)
vusart_d1fd15b7bbe9fff62f1f4b73e5bdc444 (6.0.0)
wdog01_425640a4cd6cc847fe8bf3baf0d666fc (6.0.0)
wdog01_510a9c5ba7e0ced8deac305549f23fa9 (6.0.0)
wdog_362a0fbc7b41b2e6c7f96894cfc2f4d4 (6.0.0)
wwdt_2cb925533f814de0a276eb97fc166b0f (6.0.0)
wwdt_6fc3942d460161811a54b3834c482436 (6.0.0)
      • Platform Details:
      • System properties:
applicationXMI=org.eclipse.ui.workbench/LegacyIDE.e4xmi
awt.toolkit=sun.awt.windows.WToolkit
ds.delayed.keepInstances=true
ds.delayed.keepInstances.default=true
eclipse.application=com.nxp.swtools.framework.application
eclipse.commands=-os
win32
-ws
win32
-arch
x86_64
-showsplash
-launcher
C:\nxp\MCUX_CFG_v6\bin\tools.exe
-name
Tools
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.900.v20180922-1751\eclipse_1801.dll
-startup
plugins/org.eclipse.equinox.launcher_1.5.200.v20180922-1751.jar
-data
@user.home/.nxp/nxp_conf_workspace_v6.0
-showlocation
-vm
C:\nxp\MCUX_CFG_v6\bin\jre\bin\server\jvm.dll
eclipse.home.location=file:/C:/nxp/MCUX_CFG_v6/bin/
eclipse.launcher=C:\nxp\MCUX_CFG_v6\bin\tools.exe
eclipse.startTime=1562683670301
eclipse.vm=C:\nxp\MCUX_CFG_v6\bin\jre\bin\server\jvm.dll
-Xms256m
-Xmx868m
-Dupdate.site=http://mcuxpresso.nxp.com/staticdata/updates/kex_6.0/
-Djava.class.path=C:\nxp\MCUX_CFG_v6\bin
file.separator=\
java.endorsed.dirs=C:\nxp\MCUX_CFG_v6\bin\jre\lib\endorsed
java.ext.dirs=C:\nxp\MCUX_CFG_v6\bin\jre\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\nxp\MCUX_CFG_v6\bin\jre
java.library.path=C:\nxp\MCUX_CFG_v6\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:/nxp/MCUX_CFG_v6/bin/jre/bin/server;C:/nxp/MCUX_CFG_v6/bin/jre/bin;C:/nxp/MCUX_CFG_v6/bin/jre/lib/amd64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\SafeNet\Authentication\SAC\x64;C:\Program Files\SafeNet\Authentication\SAC\x32;C:\Program Files (x86)\CheckPoint\Endpoint Security\Endpoint Common\bin;C:\Program Files\Perforce\;C:\Program Files\PuTTY\;C:\Program Files\Git\cmd;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\bin;C:\Users\lciummo\AppData\Local\Microsoft\WindowsApps;;C:\nxp\MCUX_CFG_v6\bin;;.
java.runtime.version=1.8.0_201-b09
java.version=1.8.0_201
java.vm.version=25.201-b09
line.separator=
org.eclipse.equinox.launcher.splash.location=c:\nxp\MCUX_CFG_v6\bin\configuration\org.eclipse.equinox.launcher\com.nxp.swtools.framework.kinetis_6.0.0.201905210938\splash.bmp
org.eclipse.swt.internal.deviceZoom=100
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,OSGi/Minimum-1.2,JavaSE/compact1-1.8,JavaSE/compact2-1.8,JavaSE/compact3-1.8,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,JavaSE-1.6,JavaSE-1.7,JavaSE-1.8
org.osgi.framework.language=en
org.osgi.framework.os.name=Windows10
org.osgi.framework.os.version=10.0.0
org.osgi.framework.processor=x86-64
org.osgi.framework.storage=C:\nxp\MCUX_CFG_v6\bin\configuration
org.osgi.framework.system.capabilities=osgi.ee; osgi.ee="OSGi/Minimum"; version:List="1.8"
org.osgi.framework.system.packages=java.applet,java.awt,java.awt.color,java.awt.datatransfer,java.awt.dnd,java.awt.event,java.awt.font,java.awt.geom,java.awt.im,java.awt.im.spi,java.awt.image,java.awt.image.renderable,java.awt.print,java.beans,java.beans.beancontext,java.io,java.lang,java.lang.annotation,java.lang.instrument,java.lang.invoke,java.lang.management,java.lang.ref,java.lang.reflect,java.math,java.net,java.nio,java.nio.channels,java.nio.channels.spi,java.nio.charset,java.nio.charset.spi,java.nio.file,java.nio.file.attribute,java.nio.file.spi,java.rmi,java.rmi.activation,java.rmi.dgc,java.rmi.registry,java.rmi.server,java.security,java.security.acl,java.security.cert,java.security.interfaces,java.security.spec,java.sql,java.text,java.text.spi,java.time,java.time.chrono,java.time.format,java.time.temporal,java.time.zone,java.util,java.util.concurrent,java.util.concurrent.atomic,java.util.concurrent.locks,java.util.function,java.util.jar,java.util.logging,java.util.prefs,java.util.regex,java.util.spi,java.util.stream,java.util.zip,javax.accessibility,javax.activation,javax.activity,javax.annotation,javax.annotation.processing,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap,javax.lang.model,javax.lang.model.element,javax.lang.model.type,javax.lang.model.util,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.script,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.nimbus,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.tools,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotation.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,javax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.crypto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,javax.xml.stream,javax.xml.stream.events,javax.xml.stream.util,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stax,javax.xml.transform.stream,javax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax.xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,javax.xml.ws.spi,javax.xml.ws.spi.http,javax.xml.ws.wsaddressing,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.css,org.w3c.dom.events,org.w3c.dom.html,org.w3c.dom.ls,org.w3c.dom.ranges,org.w3c.dom.stylesheets,org.w3c.dom.traversal,org.w3c.dom.views,org.w3c.dom.xpath,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.uuid=59052962-dba7-433f-b3e2-6a7cf0feffeb
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.9.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=amd64
os.name=Windows 10
os.version=10.0
osgi.arch=x86_64
osgi.bundles=reference:file:org.eclipse.osgi.compatibility.state_1.1.300.v20181116-1550.jar,reference:file:org.eclipse.osgi.compatibility.state.nl_zh_4.10.0.v20190126060001.jar,reference:file:org.eclipse.osgi.nl_zh_4.10.0.v20190126060001.jar,reference:file:org.eclipse.osgi.services.nl_zh_4.10.0.v20190126060001.jar,reference:file:org.eclipse.osgi.util.nl_zh_4.10.0.v20190126060001.jar,reference:file:com.google.gson_2.8.2.v20180104-1110.jar@4,reference:file:com.google.guava_21.0.0.v20170206-1425.jar@4,reference:file:com.ibm.icu_63.1.0.v20181030-1705.jar@4,reference:file:com.nxp.kex.standalone_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.clocks_5.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.clocks.model_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.clocks.swt_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.common.ui.utils_1.4.0.201905210938.jar@4,reference:file:com.nxp.swtools.common.ui.utils.swt_1.2.0.201905210938.jar@4,reference:file:com.nxp.swtools.common.utils_1.1.1.201905210938.jar@4,reference:file:com.nxp.swtools.configuration_1.6.0.201905210938.jar@4,reference:file:com.nxp.swtools.core_1.10.0.201905210938.jar@4,reference:file:com.nxp.swtools.core.service_1.13.0.201905210938.jar@4,reference:file:com.nxp.swtools.dashboard_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.databinding_1.4.0.201905210938.jar@4,reference:file:com.nxp.swtools.dcd.model_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.dcdx_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.dcdx.swt_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.derivative_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.derivative.rcp_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.doc.kinetis_4.0.0.201905210938/@4,reference:file:com.nxp.swtools.docannotations_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.expert_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.framework_4.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.framework.kinetis_6.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.mux_5.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.mux.swt_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.periphs.controller_0.0.1.201905210938.jar@4,reference:file:com.nxp.swtools.periphs.gui_5.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.periphs.gui.swt_0.0.1.201905210938.jar@4,reference:file:com.nxp.swtools.periphs.model_0.0.1.201905210938.jar@4,reference:file:com.nxp.swtools.projectcloner_2.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.projectcloner.engine_2.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.projectcloner.rcp_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.rcp_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.rcp.analytics_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.sdkmanifest_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.sdkproject_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.sharedconfiguration_1.1.0.201905210938.jar@4,reference:file:com.nxp.swtools.tee.controller_0.0.1.201905210938.jar@4,reference:file:com.nxp.swtools.tee.gui_0.0.1.201905210938.jar@4,reference:file:com.nxp.swtools.tee.model_0.0.1.201905210938.jar@4,reference:file:com.nxp.swtools.tutorial_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.ui.inspector_1.10.0.201905210938.jar@4,reference:file:com.nxp.swtools.ui.inspector.graphical_1.3.0.201905210938.jar@4,reference:file:com.nxp.swtools.ui.targetcpu_1.6.0.201905210938.jar@4,reference:file:com.nxp.swtools.ui.views_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.utils_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.utils.support.markdown_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.utils.swt_1.0.0.201905210938.jar@4,reference:file:com.nxp.swtools.validation_1.1.0.201905210938.jar@4,reference:file:com.sun.el_2.2.0.v201303151357.jar@4,reference:file:javax.activation_1.1.0.v201211130549.jar@4,reference:file:javax.annotation_1.2.0.v201602091430.jar@4,reference:file:javax.el_2.2.0.v201303151357.jar@4,reference:file:javax.inject_1.0.0.v20091030.jar@4,reference:file:javax.servlet_3.1.0.v201410161800.jar@4,reference:file:javax.servlet.jsp_2.2.0.v201112011158.jar@4,reference:file:javax.xml_1.3.4.v201005080400.jar@4,reference:file:javax.xml.bind_2.2.0.v201105210648.jar@4,reference:file:org.apache.batik.constants_1.10.0.v20180703-1553.jar@4,reference:file:org.apache.batik.css_1.10.0.v20180703-1553.jar@4,reference:file:org.apache.batik.i18n_1.10.0.v20180703-1553.jar@4,reference:file:org.apache.batik.util_1.10.0.v20180703-1553.jar@4,reference:file:org.apache.commons.codec_1.10.0.v20180409-1845.jar@4,reference:file:org.apache.commons.io_2.2.0.v201405211200.jar@4,reference:file:org.apache.commons.jxpath_1.3.0.v200911051830.jar@4,reference:file:org.apache.commons.logging_1.2.0.v20180409-1502.jar@4,reference:file:org.apache.felix.gogo.command_1.0.2.v20170914-1324.jar@4,reference:file:org.apache.felix.gogo.runtime_1.1.0.v20180713-1646.jar@4,reference:file:org.apache.felix.gogo.shell_1.1.0.v20180713-1646.jar@4,reference:file:org.apache.felix.scr_2.0.14.v20180822-1822.jar@1:start,reference:file:org.apache.httpcomponents.httpclient_4.5.5.v20180409-1525.jar@4,reference:file:org.apache.httpcomponents.httpcore_4.4.9.v20180409-1525.jar@4,reference:file:org.apache.jasper.glassfish_2.2.2.v201501141630.jar@4,reference:file:org.apache.lucene.analyzers-common_7.5.0.v20181003-1532.jar@4,reference:file:org.apache.lucene.analyzers-smartcn_7.5.0.v20181003-1532.jar@4,reference:file:org.apache.lucene.core_7.5.0.v20181003-1532.jar@4,reference:file:org.apache.xmlgraphics_2.2.0.v20180809-1640.jar@4,reference:file:org.eclipse.cdt.core_6.6.0.201812101042.jar@4,reference:file:org.eclipse.cdt.core.native_5.10.1.201811241055.jar@4,reference:file:org.eclipse.cdt.ui_6.4.0.201811241855.jar@4,reference:file:org.eclipse.compare_3.7.400.v20181109-1335.jar@4,reference:file:org.eclipse.compare.core_3.6.300.v20180827-1041.jar@4,reference:file:org.eclipse.compare.core.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.compare.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.compare.win32_1.2.300.v20180926-0905.jar@4,reference:file:org.eclipse.compare.win32.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.commands_3.9.200.v20180827-1727.jar@4,reference:file:org.eclipse.core.commands.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.contenttype_3.7.200.v20181107-1343.jar@4,reference:file:org.eclipse.core.contenttype.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.databinding_1.7.100.v20181030-1443.jar@4,reference:file:org.eclipse.core.databinding.beans_1.4.300.v20181030-1443.jar@4,reference:file:org.eclipse.core.databinding.beans.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.databinding.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.databinding.observable_1.6.300.v20180827-2028.jar@4,reference:file:org.eclipse.core.databinding.observable.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.databinding.property_1.6.300.v20180827-2028.jar@4,reference:file:org.eclipse.core.databinding.property.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.expressions_3.6.200.v20180817-1401.jar@4,reference:file:org.eclipse.core.expressions.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.filebuffers_3.6.400.v20181028-0633.jar@4,reference:file:org.eclipse.core.filebuffers.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.filesystem_1.7.200.v20180828-0158.jar@4,reference:file:org.eclipse.core.filesystem.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.filesystem.win32.x86_64_1.4.100.v20180828-0158.jar@4,reference:file:org.eclipse.core.filesystem.win32.x86_64.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.jobs_3.10.200.v20180912-1356.jar@4,reference:file:org.eclipse.core.jobs.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.net_1.3.400.v20181030-1645.jar@4,reference:file:org.eclipse.core.net.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.net.win32.x86_64_1.1.300.v20181126-0635.jar@4,reference:file:org.eclipse.core.net.win32.x86_64.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.resources_3.13.200.v20181121-1020.jar@4,reference:file:org.eclipse.core.resources.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.resources.win32.x86_64_3.5.300.v20181030-1942.jar@4,reference:file:org.eclipse.core.resources.win32.x86_64.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.runtime_3.15.100.v20181107-1343.jar@4:start,reference:file:org.eclipse.core.runtime.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.core.variables_3.4.300.v20181028-0627.jar@4,reference:file:org.eclipse.core.variables.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.debug.core_3.13.100.v20181201-1650.jar@4,reference:file:org.eclipse.debug.core.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.core.commands_0.12.400.v20181119-1026.jar@4,reference:file:org.eclipse.e4.core.contexts_1.7.100.v20180817-1215.jar@4,reference:file:org.eclipse.e4.core.contexts.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.core.di_1.7.100.v20180817-1215.jar@4,reference:file:org.eclipse.e4.core.di.annotations_1.6.200.v20180817-1215.jar@4,reference:file:org.eclipse.e4.core.di.annotations.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.core.di.extensions_0.15.200.v20180817-1215.jar@4,reference:file:org.eclipse.e4.core.di.extensions.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.core.di.extensions.supplier_0.15.200.v20180817-1215.jar@4,reference:file:org.eclipse.e4.core.di.extensions.supplier.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.core.di.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.core.services_2.1.300.v20180930-0910.jar@4,reference:file:org.eclipse.e4.core.services.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.emf.xpath_0.2.200.v20180828-0227.jar@4,reference:file:org.eclipse.e4.emf.xpath.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.ui.bindings_0.12.300.v20180913-1535.jar@4,reference:file:org.eclipse.e4.ui.css.core_0.12.400.v20180917-1628.jar@4,reference:file:org.eclipse.e4.ui.css.core.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.ui.css.swt_0.13.300.v20181030-1443.jar@4,reference:file:org.eclipse.e4.ui.css.swt.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.ui.css.swt.theme_0.12.100.v20180828-0227.jar@4,reference:file:org.eclipse.e4.ui.css.swt.theme.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.ui.di_1.2.400.v20180920-1522.jar@4,reference:file:org.eclipse.e4.ui.di.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.ui.dialogs_1.1.300.v20180828-0227.jar@4,reference:file:org.eclipse.e4.ui.dialogs.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.ui.model.workbench_2.1.200.v20180920-1522.jar@4,reference:file:org.eclipse.e4.ui.model.workbench.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.ui.services_1.3.300.v20180920-1522.jar@4,reference:file:org.eclipse.e4.ui.services.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.ui.widgets_1.2.300.v20180920-1522.jar@4,reference:file:org.eclipse.e4.ui.widgets.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.e4.ui.workbench_1.8.0.v20181119-1304.jar@4,reference:file:org.eclipse.e4.ui.workbench.addons.swt_1.3.300.v20181102-1042.jar@4,reference:file:org.eclipse.e4.ui.workbench.renderers.swt_0.14.400.v20181112-1716.jar@4,reference:file:org.eclipse.e4.ui.workbench.swt_0.14.400.v20181022-1348.jar@4,reference:file:org.eclipse.e4.ui.workbench3_0.14.200.v20180828-0227.jar@4,reference:file:org.eclipse.e4.ui.workbench3.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ecf_3.9.3.v20181012-2016.jar@4,reference:file:org.eclipse.ecf.filetransfer_5.0.100.v20180301-0132.jar@4,reference:file:org.eclipse.ecf.identity_3.9.1.v20180810-0833.jar@4,reference:file:org.eclipse.ecf.provider.filetransfer_3.2.400.v20180306-0429.jar@4,reference:file:org.eclipse.ecf.provider.filetransfer.httpclient4_1.1.300.v20180301-0132.jar@4,reference:file:org.eclipse.ecf.provider.filetransfer.httpclient4.ssl_1.1.100.v20180301-0132.jar@4,reference:file:org.eclipse.ecf.provider.filetransfer.ssl_1.0.100.v20180301-0132.jar@4,reference:file:org.eclipse.ecf.ssl_1.2.100.v20180301-0132.jar@4,reference:file:org.eclipse.emf.common_2.15.0.v20180914-1817.jar@4,reference:file:org.eclipse.emf.ecore_2.16.0.v20181124-0637.jar@4,reference:file:org.eclipse.emf.ecore.change_2.13.0.v20180706-1146.jar@4,reference:file:org.eclipse.emf.ecore.xmi_2.15.0.v20180706-1146.jar@4,reference:file:org.eclipse.equinox.app_1.4.0.v20181009-1752.jar@4,reference:file:org.eclipse.equinox.bidi_1.1.200.v20180827-1235.jar@4,reference:file:org.eclipse.equinox.common_3.10.200.v20181021-1645.jar@2:start,reference:file:org.eclipse.equinox.concurrent_1.1.200.v20180827-1235.jar@4,reference:file:org.eclipse.equinox.console_1.3.200.v20181115-0906.jar@4,reference:file:org.eclipse.equinox.event_1.5.0.v20181008-1938.jar@2:start,reference:file:org.eclipse.equinox.frameworkadmin_2.1.100.v20180822-1258.jar@4,reference:file:org.eclipse.equinox.frameworkadmin.equinox_1.1.100.v20180822-1258.jar@4,reference:file:org.eclipse.equinox.frameworkadmin.equinox.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.frameworkadmin.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.http.jetty_3.6.200.v20181115-1346.jar@4,reference:file:org.eclipse.equinox.http.registry_1.1.600.v20180827-1235.jar@4,reference:file:org.eclipse.equinox.http.servlet_1.5.200.v20181008-1912.jar@4,reference:file:org.eclipse.equinox.jsp.jasper_1.1.100.v20180827-1235.jar@4,reference:file:org.eclipse.equinox.jsp.jasper.registry_1.1.100.v20180827-1235.jar@4,reference:file:org.eclipse.equinox.launcher_1.5.200.v20180922-1751.jar@4,reference:file:org.eclipse.equinox.launcher.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.900.v20180922-1751/@4,reference:file:org.eclipse.equinox.launcher.win32.win32.x86_64.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.artifact.repository_1.2.200.v20181119-1308.jar@4,reference:file:org.eclipse.equinox.p2.artifact.repository.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.console_1.1.100.v20180822-1258.jar@4,reference:file:org.eclipse.equinox.p2.console.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.core_2.5.100.v20180822-1532.jar@4,reference:file:org.eclipse.equinox.p2.core.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.director_2.4.200.v20181102-0649.jar@4,reference:file:org.eclipse.equinox.p2.director.app_1.1.200.v20180822-1302.jar@4,reference:file:org.eclipse.equinox.p2.director.app.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.director.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.directorywatcher_1.2.100.v20180822-1302.jar@4,reference:file:org.eclipse.equinox.p2.directorywatcher.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.engine_2.6.100.v20180822-1302.jar@4,reference:file:org.eclipse.equinox.p2.engine.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.extensionlocation_1.3.100.v20180822-1302.jar@4,reference:file:org.eclipse.equinox.p2.extensionlocation.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.garbagecollector_1.1.100.v20180822-1302.jar@4,reference:file:org.eclipse.equinox.p2.garbagecollector.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.jarprocessor_1.1.200.v20180921-1009.jar@4,reference:file:org.eclipse.equinox.p2.jarprocessor.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.metadata_2.4.200.v20181102-0649.jar@4,reference:file:org.eclipse.equinox.p2.metadata.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.metadata.repository_1.3.100.v20180822-1302.jar@4,reference:file:org.eclipse.equinox.p2.metadata.repository.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.operations_2.5.200.v20180928-1359.jar@4,reference:file:org.eclipse.equinox.p2.operations.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.publisher_1.5.100.v20180822-1302.jar@4,reference:file:org.eclipse.equinox.p2.publisher.eclipse_1.3.100.v20180822-1354.jar@4,reference:file:org.eclipse.equinox.p2.publisher.eclipse.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.publisher.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.reconciler.dropins_1.3.0.v20181023-0914.jar@4,reference:file:org.eclipse.equinox.p2.reconciler.dropins.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.repository_2.4.200.v20181005-1131.jar@4,reference:file:org.eclipse.equinox.p2.repository.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.repository.tools_2.2.200.v20181102-0649.jar@4,reference:file:org.eclipse.equinox.p2.repository.tools.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.touchpoint.eclipse_2.2.200.v20181123-1405.jar@4,reference:file:org.eclipse.equinox.p2.touchpoint.eclipse.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.touchpoint.natives_1.3.200.v20180921-1019.jar@4,reference:file:org.eclipse.equinox.p2.touchpoint.natives.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.p2.transport.ecf_1.2.100.v20180822-1354.jar@4,reference:file:org.eclipse.equinox.p2.transport.ecf.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.preferences_3.7.200.v20180827-1235.jar@4,reference:file:org.eclipse.equinox.registry_3.8.200.v20181008-1820.jar@4,reference:file:org.eclipse.equinox.security_1.3.0.v20181115-0746.jar@4,reference:file:org.eclipse.equinox.security.win32.x86_64_1.1.100.v20180827-1235.jar@4,reference:file:org.eclipse.equinox.simpleconfigurator_1.3.200.v20181101-1115.jar@4,reference:file:org.eclipse.equinox.simpleconfigurator.manipulator_2.1.200.v20181123-1405.jar@4,reference:file:org.eclipse.equinox.simpleconfigurator.manipulator.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.simpleconfigurator.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.equinox.util_1.1.200.v20181008-1820.jar@4,reference:file:org.eclipse.help_3.8.200.v20180821-0700.jar@4,reference:file:org.eclipse.help.base_4.2.400.v20181206-0815.jar@4,reference:file:org.eclipse.help.base.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.help.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.help.ui_4.1.300.v20181018-1136.jar@4,reference:file:org.eclipse.help.ui.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.help.webapp_3.9.300.v20181127-2310.jar@4,reference:file:org.eclipse.help.webapp.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.jetty.continuation_9.4.14.v20181113.jar@4,reference:file:org.eclipse.jetty.http_9.4.14.v20181113.jar@4,reference:file:org.eclipse.jetty.io_9.4.14.v20181113.jar@4,reference:file:org.eclipse.jetty.security_9.4.14.v20181113.jar@4,reference:file:org.eclipse.jetty.server_9.4.14.v20181113.jar@4,reference:file:org.eclipse.jetty.servlet_9.4.14.v20181113.jar@4,reference:file:org.eclipse.jetty.util_9.4.14.v20181113.jar@4,reference:file:org.eclipse.jface_3.15.0.v20181123-1505.jar@4,reference:file:org.eclipse.jface.databinding_1.8.400.v20181030-1443.jar@4,reference:file:org.eclipse.jface.databinding.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.jface.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.jface.text_3.15.0.v20181119-1708.jar@4,reference:file:org.eclipse.jface.text.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ltk.core.refactoring_3.9.200.v20181024-1629.jar@4,reference:file:org.eclipse.ltk.core.refactoring.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ltk.ui.refactoring_3.9.200.v20180828-0626.jar@4,reference:file:org.eclipse.ltk.ui.refactoring.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.mylyn.wikitext_3.0.25.20180620133858.jar@4,reference:file:org.eclipse.mylyn.wikitext.markdown_3.0.25.20180620133858.jar@4,reference:file:org.eclipse.nebula.widgets.grid_1.1.0.201803231500.jar@4,reference:file:org.eclipse.osgi.services_3.7.100.v20180827-1536.jar@4,reference:file:org.eclipse.osgi.util_3.5.100.v20180827-1536.jar@4,reference:file:org.eclipse.rcp_4.10.0.v20181206-0815.jar@4,reference:file:org.eclipse.search_3.11.400.v20181028-0633.jar@4,reference:file:org.eclipse.search.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.swt_3.109.0.v20181204-1801.jar@4,reference:file:org.eclipse.swt.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.swt.win32.win32.x86_64_3.109.0.v20181204-1801.jar@4,reference:file:org.eclipse.team.core_3.8.400.v20181109-0825.jar@4,reference:file:org.eclipse.team.core.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.team.ui_3.8.300.v20181030-1259.jar@4,reference:file:org.eclipse.team.ui.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.text_3.8.0.v20180923-1636.jar@4,reference:file:org.eclipse.text.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.tools.templates.core_1.1.0.201812111206.jar@4,reference:file:org.eclipse.tools.templates.ui_1.1.1.201812111206.jar@4,reference:file:org.eclipse.ui_3.111.0.v20181117-0847.jar@4,reference:file:org.eclipse.ui.cheatsheets_3.5.300.v20180823-1505.jar@4,reference:file:org.eclipse.ui.cheatsheets.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.console_3.8.300.v20181019-1609.jar@4,reference:file:org.eclipse.ui.console.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.editors_3.11.300.v20180914-0606.jar@4,reference:file:org.eclipse.ui.editors.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.forms_3.7.400.v20181123-1505.jar@4,reference:file:org.eclipse.ui.forms.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.ide_3.14.200.v20181205-2143.jar@4,reference:file:org.eclipse.ui.ide.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.navigator_3.7.300.v20181016-1531.jar@4,reference:file:org.eclipse.ui.navigator.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.navigator.resources_3.6.300.v20181110-1011.jar@4,reference:file:org.eclipse.ui.navigator.resources.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.themes_1.2.300.v20181108-1102/@4,reference:file:org.eclipse.ui.themes.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.views_3.9.200.v20180828-0837.jar@4,reference:file:org.eclipse.ui.views.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.views.properties.tabbed_3.8.300.v20180921-1036.jar@4,reference:file:org.eclipse.ui.views.properties.tabbed.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.win32.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.workbench_3.112.100.v20181127-1518.jar@4,reference:file:org.eclipse.ui.workbench.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.ui.workbench.texteditor_3.11.200.v20181108-1458.jar@4,reference:file:org.eclipse.ui.workbench.texteditor.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.eclipse.update.configurator_3.4.100.v20180821-1913.jar@4,reference:file:org.eclipse.update.configurator.nl_zh_4.10.0.v20190126060001.jar@4,reference:file:org.jsoup_1.7.2.v201411291515.jar@4,reference:file:org.sat4j.core_2.3.5.v201308161310.jar@4,reference:file:org.sat4j.pb_2.3.5.v201404071733.jar@4,reference:file:org.simpleframework.xml_2.7.1.201905210938.jar@4,reference:file:org.tukaani.xz_1.8.0.v20180207-1613.jar@4,reference:file:org.w3c.css.sac_1.3.1.v200903091627.jar@4,reference:file:org.w3c.dom.events_3.0.0.draft20060413_v201105210656.jar@4,reference:file:org.w3c.dom.smil_1.0.1.v200903091627.jar@4,reference:file:org.w3c.dom.svg_1.1.0.v201011041433.jar@4,reference:file:org.yaml.snakeyaml_1.0.0.201905210938.jar@4
osgi.bundles.defaultStartLevel=4
osgi.compatibility.bootdelegation=true
osgi.compatibility.bootdelegation.default=true
osgi.configuration.area=file:/C:/nxp/MCUX_CFG_v6/bin/configuration/
osgi.framework=file:/c:/nxp/MCUX_CFG_v6/bin/plugins/org.eclipse.osgi_3.13.200.v20181130-2106.jar
osgi.framework.extensions=reference:file:org.eclipse.osgi.compatibility.state_1.1.300.v20181116-1550.jar,reference:file:org.eclipse.osgi.compatibility.state.nl_zh_4.10.0.v20190126060001.jar,reference:file:org.eclipse.osgi.nl_zh_4.10.0.v20190126060001.jar,reference:file:org.eclipse.osgi.services.nl_zh_4.10.0.v20190126060001.jar,reference:file:org.eclipse.osgi.util.nl_zh_4.10.0.v20190126060001.jar
osgi.framework.shape=jar
osgi.framework.useSystemProperties=true
osgi.frameworkClassPath=., file:c:/nxp/MCUX_CFG_v6/bin/plugins/org.eclipse.osgi.compatibility.state_1.1.300.v20181116-1550.jar, file:c:/nxp/MCUX_CFG_v6/bin/plugins/org.eclipse.osgi.compatibility.state.nl_zh_4.10.0.v20190126060001.jar, file:c:/nxp/MCUX_CFG_v6/bin/plugins/org.eclipse.osgi.nl_zh_4.10.0.v20190126060001.jar, file:c:/nxp/MCUX_CFG_v6/bin/plugins/org.eclipse.osgi.services.nl_zh_4.10.0.v20190126060001.jar, file:c:/nxp/MCUX_CFG_v6/bin/plugins/org.eclipse.osgi.util.nl_zh_4.10.0.v20190126060001.jar
osgi.install.area=file:/C:/nxp/MCUX_CFG_v6/bin/
osgi.instance.area=file:/C:/Users/lciummo/.nxp/nxp_conf_workspace_v6.0/
osgi.logfile=C:\Users\lciummo\.nxp\nxp_conf_workspace_v6.0\.metadata\.log
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\nxp\MCUX_CFG_v6\bin\configuration\org.eclipse.equinox.launcher\com.nxp.swtools.framework.kinetis_6.0.0.201905210938\splash.bmp
osgi.splashPath=platform:/base/plugins/com.nxp.swtools.framework.kinetis
osgi.syspath=c:\nxp\MCUX_CFG_v6\bin\plugins
osgi.tracefile=C:\Users\lciummo\.nxp\nxp_conf_workspace_v6.0\.metadata\trace.log
osgi.ws=win32
path.separator=;
sun.arch.data.model=64
sun.boot.class.path=C:\nxp\MCUX_CFG_v6\bin\jre\lib\resources.jar;C:\nxp\MCUX_CFG_v6\bin\jre\lib\rt.jar;C:\nxp\MCUX_CFG_v6\bin\jre\lib\sunrsasign.jar;C:\nxp\MCUX_CFG_v6\bin\jre\lib\jsse.jar;C:\nxp\MCUX_CFG_v6\bin\jre\lib\jce.jar;C:\nxp\MCUX_CFG_v6\bin\jre\lib\charsets.jar;C:\nxp\MCUX_CFG_v6\bin\jre\lib\jfr.jar;C:\nxp\MCUX_CFG_v6\bin\jre\classes
sun.boot.library.path=C:\nxp\MCUX_CFG_v6\bin\jre\bin
sun.cpu.endian=little
sun.cpu.isalist=amd64
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot 64-Bit Tiered Compilers
sun.os.patch.level=
user.country=US
user.dir=C:\nxp\MCUX_CFG_v6\bin
user.home=C:\Users\lciummo
user.language=en
user.name=LCiummo
user.script=
user.timezone=America/New_York
user.variant=
      • System environment variables:
ALLUSERSPROFILE=C:\ProgramData
APPDATA=C:\Users\lciummo\AppData\Roaming
COMPUTERNAME=BOS1-01087-L
ComSpec=C:\WINDOWS\system32\cmd.exe
CommonProgramFiles=C:\Program Files\Common Files
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
CommonProgramW6432=C:\Program Files\Common Files
DADIR=C:\Program Files (x86)\CheckPoint\Endpoint Security\Endpoint Common
DriverData=C:\Windows\System32\Drivers\DriverData
FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
FPS_BROWSER_USER_PROFILE_STRING=Default
HOMEDRIVE=C:
HOMEPATH=\Users\lciummo
LOCALAPPDATA=C:\Users\lciummo\AppData\Local
LOGONSERVER=
US-BOS-DC3
NUMBER_OF_PROCESSORS=8
OS=Windows_NT
OneDrive=C:\Users\lciummo\OneDrive
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE=AMD64
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 158 Stepping 9, GenuineIntel
PROCESSOR_LEVEL=6
PROCESSOR_REVISION=9e09
PSDistrict_BootImageVersion=CAS00128
PSDistrict_DeploymentID=CAS00355
PSDistrict_Install_CheckPointEDLP=Yes
PSDistrict_Install_adobeflash=Yes
PSDistrict_Install_bomgar=Yes
PSDistrict_Install_carbonblack=Yes
PSDistrict_Install_foxit=Yes
PSDistrict_Install_googlechrome=Yes
PSDistrict_Install_mbam=Yes
PSDistrict_Install_office2016=Yes
PSDistrict_Install_phishalert=Yes
PSDistrict_Install_pulsesecure=Yes
PSDistrict_Install_safenet=Yes
PSDistrict_Install_sap=Yes
PSDistrict_Install_sevenzip=Yes
PSDistrict_Install_vlc=Yes
PSDistrict_Install_xagt=Yes
PSDistrict_InstallationDate=20190515-17:33:57
PSDistrict_InstallationMethod=PXE
PSDistrict_OSDDeploymentVersion=2.2.1
PSDistrict_OSDTechName=arauseo
PSDistrict_OSDTicketNumber=TS00082155
PSDistrict_SiteCode=PS1
PSDistrict_TSID=CAS00355
PSDistrict_TSName=FLIR Windows Installation (7 & 10)
PSDistrict_TattooScriptVersion=1.4.3
PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
PUBLIC=C:\Users\Public
Path=C:/nxp/MCUX_CFG_v6/bin/jre/bin/server;C:/nxp/MCUX_CFG_v6/bin/jre/bin;C:/nxp/MCUX_CFG_v6/bin/jre/lib/amd64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files\SafeNet\Authentication\SAC\x64;C:\Program Files\SafeNet\Authentication\SAC\x32;C:\Program Files (x86)\CheckPoint\Endpoint Security\Endpoint Common\bin;C:\Program Files\Perforce\;C:\Program Files\PuTTY\;C:\Program Files\Git\cmd;C:\Program Files\Git\mingw64\bin;C:\Program Files\Git\usr\bin;C:\Users\lciummo\AppData\Local\Microsoft\WindowsApps;;C:\nxp\MCUX_CFG_v6\bin;
ProgramData=C:\ProgramData
SESSIONNAME=Console
SNC_LIB=C:\Program Files (x86)\SAP\FrontEnd\SAPgui\gssntlm.dll
SystemDrive=C:
SystemRoot=C:\WINDOWS
TEMP=C:\Users\lciummo\AppData\Local\Temp
TMP=C:\Users\lciummo\AppData\Local\Temp
UATDATA=C:\WINDOWS\CCM\UATData\D9F8C395-CAB8-491d-B8AC-179A1FE1BE77
USERDNSDOMAIN=ZONE1.FLIR.NET
USERDOMAIN=ZONE1
USERDOMAIN_ROAMINGPROFILE=ZONE1
USERNAME=LCiummo
USERPROFILE=C:\Users\lciummo
windir=C:\WINDOWS
      • Features:
com.nxp.swtools.clocks.feature (6.0.0.201905210938) "Config Tools - Clocks Tool"
com.nxp.swtools.dcdx.feature (1.0.0.201905210938) "DCDx"
com.nxp.swtools.framework.feature (6.0.0.201905210938) "Config Tools Framework"
com.nxp.swtools.periphs.feature (6.0.0.201905210938) "Config Tools - Peripherals Tool"
com.nxp.swtools.pins.feature (6.0.0.201905210938) "Config Tools - Pins Tool"
org.eclipse.emf.common (2.15.0.v20180914-1817) "EMF Common"
org.eclipse.emf.ecore (2.16.0.v20181124-0637) "EMF Ecore"
org.eclipse.help (2.2.400.v20181206-0815) "Help System Base"
org.eclipse.rcp (4.10.0.v20181206-0815) "Eclipse RCP"
      • Plug-in Registry:
com.google.gson (2.8.2.v20180104-1110) "Gson: Google Json Library for Java"
com.google.guava (21.0.0.v20170206-1425) "Guava: Google Core Libraries for Java"
com.ibm.icu (63.1.0.v20181030-1705) "ICU4J"
com.nxp.kex.standalone (1.0.0.201905210938) "NXP Configuration Tools Framework Standalone"
com.nxp.swtools.clocks (5.0.0.201905210938) "Config Tools - Clocks Tool"
com.nxp.swtools.clocks.model (1.0.0.201905210938) "Model"
com.nxp.swtools.clocks.swt (1.0.0.201905210938) "Clocks Swt"
com.nxp.swtools.common.ui.utils (1.4.0.201905210938) "Miscellaneous UI Utils"
com.nxp.swtools.common.ui.utils.swt (1.2.0.201905210938) "NXP Configuration Tools SWT UI Utils"
com.nxp.swtools.common.utils (1.1.1.201905210938) "Miscellaneous Utilities Plug-in"
com.nxp.swtools.configuration (1.6.0.201905210938) "NXP Configuration Tools Configuration"
com.nxp.swtools.core (1.10.0.201905210938) "NXP Configuration Tools Core"
com.nxp.swtools.core.service (1.13.0.201905210938) "SWTools Service"
com.nxp.swtools.dashboard (1.0.0.201905210938) "Dashboard"
com.nxp.swtools.databinding (1.4.0.201905210938) "Databinding"
com.nxp.swtools.dcd.model (1.0.0.201905210938) "DCD model"
com.nxp.swtools.dcdx (1.0.0.201905210938) "DCDx"
com.nxp.swtools.dcdx.swt (1.0.0.201905210938) "DCDx SWT"
com.nxp.swtools.derivative (1.0.0.201905210938) "Config Tools Derivative"
com.nxp.swtools.derivative.rcp (1.0.0.201905210938) "derivative_rcp"
com.nxp.swtools.doc.kinetis (4.0.0.201905210938) "NXP Configuration Tools Documentation"
com.nxp.swtools.docannotations (1.0.0.201905210938) "Plugin for dynamic help generating support"
com.nxp.swtools.expert (1.0.0.201905210938) "Code shared for SWtools and PEx"
com.nxp.swtools.framework (4.0.0.201905210938) "Config Tools Framework"
com.nxp.swtools.framework.kinetis (6.0.0.201905210938) "Branding plug-in"
com.nxp.swtools.mux (5.0.0.201905210938) "Config Tools - Pins Tool"
com.nxp.swtools.mux.swt (1.0.0.201905210938) "Pins Swt"
com.nxp.swtools.periphs.controller (0.0.1.201905210938) "Config Tools - Peripherals Tool"
com.nxp.swtools.periphs.gui (5.0.0.201905210938) "Peripherals Tool Gui"
com.nxp.swtools.periphs.gui.swt (0.0.1.201905210938) "Peripherals Tool Gui Swt"
com.nxp.swtools.periphs.model (0.0.1.201905210938) "Peripherals Tool Model"
com.nxp.swtools.projectcloner (2.0.0.201905210938) "Project Cloner"
com.nxp.swtools.projectcloner.engine (2.0.0.201905210938) "KEx Project Cloner"
com.nxp.swtools.projectcloner.rcp (1.0.0.201905210938) "Project Cloner extension for standalone tool"
com.nxp.swtools.rcp (1.0.0.201905210938) "Eclipse integration plugin"
com.nxp.swtools.rcp.analytics (1.0.0.201905210938) "NXP Analytics Collector"
com.nxp.swtools.sdkmanifest (1.0.0.201905210938) "SDK Manifest"
com.nxp.swtools.sdkproject (1.0.0.201905210938) "SdkComponents"
com.nxp.swtools.sharedconfiguration (1.1.0.201905210938) "NXP Configuration Tools API provider"
com.nxp.swtools.tee.controller (0.0.1.201905210938) "MCUXpresso Configuration Tools - Trusted Execution Environment Tool"
com.nxp.swtools.tee.gui (0.0.1.201905210938) "Trusted Execution Environment tool gui"
com.nxp.swtools.tee.model (0.0.1.201905210938) "Trusted Execution Environment tool model"
com.nxp.swtools.tutorial (1.0.0.201905210938) "Tutorial"
com.nxp.swtools.ui.inspector (1.10.0.201905210938) "NXP Configuration Tools Inspector Plug-in"
com.nxp.swtools.ui.inspector.graphical (1.3.0.201905210938) "Generic Custom Views"
com.nxp.swtools.ui.targetcpu (1.6.0.201905210938) "Target Processor Plug-in"
com.nxp.swtools.ui.views (1.0.0.201905210938) "SWTools Common View API"
com.nxp.swtools.utils (1.0.0.201905210938) "NXP Configuration Tools Utils"
com.nxp.swtools.utils.support.markdown (1.0.0.201905210938) "Markdown support for eclipse oxygen and newer"
com.nxp.swtools.utils.swt (1.0.0.201905210938) "NXP Configuration Tools SWT Utils"
com.nxp.swtools.validation (1.1.0.201905210938) "NXP Configuration Tools Validation Engine"
com.sun.el (2.2.0.v201303151357) "Javax Expression Language Reference Implementation Bundle"
javax.activation (1.1.0.v201211130549) "Apache Geronimo Activation Plug-in"
javax.annotation (1.2.0.v201602091430) "javax.annotation Bundle"
javax.el (2.2.0.v201303151357) "Javax Expression Language Bundle"
javax.inject (1.0.0.v20091030) "Atinject Dependency Injection Annotations"
javax.servlet (3.1.0.v201410161800) "Servlet API Bundle"
javax.servlet.jsp (2.2.0.v201112011158) "JSP API Bundle"
javax.xml (1.3.4.v201005080400) "JAXP XML"
javax.xml.bind (2.2.0.v201105210648) "XML Binding for Java"
org.apache.batik.constants (1.10.0.v20180703-1553) "Batik constants library"
org.apache.batik.css (1.10.0.v20180703-1553) "Batik CSS engine"
org.apache.batik.i18n (1.10.0.v20180703-1553) "Batik i18n library"
org.apache.batik.util (1.10.0.v20180703-1553) "Batik utility library"
org.apache.commons.codec (1.10.0.v20180409-1845) "Apache Commons Codec"
org.apache.commons.io (2.2.0.v201405211200) "Apache Commons IO"
org.apache.commons.jxpath (1.3.0.v200911051830) "Apache Commons JXPath"
org.apache.commons.logging (1.2.0.v20180409-1502) "Apache Commons Logging"
org.apache.felix.gogo.command (1.0.2.v20170914-1324) "Apache Felix Gogo Command"
org.apache.felix.gogo.runtime (1.1.0.v20180713-1646) "Apache Felix Gogo Runtime"
org.apache.felix.gogo.shell (1.1.0.v20180713-1646) "Apache Felix Gogo Shell"
org.apache.felix.scr (2.0.14.v20180822-1822) "Apache Felix Declarative Services"
org.apache.httpcomponents.httpclient (4.5.5.v20180409-1525) "Apache HttpClient"
org.apache.httpcomponents.httpcore (4.4.9.v20180409-1525) "Apache HttpCore"
org.apache.jasper.glassfish (2.2.2.v201501141630) "JSP 2.2 implementation from Glassfish"
org.apache.lucene.analyzers-common (7.5.0.v20181003-1532) "Lucene Common Analyzers"
org.apache.lucene.analyzers-smartcn (7.5.0.v20181003-1532) "Lucene Smart Chinese Analyzer"
org.apache.lucene.core (7.5.0.v20181003-1532) "Lucene Core"
org.apache.xmlgraphics (2.2.0.v20180809-1640) "Apache XML Graphics Commons"
org.eclipse.cdt.core (6.6.0.201812101042) "C/C++ Development Tools Core"
org.eclipse.cdt.core.native (5.10.1.201811241055) "C/C++ Development Tools Core Native Utilities"
org.eclipse.cdt.ui (6.4.0.201811241855) "C/C++ Development Tools UI"
org.eclipse.compare (3.7.400.v20181109-1335) "Compare Support"
org.eclipse.compare.core (3.6.300.v20180827-1041) "Core Compare Support"
org.eclipse.compare.core.nl_zh (4.10.0.v20190126060001) "org.eclipse.compare.core Chinese (Simplified) NLS Support"
org.eclipse.compare.nl_zh (4.10.0.v20190126060001) "org.eclipse.compare Chinese (Simplified) NLS Support"
org.eclipse.compare.win32 (1.2.300.v20180926-0905) "Compare Support for Word"
org.eclipse.compare.win32.nl_zh (4.10.0.v20190126060001) "org.eclipse.compare.win32 Chinese (Simplified) NLS Support"
org.eclipse.core.commands (3.9.200.v20180827-1727) "Commands"
org.eclipse.core.commands.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.commands Chinese (Simplified) NLS Support"
org.eclipse.core.contenttype (3.7.200.v20181107-1343) "Eclipse Content Mechanism"
org.eclipse.core.contenttype.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.contenttype Chinese (Simplified) NLS Support"
org.eclipse.core.databinding (1.7.100.v20181030-1443) "JFace Data Binding"
org.eclipse.core.databinding.beans (1.4.300.v20181030-1443) "JFace Data Binding for JavaBeans"
org.eclipse.core.databinding.beans.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.databinding.beans Chinese (Simplified) NLS Support"
org.eclipse.core.databinding.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.databinding Chinese (Simplified) NLS Support"
org.eclipse.core.databinding.observable (1.6.300.v20180827-2028) "JFace Data Binding Observables"
org.eclipse.core.databinding.observable.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.databinding.observable Chinese (Simplified) NLS Support"
org.eclipse.core.databinding.property (1.6.300.v20180827-2028) "JFace Data Binding Properties"
org.eclipse.core.databinding.property.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.databinding.property Chinese (Simplified) NLS Support"
org.eclipse.core.expressions (3.6.200.v20180817-1401) "Expression Language"
org.eclipse.core.expressions.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.expressions Chinese (Simplified) NLS Support"
org.eclipse.core.filebuffers (3.6.400.v20181028-0633) "File Buffers"
org.eclipse.core.filebuffers.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.filebuffers Chinese (Simplified) NLS Support"
org.eclipse.core.filesystem (1.7.200.v20180828-0158) "Core File Systems"
org.eclipse.core.filesystem.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.filesystem Chinese (Simplified) NLS Support"
org.eclipse.core.filesystem.win32.x86_64 (1.4.100.v20180828-0158) "Core File System for Windows 64 bit"
org.eclipse.core.filesystem.win32.x86_64.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.filesystem.win32.x86_64 Chinese (Simplified) NLS Support"
org.eclipse.core.jobs (3.10.200.v20180912-1356) "Eclipse Jobs Mechanism"
org.eclipse.core.jobs.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.jobs Chinese (Simplified) NLS Support"
org.eclipse.core.net (1.3.400.v20181030-1645) "Internet Connection Management"
org.eclipse.core.net.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.net Chinese (Simplified) NLS Support"
org.eclipse.core.net.win32.x86_64 (1.1.300.v20181126-0635) "Proxy for Windows"
org.eclipse.core.net.win32.x86_64.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.net.win32.x86_64 Chinese (Simplified) NLS Support"
org.eclipse.core.resources (3.13.200.v20181121-1020) "Core Resource Management"
org.eclipse.core.resources.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.resources Chinese (Simplified) NLS Support"
org.eclipse.core.resources.win32.x86_64 (3.5.300.v20181030-1942) "Core Resource Management Win32 Fragment"
org.eclipse.core.resources.win32.x86_64.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.resources.win32.x86_64 Chinese (Simplified) NLS Support"
org.eclipse.core.runtime (3.15.100.v20181107-1343) "Core Runtime"
org.eclipse.core.runtime.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.runtime Chinese (Simplified) NLS Support"
org.eclipse.core.variables (3.4.300.v20181028-0627) "Core Variables"
org.eclipse.core.variables.nl_zh (4.10.0.v20190126060001) "org.eclipse.core.variables Chinese (Simplified) NLS Support"
org.eclipse.debug.core (3.13.100.v20181201-1650) "Debug Core"
org.eclipse.debug.core.nl_zh (4.10.0.v20190126060001) "org.eclipse.debug.core Chinese (Simplified) NLS Support"
org.eclipse.e4.core.commands (0.12.400.v20181119-1026) "Eclipse e4 core commands"
org.eclipse.e4.core.contexts (1.7.100.v20180817-1215) "Eclipse Contexts"
org.eclipse.e4.core.contexts.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.core.contexts Chinese (Simplified) NLS Support"
org.eclipse.e4.core.di (1.7.100.v20180817-1215) "Eclipse Dependency Injection"
org.eclipse.e4.core.di.annotations (1.6.200.v20180817-1215) "Eclipse Dependency Injection Annotations"
org.eclipse.e4.core.di.annotations.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.core.di.annotations Chinese (Simplified) NLS Support"
org.eclipse.e4.core.di.extensions (0.15.200.v20180817-1215) "Eclipse Dependency Injection Extensions"
org.eclipse.e4.core.di.extensions.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.core.di.extensions Chinese (Simplified) NLS Support"
org.eclipse.e4.core.di.extensions.supplier (0.15.200.v20180817-1215) "Eclipse Dependency Injection Extensions Supplier"
org.eclipse.e4.core.di.extensions.supplier.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.core.di.extensions.supplier Chinese (Simplified) NLS Support"
org.eclipse.e4.core.di.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.core.di Chinese (Simplified) NLS Support"
org.eclipse.e4.core.services (2.1.300.v20180930-0910) "Eclipse Application Services"
org.eclipse.e4.core.services.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.core.services Chinese (Simplified) NLS Support"
org.eclipse.e4.emf.xpath (0.2.200.v20180828-0227) "Eclipse Model Xpath"
org.eclipse.e4.emf.xpath.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.emf.xpath Chinese (Simplified) NLS Support"
org.eclipse.e4.ui.bindings (0.12.300.v20180913-1535) "Eclipse Bindings Support"
org.eclipse.e4.ui.css.core (0.12.400.v20180917-1628) "Eclipse CSS Core Support"
org.eclipse.e4.ui.css.core.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.ui.css.core Chinese (Simplified) NLS Support"
org.eclipse.e4.ui.css.swt (0.13.300.v20181030-1443) "Eclipse CSS SWT Support"
org.eclipse.e4.ui.css.swt.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.ui.css.swt Chinese (Simplified) NLS Support"
org.eclipse.e4.ui.css.swt.theme (0.12.100.v20180828-0227) "Eclipse CSS SWT Theme Support"
org.eclipse.e4.ui.css.swt.theme.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.ui.css.swt.theme Chinese (Simplified) NLS Support"
org.eclipse.e4.ui.di (1.2.400.v20180920-1522) "Eclipse UI Dependency Injection"
org.eclipse.e4.ui.di.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.ui.di Chinese (Simplified) NLS Support"
org.eclipse.e4.ui.dialogs (1.1.300.v20180828-0227) "Eclipse e4 dialogs"
org.eclipse.e4.ui.dialogs.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.ui.dialogs Chinese (Simplified) NLS Support"
org.eclipse.e4.ui.model.workbench (2.1.200.v20180920-1522) "Eclipse Workbench Model"
org.eclipse.e4.ui.model.workbench.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.ui.model.workbench Chinese (Simplified) NLS Support"
org.eclipse.e4.ui.services (1.3.300.v20180920-1522) "Eclipse UI Application Services"
org.eclipse.e4.ui.services.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.ui.services Chinese (Simplified) NLS Support"
org.eclipse.e4.ui.widgets (1.2.300.v20180920-1522) "Eclipse UI Custom widgets"
org.eclipse.e4.ui.widgets.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.ui.widgets Chinese (Simplified) NLS Support"
org.eclipse.e4.ui.workbench (1.8.0.v20181119-1304) "Eclipse e4 Workbench"
org.eclipse.e4.ui.workbench.addons.swt (1.3.300.v20181102-1042) "Eclipse e4 Workbench Add-ons"
org.eclipse.e4.ui.workbench.renderers.swt (0.14.400.v20181112-1716) "Eclipse e4 Workbench SWT Renderer"
org.eclipse.e4.ui.workbench.swt (0.14.400.v20181022-1348) "Eclipse e4 Workbench SWT"
org.eclipse.e4.ui.workbench3 (0.14.200.v20180828-0227) "Bundle for Workbench APIs available in e4"
org.eclipse.e4.ui.workbench3.nl_zh (4.10.0.v20190126060001) "org.eclipse.e4.ui.workbench3 Chinese (Simplified) NLS Support"
org.eclipse.ecf (3.9.3.v20181012-2016) "ECF Core API"
org.eclipse.ecf.filetransfer (5.0.100.v20180301-0132) "ECF Filetransfer API"
org.eclipse.ecf.identity (3.9.1.v20180810-0833) "ECF Identity Core API"
org.eclipse.ecf.provider.filetransfer (3.2.400.v20180306-0429) "ECF Filetransfer Provider"
org.eclipse.ecf.provider.filetransfer.httpclient4 (1.1.300.v20180301-0132) "ECF HttpComponents Filetransfer Provider"
org.eclipse.ecf.provider.filetransfer.httpclient4.ssl (1.1.100.v20180301-0132) "ECF HttpComponents Filetransfer Provider"
org.eclipse.ecf.provider.filetransfer.ssl (1.0.100.v20180301-0132) "ECF Filetransfer Provider"
org.eclipse.ecf.ssl (1.2.100.v20180301-0132) "ECF Core API"
org.eclipse.emf.ecore.change (2.13.0.v20180706-1146) "EMF Change Model"
org.eclipse.emf.ecore.xmi (2.15.0.v20180706-1146) "EMF XML/XMI Persistence"
org.eclipse.equinox.app (1.4.0.v20181009-1752) "Equinox Application Container"
org.eclipse.equinox.bidi (1.1.200.v20180827-1235) "Bidirectional Text Support"
org.eclipse.equinox.common (3.10.200.v20181021-1645) "Common Eclipse Runtime"
org.eclipse.equinox.concurrent (1.1.200.v20180827-1235) "Equinox Concurrent API"
org.eclipse.equinox.console (1.3.200.v20181115-0906) "Console plug-in"
org.eclipse.equinox.event (1.5.0.v20181008-1938) "Event Admin"
org.eclipse.equinox.frameworkadmin (2.1.100.v20180822-1258) "Equinox Framework Admin"
org.eclipse.equinox.frameworkadmin.equinox (1.1.100.v20180822-1258) "Equinox Framework Admin for Equinox"
org.eclipse.equinox.frameworkadmin.equinox.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.frameworkadmin.equinox Chinese (Simplified) NLS Support"
org.eclipse.equinox.frameworkadmin.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.frameworkadmin Chinese (Simplified) NLS Support"
org.eclipse.equinox.http.jetty (3.6.200.v20181115-1346) "Jetty Http Service"
org.eclipse.equinox.http.registry (1.1.600.v20180827-1235) "Http Service Registry Extensions"
org.eclipse.equinox.http.servlet (1.5.200.v20181008-1912) "Http Services Servlet"
org.eclipse.equinox.jsp.jasper (1.1.100.v20180827-1235) "Jasper Jsp Support Bundle"
org.eclipse.equinox.jsp.jasper.registry (1.1.100.v20180827-1235) "Jasper Jsp Registry Support Plug-in"
org.eclipse.equinox.launcher (1.5.200.v20180922-1751) "Equinox Launcher"
org.eclipse.equinox.launcher.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.launcher Chinese (Simplified) NLS Support"
org.eclipse.equinox.launcher.win32.win32.x86_64 (1.1.900.v20180922-1751) "Equinox Launcher Win32 X86_64 Fragment"
org.eclipse.equinox.launcher.win32.win32.x86_64.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.launcher.win32.win32.x86_64 Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.artifact.repository (1.2.200.v20181119-1308) "Equinox Provisioning Artifact Repository Support"
org.eclipse.equinox.p2.artifact.repository.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.artifact.repository Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.console (1.1.100.v20180822-1258) "Equinox Provisioning Console"
org.eclipse.equinox.p2.console.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.console Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.core (2.5.100.v20180822-1532) "Equinox Provisioning Core"
org.eclipse.equinox.p2.core.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.core Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.director (2.4.200.v20181102-0649) "Equinox Provisioning Director"
org.eclipse.equinox.p2.director.app (1.1.200.v20180822-1302) "Equinox Provisioning Director Application"
org.eclipse.equinox.p2.director.app.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.director.app Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.director.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.director Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.directorywatcher (1.2.100.v20180822-1302) "Equinox Provisioning Directory Watcher"
org.eclipse.equinox.p2.directorywatcher.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.directorywatcher Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.engine (2.6.100.v20180822-1302) "Equinox Provisioning Engine"
org.eclipse.equinox.p2.engine.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.engine Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.extensionlocation (1.3.100.v20180822-1302) "Equinox Provisioning Extension Location Repository Support"
org.eclipse.equinox.p2.extensionlocation.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.extensionlocation Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.garbagecollector (1.1.100.v20180822-1302) "Equinox Provisioning Garbage Collector"
org.eclipse.equinox.p2.garbagecollector.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.garbagecollector Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.jarprocessor (1.1.200.v20180921-1009) "Equinox Provisioning JAR Processor"
org.eclipse.equinox.p2.jarprocessor.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.jarprocessor Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.metadata (2.4.200.v20181102-0649) "Equinox Provisioning Metadata"
org.eclipse.equinox.p2.metadata.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.metadata Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.metadata.repository (1.3.100.v20180822-1302) "Equinox Provisioning Metadata Repository"
org.eclipse.equinox.p2.metadata.repository.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.metadata.repository Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.operations (2.5.200.v20180928-1359) "Equinox Provisioning Operations API"
org.eclipse.equinox.p2.operations.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.operations Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.publisher (1.5.100.v20180822-1302) "Equinox Provisioning Publisher Infrastructure"
org.eclipse.equinox.p2.publisher.eclipse (1.3.100.v20180822-1354) "Equinox Provisioning Publisher for Eclipse"
org.eclipse.equinox.p2.publisher.eclipse.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.publisher.eclipse Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.publisher.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.publisher Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.reconciler.dropins (1.3.0.v20181023-0914) "Equinox Provisioning Drop-in"
org.eclipse.equinox.p2.reconciler.dropins.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.reconciler.dropins Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.repository (2.4.200.v20181005-1131) "Equinox Provisioning Repository"
org.eclipse.equinox.p2.repository.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.repository Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.repository.tools (2.2.200.v20181102-0649) "Equinox Provisioning Repository Tools"
org.eclipse.equinox.p2.repository.tools.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.repository.tools Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.touchpoint.eclipse (2.2.200.v20181123-1405) "Equinox Provisioning Eclipse Touchpoint"
org.eclipse.equinox.p2.touchpoint.eclipse.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.touchpoint.eclipse Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.touchpoint.natives (1.3.200.v20180921-1019) "Equinox Provisioning Native Touchpoint"
org.eclipse.equinox.p2.touchpoint.natives.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.touchpoint.natives Chinese (Simplified) NLS Support"
org.eclipse.equinox.p2.transport.ecf (1.2.100.v20180822-1354) "Equinox Provisioning ECF based Transport"
org.eclipse.equinox.p2.transport.ecf.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.p2.transport.ecf Chinese (Simplified) NLS Support"
org.eclipse.equinox.preferences (3.7.200.v20180827-1235) "Eclipse Preferences Mechanism"
org.eclipse.equinox.registry (3.8.200.v20181008-1820) "Extension Registry Support"
org.eclipse.equinox.security (1.3.0.v20181115-0746) "Equinox Java Authentication and Authorization Service (JAAS)"
org.eclipse.equinox.security.win32.x86_64 (1.1.100.v20180827-1235) "Windows Data Protection services integration (64 bit)"
org.eclipse.equinox.simpleconfigurator (1.3.200.v20181101-1115) "Simple Configurator"
org.eclipse.equinox.simpleconfigurator.manipulator (2.1.200.v20181123-1405) "Simple Configurator Manipulator"
org.eclipse.equinox.simpleconfigurator.manipulator.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.simpleconfigurator.manipulator Chinese (Simplified) NLS Support"
org.eclipse.equinox.simpleconfigurator.nl_zh (4.10.0.v20190126060001) "org.eclipse.equinox.simpleconfigurator Chinese (Simplified) NLS Support"
org.eclipse.equinox.util (1.1.200.v20181008-1820) "Equinox Util Bundle"
org.eclipse.help (3.8.200.v20180821-0700) "Help System Core"
org.eclipse.help.base (4.2.400.v20181206-0815) "Help System Base"
org.eclipse.help.base.nl_zh (4.10.0.v20190126060001) "org.eclipse.help.base Chinese (Simplified) NLS Support"
org.eclipse.help.nl_zh (4.10.0.v20190126060001) "org.eclipse.help Chinese (Simplified) NLS Support"
org.eclipse.help.ui (4.1.300.v20181018-1136) "Help System UI"
org.eclipse.help.ui.nl_zh (4.10.0.v20190126060001) "org.eclipse.help.ui Chinese (Simplified) NLS Support"
org.eclipse.help.webapp (3.9.300.v20181127-2310) "Help System Webapp"
org.eclipse.help.webapp.nl_zh (4.10.0.v20190126060001) "org.eclipse.help.webapp Chinese (Simplified) NLS Support"
org.eclipse.jetty.continuation (9.4.14.v20181113) "Jetty :: Continuation"
org.eclipse.jetty.http (9.4.14.v20181113) "Jetty :: Http Utility"
org.eclipse.jetty.io (9.4.14.v20181113) "Jetty :: IO Utility"
org.eclipse.jetty.security (9.4.14.v20181113) "Jetty :: Security"
org.eclipse.jetty.server (9.4.14.v20181113) "Jetty :: Server Core"
org.eclipse.jetty.servlet (9.4.14.v20181113) "Jetty :: Servlet Handling"
org.eclipse.jetty.util (9.4.14.v20181113) "Jetty :: Utilities"
org.eclipse.jface (3.15.0.v20181123-1505) "JFace"
org.eclipse.jface.databinding (1.8.400.v20181030-1443) "JFace Data Binding for SWT and JFace"
org.eclipse.jface.databinding.nl_zh (4.10.0.v20190126060001) "org.eclipse.jface.databinding Chinese (Simplified) NLS Support"
org.eclipse.jface.nl_zh (4.10.0.v20190126060001) "org.eclipse.jface Chinese (Simplified) NLS Support"
org.eclipse.jface.text (3.15.0.v20181119-1708) "JFace Text"
org.eclipse.jface.text.nl_zh (4.10.0.v20190126060001) "org.eclipse.jface.text Chinese (Simplified) NLS Support"
org.eclipse.ltk.core.refactoring (3.9.200.v20181024-1629) "Refactoring Core"
org.eclipse.ltk.core.refactoring.nl_zh (4.10.0.v20190126060001) "org.eclipse.ltk.core.refactoring Chinese (Simplified) NLS Support"
org.eclipse.ltk.ui.refactoring (3.9.200.v20180828-0626) "Refactoring UI"
org.eclipse.ltk.ui.refactoring.nl_zh (4.10.0.v20190126060001) "org.eclipse.ltk.ui.refactoring Chinese (Simplified) NLS Support"
org.eclipse.mylyn.wikitext (3.0.25.20180620133858) "Mylyn WikiText"
org.eclipse.mylyn.wikitext.markdown (3.0.25.20180620133858) "Mylyn WikiText Markdown"
org.eclipse.nebula.widgets.grid (1.1.0.201803231500) "Nebula Grid"
org.eclipse.osgi (3.13.200.v20181130-2106) "OSGi System Bundle"
org.eclipse.osgi.compatibility.state (1.1.300.v20181116-1550) "Equinox State and Resolver Compatibility Fragment"
org.eclipse.osgi.compatibility.state.nl_zh (4.10.0.v20190126060001) "org.eclipse.osgi.compatibility.state Chinese (Simplified) NLS Support"
org.eclipse.osgi.nl_zh (4.10.0.v20190126060001) "org.eclipse.osgi Chinese (Simplified) NLS Support"
org.eclipse.osgi.services (3.7.100.v20180827-1536) "OSGi Release 4.2.0 Services"
org.eclipse.osgi.services.nl_zh (4.10.0.v20190126060001) "org.eclipse.osgi.services Chinese (Simplified) NLS Support"
org.eclipse.osgi.util (3.5.100.v20180827-1536) "OSGi Release 4.2.0 Utility Classes"
org.eclipse.osgi.util.nl_zh (4.10.0.v20190126060001) "org.eclipse.osgi.util Chinese (Simplified) NLS Support"
org.eclipse.search (3.11.400.v20181028-0633) "Search Support"
org.eclipse.search.nl_zh (4.10.0.v20190126060001) "org.eclipse.search Chinese (Simplified) NLS Support"
org.eclipse.swt (3.109.0.v20181204-1801) "Standard Widget Toolkit"
org.eclipse.swt.nl_zh (4.10.0.v20190126060001) "org.eclipse.swt Chinese (Simplified) NLS Support"
org.eclipse.swt.win32.win32.x86_64 (3.109.0.v20181204-1801) "Standard Widget Toolkit for Windows"
org.eclipse.team.core (3.8.400.v20181109-0825) "Team Support Core"
org.eclipse.team.core.nl_zh (4.10.0.v20190126060001) "org.eclipse.team.core Chinese (Simplified) NLS Support"
org.eclipse.team.ui (3.8.300.v20181030-1259) "Team Support UI"
org.eclipse.team.ui.nl_zh (4.10.0.v20190126060001) "org.eclipse.team.ui Chinese (Simplified) NLS Support"
org.eclipse.text (3.8.0.v20180923-1636) "Text"
org.eclipse.text.nl_zh (4.10.0.v20190126060001) "org.eclipse.text Chinese (Simplified) NLS Support"
org.eclipse.tools.templates.core (1.1.0.201812111206) "Template Engine Core"
org.eclipse.tools.templates.ui (1.1.1.201812111206) "Template Engine UI"
org.eclipse.ui (3.111.0.v20181117-0847) "Eclipse UI"
org.eclipse.ui.cheatsheets (3.5.300.v20180823-1505) "Cheat Sheets"
org.eclipse.ui.cheatsheets.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.cheatsheets Chinese (Simplified) NLS Support"
org.eclipse.ui.console (3.8.300.v20181019-1609) "Console"
org.eclipse.ui.console.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.console Chinese (Simplified) NLS Support"
org.eclipse.ui.editors (3.11.300.v20180914-0606) "Default Text Editor"
org.eclipse.ui.editors.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.editors Chinese (Simplified) NLS Support"
org.eclipse.ui.forms (3.7.400.v20181123-1505) "Eclipse Forms"
org.eclipse.ui.forms.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.forms Chinese (Simplified) NLS Support"
org.eclipse.ui.ide (3.14.200.v20181205-2143) "Eclipse IDE UI"
org.eclipse.ui.ide.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.ide Chinese (Simplified) NLS Support"
org.eclipse.ui.navigator (3.7.300.v20181016-1531) "Common Navigator View"
org.eclipse.ui.navigator.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.navigator Chinese (Simplified) NLS Support"
org.eclipse.ui.navigator.resources (3.6.300.v20181110-1011) "Navigator Workbench Components"
org.eclipse.ui.navigator.resources.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.navigator.resources Chinese (Simplified) NLS Support"
org.eclipse.ui.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui Chinese (Simplified) NLS Support"
org.eclipse.ui.themes (1.2.300.v20181108-1102) "Eclipse SDK Themes"
org.eclipse.ui.themes.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.themes Chinese (Simplified) NLS Support"
org.eclipse.ui.views (3.9.200.v20180828-0837) "Views"
org.eclipse.ui.views.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.views Chinese (Simplified) NLS Support"
org.eclipse.ui.views.properties.tabbed (3.8.300.v20180921-1036) "Tabbed Properties View"
org.eclipse.ui.views.properties.tabbed.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.views.properties.tabbed Chinese (Simplified) NLS Support"
org.eclipse.ui.win32.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.win32 Chinese (Simplified) NLS Support"
org.eclipse.ui.workbench (3.112.100.v20181127-1518) "Eclipse Workbench"
org.eclipse.ui.workbench.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.workbench Chinese (Simplified) NLS Support"
org.eclipse.ui.workbench.texteditor (3.11.200.v20181108-1458) "Text Editor Framework"
org.eclipse.ui.workbench.texteditor.nl_zh (4.10.0.v20190126060001) "org.eclipse.ui.workbench.texteditor Chinese (Simplified) NLS Support"
org.eclipse.update.configurator (3.4.100.v20180821-1913) "Install/Update Configurator"
org.eclipse.update.configurator.nl_zh (4.10.0.v20190126060001) "org.eclipse.update.configurator Chinese (Simplified) NLS Support"
org.jsoup (1.7.2.v201411291515) "jsoup: Java HTML Parser"
org.sat4j.core (2.3.5.v201308161310) "SAT4J Core"
org.sat4j.pb (2.3.5.v201404071733) "SAT4J Pseudo"
org.simpleframework.xml (2.7.1.201905210938) "simpleframework.xml"
org.tukaani.xz (1.8.0.v20180207-1613) "XZ for Java"
org.w3c.css.sac (1.3.1.v200903091627) "W3C CSS SAC"
org.w3c.dom.events (3.0.0.draft20060413_v201105210656) "W3C DOM Level 3 Events"
org.w3c.dom.smil (1.0.1.v200903091627) "W3C SMIL DOM"
org.w3c.dom.svg (1.1.0.v201011041433) "W3C SVG DOM"
org.yaml.snakeyaml (1.0.0.201905210938) "Snakeyaml"
      • User Preferences:
#Tue Jul 09 10:49:32 EDT 2019
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.AddedLinesRegex=
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.CappingDisable=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.HighlightTokenChanges=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.IgnoreWhitespace=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.InitiallyShowAncestorPane=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.NavigationEndAction=prompt
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.NavigationEndActionLocal=loop
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.OpenStructureCompare=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.PathFilter=
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.RemovedLinesRegex=
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.SaveAllEditors=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.ShowPseudoConflicts=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.Swapped=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.SynchronizeScrolling=true
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.UseOutlineView=false
/bundle_defaults/org.eclipse.compare/org.eclipse.compare.UseSingleLine=true
/bundle_defaults/org.eclipse.core.resources/delta.expiration=2592000000
/bundle_defaults/org.eclipse.core.resources/description.applyfilestatepolicy=true
/bundle_defaults/org.eclipse.core.resources/description.autobuilding=true
/bundle_defaults/org.eclipse.core.resources/description.buildorder=
/bundle_defaults/org.eclipse.core.resources/description.defaultbuildorder=true
/bundle_defaults/org.eclipse.core.resources/description.disableLinking=false
/bundle_defaults/org.eclipse.core.resources/description.filestatelongevity=604800000
/bundle_defaults/org.eclipse.core.resources/description.maxbuilditerations=10
/bundle_defaults/org.eclipse.core.resources/description.maxfilestates=50
/bundle_defaults/org.eclipse.core.resources/description.maxfilestatesize=1048576
/bundle_defaults/org.eclipse.core.resources/description.snapshotinterval=300000
/bundle_defaults/org.eclipse.core.resources/encoding=
/bundle_defaults/org.eclipse.core.resources/maxConcurrentBuilds=1
/bundle_defaults/org.eclipse.core.resources/missingNatureMarkerSeverity=1
/bundle_defaults/org.eclipse.core.resources/refresh.enabled=false
/bundle_defaults/org.eclipse.core.resources/refresh.lightweight.enabled=true
/bundle_defaults/org.eclipse.core.resources/snapshots.operations=100
/bundle_defaults/org.eclipse.ui.ide/BOOKMARKS_FILTERS_MIGRATE=false
/bundle_defaults/org.eclipse.ui.ide/CLOSE_UNRELATED_PROJECTS=false
/bundle_defaults/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDOW=true
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_MODE=prompt
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_RELATIVE=true
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_TYPE=
/bundle_defaults/org.eclipse.ui.ide/IMPORT_FILES_AND_FOLDERS_VIRTUAL_FOLDER_MODE=prompt
/bundle_defaults/org.eclipse.ui.ide/LIMIT_PROBLEMS=true
/bundle_defaults/org.eclipse.ui.ide/MARKER_LIMITS_VALUE=100
/bundle_defaults/org.eclipse.ui.ide/OPEN_REQUIRED_PROJECTS=prompt
/bundle_defaults/org.eclipse.ui.ide/PROBLEMS_FILTERS_MIGRATE=false
/bundle_defaults/org.eclipse.ui.ide/PROBLEMS_LIMIT=100
/bundle_defaults/org.eclipse.ui.ide/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui.ide/REFRESH_WORKSPACE_ON_STARTUP=false
/bundle_defaults/org.eclipse.ui.ide/SAVE_ALL_BEFORE_BUILD=false
/bundle_defaults/org.eclipse.ui.ide/SHOW_LOCATION=false
/bundle_defaults/org.eclipse.ui.ide/SHOW_LOCATION_NAME=true
/bundle_defaults/org.eclipse.ui.ide/SHOW_PERSPECTIVE_IN_TITLE=false
/bundle_defaults/org.eclipse.ui.ide/SHOW_PROBLEMS_VIEW_DECORATIONS_ON_STARTUP=false
/bundle_defaults/org.eclipse.ui.ide/SHOW_PRODUCT_IN_TITLE=true
/bundle_defaults/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=true
/bundle_defaults/org.eclipse.ui.ide/SWITCH_PERSPECTIVE_ON_PROJECT_CREATION=prompt
/bundle_defaults/org.eclipse.ui.ide/SYSTEM_EXPLORER=explorer /E,/select\=$
/bundle_defaults/org.eclipse.ui.ide/TASKS_FILTERS_MIGRATE=false
/bundle_defaults/org.eclipse.ui.ide/USE_MARKER_LIMITS=true
/bundle_defaults/org.eclipse.ui.ide/WARN_ABOUT_WORKSPACE_INCOMPATIBILITY=true
/bundle_defaults/org.eclipse.ui.ide/WELCOME_DIALOG=true
/bundle_defaults/org.eclipse.ui.ide/saveInterval=5
/bundle_defaults/org.eclipse.ui.ide/unassociatedEditorStrategy=org.eclipse.ui.ide.systemEditorThenTextEditor
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.assist=true
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.main=true
/bundle_defaults/org.eclipse.ui.ide/useSeparator.help.group.updates=true
/bundle_defaults/org.eclipse.ui.workbench/BIDI_SUPPORT=false
/bundle_defaults/org.eclipse.ui.workbench/COLOR_ICONS=true
/bundle_defaults/org.eclipse.ui.workbench/DISABLE_DIALOG_FONT=false
/bundle_defaults/org.eclipse.ui.workbench/DISABLE_OPEN_EDITOR_IN_PLACE=false
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_DISPLAY_FULL_NAME=false
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_PULLDOWN_ACTIVE=false
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_SELECTION_SCOPE=1
/bundle_defaults/org.eclipse.ui.workbench/EDITORLIST_SORT_CRITERIA=0
/bundle_defaults/org.eclipse.ui.workbench/EDITOR_TAB_WIDTH=3
/bundle_defaults/org.eclipse.ui.workbench/ENABLED_DECORATORS=
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_CONFIGURABLE_PROJECT_WIZARD=false
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_COOL_BARS=true
/bundle_defaults/org.eclipse.ui.workbench/ENABLE_NEW_MENUS=true
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.showMax=false
/bundle_defaults/org.eclipse.ui.workbench/HeapStatus.updateInterval=500
/bundle_defaults/org.eclipse.ui.workbench/KEYS_PREFERENCE_SELECTED_TAB=0
/bundle_defaults/org.eclipse.ui.workbench/LAYOUT_DIRECTION=0
/bundle_defaults/org.eclipse.ui.workbench/MAX_PROGRESS_ENTRIES=20
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST=true
/bundle_defaults/org.eclipse.ui.workbench/MULTI_KEY_ASSIST_TIME=1000
/bundle_defaults/org.eclipse.ui.workbench/NL_EXTENSIONS=
/bundle_defaults/org.eclipse.ui.workbench/OPEN_AFTER_DELAY=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_ON_SINGLE_CLICK=false
/bundle_defaults/org.eclipse.ui.workbench/OPEN_PERSPECTIVE_MODE=0
/bundle_defaults/org.eclipse.ui.workbench/RECENT_FILES=20
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS=8
/bundle_defaults/org.eclipse.ui.workbench/REUSE_OPEN_EDITORS_BOOLEAN=false
/bundle_defaults/org.eclipse.ui.workbench/RUN_IN_BACKGROUND=true
/bundle_defaults/org.eclipse.ui.workbench/SAVE_AUTOMATICALLY=false
/bundle_defaults/org.eclipse.ui.workbench/SAVE_AUTOMATICALLY_INTERVAL=20
/bundle_defaults/org.eclipse.ui.workbench/SELECT_ON_HOVER=false
/bundle_defaults/org.eclipse.ui.workbench/SHOW_MEMORY_MONITOR=false
/bundle_defaults/org.eclipse.ui.workbench/SINGLE_CLICK_METHOD=0
/bundle_defaults/org.eclipse.ui.workbench/STICKY_CYCLE=false
/bundle_defaults/org.eclipse.ui.workbench/TEXT_DIRECTION=
/bundle_defaults/org.eclipse.ui.workbench/USE_IPERSISTABLE_EDITORS=true
/bundle_defaults/org.eclipse.ui.workbench/WORKBENCH_SAVE_INTERVAL=5
/bundle_defaults/org.eclipse.ui.workbench/coolBarVisible=true
/bundle_defaults/org.eclipse.ui.workbench/overridepresentation=false
/bundle_defaults/org.eclipse.ui.workbench/perspectiveBarVisible=true
/bundle_defaults/org.eclipse.ui.workbench/shouldPromptForEnablement=true
/bundle_defaults/org.eclipse.ui/ALTERNATE_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui/CLOSE_EDITORS_ON_EXIT=false
/bundle_defaults/org.eclipse.ui/DOCK_PERSPECTIVE_BAR=topLeft
/bundle_defaults/org.eclipse.ui/EDITOR_MINIMUM_CHARACTERS=-1
/bundle_defaults/org.eclipse.ui/EDITOR_TAB_POSITION=128
/bundle_defaults/org.eclipse.ui/ENABLE_32_STICKY_CLOSE_BEHAVIOR=false
/bundle_defaults/org.eclipse.ui/ENABLE_ANIMATIONS=false
/bundle_defaults/org.eclipse.ui/ENABLE_DETACHED_VIEWS=true
/bundle_defaults/org.eclipse.ui/ENABLE_MIN_MAX=true
/bundle_defaults/org.eclipse.ui/KEY_CONFIGURATION_ID=org.eclipse.ui.defaultAcceleratorConfiguration
/bundle_defaults/org.eclipse.ui/LINK_NAVIGATOR_TO_EDITOR=false
/bundle_defaults/org.eclipse.ui/OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui/PROJECT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui/PROMPT_WHEN_SAVEABLE_STILL_OPEN=true
/bundle_defaults/org.eclipse.ui/RECENTLY_USED_WORKINGSETS_SIZE=5
/bundle_defaults/org.eclipse.ui/SHIFT_OPEN_NEW_PERSPECTIVE=OPEN_PERSPECTIVE_REPLACE
/bundle_defaults/org.eclipse.ui/SHOW_FILTERED_TEXTS=true
/bundle_defaults/org.eclipse.ui/SHOW_MULTIPLE_EDITOR_TABS=true
/bundle_defaults/org.eclipse.ui/SHOW_OPEN_ON_PERSPECTIVE_BAR=true
/bundle_defaults/org.eclipse.ui/SHOW_OTHER_IN_PERSPECTIVE_MENU=true
/bundle_defaults/org.eclipse.ui/SHOW_SYSTEM_JOBS=false
/bundle_defaults/org.eclipse.ui/SHOW_TEXT_ON_PERSPECTIVE_BAR=false
/bundle_defaults/org.eclipse.ui/SHOW_TRADITIONAL_STYLE_TABS=true
/bundle_defaults/org.eclipse.ui/USE_COLORED_LABELS=true
/bundle_defaults/org.eclipse.ui/USE_WINDOW_WORKING_SET_BY_DEFAULT=false
/bundle_defaults/org.eclipse.ui/VIEW_MINIMUM_CHARACTERS=1
/bundle_defaults/org.eclipse.ui/VIEW_TAB_POSITION=128
/bundle_defaults/org.eclipse.ui/disableNewFastView=false
/bundle_defaults/org.eclipse.ui/initialFastViewBarLocation=bottom
/bundle_defaults/org.eclipse.ui/showIntro=true
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.ui.workbench//org.eclipse.ui.commands/state/org.eclipse.ui.navigator.resources.nested.changeProjectPresentation/org.eclipse.ui.commands.radioState=false
/instance/org.eclipse.ui/showIntro=false
@org.eclipse.core.resources=3.13.200.v20181121-1020
@org.eclipse.ui=3.111.0.v20181117-0847
@org.eclipse.ui.workbench=3.112.100.v20181127-1518
file_export_version=3.0
      • Current Install Configuration:
Bundles in the system:
Id: com.google.gson, Version: 2.8.2.v20180104-1110, Location: initial@reference:file:plugins/com.google.gson_2.8.2.v20180104-1110.jar
Id: com.google.guava, Version: 21.0.0.v20170206-1425, Location: initial@reference:file:plugins/com.google.guava_21.0.0.v20170206-1425.jar
Id: com.ibm.icu, Version: 63.1.0.v20181030-1705, Location: initial@reference:file:plugins/com.ibm.icu_63.1.0.v20181030-1705.jar
Id: com.nxp.kex.standalone, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.kex.standalone_1.0.0.201905210938.jar
Id: com.nxp.swtools.clocks, Version: 5.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.clocks_5.0.0.201905210938.jar
Id: com.nxp.swtools.clocks.model, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.clocks.model_1.0.0.201905210938.jar
Id: com.nxp.swtools.clocks.swt, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.clocks.swt_1.0.0.201905210938.jar
Id: com.nxp.swtools.common.ui.utils, Version: 1.4.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.common.ui.utils_1.4.0.201905210938.jar
Id: com.nxp.swtools.common.ui.utils.swt, Version: 1.2.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.common.ui.utils.swt_1.2.0.201905210938.jar
Id: com.nxp.swtools.common.utils, Version: 1.1.1.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.common.utils_1.1.1.201905210938.jar
Id: com.nxp.swtools.configuration, Version: 1.6.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.configuration_1.6.0.201905210938.jar
Id: com.nxp.swtools.core, Version: 1.10.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.core_1.10.0.201905210938.jar
Id: com.nxp.swtools.core.service, Version: 1.13.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.core.service_1.13.0.201905210938.jar
Id: com.nxp.swtools.dashboard, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.dashboard_1.0.0.201905210938.jar
Id: com.nxp.swtools.databinding, Version: 1.4.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.databinding_1.4.0.201905210938.jar
Id: com.nxp.swtools.dcd.model, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.dcd.model_1.0.0.201905210938.jar
Id: com.nxp.swtools.dcdx, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.dcdx_1.0.0.201905210938.jar
Id: com.nxp.swtools.dcdx.swt, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.dcdx.swt_1.0.0.201905210938.jar
Id: com.nxp.swtools.derivative, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.derivative_1.0.0.201905210938.jar
Id: com.nxp.swtools.derivative.rcp, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.derivative.rcp_1.0.0.201905210938.jar
Id: com.nxp.swtools.doc.kinetis, Version: 4.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.doc.kinetis_4.0.0.201905210938/
Id: com.nxp.swtools.docannotations, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.docannotations_1.0.0.201905210938.jar
Id: com.nxp.swtools.expert, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.expert_1.0.0.201905210938.jar
Id: com.nxp.swtools.framework, Version: 4.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.framework_4.0.0.201905210938.jar
Id: com.nxp.swtools.framework.kinetis, Version: 6.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.framework.kinetis_6.0.0.201905210938.jar
Id: com.nxp.swtools.mux, Version: 5.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.mux_5.0.0.201905210938.jar
Id: com.nxp.swtools.mux.swt, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.mux.swt_1.0.0.201905210938.jar
Id: com.nxp.swtools.periphs.controller, Version: 0.0.1.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.periphs.controller_0.0.1.201905210938.jar
Id: com.nxp.swtools.periphs.gui, Version: 5.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.periphs.gui_5.0.0.201905210938.jar
Id: com.nxp.swtools.periphs.gui.swt, Version: 0.0.1.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.periphs.gui.swt_0.0.1.201905210938.jar
Id: com.nxp.swtools.periphs.model, Version: 0.0.1.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.periphs.model_0.0.1.201905210938.jar
Id: com.nxp.swtools.projectcloner, Version: 2.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.projectcloner_2.0.0.201905210938.jar
Id: com.nxp.swtools.projectcloner.engine, Version: 2.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.projectcloner.engine_2.0.0.201905210938.jar
Id: com.nxp.swtools.projectcloner.rcp, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.projectcloner.rcp_1.0.0.201905210938.jar
Id: com.nxp.swtools.rcp, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.rcp_1.0.0.201905210938.jar
Id: com.nxp.swtools.rcp.analytics, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.rcp.analytics_1.0.0.201905210938.jar
Id: com.nxp.swtools.sdkmanifest, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.sdkmanifest_1.0.0.201905210938.jar
Id: com.nxp.swtools.sdkproject, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.sdkproject_1.0.0.201905210938.jar
Id: com.nxp.swtools.sharedconfiguration, Version: 1.1.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.sharedconfiguration_1.1.0.201905210938.jar
Id: com.nxp.swtools.tee.controller, Version: 0.0.1.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.tee.controller_0.0.1.201905210938.jar
Id: com.nxp.swtools.tee.gui, Version: 0.0.1.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.tee.gui_0.0.1.201905210938.jar
Id: com.nxp.swtools.tee.model, Version: 0.0.1.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.tee.model_0.0.1.201905210938.jar
Id: com.nxp.swtools.tutorial, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.tutorial_1.0.0.201905210938.jar
Id: com.nxp.swtools.ui.inspector, Version: 1.10.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.ui.inspector_1.10.0.201905210938.jar
Id: com.nxp.swtools.ui.inspector.graphical, Version: 1.3.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.ui.inspector.graphical_1.3.0.201905210938.jar
Id: com.nxp.swtools.ui.targetcpu, Version: 1.6.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.ui.targetcpu_1.6.0.201905210938.jar
Id: com.nxp.swtools.ui.views, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.ui.views_1.0.0.201905210938.jar
Id: com.nxp.swtools.utils, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.utils_1.0.0.201905210938.jar
Id: com.nxp.swtools.utils.support.markdown, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.utils.support.markdown_1.0.0.201905210938.jar
Id: com.nxp.swtools.utils.swt, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.utils.swt_1.0.0.201905210938.jar
Id: com.nxp.swtools.validation, Version: 1.1.0.201905210938, Location: initial@reference:file:plugins/com.nxp.swtools.validation_1.1.0.201905210938.jar
Id: com.sun.el, Version: 2.2.0.v201303151357, Location: initial@reference:file:plugins/com.sun.el_2.2.0.v201303151357.jar
Id: javax.activation, Version: 1.1.0.v201211130549, Location: initial@reference:file:plugins/javax.activation_1.1.0.v201211130549.jar
Id: javax.annotation, Version: 1.2.0.v201602091430, Location: initial@reference:file:plugins/javax.annotation_1.2.0.v201602091430.jar
Id: javax.el, Version: 2.2.0.v201303151357, Location: initial@reference:file:plugins/javax.el_2.2.0.v201303151357.jar
Id: javax.inject, Version: 1.0.0.v20091030, Location: initial@reference:file:plugins/javax.inject_1.0.0.v20091030.jar
Id: javax.servlet, Version: 3.1.0.v201410161800, Location: initial@reference:file:plugins/javax.servlet_3.1.0.v201410161800.jar
Id: javax.servlet.jsp, Version: 2.2.0.v201112011158, Location: initial@reference:file:plugins/javax.servlet.jsp_2.2.0.v201112011158.jar
Id: javax.xml, Version: 1.3.4.v201005080400, Location: initial@reference:file:plugins/javax.xml_1.3.4.v201005080400.jar
Id: javax.xml.bind, Version: 2.2.0.v201105210648, Location: initial@reference:file:plugins/javax.xml.bind_2.2.0.v201105210648.jar
Id: org.apache.batik.constants, Version: 1.10.0.v20180703-1553, Location: initial@reference:file:plugins/org.apache.batik.constants_1.10.0.v20180703-1553.jar
Id: org.apache.batik.css, Version: 1.10.0.v20180703-1553, Location: initial@reference:file:plugins/org.apache.batik.css_1.10.0.v20180703-1553.jar
Id: org.apache.batik.i18n, Version: 1.10.0.v20180703-1553, Location: initial@reference:file:plugins/org.apache.batik.i18n_1.10.0.v20180703-1553.jar
Id: org.apache.batik.util, Version: 1.10.0.v20180703-1553, Location: initial@reference:file:plugins/org.apache.batik.util_1.10.0.v20180703-1553.jar
Id: org.apache.commons.codec, Version: 1.10.0.v20180409-1845, Location: initial@reference:file:plugins/org.apache.commons.codec_1.10.0.v20180409-1845.jar
Id: org.apache.commons.io, Version: 2.2.0.v201405211200, Location: initial@reference:file:plugins/org.apache.commons.io_2.2.0.v201405211200.jar
Id: org.apache.commons.jxpath, Version: 1.3.0.v200911051830, Location: initial@reference:file:plugins/org.apache.commons.jxpath_1.3.0.v200911051830.jar
Id: org.apache.commons.logging, Version: 1.2.0.v20180409-1502, Location: initial@reference:file:plugins/org.apache.commons.logging_1.2.0.v20180409-1502.jar
Id: org.apache.felix.gogo.command, Version: 1.0.2.v20170914-1324, Location: initial@reference:file:plugins/org.apache.felix.gogo.command_1.0.2.v20170914-1324.jar
Id: org.apache.felix.gogo.runtime, Version: 1.1.0.v20180713-1646, Location: initial@reference:file:plugins/org.apache.felix.gogo.runtime_1.1.0.v20180713-1646.jar
Id: org.apache.felix.gogo.shell, Version: 1.1.0.v20180713-1646, Location: initial@reference:file:plugins/org.apache.felix.gogo.shell_1.1.0.v20180713-1646.jar
Id: org.apache.felix.scr, Version: 2.0.14.v20180822-1822, Location: initial@reference:file:plugins/org.apache.felix.scr_2.0.14.v20180822-1822.jar
Id: org.apache.httpcomponents.httpclient, Version: 4.5.5.v20180409-1525, Location: initial@reference:file:plugins/org.apache.httpcomponents.httpclient_4.5.5.v20180409-1525.jar
Id: org.apache.httpcomponents.httpcore, Version: 4.4.9.v20180409-1525, Location: initial@reference:file:plugins/org.apache.httpcomponents.httpcore_4.4.9.v20180409-1525.jar
Id: org.apache.jasper.glassfish, Version: 2.2.2.v201501141630, Location: initial@reference:file:plugins/org.apache.jasper.glassfish_2.2.2.v201501141630.jar
Id: org.apache.lucene.analyzers-common, Version: 7.5.0.v20181003-1532, Location: initial@reference:file:plugins/org.apache.lucene.analyzers-common_7.5.0.v20181003-1532.jar
Id: org.apache.lucene.analyzers-smartcn, Version: 7.5.0.v20181003-1532, Location: initial@reference:file:plugins/org.apache.lucene.analyzers-smartcn_7.5.0.v20181003-1532.jar
Id: org.apache.lucene.core, Version: 7.5.0.v20181003-1532, Location: initial@reference:file:plugins/org.apache.lucene.core_7.5.0.v20181003-1532.jar
Id: org.apache.xmlgraphics, Version: 2.2.0.v20180809-1640, Location: initial@reference:file:plugins/org.apache.xmlgraphics_2.2.0.v20180809-1640.jar
Id: org.eclipse.cdt.core, Version: 6.6.0.201812101042, Location: initial@reference:file:plugins/org.eclipse.cdt.core_6.6.0.201812101042.jar
Id: org.eclipse.cdt.core.native, Version: 5.10.1.201811241055, Location: initial@reference:file:plugins/org.eclipse.cdt.core.native_5.10.1.201811241055.jar
Id: org.eclipse.cdt.ui, Version: 6.4.0.201811241855, Location: initial@reference:file:plugins/org.eclipse.cdt.ui_6.4.0.201811241855.jar
Id: org.eclipse.compare, Version: 3.7.400.v20181109-1335, Location: initial@reference:file:plugins/org.eclipse.compare_3.7.400.v20181109-1335.jar
Id: org.eclipse.compare.core, Version: 3.6.300.v20180827-1041, Location: initial@reference:file:plugins/org.eclipse.compare.core_3.6.300.v20180827-1041.jar
Id: org.eclipse.compare.core.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.compare.core.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.compare.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.compare.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.compare.win32, Version: 1.2.300.v20180926-0905, Location: initial@reference:file:plugins/org.eclipse.compare.win32_1.2.300.v20180926-0905.jar
Id: org.eclipse.compare.win32.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.compare.win32.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.commands, Version: 3.9.200.v20180827-1727, Location: initial@reference:file:plugins/org.eclipse.core.commands_3.9.200.v20180827-1727.jar
Id: org.eclipse.core.commands.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.commands.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.contenttype, Version: 3.7.200.v20181107-1343, Location: initial@reference:file:plugins/org.eclipse.core.contenttype_3.7.200.v20181107-1343.jar
Id: org.eclipse.core.contenttype.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.contenttype.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.databinding, Version: 1.7.100.v20181030-1443, Location: initial@reference:file:plugins/org.eclipse.core.databinding_1.7.100.v20181030-1443.jar
Id: org.eclipse.core.databinding.beans, Version: 1.4.300.v20181030-1443, Location: initial@reference:file:plugins/org.eclipse.core.databinding.beans_1.4.300.v20181030-1443.jar
Id: org.eclipse.core.databinding.beans.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.databinding.beans.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.databinding.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.databinding.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.databinding.observable, Version: 1.6.300.v20180827-2028, Location: initial@reference:file:plugins/org.eclipse.core.databinding.observable_1.6.300.v20180827-2028.jar
Id: org.eclipse.core.databinding.observable.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.databinding.observable.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.databinding.property, Version: 1.6.300.v20180827-2028, Location: initial@reference:file:plugins/org.eclipse.core.databinding.property_1.6.300.v20180827-2028.jar
Id: org.eclipse.core.databinding.property.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.databinding.property.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.expressions, Version: 3.6.200.v20180817-1401, Location: initial@reference:file:plugins/org.eclipse.core.expressions_3.6.200.v20180817-1401.jar
Id: org.eclipse.core.expressions.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.expressions.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.filebuffers, Version: 3.6.400.v20181028-0633, Location: initial@reference:file:plugins/org.eclipse.core.filebuffers_3.6.400.v20181028-0633.jar
Id: org.eclipse.core.filebuffers.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.filebuffers.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.filesystem, Version: 1.7.200.v20180828-0158, Location: initial@reference:file:plugins/org.eclipse.core.filesystem_1.7.200.v20180828-0158.jar
Id: org.eclipse.core.filesystem.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.filesystem.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.filesystem.win32.x86_64, Version: 1.4.100.v20180828-0158, Location: initial@reference:file:plugins/org.eclipse.core.filesystem.win32.x86_64_1.4.100.v20180828-0158.jar
Id: org.eclipse.core.filesystem.win32.x86_64.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.filesystem.win32.x86_64.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.jobs, Version: 3.10.200.v20180912-1356, Location: initial@reference:file:plugins/org.eclipse.core.jobs_3.10.200.v20180912-1356.jar
Id: org.eclipse.core.jobs.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.jobs.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.net, Version: 1.3.400.v20181030-1645, Location: initial@reference:file:plugins/org.eclipse.core.net_1.3.400.v20181030-1645.jar
Id: org.eclipse.core.net.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.net.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.net.win32.x86_64, Version: 1.1.300.v20181126-0635, Location: initial@reference:file:plugins/org.eclipse.core.net.win32.x86_64_1.1.300.v20181126-0635.jar
Id: org.eclipse.core.net.win32.x86_64.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.net.win32.x86_64.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.resources, Version: 3.13.200.v20181121-1020, Location: initial@reference:file:plugins/org.eclipse.core.resources_3.13.200.v20181121-1020.jar
Id: org.eclipse.core.resources.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.resources.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.resources.win32.x86_64, Version: 3.5.300.v20181030-1942, Location: initial@reference:file:plugins/org.eclipse.core.resources.win32.x86_64_3.5.300.v20181030-1942.jar
Id: org.eclipse.core.resources.win32.x86_64.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.resources.win32.x86_64.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.runtime, Version: 3.15.100.v20181107-1343, Location: initial@reference:file:plugins/org.eclipse.core.runtime_3.15.100.v20181107-1343.jar
Id: org.eclipse.core.runtime.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.runtime.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.core.variables, Version: 3.4.300.v20181028-0627, Location: initial@reference:file:plugins/org.eclipse.core.variables_3.4.300.v20181028-0627.jar
Id: org.eclipse.core.variables.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.core.variables.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.debug.core, Version: 3.13.100.v20181201-1650, Location: initial@reference:file:plugins/org.eclipse.debug.core_3.13.100.v20181201-1650.jar
Id: org.eclipse.debug.core.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.debug.core.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.core.commands, Version: 0.12.400.v20181119-1026, Location: initial@reference:file:plugins/org.eclipse.e4.core.commands_0.12.400.v20181119-1026.jar
Id: org.eclipse.e4.core.contexts, Version: 1.7.100.v20180817-1215, Location: initial@reference:file:plugins/org.eclipse.e4.core.contexts_1.7.100.v20180817-1215.jar
Id: org.eclipse.e4.core.contexts.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.core.contexts.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.core.di, Version: 1.7.100.v20180817-1215, Location: initial@reference:file:plugins/org.eclipse.e4.core.di_1.7.100.v20180817-1215.jar
Id: org.eclipse.e4.core.di.annotations, Version: 1.6.200.v20180817-1215, Location: initial@reference:file:plugins/org.eclipse.e4.core.di.annotations_1.6.200.v20180817-1215.jar
Id: org.eclipse.e4.core.di.annotations.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.core.di.annotations.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.core.di.extensions, Version: 0.15.200.v20180817-1215, Location: initial@reference:file:plugins/org.eclipse.e4.core.di.extensions_0.15.200.v20180817-1215.jar
Id: org.eclipse.e4.core.di.extensions.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.core.di.extensions.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.core.di.extensions.supplier, Version: 0.15.200.v20180817-1215, Location: initial@reference:file:plugins/org.eclipse.e4.core.di.extensions.supplier_0.15.200.v20180817-1215.jar
Id: org.eclipse.e4.core.di.extensions.supplier.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.core.di.extensions.supplier.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.core.di.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.core.di.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.core.services, Version: 2.1.300.v20180930-0910, Location: initial@reference:file:plugins/org.eclipse.e4.core.services_2.1.300.v20180930-0910.jar
Id: org.eclipse.e4.core.services.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.core.services.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.emf.xpath, Version: 0.2.200.v20180828-0227, Location: initial@reference:file:plugins/org.eclipse.e4.emf.xpath_0.2.200.v20180828-0227.jar
Id: org.eclipse.e4.emf.xpath.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.emf.xpath.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.ui.bindings, Version: 0.12.300.v20180913-1535, Location: initial@reference:file:plugins/org.eclipse.e4.ui.bindings_0.12.300.v20180913-1535.jar
Id: org.eclipse.e4.ui.css.core, Version: 0.12.400.v20180917-1628, Location: initial@reference:file:plugins/org.eclipse.e4.ui.css.core_0.12.400.v20180917-1628.jar
Id: org.eclipse.e4.ui.css.core.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.ui.css.core.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.ui.css.swt, Version: 0.13.300.v20181030-1443, Location: initial@reference:file:plugins/org.eclipse.e4.ui.css.swt_0.13.300.v20181030-1443.jar
Id: org.eclipse.e4.ui.css.swt.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.ui.css.swt.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.ui.css.swt.theme, Version: 0.12.100.v20180828-0227, Location: initial@reference:file:plugins/org.eclipse.e4.ui.css.swt.theme_0.12.100.v20180828-0227.jar
Id: org.eclipse.e4.ui.css.swt.theme.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.ui.css.swt.theme.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.ui.di, Version: 1.2.400.v20180920-1522, Location: initial@reference:file:plugins/org.eclipse.e4.ui.di_1.2.400.v20180920-1522.jar
Id: org.eclipse.e4.ui.di.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.ui.di.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.ui.dialogs, Version: 1.1.300.v20180828-0227, Location: initial@reference:file:plugins/org.eclipse.e4.ui.dialogs_1.1.300.v20180828-0227.jar
Id: org.eclipse.e4.ui.dialogs.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.ui.dialogs.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.ui.model.workbench, Version: 2.1.200.v20180920-1522, Location: initial@reference:file:plugins/org.eclipse.e4.ui.model.workbench_2.1.200.v20180920-1522.jar
Id: org.eclipse.e4.ui.model.workbench.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.ui.model.workbench.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.ui.services, Version: 1.3.300.v20180920-1522, Location: initial@reference:file:plugins/org.eclipse.e4.ui.services_1.3.300.v20180920-1522.jar
Id: org.eclipse.e4.ui.services.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.ui.services.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.ui.widgets, Version: 1.2.300.v20180920-1522, Location: initial@reference:file:plugins/org.eclipse.e4.ui.widgets_1.2.300.v20180920-1522.jar
Id: org.eclipse.e4.ui.widgets.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.ui.widgets.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.e4.ui.workbench, Version: 1.8.0.v20181119-1304, Location: initial@reference:file:plugins/org.eclipse.e4.ui.workbench_1.8.0.v20181119-1304.jar
Id: org.eclipse.e4.ui.workbench.addons.swt, Version: 1.3.300.v20181102-1042, Location: initial@reference:file:plugins/org.eclipse.e4.ui.workbench.addons.swt_1.3.300.v20181102-1042.jar
Id: org.eclipse.e4.ui.workbench.renderers.swt, Version: 0.14.400.v20181112-1716, Location: initial@reference:file:plugins/org.eclipse.e4.ui.workbench.renderers.swt_0.14.400.v20181112-1716.jar
Id: org.eclipse.e4.ui.workbench.swt, Version: 0.14.400.v20181022-1348, Location: initial@reference:file:plugins/org.eclipse.e4.ui.workbench.swt_0.14.400.v20181022-1348.jar
Id: org.eclipse.e4.ui.workbench3, Version: 0.14.200.v20180828-0227, Location: initial@reference:file:plugins/org.eclipse.e4.ui.workbench3_0.14.200.v20180828-0227.jar
Id: org.eclipse.e4.ui.workbench3.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.e4.ui.workbench3.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ecf, Version: 3.9.3.v20181012-2016, Location: initial@reference:file:plugins/org.eclipse.ecf_3.9.3.v20181012-2016.jar
Id: org.eclipse.ecf.filetransfer, Version: 5.0.100.v20180301-0132, Location: initial@reference:file:plugins/org.eclipse.ecf.filetransfer_5.0.100.v20180301-0132.jar
Id: org.eclipse.ecf.identity, Version: 3.9.1.v20180810-0833, Location: initial@reference:file:plugins/org.eclipse.ecf.identity_3.9.1.v20180810-0833.jar
Id: org.eclipse.ecf.provider.filetransfer, Version: 3.2.400.v20180306-0429, Location: initial@reference:file:plugins/org.eclipse.ecf.provider.filetransfer_3.2.400.v20180306-0429.jar
Id: org.eclipse.ecf.provider.filetransfer.httpclient4, Version: 1.1.300.v20180301-0132, Location: initial@reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient4_1.1.300.v20180301-0132.jar
Id: org.eclipse.ecf.provider.filetransfer.httpclient4.ssl, Version: 1.1.100.v20180301-0132, Location: initial@reference:file:plugins/org.eclipse.ecf.provider.filetransfer.httpclient4.ssl_1.1.100.v20180301-0132.jar
Id: org.eclipse.ecf.provider.filetransfer.ssl, Version: 1.0.100.v20180301-0132, Location: initial@reference:file:plugins/org.eclipse.ecf.provider.filetransfer.ssl_1.0.100.v20180301-0132.jar
Id: org.eclipse.ecf.ssl, Version: 1.2.100.v20180301-0132, Location: initial@reference:file:plugins/org.eclipse.ecf.ssl_1.2.100.v20180301-0132.jar
Id: org.eclipse.emf.common, Version: 2.15.0.v20180914-1817, Location: initial@reference:file:plugins/org.eclipse.emf.common_2.15.0.v20180914-1817.jar
Id: org.eclipse.emf.ecore, Version: 2.16.0.v20181124-0637, Location: initial@reference:file:plugins/org.eclipse.emf.ecore_2.16.0.v20181124-0637.jar
Id: org.eclipse.emf.ecore.change, Version: 2.13.0.v20180706-1146, Location: initial@reference:file:plugins/org.eclipse.emf.ecore.change_2.13.0.v20180706-1146.jar
Id: org.eclipse.emf.ecore.xmi, Version: 2.15.0.v20180706-1146, Location: initial@reference:file:plugins/org.eclipse.emf.ecore.xmi_2.15.0.v20180706-1146.jar
Id: org.eclipse.equinox.app, Version: 1.4.0.v20181009-1752, Location: initial@reference:file:plugins/org.eclipse.equinox.app_1.4.0.v20181009-1752.jar
Id: org.eclipse.equinox.bidi, Version: 1.1.200.v20180827-1235, Location: initial@reference:file:plugins/org.eclipse.equinox.bidi_1.1.200.v20180827-1235.jar
Id: org.eclipse.equinox.common, Version: 3.10.200.v20181021-1645, Location: initial@reference:file:plugins/org.eclipse.equinox.common_3.10.200.v20181021-1645.jar
Id: org.eclipse.equinox.concurrent, Version: 1.1.200.v20180827-1235, Location: initial@reference:file:plugins/org.eclipse.equinox.concurrent_1.1.200.v20180827-1235.jar
Id: org.eclipse.equinox.console, Version: 1.3.200.v20181115-0906, Location: initial@reference:file:plugins/org.eclipse.equinox.console_1.3.200.v20181115-0906.jar
Id: org.eclipse.equinox.event, Version: 1.5.0.v20181008-1938, Location: initial@reference:file:plugins/org.eclipse.equinox.event_1.5.0.v20181008-1938.jar
Id: org.eclipse.equinox.frameworkadmin, Version: 2.1.100.v20180822-1258, Location: initial@reference:file:plugins/org.eclipse.equinox.frameworkadmin_2.1.100.v20180822-1258.jar
Id: org.eclipse.equinox.frameworkadmin.equinox, Version: 1.1.100.v20180822-1258, Location: initial@reference:file:plugins/org.eclipse.equinox.frameworkadmin.equinox_1.1.100.v20180822-1258.jar
Id: org.eclipse.equinox.frameworkadmin.equinox.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.frameworkadmin.equinox.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.frameworkadmin.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.frameworkadmin.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.http.jetty, Version: 3.6.200.v20181115-1346, Location: initial@reference:file:plugins/org.eclipse.equinox.http.jetty_3.6.200.v20181115-1346.jar
Id: org.eclipse.equinox.http.registry, Version: 1.1.600.v20180827-1235, Location: initial@reference:file:plugins/org.eclipse.equinox.http.registry_1.1.600.v20180827-1235.jar
Id: org.eclipse.equinox.http.servlet, Version: 1.5.200.v20181008-1912, Location: initial@reference:file:plugins/org.eclipse.equinox.http.servlet_1.5.200.v20181008-1912.jar
Id: org.eclipse.equinox.jsp.jasper, Version: 1.1.100.v20180827-1235, Location: initial@reference:file:plugins/org.eclipse.equinox.jsp.jasper_1.1.100.v20180827-1235.jar
Id: org.eclipse.equinox.jsp.jasper.registry, Version: 1.1.100.v20180827-1235, Location: initial@reference:file:plugins/org.eclipse.equinox.jsp.jasper.registry_1.1.100.v20180827-1235.jar
Id: org.eclipse.equinox.launcher, Version: 1.5.200.v20180922-1751, Location: initial@reference:file:plugins/org.eclipse.equinox.launcher_1.5.200.v20180922-1751.jar
Id: org.eclipse.equinox.launcher.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.launcher.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.launcher.win32.win32.x86_64, Version: 1.1.900.v20180922-1751, Location: initial@reference:file:plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.900.v20180922-1751/
Id: org.eclipse.equinox.launcher.win32.win32.x86_64.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.launcher.win32.win32.x86_64.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.artifact.repository, Version: 1.2.200.v20181119-1308, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.artifact.repository_1.2.200.v20181119-1308.jar
Id: org.eclipse.equinox.p2.artifact.repository.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.artifact.repository.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.console, Version: 1.1.100.v20180822-1258, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.console_1.1.100.v20180822-1258.jar
Id: org.eclipse.equinox.p2.console.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.console.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.core, Version: 2.5.100.v20180822-1532, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.core_2.5.100.v20180822-1532.jar
Id: org.eclipse.equinox.p2.core.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.core.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.director, Version: 2.4.200.v20181102-0649, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.director_2.4.200.v20181102-0649.jar
Id: org.eclipse.equinox.p2.director.app, Version: 1.1.200.v20180822-1302, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.director.app_1.1.200.v20180822-1302.jar
Id: org.eclipse.equinox.p2.director.app.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.director.app.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.director.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.director.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.directorywatcher, Version: 1.2.100.v20180822-1302, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.directorywatcher_1.2.100.v20180822-1302.jar
Id: org.eclipse.equinox.p2.directorywatcher.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.directorywatcher.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.engine, Version: 2.6.100.v20180822-1302, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.engine_2.6.100.v20180822-1302.jar
Id: org.eclipse.equinox.p2.engine.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.engine.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.extensionlocation, Version: 1.3.100.v20180822-1302, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.extensionlocation_1.3.100.v20180822-1302.jar
Id: org.eclipse.equinox.p2.extensionlocation.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.extensionlocation.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.garbagecollector, Version: 1.1.100.v20180822-1302, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.garbagecollector_1.1.100.v20180822-1302.jar
Id: org.eclipse.equinox.p2.garbagecollector.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.garbagecollector.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.jarprocessor, Version: 1.1.200.v20180921-1009, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.jarprocessor_1.1.200.v20180921-1009.jar
Id: org.eclipse.equinox.p2.jarprocessor.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.jarprocessor.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.metadata, Version: 2.4.200.v20181102-0649, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.metadata_2.4.200.v20181102-0649.jar
Id: org.eclipse.equinox.p2.metadata.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.metadata.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.metadata.repository, Version: 1.3.100.v20180822-1302, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.metadata.repository_1.3.100.v20180822-1302.jar
Id: org.eclipse.equinox.p2.metadata.repository.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.metadata.repository.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.operations, Version: 2.5.200.v20180928-1359, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.operations_2.5.200.v20180928-1359.jar
Id: org.eclipse.equinox.p2.operations.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.operations.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.publisher, Version: 1.5.100.v20180822-1302, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.publisher_1.5.100.v20180822-1302.jar
Id: org.eclipse.equinox.p2.publisher.eclipse, Version: 1.3.100.v20180822-1354, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.publisher.eclipse_1.3.100.v20180822-1354.jar
Id: org.eclipse.equinox.p2.publisher.eclipse.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.publisher.eclipse.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.publisher.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.publisher.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.reconciler.dropins, Version: 1.3.0.v20181023-0914, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.reconciler.dropins_1.3.0.v20181023-0914.jar
Id: org.eclipse.equinox.p2.reconciler.dropins.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.reconciler.dropins.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.repository, Version: 2.4.200.v20181005-1131, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.repository_2.4.200.v20181005-1131.jar
Id: org.eclipse.equinox.p2.repository.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.repository.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.repository.tools, Version: 2.2.200.v20181102-0649, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.repository.tools_2.2.200.v20181102-0649.jar
Id: org.eclipse.equinox.p2.repository.tools.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.repository.tools.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.touchpoint.eclipse, Version: 2.2.200.v20181123-1405, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.touchpoint.eclipse_2.2.200.v20181123-1405.jar
Id: org.eclipse.equinox.p2.touchpoint.eclipse.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.touchpoint.eclipse.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.touchpoint.natives, Version: 1.3.200.v20180921-1019, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.touchpoint.natives_1.3.200.v20180921-1019.jar
Id: org.eclipse.equinox.p2.touchpoint.natives.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.touchpoint.natives.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.p2.transport.ecf, Version: 1.2.100.v20180822-1354, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.transport.ecf_1.2.100.v20180822-1354.jar
Id: org.eclipse.equinox.p2.transport.ecf.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.p2.transport.ecf.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.preferences, Version: 3.7.200.v20180827-1235, Location: initial@reference:file:plugins/org.eclipse.equinox.preferences_3.7.200.v20180827-1235.jar
Id: org.eclipse.equinox.registry, Version: 3.8.200.v20181008-1820, Location: initial@reference:file:plugins/org.eclipse.equinox.registry_3.8.200.v20181008-1820.jar
Id: org.eclipse.equinox.security, Version: 1.3.0.v20181115-0746, Location: initial@reference:file:plugins/org.eclipse.equinox.security_1.3.0.v20181115-0746.jar
Id: org.eclipse.equinox.security.win32.x86_64, Version: 1.1.100.v20180827-1235, Location: initial@reference:file:plugins/org.eclipse.equinox.security.win32.x86_64_1.1.100.v20180827-1235.jar
Id: org.eclipse.equinox.simpleconfigurator, Version: 1.3.200.v20181101-1115, Location: initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.3.200.v20181101-1115.jar
Id: org.eclipse.equinox.simpleconfigurator.manipulator, Version: 2.1.200.v20181123-1405, Location: initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator.manipulator_2.1.200.v20181123-1405.jar
Id: org.eclipse.equinox.simpleconfigurator.manipulator.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator.manipulator.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.simpleconfigurator.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.equinox.util, Version: 1.1.200.v20181008-1820, Location: initial@reference:file:plugins/org.eclipse.equinox.util_1.1.200.v20181008-1820.jar
Id: org.eclipse.help, Version: 3.8.200.v20180821-0700, Location: initial@reference:file:plugins/org.eclipse.help_3.8.200.v20180821-0700.jar
Id: org.eclipse.help.base, Version: 4.2.400.v20181206-0815, Location: initial@reference:file:plugins/org.eclipse.help.base_4.2.400.v20181206-0815.jar
Id: org.eclipse.help.base.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.help.base.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.help.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.help.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.help.ui, Version: 4.1.300.v20181018-1136, Location: initial@reference:file:plugins/org.eclipse.help.ui_4.1.300.v20181018-1136.jar
Id: org.eclipse.help.ui.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.help.ui.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.help.webapp, Version: 3.9.300.v20181127-2310, Location: initial@reference:file:plugins/org.eclipse.help.webapp_3.9.300.v20181127-2310.jar
Id: org.eclipse.help.webapp.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.help.webapp.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.jetty.continuation, Version: 9.4.14.v20181113, Location: initial@reference:file:plugins/org.eclipse.jetty.continuation_9.4.14.v20181113.jar
Id: org.eclipse.jetty.http, Version: 9.4.14.v20181113, Location: initial@reference:file:plugins/org.eclipse.jetty.http_9.4.14.v20181113.jar
Id: org.eclipse.jetty.io, Version: 9.4.14.v20181113, Location: initial@reference:file:plugins/org.eclipse.jetty.io_9.4.14.v20181113.jar
Id: org.eclipse.jetty.security, Version: 9.4.14.v20181113, Location: initial@reference:file:plugins/org.eclipse.jetty.security_9.4.14.v20181113.jar
Id: org.eclipse.jetty.server, Version: 9.4.14.v20181113, Location: initial@reference:file:plugins/org.eclipse.jetty.server_9.4.14.v20181113.jar
Id: org.eclipse.jetty.servlet, Version: 9.4.14.v20181113, Location: initial@reference:file:plugins/org.eclipse.jetty.servlet_9.4.14.v20181113.jar
Id: org.eclipse.jetty.util, Version: 9.4.14.v20181113, Location: initial@reference:file:plugins/org.eclipse.jetty.util_9.4.14.v20181113.jar
Id: org.eclipse.jface, Version: 3.15.0.v20181123-1505, Location: initial@reference:file:plugins/org.eclipse.jface_3.15.0.v20181123-1505.jar
Id: org.eclipse.jface.databinding, Version: 1.8.400.v20181030-1443, Location: initial@reference:file:plugins/org.eclipse.jface.databinding_1.8.400.v20181030-1443.jar
Id: org.eclipse.jface.databinding.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.jface.databinding.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.jface.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.jface.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.jface.text, Version: 3.15.0.v20181119-1708, Location: initial@reference:file:plugins/org.eclipse.jface.text_3.15.0.v20181119-1708.jar
Id: org.eclipse.jface.text.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.jface.text.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ltk.core.refactoring, Version: 3.9.200.v20181024-1629, Location: initial@reference:file:plugins/org.eclipse.ltk.core.refactoring_3.9.200.v20181024-1629.jar
Id: org.eclipse.ltk.core.refactoring.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ltk.core.refactoring.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ltk.ui.refactoring, Version: 3.9.200.v20180828-0626, Location: initial@reference:file:plugins/org.eclipse.ltk.ui.refactoring_3.9.200.v20180828-0626.jar
Id: org.eclipse.ltk.ui.refactoring.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ltk.ui.refactoring.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.mylyn.wikitext, Version: 3.0.25.20180620133858, Location: initial@reference:file:plugins/org.eclipse.mylyn.wikitext_3.0.25.20180620133858.jar
Id: org.eclipse.mylyn.wikitext.markdown, Version: 3.0.25.20180620133858, Location: initial@reference:file:plugins/org.eclipse.mylyn.wikitext.markdown_3.0.25.20180620133858.jar
Id: org.eclipse.nebula.widgets.grid, Version: 1.1.0.201803231500, Location: initial@reference:file:plugins/org.eclipse.nebula.widgets.grid_1.1.0.201803231500.jar
Id: org.eclipse.osgi, Version: 3.13.200.v20181130-2106, Location: System Bundle
Id: org.eclipse.osgi.compatibility.state, Version: 1.1.300.v20181116-1550, Location: initial@reference:file:plugins/org.eclipse.osgi.compatibility.state_1.1.300.v20181116-1550.jar
Id: org.eclipse.osgi.compatibility.state.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.osgi.compatibility.state.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.osgi.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.osgi.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.osgi.services, Version: 3.7.100.v20180827-1536, Location: initial@reference:file:plugins/org.eclipse.osgi.services_3.7.100.v20180827-1536.jar
Id: org.eclipse.osgi.services.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.osgi.services.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.osgi.util, Version: 3.5.100.v20180827-1536, Location: initial@reference:file:plugins/org.eclipse.osgi.util_3.5.100.v20180827-1536.jar
Id: org.eclipse.osgi.util.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.osgi.util.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.rcp, Version: 4.10.0.v20181206-0815, Location: initial@reference:file:plugins/org.eclipse.rcp_4.10.0.v20181206-0815.jar
Id: org.eclipse.search, Version: 3.11.400.v20181028-0633, Location: initial@reference:file:plugins/org.eclipse.search_3.11.400.v20181028-0633.jar
Id: org.eclipse.search.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.search.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.swt, Version: 3.109.0.v20181204-1801, Location: initial@reference:file:plugins/org.eclipse.swt_3.109.0.v20181204-1801.jar
Id: org.eclipse.swt.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.swt.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.swt.win32.win32.x86_64, Version: 3.109.0.v20181204-1801, Location: initial@reference:file:plugins/org.eclipse.swt.win32.win32.x86_64_3.109.0.v20181204-1801.jar
Id: org.eclipse.team.core, Version: 3.8.400.v20181109-0825, Location: initial@reference:file:plugins/org.eclipse.team.core_3.8.400.v20181109-0825.jar
Id: org.eclipse.team.core.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.team.core.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.team.ui, Version: 3.8.300.v20181030-1259, Location: initial@reference:file:plugins/org.eclipse.team.ui_3.8.300.v20181030-1259.jar
Id: org.eclipse.team.ui.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.team.ui.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.text, Version: 3.8.0.v20180923-1636, Location: initial@reference:file:plugins/org.eclipse.text_3.8.0.v20180923-1636.jar
Id: org.eclipse.text.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.text.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.tools.templates.core, Version: 1.1.0.201812111206, Location: initial@reference:file:plugins/org.eclipse.tools.templates.core_1.1.0.201812111206.jar
Id: org.eclipse.tools.templates.ui, Version: 1.1.1.201812111206, Location: initial@reference:file:plugins/org.eclipse.tools.templates.ui_1.1.1.201812111206.jar
Id: org.eclipse.ui, Version: 3.111.0.v20181117-0847, Location: initial@reference:file:plugins/org.eclipse.ui_3.111.0.v20181117-0847.jar
Id: org.eclipse.ui.cheatsheets, Version: 3.5.300.v20180823-1505, Location: initial@reference:file:plugins/org.eclipse.ui.cheatsheets_3.5.300.v20180823-1505.jar
Id: org.eclipse.ui.cheatsheets.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.cheatsheets.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.console, Version: 3.8.300.v20181019-1609, Location: initial@reference:file:plugins/org.eclipse.ui.console_3.8.300.v20181019-1609.jar
Id: org.eclipse.ui.console.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.console.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.editors, Version: 3.11.300.v20180914-0606, Location: initial@reference:file:plugins/org.eclipse.ui.editors_3.11.300.v20180914-0606.jar
Id: org.eclipse.ui.editors.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.editors.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.forms, Version: 3.7.400.v20181123-1505, Location: initial@reference:file:plugins/org.eclipse.ui.forms_3.7.400.v20181123-1505.jar
Id: org.eclipse.ui.forms.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.forms.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.ide, Version: 3.14.200.v20181205-2143, Location: initial@reference:file:plugins/org.eclipse.ui.ide_3.14.200.v20181205-2143.jar
Id: org.eclipse.ui.ide.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.ide.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.navigator, Version: 3.7.300.v20181016-1531, Location: initial@reference:file:plugins/org.eclipse.ui.navigator_3.7.300.v20181016-1531.jar
Id: org.eclipse.ui.navigator.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.navigator.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.navigator.resources, Version: 3.6.300.v20181110-1011, Location: initial@reference:file:plugins/org.eclipse.ui.navigator.resources_3.6.300.v20181110-1011.jar
Id: org.eclipse.ui.navigator.resources.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.navigator.resources.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.themes, Version: 1.2.300.v20181108-1102, Location: initial@reference:file:plugins/org.eclipse.ui.themes_1.2.300.v20181108-1102/
Id: org.eclipse.ui.themes.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.themes.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.views, Version: 3.9.200.v20180828-0837, Location: initial@reference:file:plugins/org.eclipse.ui.views_3.9.200.v20180828-0837.jar
Id: org.eclipse.ui.views.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.views.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.views.properties.tabbed, Version: 3.8.300.v20180921-1036, Location: initial@reference:file:plugins/org.eclipse.ui.views.properties.tabbed_3.8.300.v20180921-1036.jar
Id: org.eclipse.ui.views.properties.tabbed.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.views.properties.tabbed.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.win32.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.win32.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.workbench, Version: 3.112.100.v20181127-1518, Location: initial@reference:file:plugins/org.eclipse.ui.workbench_3.112.100.v20181127-1518.jar
Id: org.eclipse.ui.workbench.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.workbench.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.ui.workbench.texteditor, Version: 3.11.200.v20181108-1458, Location: initial@reference:file:plugins/org.eclipse.ui.workbench.texteditor_3.11.200.v20181108-1458.jar
Id: org.eclipse.ui.workbench.texteditor.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.ui.workbench.texteditor.nl_zh_4.10.0.v20190126060001.jar
Id: org.eclipse.update.configurator, Version: 3.4.100.v20180821-1913, Location: initial@reference:file:plugins/org.eclipse.update.configurator_3.4.100.v20180821-1913.jar
Id: org.eclipse.update.configurator.nl_zh, Version: 4.10.0.v20190126060001, Location: initial@reference:file:plugins/org.eclipse.update.configurator.nl_zh_4.10.0.v20190126060001.jar
Id: org.jsoup, Version: 1.7.2.v201411291515, Location: initial@reference:file:plugins/org.jsoup_1.7.2.v201411291515.jar
Id: org.sat4j.core, Version: 2.3.5.v201308161310, Location: initial@reference:file:plugins/org.sat4j.core_2.3.5.v201308161310.jar
Id: org.sat4j.pb, Version: 2.3.5.v201404071733, Location: initial@reference:file:plugins/org.sat4j.pb_2.3.5.v201404071733.jar
Id: org.simpleframework.xml, Version: 2.7.1.201905210938, Location: initial@reference:file:plugins/org.simpleframework.xml_2.7.1.201905210938.jar
Id: org.tukaani.xz, Version: 1.8.0.v20180207-1613, Location: initial@reference:file:plugins/org.tukaani.xz_1.8.0.v20180207-1613.jar
Id: org.w3c.css.sac, Version: 1.3.1.v200903091627, Location: initial@reference:file:plugins/org.w3c.css.sac_1.3.1.v200903091627.jar
Id: org.w3c.dom.events, Version: 3.0.0.draft20060413_v201105210656, Location: initial@reference:file:plugins/org.w3c.dom.events_3.0.0.draft20060413_v201105210656.jar
Id: org.w3c.dom.smil, Version: 1.0.1.v200903091627, Location: initial@reference:file:plugins/org.w3c.dom.smil_1.0.1.v200903091627.jar
Id: org.w3c.dom.svg, Version: 1.1.0.v201011041433, Location: initial@reference:file:plugins/org.w3c.dom.svg_1.1.0.v201011041433.jar
Id: org.yaml.snakeyaml, Version: 1.0.0.201905210938, Location: initial@reference:file:plugins/org.yaml.snakeyaml_1.0.0.201905210938.jar
liborukropec
Hi Larry,
it seems correct Java is used. Could you also try the certificate test as I described at the end of this page? This way we can find out if there's a MITM or not.
Thank you,
Libor
larry_ciummo
Copy of what I sent earlier. I’m guessing this is an issue with the trust chain. Perhaps on of the intermediates CA’s is not longer trusted.
Kc
liborukropec
I meant also output of the java keytool:
c:
cd c:\nxp\MCUX_CFG_v5\bin\jre\bin
keytool.exe -printcert --sslserver mcuxpresso.nxp.com:443 -rfc | clip
To compare if the certificate chain is the same. The Java does not rely on any 3rd trusted CA's, Java has its own list of trusted keys, so I do not know how it can stop trust...
Libor
larry_ciummo
Here you go…
larry_ciummo
My comparison of the PEM’s…
This is the FLIR chain
Intermediate certificate required. Unable to get issuer certificate.
1. Subject CN: mcuxpresso.nxp.com > Issuer CN: FLIR-DLP2. Subject CN: FLIR-DLP > Issuer CN: EnterpriseCA1
DECODED CERTIFICATE
From <https://tools.keycdn.com/ssl>
DECODED CERTIFICATE
"name": "\/OU=Domain Control Validated\/OU=Issued through NXP Semiconductors E-PKI Manager\/OU=COMODO SSL\/CN=mcuxpresso.nxp.com",
"subject": {
"OU": [
"Domain Control Validated",
"Issued through NXP Semiconductors E-PKI Manager",
"COMODO SSL"
"CN": "mcuxpresso.nxp.com"
"hash": "19615666",
"issuer": {
"C": "US",
"ST": "Massachusetts",
"L": "North Billerica",
"O": "FLIR Systems, Inc.",
"OU": "IT",
"CN": "FLIR-DLP"
"version": 2,
"serialNumber": "0x856540073DDF5B355BBF3DDE68C64F08",
"serialNumberHex": "856540073DDF5B355BBF3DDE68C64F08",
"validFrom": "181017000000Z",
"validTo": "201105235959Z",
"validFrom_time_t": 1539734400,
"validTo_time_t": 1604620799,
"signatureTypeSN": "RSA-SHA256",
"signatureTypeLN": "sha256WithRSAEncryption",
"signatureTypeNID": 668,
"purposes": {
"1": [
true,
false,
"sslclient"
"2": [
true,
false,
"sslserver"
"3": [
true,
false,
"nssslserver"
"4": [
false,
false,
"smimesign"
"5": [
false,
false,
"smimeencrypt"
"6": [
false,
false,
"crlsign"
"7": [
true,
true,
"any"
"8": [
true,
false,
"ocsphelper"
"9": [
false,
false,
"timestampsign"
"extensions": {
"extendedKeyUsage": "TLS Web Server Authentication, TLS Web Client Authentication",
"subjectAltName": "DNS:mcuxpresso.nxp.com, DNS:www.mcuxpresso.nxp.com",
"keyUsage": "Digital Signature, Key Encipherment",
"basicConstraints": "CA:FALSE"
DECODED CERTIFICATE
"name": "\/C=US\/ST=Massachusetts\/L=North Billerica\/O=FLIR Systems, Inc.\/OU=IT\/CN=FLIR-DLP",
"subject": {
"C": "US",
"OU": "IT",
"CN": "FLIR-DLP"
"hash": "d4c2d2ec",
"issuer": {
"DC": [
"net",
"flir"
"CN": "EnterpriseCA1"
"version": 2,
"serialNumber": "0x780000BC58DE2F85FBB23AC6C000000000BC58",
"serialNumberHex": "780000BC58DE2F85FBB23AC6C000000000BC58",
"validFrom": "190107231244Z",
"validTo": "201007183752Z",
"validFrom_time_t": 1546902764,
"validTo_time_t": 1602095872,
"purposes": {
"1": [
true,
true,
"sslclient"
"2": [
true,
true,
"sslserver"
"3": [
false,
true,
"nssslserver"
"4": [
true,
true,
"smimesign"
"5": [
false,
true,
"smimeencrypt"
"6": [
true,
true,
"crlsign"
"7": [
true,
true,
"any"
"8": [
true,
true,
"ocsphelper"
"9": [
false,
true,
"timestampsign"
"extensions": {
"subjectKeyIdentifier": "CB:2B:91:AD:75:7D:8D:67:AD:A4:8B:1B:CF:1C:36:43:97:2B:6A:53",
"authorityKeyIdentifier": "keyid:3D:87:47:25:76:2F:8B:08:88:94:D4:48:D9:9E:D2:36:A7:D0:A4:68\n",
"crlDistributionPoints": "\nFull Name:\n URI:ldap:\/\/\/CN=EnterpriseCA1,CN=us-bos-ca1,CN=CDP,CN=Public%20Key%20Services,CN=Services,CN=Configuration,DC=flir,DC=net?certificateRevocationList?base?objectClass=cRLDistributionPoint\n URI:http:\/\/certs.flir.net\/certdata\/EnterpriseCA1.crl\n",
"authorityInfoAccess": "CA Issuers - URI:ldap:\/\/\/CN=EnterpriseCA1,CN=AIA,CN=Public%20Key%20Services,CN=Services,CN=Configuration,DC=flir,DC=net?cACertificate?base?objectClass=certificationAuthority\n",
"1.3.6.1.4.1.311.20.2": "\u001e\n\u0000S\u0000u\u0000b\u0000C\u0000A",
"basicConstraints": "CA:TRUE",
"keyUsage": "Digital Signature, Certificate Sign, CRL Sign"
This is the NXP chain…
Chain issues detected. Possible reasons are missing intermediate certificate or wrong order of the certificates.
1. Subject CN: mcuxpresso.nxp.com > Issuer CN: COMODO RSA Domain Validation Secure Server CA2. Subject CN: AddTrust External CA Root > Issuer CN: AddTrust External CA Root3. Subject CN: COMODO RSA Certification Authority > Issuer CN: AddTrust External CA Root4. Subject CN: COMODO RSA Domain Validation Secure Server CA > Issuer CN: COMODO RSA Certification Authority
DECODED CERTIFICATE
"subject": {
"OU": [
"COMODO SSL"
"hash": "19615666",
"issuer": {
"C": "GB",
"ST": "Greater Manchester",
"L": "Salford",
"O": "COMODO CA Limited",
"CN": "COMODO RSA Domain Validation Secure Server CA"
"version": 2,
"serialNumber": "0xF3326ECEE3BCFDD6CEEAC71386F750AD",
"serialNumberHex": "F3326ECEE3BCFDD6CEEAC71386F750AD",
"purposes": {
"1": [
true,
false,
"sslclient"
"2": [
true,
false,
"sslserver"
"3": [
true,
false,
"nssslserver"
"4": [
false,
false,
"smimesign"
"5": [
false,
false,
"smimeencrypt"
"6": [
false,
false,
"crlsign"
"7": [
true,
true,
"any"
"8": [
true,
false,
"ocsphelper"
"9": [
false,
false,
"timestampsign"
"extensions": {
"authorityKeyIdentifier": "keyid:90:AF:6A:3A:94:5A:0B:D8:90:EA:12:56:73:DF:43:B4:3A:28:DA:E7\n",
"subjectKeyIdentifier": "7F:88:2E:D2:47:84:24:B2:8E:19:35:32:70:34:09:39:DD:05:50:46",
"basicConstraints": "CA:FALSE",
"certificatePolicies": "Policy: 1.3.6.1.4.1.6449.1.2.2.7\n CPS: https:\/\/secure.comodo.com\/CPS\nPolicy: 2.23.140.1.2.1\n",
"crlDistributionPoints": "\nFull Name:\n URI:http:\/\/crl.comodoca.com\/COMODORSADomainValidationSecureServerCA.crl\n",
"authorityInfoAccess": "CA Issuers - URI:http:\/\/crt.comodoca.com\/COMODORSADomainValidationSecureServerCA.crt\nOCSP - URI:http:\/\/ocsp.comodoca.com\n",
"ct_precert_scts": "Signed Certificate Timestamp:\n Version : v1 (0x0)\n Log ID : EE:4B:BD:B7:75:CE:60:BA:E1:42:69:1F:AB:E1:9E:66:\n A3:0F:7E:5F:B0:72:D8:83:00:C4:7B:89:7A:A8:FD:CB\n Timestamp : Oct 17 08:03:54.636 2018 GMT\n Extensions: none\n Signature : ecdsa-with-SHA256\n 30:45:02:20:76:5D:F2:9E:92:8B:1F:20:5C:B2:10:E6:\n 6E:A5:9D:7E:F9:4E:07:EF:9C:94:CF:1F:41:DB:1B:58:\n C5:EC:B7:4D:02:21:00:BF:69:7D:DD:38:EA:A5:ED:03:\n 62:61:DE:B2:B2:73:49:04:DA:78:AE:72:DB:12:27:04:\n 17:B3:87:A3:74:C2:35\nSigned Certificate Timestamp:\n Version : v1 (0x0)\n Log ID : 5E:A7:73:F9:DF:56:C0:E7:B5:36:48:7D:D0:49:E0:32:\n 7A:91:9A:0C:84:A1:12:12:84:18:75:96:81:71:45:58\n Timestamp : Oct 17 08:03:54.700 2018 GMT\n Extensions: none\n Signature : ecdsa-with-SHA256\n 30:45:02:21:00:96:44:17:BE:23:AE:6A:15:F2:C7:F1:\n 95:2D:F5:40:36:B4:F0:21:B6:E7:D4:94:C3:A6:92:1E:\n 2F:2B:09:B7:A5:02:20:1A:D0:45:B5:44:1C:93:10:BA:\n C7:96:82:3F:4C:03:A1:3D:2D:0B:04:33:AA:5B:54:AF:\n 79:D3:C9:16:BA:26:A6\nSigned Certificate Timestamp:\n Version : v1 (0x0)\n Log ID : 55:81:D4:C2:16:90:36:01:4A:EA:0B:9B:57:3C:53:F0:\n C0:E4:38:78:70:25:08:17:2F:A3:AA:1D:07:13:D3:0C\n Timestamp : Oct 17 08:03:54.988 2018 GMT\n Extensions: none\n Signature : ecdsa-with-SHA256\n 30:46:02:21:00:D4:71:74:A5:6F:88:A4:2F:BE:0D:FD:\n 70:50:1C:B3:F8:66:BC:29:BA:75:0B:E7:17:50:05:DD:\n F1:A3:E2:84:3D:02:21:00:F0:E6:5D:AF:18:64:7C:C7:\n E8:4E:74:29:15:5C:08:78:01:41:6F:76:F3:41:38:BF:\n BB:71:0F:BD:8D:70:B5:6C"
DECODED CERTIFICATE
"name": "\/C=SE\/O=AddTrust AB\/OU=AddTrust External TTP Network\/CN=AddTrust External CA Root",
"subject": {
"C": "SE",
"O": "AddTrust AB",
"OU": "AddTrust External TTP Network",
"CN": "AddTrust External CA Root"
"hash": "157753a5",
"issuer": {
"C": "SE",
"O": "AddTrust AB",
"version": 2,
"serialNumber": "1",
"serialNumberHex": "01",
"validFrom": "000530104838Z",
"validTo": "200530104838Z",
"validFrom_time_t": 959683718,
"validTo_time_t": 1590835718,
"signatureTypeSN": "RSA-SHA1",
"signatureTypeLN": "sha1WithRSAEncryption",
"signatureTypeNID": 65,
"purposes": {
"1": [
false,
true,
"sslclient"
"2": [
false,
true,
"sslserver"
"3": [
false,
true,
"nssslserver"
"4": [
false,
true,
"smimesign"
"5": [
false,
true,
"smimeencrypt"
"6": [
true,
true,
"crlsign"
"7": [
true,
true,
"any"
"8": [
true,
true,
"ocsphelper"
"9": [
false,
true,
"timestampsign"
"extensions": {
"subjectKeyIdentifier": "AD:BD:98:7A:34:B4:26:F7:FA:C4:26:54:EF:03:BD:E0:24:CB:54:1A",
"keyUsage": "Certificate Sign, CRL Sign",
"authorityKeyIdentifier": "keyid:AD:BD:98:7A:34:B4:26:F7:FA:C4:26:54:EF:03:BD:E0:24:CB:54:1A\nDirName:\/C=SE\/O=AddTrust AB\/OU=AddTrust External TTP Network\/CN=AddTrust External CA Root\nserial:01\n"
DECODED CERTIFICATE
"name": "\/C=GB\/ST=Greater Manchester\/L=Salford\/O=COMODO CA Limited\/CN=COMODO RSA Certification Authority",
"subject": {
"C": "GB",
"L": "Salford",
"CN": "COMODO RSA Certification Authority"
"hash": "d6325660",
"issuer": {
"C": "SE",
"O": "AddTrust AB",
"version": 2,
"serialNumber": "52374340215108295845375962883522092578",
"serialNumberHex": "2766EE56EB49F38EABD770A2FC84DE22",
"signatureTypeSN": "RSA-SHA384",
"signatureTypeLN": "sha384WithRSAEncryption",
"signatureTypeNID": 669,
"purposes": {
"1": [
true,
true,
"sslclient"
"2": [
true,
true,
"sslserver"
"3": [
false,
true,
"nssslserver"
"4": [
true,
true,
"smimesign"
"5": [
false,
true,
"smimeencrypt"
"6": [
true,
true,
"crlsign"
"7": [
true,
true,
"any"
"8": [
true,
true,
"ocsphelper"
"9": [
false,
true,
"timestampsign"
"extensions": {
"authorityKeyIdentifier": "keyid:AD:BD:98:7A:34:B4:26:F7:FA:C4:26:54:EF:03:BD:E0:24:CB:54:1A\n",
"subjectKeyIdentifier": "BB:AF:7E:02:3D:FA:A6:F1:3C:84:8E:AD:EE:38:98:EC:D9:32:32:D4",
"keyUsage": "Digital Signature, Certificate Sign, CRL Sign",
"certificatePolicies": "Policy: X509v3 Any Policy\n",
"crlDistributionPoints": "\nFull Name:\n URI:http:\/\/crl.usertrust.com\/AddTrustExternalCARoot.crl\n",
"authorityInfoAccess": "OCSP - URI:http:\/\/ocsp.usertrust.com\n"
DECODED CERTIFICATE
"name": "\/C=GB\/ST=Greater Manchester\/L=Salford\/O=COMODO CA Limited\/CN=COMODO RSA Domain Validation Secure Server CA",
"subject": {
"C": "GB",
"L": "Salford",
"hash": "8d28ae65",
"issuer": {
"C": "GB",
"L": "Salford",
"version": 2,
"serialNumber": "57397899145990363081023081275480378375",
"serialNumberHex": "2B2E6EEAD975366C148A6EDBA37C8C07",
"validFrom": "140212000000Z",
"validTo": "290211235959Z",
"validFrom_time_t": 1392163200,
"validTo_time_t": 1865548799,
"purposes": {
"1": [
true,
true,
"sslclient"
"2": [
true,
true,
"sslserver"
"3": [
false,
true,
"nssslserver"
"4": [
false,
false,
"smimesign"
"5": [
false,
false,
"smimeencrypt"
"6": [
true,
true,
"crlsign"
"7": [
true,
true,
"any"
"8": [
true,
true,
"ocsphelper"
"9": [
false,
true,
"timestampsign"
"extensions": {
"authorityKeyIdentifier": "keyid:BB:AF:7E:02:3D:FA:A6:F1:3C:84:8E:AD:EE:38:98:EC:D9:32:32:D4\n",
"subjectKeyIdentifier": "90:AF:6A:3A:94:5A:0B:D8:90:EA:12:56:73:DF:43:B4:3A:28:DA:E7",
"basicConstraints": "CA:TRUE, pathlen:0",
"certificatePolicies": "Policy: X509v3 Any Policy\nPolicy: 2.23.140.1.2.1\n",
"crlDistributionPoints": "\nFull Name:\n URI:http:\/\/crl.comodoca.com\/COMODORSACertificationAuthority.crl\n",
"authorityInfoAccess": "CA Issuers - URI:http:\/\/crt.comodoca.com\/COMODORSAAddTrustCA.crt\nOCSP - URI:http:\/\/ocsp.comodoca.com\n"
larry_ciummo
I compared the two chains and they are different. In the V6 chain, the mcuexpresso cert id signed my my company – in the V5 it signed by a Comodo. Not sure why we’d have a cert signed by us for nxp.
The java cert store is separate from Windows, right?
Larry
liborukropec
Hi Larry,
correct, Java has its own cert store, independent on system. I do not understand why for version v5 and v6 (you used the key tools) it behaves differently, but this is another story. The main point is that your company does nasty thing and spies also encrypted communication. For applications that uses windows cert store it seems correct, but our java was not tampered => that's why it refuses the communication, because it does not trust your company CA. Question is you are aware of such corporate settings...
So solution is:
a) remove the https => http as you already did
b) using the keytool import the corporate CA into the JRE inside the Config Tools
Libor
I'm curious, how many companies does this dirty MITM thing.
larry_ciummo
OK. Here we go.
1. You’re providing tech support to our company, that buys your product, which in some sense pays your salary.
2. We do what’s right for our company – we’re the frequent target of foreign government attacks, and we do everything we can to protect our intellectual assets and government property.
3. Our company monitors all traffic in and out on it’s networks, and flags suspicious traffic and stops it – protected by SSL sessions or otherwise.
4. Employees are free to use the network, knowing that traffic is monitored, or can use there own devices or our guess networks.
Please close this ticket.
lc
liborukropec
Hi Larry,
you can close the ticket by marking the helpful response as 'helpful'.
And let me apologize if my post could be understood as negative. The thing is that MITM (dirty) stuff makes programs stop working like in this case and it might be very hard to find the root cause. Lessons learned is that we should at least document it in the next version, because not only data are retrieved over the net - updates of the application itself (less frequent) and also checks if there's a brand new version released or not.
Libor
larry_ciummo
I sent that earlier today.
Larry
larry_ciummo
Processor is :
V6 is not on my machine anymore.
Can two version coexists on a PC w/o any difficulties?  If they can, I'll reinstall V6.
An you can make a design with V5 and open it in V6?
When I opened the design in V5, it downloaded a lot of files. Not sure what they were but there was a lot of downloading.
Larry
liborukropec
Hello Larry,
yes, there can be multiple versions of MCUX Configuration Tools installed on the computer. Only the last one installed will assign the*.mex file association. So you can have V5 and V6 installed at the same time. Please also see my next post regarding the log.
Libor
liborukropec
Hi Larry,
are you behind some proxy? If you use stand-alone MCUX Config Tools, you can attach here the log file, located here (on Windows platform) c:\Users\<you user name>\.nxp\swtools.log  (or on Linux $HOME/.nxp/swtools.log).
As a workaround you can log into the https://mcuxpresso.nxp.com and here https://mcuxpresso.nxp.com/en/select_config_tools_data  you can download the data for the Config Tools V6, that you can import in the Config Tools (File | Import ... | Import Processor Data).
Libor
larry_ciummo
No proxy. I removed V6 from PC. I installed V5 and it works fine.
The file was created by others with V5.
Is a .mex with V5 supposed to open on V6?
Larry
larry_ciummo
So I uninstalled the new V6 of the MCU config tool and replaced it with version 5 - the existing .mex file opens fine now.
Not sure what's up with version 6 of the MCU config tool.
