LPCXpresso getting started
eunkyung
Hi, I'm definitely new comer to this field.
I'll use NHS3152, so I'm follwing the UM_NHS31xx_GettingStarted user manual.
I installed LPCXpresso(UM2.1) and NHS31xx plugin(UM2.2), and now blocked at Chip support(UM2.2.1).
The manual says
go to Project>Properties>C/C++ Build>MCU Settings
But the button 'Properties' in the 'Project' tap is unactivated so that I can't click it. (as attached file)
How can I solve this basic problem?
Thanks.
driesmoors
Blame the manual. $2.2.1 is explaining what the plugin you just installed is adding to the table. The properties explained in $2.2.1 apply to a project. You don't have a project (yet), so can't access its properties.
Please continue with $2.3 SDK, where you will import the projects into your workspace.
Kind regards,
Dries.
