imx8qxpmek CAN-FD cannot found
chenchen_xi
As described in the <i.MX linux Release Notes> Rev.L4.14.78-1.0.0_GA, 01/2019 Charter 2.1 the kernel supports CAN-FD. Then  I downloaded the image based on L4.14.78 and flash the *.sdcard file into the SD card.
when the MEK board boots,it show the kernel version 4.14.78 and it is confirmed that the L4.14.78 image has been flashed successfully.
however, when I check the "ifconfig" there is no can0 or other can bus information.
so i try to recompile the kernel using "bitbake imx-linux -c menuconfig",and see all of the options regarding CAN bus are already included, and I did not recomliled the kernel again, only to see the CAN options.
In my mind, IMX8 has its own CANFD ,so there is no need to connect a extended CAN chip using SPI, or a BB borad, and the CAN drivers can be found directly in the kernel, but it doesn't.
in a word, how can i deploy the CAN/CANFD function in my design?
thanks in advance.
Tags (2)
notify1forme
Hello, vincent.aubineau
I just performed what you are asking me.  unfortunately it is the same as before.
is there a missing setting for H/W board?
To check the date out I execute the command "cat /proc/version" at the end of the message.
after seeing the date I am sure writing is ok.
This is the messages what I get after flushing into sd card.
resetting ...
U-Boot SPL 2018.03-imx_v2018.03_4.14.98_2.0.0_ga+g87a19df (Apr 11 2019 - 10:41:11 +0000)
Normal Boot
Trying to boot from MMC2_2
Load image from MMC/SD 0x50400
U
U-Boot 2018.03-imx_v2018.03_4.14.98_2.0.0_ga+g87a19df (Apr 11 2019 - 10:41:11 +0000)
CPU: Freescale i.MX8QXP revB A35 at 1200 MHz at 25C
Model: Freescale i.MX8QXP MEK
Board: iMX8QXP MEK
Boot: SD1
DRAM: 2.8 GiB
VService: Connection is ok on MU mu@5d230000
TCPC: Vendor ID [0x1fc9], Product ID [0x5110], Addr [I2C1 0x50]
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Loading Environment from MMC... *** Warning - bad CRC, using default environment
Failed (-5)
[pcie_ctrlb_sata_phy_init_rc] LNK DOWN 8600000
In: serial
Out: serial
Err: serial
BuildInfo:
- SCFW f83a2bed, SECO-FW 92ef1143, IMX-MKIMAGE dd023400, ATF 1cb68fa
- U-Boot 2018.03-imx_v2018.03_4.14.98_2.0.0_ga+g87a19df
switch to partitions #0, OK
mmc1 is current device
flash target is MMC:1
Net:
Warning: ethernet@5b040000 using MAC address from ROM
eth0: ethernet@5b040000 [PRIME]
Warning: ethernet@5b050000 (eth1) using random MAC address - a2:3a:31:d7:0c:75
, eth1: ethernet@5b050000
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 3 2 1 0
** Unable to read file boot.scr **
23163392 bytes read in 995 ms (22.2 MiB/s)
Booting from mmc ...
82009 bytes read in 18 ms (4.3 MiB/s)
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Using Device Tree in place at 0000000083000000, end 0000000083017058
Disable gpt0@5d140000, resource id 207 not owned
/dma-controller@591F0000, 61284
/dma-controller@599F0000, 62172
/dma-controller@5a1f0000, 60408
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbea (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 SMP PREEMPT Sun Apr 14 10:39:56 UTC 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd042]
[ 0.000000] Machine model: Freescale i.MX8QXP MEK
[ 0.000000] earlycon: lpuart32 at MMIO 0x000000005a060000 (options '115200')
[ 0.000000] bootconsole [lpuart32] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000096000000, size 960 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000090400000, size 28 MiB
[ 0.000000] OF: reserved mem: initialized node rpmsg_dma@0x90400000, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000008bfffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x8bff7aa00-0x8bff7c7ff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080200000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008bfffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080200000-0x0000000083ffffff]
[ 0.000000] node 0: [mem 0x0000000086200000-0x0000000087ffffff]
[ 0.000000] node 0: [mem 0x0000000094c00000-0x00000000fdffffff]
[ 0.000000] node 0: [mem 0x00000000ffc00000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x00000008bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x00000008bfffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 24 pages/cpu @ffff80083ff15000 s57624 r8192 d32488 u98304
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 706608
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: console=ttyLP0,115200 earlycon=lpuart32,0x5a060000,115200 root=/dev/mmcblk1p2 rootwait rw
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] software IO TLB: mapped [mem 0xfa000000-0xfe000000] (64MB)
[ 0.000000] Memory: 1749008K/2871296K available (13564K kernel code, 1692K rwdata, 6052K rodata, 1280K init, 434K bss, 139248K reserved, 983040K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000008dc0000 ( 13568 KB)
[ 0.000000] .rodata : 0xffff000008dc0000 - 0xffff0000093b0000 ( 6080 KB)
[ 0.000000] .init : 0xffff0000093b0000 - 0xffff0000094f0000 ( 1280 KB)
[ 0.000000] .data : 0xffff0000094f0000 - 0xffff000009697200 ( 1693 KB)
[ 0.000000] .bss : 0xffff000009697200 - 0xffff000009703b40 ( 435 KB)
[ 0.000000] fixed : 0xffff7dfffe7f9000 - 0xffff7dfffec00000 ( 4124 KB)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum)
[ 0.000000] 0xffff7e0000008000 - 0xffff7e0021000000 ( 527 MB actual)
[ 0.000000] memory : 0xffff800000200000 - 0xffff800840000000 ( 33790 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: no VLPI support, no direct LPI support
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000051b00000
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000005] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.011305] Console: colour dummy device 80x25
[ 0.015477] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.025664] pid_max: default: 32768 minimum: 301
[ 0.030350] Security Framework initialized
[ 0.035630] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.043150] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.049897] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.056574] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.079750] ASID allocator initialised with 32768 entries
[ 0.092841] Hierarchical SRCU implementation.
[ 0.106234] *****Initialized MU
[ 0.109087] ***** imx8_init_pm_domains *****
[ 0.114486] CPU identified as i.MX8QXP, silicon rev 1.1
[ 0.121135] EFI services will not be available.
[ 0.133377] smp: Bringing up secondary CPUs ...
[ 0.166352] Detected VIPT I-cache on CPU1
[ 0.166384] GICv3: CPU1: found redistributor 1 region 0:0x0000000051b20000
[ 0.166418] CPU1: Booted secondary processor [410fd042]
[ 0.194379] Detected VIPT I-cache on CPU2
[ 0.194399] GICv3: CPU2: found redistributor 2 region 0:0x0000000051b40000
[ 0.194417] CPU2: Booted secondary processor [410fd042]
[ 0.222439] Detected VIPT I-cache on CPU3
[ 0.222457] GICv3: CPU3: found redistributor 3 region 0:0x0000000051b60000
[ 0.222473] CPU3: Booted secondary processor [410fd042]
[ 0.222533] smp: Brought up 1 node, 4 CPUs
[ 0.274516] SMP: Total of 4 processors activated.
[ 0.279199] CPU features: detected feature: GIC system register CPU interface
[ 0.286334] CPU features: detected feature: 32-bit EL0 Support
[ 0.292153] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.304582] CPU: All CPU(s) started at EL2
[ 0.308355] alternatives: patching kernel code
[ 0.313540] devtmpfs: initialized
[ 0.330266] random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
[ 0.339194] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.348650] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.378228] pinctrl core: initialized pinctrl subsystem
[ 0.385520] DMI not present or invalid.
[ 0.389461] NET: Registered protocol family 16
[ 0.397660] cpuidle: using governor menu
[ 0.402749] vdso: 2 pages (1 code @ ffff000008dc6000, 1 data @ ffff0000094f4000)
[ 0.409971] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.422849] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.429425] Serial: AMBA PL011 UART driver
[ 0.433362] imx rpmsg driver is registered.
[ 0.439884] MU and Power domains initialized
[ 0.443848] ***** imx8qxp_clocks_init *****
[ 0.521899] imx8qxp-pinctrl iomuxc: initialized IMX pinctrl driver
[ 0.561514] mxs_phy 5b100000.usbphy: 5b100000.usbphy supply phy-3p0 not found, using dummy regulator
[ 0.583496] MU is ready for cross core communication!
[ 0.588474] imx-rpmsg 90000000.rpmsg: assigned reserved memory node rpmsg_dma@0x90400000
[ 0.596760] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 0.601958] virtio_rpmsg_bus virtio0: creating channel rpmsg-vehicle-channel addr 0x1
[ 0.609833] virtio_rpmsg_bus virtio0: creating channel rpmsg-i2c-channel addr 0x2
[ 0.617541] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 0.640112] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.670511] ACPI: Interpreter disabled.
[ 0.683516] vgaarb: loaded
[ 0.686223] SCSI subsystem initialized
[ 0.690166] usbcore: registered new interface driver usbfs
[ 0.695392] usbcore: registered new interface driver hub
[ 0.700844] usbcore: registered new device driver usb
[ 0.706461] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
[ 0.718269] i2c i2c-16: LPI2C adapter registered
[ 0.725216] i2c i2c-17: LPI2C adapter registered
[ 0.731449] i2c i2c-18: LPI2C adapter registered
[ 0.740644] i2c-rpmsg virtio0.rpmsg-i2c-channel.-1.2: new channel: 0x400 -> 0x2!
[ 0.748527] imx_rpmsg_i2c i2c-rpbus-1: add I2C adapter i2c-rpmsg-adapter successfully
[ 0.756782] pca953x 5-0020: 5-0020 supply vcc not found, using dummy regulator
[ 0.767527] imx_rpmsg_i2c i2c-rpbus-5: add I2C adapter i2c-rpmsg-adapter successfully
[ 0.776429] imx_rpmsg_i2c i2c-rpbus-12: add I2C adapter i2c-rpmsg-adapter successfully
[ 0.784830] imx_rpmsg_i2c i2c-rpbus-14: add I2C adapter i2c-rpmsg-adapter successfully
[ 0.793079] pca953x 15-001a: 15-001a supply vcc not found, using dummy regulator
[ 0.805632] pca953x 15-001d: 15-001d supply vcc not found, using dummy regulator
[ 0.817925] imx_rpmsg_i2c i2c-rpbus-15: add I2C adapter i2c-rpmsg-adapter successfully
[ 0.825738] media: Linux media interface: v0.10
[ 0.830072] Linux video capture interface: v2.00
[ 0.834760] pps_core: LinuxPPS API ver. 1 registered
[ 0.839586] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.848727] PTP clock support registered
[ 0.853086] EDAC MC: Ver: 3.0.0
[ 0.856174] dmi: Firmware registration failed.
[ 0.861838] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.871945] Advanced Linux Sound Architecture Driver Initialized.
[ 0.878466] Bluetooth: Core ver 2.22
[ 0.881760] NET: Registered protocol family 31
[ 0.886133] Bluetooth: HCI device and connection manager initialized
[ 0.892483] Bluetooth: HCI socket layer initialized
[ 0.897343] Bluetooth: L2CAP socket layer initialized
[ 0.902402] Bluetooth: SCO socket layer initialized
[ 0.908114] clocksource: Switched to clocksource arch_sys_counter
[ 0.914031] VFS: Disk quotas dquot_6.6.0
[ 0.917831] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.924789] pnp: PnP ACPI: disabled
[ 0.934913] NET: Registered protocol family 2
[ 0.939621] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.946911] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.953659] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.959993] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.965939] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.972484] NET: Registered protocol family 1
[ 0.977143] RPC: Registered named UNIX socket transport module.
[ 0.982750] RPC: Registered udp transport module.
[ 0.987423] RPC: Registered tcp transport module.
[ 0.992113] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.999786] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.007859] kvm [1]: 8-bit VMID
[ 1.011711] kvm [1]: GICv3: no GICV resource entry
[ 1.016171] kvm [1]: disabling GICv2 emulation
[ 1.020623] kvm [1]: GIC system register CPU interface enabled
[ 1.026501] kvm [1]: vgic interrupt IRQ1
[ 1.030424] kvm [1]: Hyp mode initialized successfully
[ 1.038211] audit: initializing netlink subsys (disabled)
[ 1.043402] audit: type=2000 audit(0.928:1): state=initialized audit_enabled=0 res=1
[ 1.043771] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[ 1.064251] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.070425] NFS: Registering the id_resolver key type
[ 1.075285] Key type id_resolver registered
[ 1.079309] Key type id_legacy registered
[ 1.083313] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.090017] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 1.096816] 9p: Installing v9fs 9p2000 file system support
[ 1.107047] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 1.114128] io scheduler noop registered
[ 1.118194] io scheduler cfq registered (default)
[ 1.122716] io scheduler mq-deadline registered
[ 1.127298] io scheduler kyber registered
[ 1.159557] pwm-backlight lvds_backlight@0: lvds_backlight@0 supply power not found, using dummy regulator
[ 1.170924] pwm-backlight lvds_backlight@1: lvds_backlight@1 supply power not found, using dummy regulator
[ 1.191234] mxs-dma 5b810000.dma-apbh: initialized
[ 1.198398] Bus freq driver module loaded
[ 1.211482] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.221421] SuperH (H)SCI(F) driver initialized
[ 1.227212] msm_serial: driver initialized
[ 1.232647] 5a060000.serial: ttyLP0 at MMIO 0x5a060010 (irq = 52, base_baud = 5000000) is a FSL_LPUAR[ 1.243831] console [ttyLP0] enabled
[ 1.250866] bootconsole [lpuart32] disabled
[ 1.259552] fsl-lpuart 5a060000.serial: NO DMA tx channel, run at cpu mode
[ 1.266452] fsl-lpuart 5a060000.serial: NO DMA rx channel, run at cpu mode
[ 1.274261] 5a070000.serial: ttyLP1 at MMIO 0x5a070010 (irq = 53, base_baud = 5000000) is a FSL_LPUART
[ 1.285111] 5a080000.serial: ttyLP2 at MMIO 0x5a080010 (irq = 54, base_baud = 5000000) is a FSL_LPUART
[ 1.323403] imx8-dpr-channel 560d0000.dpr-channel: Linked as a consumer to 56040000.prg
[ 1.331922] imx8-dpr-channel 560e0000.dpr-channel: Linked as a consumer to 56050000.prg
[ 1.339984] imx8-dpr-channel 560e0000.dpr-channel: Linked as a consumer to 56040000.prg
[ 1.348497] imx8-dpr-channel 560f0000.dpr-channel: Linked as a consumer to 56060000.prg
[ 1.359067] imx8-dpr-channel 56100000.dpr-channel: Linked as a consumer to 56070000.prg
[ 1.367120] imx8-dpr-channel 56100000.dpr-channel: Linked as a consumer to 56080000.prg
[ 1.377608] imx8-dpr-channel 56110000.dpr-channel: Linked as a consumer to 56090000.prg
[ 1.385661] imx8-dpr-channel 56110000.dpr-channel: Linked as a consumer to 560a0000.prg
[ 1.396187] imx8-dpr-channel 56120000.dpr-channel: Linked as a consumer to 560b0000.prg
[ 1.404240] imx8-dpr-channel 56120000.dpr-channel: Linked as a consumer to 560c0000.prg
[ 1.415899] dpu-core 56180000.dpu: Linked as a consumer to 56100000.dpr-channel
[ 1.423293] dpu-core 56180000.dpu: Linked as a consumer to 56110000.dpr-channel
[ 1.430660] dpu-core 56180000.dpu: Linked as a consumer to 560f0000.dpr-channel
[ 1.438047] dpu-core 56180000.dpu: Linked as a consumer to 56120000.dpr-channel
[ 1.445395] dpu-core 56180000.dpu: Linked as a consumer to 56020000.pixel-combiner
[ 1.453831] dpu-core 56180000.dpu: driver probed
[ 1.462992] adv7511 17-003d: 17-003d supply avdd not found, using dummy regulator
[ 1.470561] adv7511 17-003d: 17-003d supply dvdd not found, using dummy regulator
[ 1.478090] adv7511 17-003d: 17-003d supply pvdd not found, using dummy regulator
[ 1.485622] adv7511 17-003d: 17-003d supply a2vdd not found, using dummy regulator
[ 1.493258] adv7511 17-003d: 17-003d supply v3p3 not found, using dummy regulator
[ 1.500793] adv7511 17-003d: 17-003d supply v1p2 not found, using dummy regulator
[ 1.508822] adv7511 17-003d: Probe failed. Remote port '/mipi_dsi_bridge@56228000' disabled
[ 1.517483] adv7511 18-003d: 18-003d supply avdd not found, using dummy regulator
[ 1.525138] adv7511 18-003d: 18-003d supply dvdd not found, using dummy regulator
[ 1.532673] adv7511 18-003d: 18-003d supply pvdd not found, using dummy regulator
[ 1.540198] adv7511 18-003d: 18-003d supply a2vdd not found, using dummy regulator
[ 1.547810] adv7511 18-003d: 18-003d supply v3p3 not found, using dummy regulator
[ 1.555339] adv7511 18-003d: 18-003d supply v1p2 not found, using dummy regulator
[ 1.563367] adv7511 18-003d: Probe failed. Remote port '/mipi_dsi_bridge@56248000' disabled
[ 1.627910] it6263 17-004c: Probe failed. Remote port '/ldb@562210e0/lvds-channel@0' disabled
[ 1.692236] it6263 18-004c: Probe failed. Remote port '/ldb@562410e0/lvds-channel@0' disabled
[ 1.707023] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.713687] [drm] No driver support for vblank timestamp query.
[ 1.719696] dpu-core 56180000.dpu: Linked as a consumer to 560d0000.dpr-channel
[ 1.727047] dpu-core 56180000.dpu: Linked as a consumer to 560e0000.dpr-channel
[ 1.734391] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 1.742830] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 1.750349] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 1.757732] nwl_dsi-imx mipi_dsi@56228000: No bridge found, skipping encoder creation
[ 1.765591] imx-drm display-subsystem: bound mipi_dsi@56228000 (ops imx_nwl_dsi_component_ops)
[ 1.774300] nwl_dsi-imx mipi_dsi@56248000: No bridge found, skipping encoder creation
[ 1.782156] imx-drm display-subsystem: bound mipi_dsi@56248000 (ops imx_nwl_dsi_component_ops)
[ 1.790827] [drm] Cannot find any crtc or sizes
[ 1.795836] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[ 1.811321] loop: module loaded
[ 1.815693] input: fxos8700 as /devices/platform/i2c-rpbus-14/i2c-14/14-001e/input/input0
[ 1.825988] fxos8700 device driver probe successfully
[ 1.826836] input: fxas2100x as /devices/platform/i2c-rpbus-14/i2c-14/14-0021/input/input1
[ 1.840901] fxas2100x 14-0021: fxas2100x device driver probe successfully
[ 1.853559] slram: not enough parameters.
[ 1.863016] libphy: Fixed MDIO Bus: probed
[ 1.867530] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 1.873550] tun: Universal TUN/TAP device driver, 1.6
[ 1.878836] CAN device driver interface
[ 1.886862] fec 5b040000.ethernet: 5b040000.ethernet supply phy not found, using dummy regulator
[ 1.896091] pps pps0: new PPS source ptp0
[ 1.905144] libphy: fec_enet_mii_bus: probed
[ 1.910477] fec 5b040000.ethernet eth0: registered PHC device 0
[ 1.917687] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.923545] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.929542] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.936549] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.942177] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.950020] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.956872] sky2: driver version 1.30
[ 1.966147] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.972703] ehci-pci: EHCI PCI platform driver
[ 1.977258] ehci-platform: EHCI generic platform driver
[ 1.982978] ehci-orion: EHCI orion driver
[ 1.987307] ehci-exynos: EHCI EXYNOS driver
[ 1.991767] ehci-msm: Qualcomm On-Chip EHCI Host Controller
[ 1.997574] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.003787] ohci-pci: OHCI PCI platform driver
[ 2.008331] ohci-platform: OHCI generic platform driver
[ 2.013887] ohci-exynos: OHCI EXYNOS driver
[ 2.019446] usbcore: registered new interface driver usb-storage
[ 2.025603] usbcore: registered new interface driver usb_ehset_test
[ 2.034142] usbmisc_imx 5b0d0200.usbmisc: 5b0d0200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 2.049126] input: sc-powerkey as /devices/platform/sc-powerkey/input/input2
[ 2.057793] read mpl3115 chip id 0xc4
[ 2.061637] input: mpl3115 as /devices/virtual/input/input3
[ 2.068189] mpl3115 device driver probe successfully
[ 2.068563] isl29023 15-0044: 15-0044 supply vdd not found, using dummy regulator
[ 2.088512] input: isl29023 light sensor as /devices/virtual/input/input4
[ 2.095687] isl29023 15-0044: driver version 1.0 enabled
[ 2.103439] imx_sc_rtc rtc: rtc core: registered rtc as rtc0
[ 2.109905] i2c /dev entries driver
[ 2.118241] IR NEC protocol handler initialized
[ 2.122794] IR RC5(x/sz) protocol handler initialized
[ 2.127857] IR RC6 protocol handler initialized
[ 2.132393] IR JVC protocol handler initialized
[ 2.136936] IR Sony protocol handler initialized
[ 2.141565] IR SANYO protocol handler initialized
[ 2.146277] IR Sharp protocol handler initialized
[ 2.150993] IR MCE Keyboard/mouse protocol handler initialized
[ 2.156844] IR XMP protocol handler initialized
[ 2.171023] mxc-mipi-csi2 58227000.csi: mipi_csi2_probe
[ 2.198785] mxc-parallel-csi 58261000.pcsi: mxc_parallel_csi_probe probe successfully
[ 2.208191] ov5640_v3 5-003c: 5-003c supply DOVDD not found, using dummy regulator
[ 2.215837] ov5640_v3 5-003c: 5-003c supply DVDD not found, using dummy regulator
[ 2.223390] ov5640_v3 5-003c: 5-003c supply AVDD not found, using dummy regulator
[ 2.284243] ov5640_read_reg:write reg error:reg=300a
[ 2.289262] camera ov5640 is not found
[ 2.304263] max9286_mipi 16-006a: max9286_read_reg:read reg error: reg=1e
[ 2.311071] max9286 is not found, chip id reg 0x1e = 0xffffffff.
[ 2.318286] mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
[ 2.324742] mx8-img-md: Registered mxc_isi.1.capture as /dev/video1
[ 2.331160] mx8-img-md: Registered mxc_isi.2.capture as /dev/video2
[ 2.337573] mx8-img-md: Registered mxc_isi.3.capture as /dev/video3
[ 2.344000] mx8-img-md: Registered mxc_isi.4.capture as /dev/video4
[ 2.350400] mxc-isi 58140000.isi: register m2m device success
[ 2.356499] mxc-isi 58100000.isi: mxc_md_unregister_all unregister ISI channel[0]
[ 2.364123] mxc-isi 58110000.isi: mxc_md_unregister_all unregister ISI channel[1]
[ 2.371729] mxc-isi 58120000.isi: mxc_md_unregister_all unregister ISI channel[2]
[ 2.379323] mxc-isi 58130000.isi: mxc_md_unregister_all unregister ISI channel[3]
[ 2.386928] mxc-isi 58140000.isi: mxc_md_unregister_all unregister ISI channel[4]
[ 2.396429] mxc-jpeg 58400000.jpegdec: decoder device registered as /dev/video0 (81,0)
[ 2.405933] mxc-jpeg 58450000.jpegenc: encoder device registered as /dev/video1 (81,1)
[ 2.422649] Bluetooth: HCI UART driver ver 2.3
[ 2.427122] Bluetooth: HCI UART protocol H4 registered
[ 2.432271] Bluetooth: HCI UART protocol BCSP registered
[ 2.437599] Bluetooth: HCI UART protocol ATH3K registered
[ 2.443006] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.449533] Bluetooth: HCI UART protocol Broadcom registered
[ 2.455208] Bluetooth: HCI UART protocol QCA registered
[ 2.461800] sdhci: Secure Digital Host Controller Interface driver
[ 2.468001] sdhci: Copyright(c) Pierre Ossman
[ 2.472853] Synopsys Designware Multimedia Card Interface Driver
[ 2.481144] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.489014] mmc0: CQHCI version 5.10
[ 2.536173] mmc0: SDHCI controller on 5b010000.usdhc [5b010000.usdhc] using ADMA
[ 2.548718] mmc1: CQHCI version 5.10
[ 2.552449] sdhci-esdhc-imx 5b020000.usdhc: Got CD GPIO
[ 2.557710] sdhci-esdhc-imx 5b020000.usdhc: Got WP GPIO
[ 2.608263] mmc1: SDHCI controller on 5b020000.usdhc [5b020000.usdhc] using ADMA
[ 2.651836] mmc0: new HS400 MMC card at address 0001
[ 2.651839] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.657137] caam 31400000.caam: ERA source: device tree.
[ 2.663571] mmcblk0: mmc0:0001 R1J57L 29.1 GiB
[ 2.673273] mmcblk0boot0: mmc0:0001 R1J57L partition 1 8.00 MiB
[ 2.679740] mmcblk0boot1: mmc0:0001 R1J57L partition 2 8.00 MiB
[ 2.680230] caam algorithms registered in /proc/crypto
[ 2.686114] mmcblk0rpmb: mmc0:0001 R1J57L partition 3 4.00 MiB
[ 2.693777] caam_jr 31430000.jr2: registering rng-caam
[ 2.702611] caam 31400000.caam: caam pkc algorithms registered in /proc/crypto
[ 2.712973] platform caam_sm: blkkey_ex: 8 keystore units available
[ 2.719418] platform caam_sm: 64-bit clear key:
[ 2.723974] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.729696] platform caam_sm: 64-bit black key:
[ 2.734260] platform caam_sm: [0000] f9 c2 f2 c8 47 9f 32 02
[ 2.739938] platform caam_sm: [0008] a9 dc 7e d4 f2 63 d2 68
[ 2.745614] platform caam_sm: 128-bit clear key:
[ 2.750242] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.755930] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.761610] random: fast init done
[ 2.765031] platform caam_sm: 128-bit black key:
[ 2.769661] platform caam_sm: [0000] 66 8e cb 26 0e e2 18 bb
[ 2.775335] platform caam_sm: [0008] 79 d7 bd 4c 2b b3 7e c2
[ 2.781011] platform caam_sm: 192-bit clear key:
[ 2.785675] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.791355] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.797037] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.802705] platform caam_sm: 192-bit black key:
[ 2.807346] platform caam_sm: [0000] 78 2c 98 14 22 6b 69 8b
[ 2.813039] platform caam_sm: [0008] 40 da b9 fe 79 e2 17 9e
[ 2.818741] platform caam_sm: [0016] 5b 0d c6 e2 52 e7 e9 c6
[ 2.824436] platform caam_sm: [0024] a3 fe 7f 7f 84 47 90 22
[ 2.830122] platform caam_sm: 256-bit clear key:
[ 2.834774] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.840466] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.846163] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.851853] platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
[ 2.857537] platform caam_sm: 256-bit black key:
[ 2.862187] platform caam_sm: [0000] 6e d9 a0 ee 4f 6a 73 9d
[ 2.867885] platform caam_sm: [0008] 64 0b 90 8a 80 22 54 6c
[ 2.873576] platform caam_sm: [0016] d7 bc a5 7d 63 32 be a1
[ 2.879271] platform caam_sm: [0024] 97 cc 49 e8 26 83 0b 7d
[ 2.880285] mmc1: new high speed SDHC card at address aaaa
[ 2.884941] platform caam_sm: 64-bit unwritten blob:
[ 2.891119] mmcblk1: mmc1:aaaa SA16G 14.8 GiB
[ 2.895403] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.895411] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.911246] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.911267] mmcblk1: p1 p2
[ 2.916938] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.925395] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.931101] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.936774] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.942447] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.948122] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.953804] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.959484] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.965154] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.970834] platform caam_sm: 128-bit unwritten blob:
[ 2.975908] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.981583] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.987255] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.992928] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.998601] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 3.004274] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 3.009946] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 3.015620] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 3.021295] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.026966] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.032641] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.038316] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.043990] platform caam_sm: 196-bit unwritten blob:
[ 3.049060] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 3.054731] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 3.060404] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 3.066079] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 3.071750] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 3.077423] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 3.083097] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 3.088769] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 3.094443] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.100126] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.105796] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.111469] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.117147] platform caam_sm: 256-bit unwritten blob:
[ 3.122209] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 3.127880] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 3.133555] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 3.139225] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 3.144899] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 3.150573] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 3.156247] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 3.161917] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 3.167592] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.173263] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.178936] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.184609] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.190411] platform caam_sm: 64-bit black key in blob:
[ 3.195688] platform caam_sm: [0000] c9 b4 bf 4a 55 3e 22 66
[ 3.201361] platform caam_sm: [0008] bc eb 88 7b 27 b0 77 dc
[ 3.207034] platform caam_sm: [0016] b7 2e 0b f3 2f 6d 74 ee
[ 3.212705] platform caam_sm: [0024] e6 af 00 b5 8d b7 a9 40
[ 3.218377] platform caam_sm: [0032] 05 a5 46 77 27 29 01 3a
[ 3.224052] platform caam_sm: [0040] f9 f2 27 24 fb 2f 57 de
[ 3.229723] platform caam_sm: [0048] a1 a1 46 a7 2c 07 d6 72
[ 3.235396] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 3.241071] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.246742] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.252415] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.258090] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.263760] platform caam_sm: 128-bit black key in blob:
[ 3.269089] platform caam_sm: [0000] a4 c0 68 f0 5a 02 b8 db
[ 3.274761] platform caam_sm: [0008] 24 f7 e2 b4 f2 c9 70 32
[ 3.280433] platform caam_sm: [0016] 14 68 a1 03 fd 64 9a 6d
[ 3.286105] platform caam_sm: [0024] d7 6c ba eb a4 87 5e a0
[ 3.291778] platform caam_sm: [0032] 6f 94 80 86 b4 04 1b db
[ 3.297451] platform caam_sm: [0040] 63 2f 94 29 44 5d 32 13
[ 3.303124] platform caam_sm: [0048] 8c a3 43 e5 6d 49 fb 0a
[ 3.308797] platform caam_sm: [0056] 38 62 07 8d 2f 82 ca 18
[ 3.314472] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.320143] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.325816] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.331491] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.337158] platform caam_sm: 192-bit black key in blob:
[ 3.342489] platform caam_sm: [0000] 87 7a 46 e4 67 ad 25 24
[ 3.348162] platform caam_sm: [0008] d6 ba cb df 5f 78 c2 40
[ 3.353833] platform caam_sm: [0016] 6a 0a 23 32 47 bd 7f 1b
[ 3.359506] platform caam_sm: [0024] 15 8d 5a c2 f4 88 e2 a4
[ 3.365181] platform caam_sm: [0032] 75 93 c8 b3 75 56 be 92
[ 3.370852] platform caam_sm: [0040] 1e cd 0b e8 02 ba dd 13
[ 3.376525] platform caam_sm: [0048] 0a 43 25 08 80 ff 67 39
[ 3.382200] platform caam_sm: [0056] 7d 40 e9 93 32 9c 44 a8
[ 3.387873] platform caam_sm: [0064] f7 94 10 9f 37 23 1c 39
[ 3.393543] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.399216] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.404889] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.410561] platform caam_sm: 256-bit black key in blob:
[ 3.415890] platform caam_sm: [0000] d9 b4 04 0c bb 80 61 4b
[ 3.421561] platform caam_sm: [0008] e5 2a 90 1a fc 3d 59 13
[ 3.427233] platform caam_sm: [0016] f6 b1 b8 3f 5a a0 0d b8
[ 3.432907] platform caam_sm: [0024] f9 2e ed 18 04 06 d8 c4
[ 3.438581] platform caam_sm: [0032] f2 a0 b5 52 36 a8 78 e6
[ 3.444253] platform caam_sm: [0040] 6d d8 b9 9e 63 3e dd e4
[ 3.449930] platform caam_sm: [0048] 96 06 73 e1 4e a1 64 34
[ 3.455610] platform caam_sm: [0056] 10 dc ee 1d 04 87 24 29
[ 3.461282] platform caam_sm: [0064] 62 22 73 0e 86 8f 12 10
[ 3.466953] platform caam_sm: [0072] 20 b2 b7 ef 8a 1e e7 35
[ 3.472628] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.478299] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.484076] platform caam_sm: restored 64-bit black key:
[ 3.489407] platform caam_sm: [0000] 80 04 50 b0 aa ca 91 bd
[ 3.495086] platform caam_sm: [0008] 82 56 07 14 52 f5 9b 40
[ 3.500753] platform caam_sm: restored 128-bit black key:
[ 3.506171] platform caam_sm: [0000] 66 8e cb 26 0e e2 18 bb
[ 3.511841] platform caam_sm: [0008] 79 d7 bd 4c 2b b3 7e c2
[ 3.517511] platform caam_sm: restored 192-bit black key:
[ 3.522929] platform caam_sm: [0000] 78 2c 98 14 22 6b 69 8b
[ 3.528599] platform caam_sm: [0008] 40 da b9 fe 79 e2 17 9e
[ 3.534272] platform caam_sm: [0016] 0a 27 54 f0 85 85 94 d1
[ 3.539947] platform caam_sm: [0024] 7d fe a9 5a dd 2f b2 00
[ 3.545615] platform caam_sm: restored 256-bit black key:
[ 3.551030] platform caam_sm: [0000] 6e d9 a0 ee 4f 6a 73 9d
[ 3.556706] platform caam_sm: [0008] 64 0b 90 8a 80 22 54 6c
[ 3.562376] platform caam_sm: [0016] d7 bc a5 7d 63 32 be a1
[ 3.568049] platform caam_sm: [0024] 97 cc 49 e8 26 83 0b 7d
[ 3.574856] usbcore: registered new interface driver usbhid
[ 3.580458] usbhid: USB HID core driver
[ 3.601247] optee: probing for conduit method from DT.
[ 3.606733] optee: initialized driver
[ 3.628325] cs42xx8 5-0048: found device, revision 4
[ 3.638359] ***** imx8qm_acm_init *****
[ 3.674688] imx-cs42888 sound-cs42888: cs42888 <-> 59010000.esai mapping ok
[ 3.684206] imx-cs42888 sound-cs42888: snd-soc-dummy-dai <-> 59000000.asrc mapping ok
[ 3.692185] imx-cs42888 sound-cs42888: cs42888 <-> 59010000.esai mapping ok
[ 3.699223] imx-cs42888 sound-cs42888: ASoC: no DMI vendor name!
[ 3.707941] imx-wm8960 sound: wm8960-hifi <-> 59050000.sai mapping ok
[ 3.714452] imx-wm8960 sound: ASoC: no source widget found for ASRC-Playback
[ 3.721525] imx-wm8960 sound: ASoC: Failed to add route ASRC-Playback -> direct -> CPU-Playback
[ 3.730245] imx-wm8960 sound: ASoC: no sink widget found for ASRC-Capture
[ 3.737052] imx-wm8960 sound: ASoC: Failed to add route CPU-Capture -> direct -> ASRC-Capture
[ 3.745602] imx-wm8960 sound: ASoC: no DMI vendor name!
[ 3.863985] imx-amix sound-amix-sai: DAI FE name:HiFi-AMIX-FE-sai@59820000
[ 3.870967] imx-amix sound-amix-sai: DAI FE name:HiFi-AMIX-FE-sai@59830000
[ 3.878331] imx-amix sound-amix-sai: snd-soc-dummy-dai <-> 59820000.sai mapping ok
[ 3.885993] imx-amix sound-amix-sai: snd-soc-dummy-dai <-> 59830000.sai mapping ok
[ 3.893623] imx-amix sound-amix-sai: snd-soc-dummy-dai <-> amix-0 mapping ok
[ 3.900734] imx-amix sound-amix-sai: snd-soc-dummy-dai <-> amix-1 mapping ok
[ 3.907827] imx-amix sound-amix-sai: ASoC: no DMI vendor name!
[ 3.916662] NET: Registered protocol family 26
[ 3.921721] NET: Registered protocol family 10
[ 3.926978] Segment Routing with IPv6
[ 3.930704] NET: Registered protocol family 17
[ 3.935161] can: controller area network core (rev 20170425 abi 9)
[ 3.941393] NET: Registered protocol family 29
[ 3.945853] can: raw protocol (rev 20170425)
[ 3.950134] can: broadcast manager protocol (rev 20170425 t)
[ 3.955832] can: netlink gateway (rev 20170425) max_hops=1
[ 3.961519] Bluetooth: RFCOMM TTY layer initialized
[ 3.966422] Bluetooth: RFCOMM socket layer initialized
[ 3.971589] Bluetooth: RFCOMM ver 1.11
[ 3.975358] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.980678] Bluetooth: BNEP filters: protocol multicast
[ 3.985924] Bluetooth: BNEP socket layer initialized
[ 3.990902] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.996839] Bluetooth: HIDP socket layer initialized
[ 4.001856] lib80211: common routines for IEEE802.11 drivers
[ 4.007569] 9pnet: Installing 9P2000 support
[ 4.011910] Key type dns_resolver registered
[ 4.016881] registered taskstats version 1
[ 4.036754] imx8_cpufreq_init: cluster 0 running at freq 1200 MHz, suspend freq 1200 MHz
[ 4.057430] OF: PCI: host bridge /pcie@0x5f010000 ranges:
[ 4.062860] OF: PCI: No bus range found for /pcie@0x5f010000, using [bus 00-ff]
[ 4.070376] OF: PCI: IO 0x7ff80000..0x7ff8ffff -> 0x00000000
[ 4.076320] OF: PCI: MEM 0x70000000..0x7fefffff -> 0x70000000
[ 4.083934] imx6q-pcie 5f010000.pcie: pcie phy pll is locked.
[ 4.162720] imx6q-pcie 5f010000.pcie: Speed change timeout
[ 4.168218] imx6q-pcie 5f010000.pcie: Roll back to GEN1 link!
[ 4.173978] imx6q-pcie 5f010000.pcie: Link up, Gen1
[ 4.180077] imx6q-pcie 5f010000.pcie: PCI host bridge to bus 0000:00
[ 4.186473] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.191970] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 4.198164] pci_bus 0000:00: root bus resource [mem 0x70000000-0x7fefffff]
[ 4.206616] pci 0000:00:00.0: BAR 0: assigned [mem 0x70000000-0x70ffffff 64bit]
[ 4.213960] pci 0000:00:00.0: BAR 6: assigned [mem 0x71000000-0x71ffffff pref]
[ 4.221209] pci 0000:00:00.0: BAR 14: assigned [mem 0x72000000-0x720fffff]
[ 4.228118] pci 0000:01:00.0: BAR 0: assigned [mem 0x72000000-0x72001fff 64bit]
[ 4.235491] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 4.240735] pci 0000:00:00.0: bridge window [mem 0x72000000-0x720fffff]
[ 4.248538] pcieport 0000:00:00.0: Signaling PME with IRQ 407
[ 4.254443] pcieport 0000:00:00.0: AER enabled with IRQ 408
[ 4.276715] imx_sc_rtc rtc: setting system clock to 2019-09-06 10:36:28 UTC (1567766188)
[ 4.287268] fec2_nvcc: disabling
[ 4.290565] usb_otg1_vbus: disabling
[ 4.294156] ALSA device list:
[ 4.297155] #0: cs42888-audio
[ 4.300313] #1: wm8960-audio
[ 4.303364] #2: amix-audio-sai
[ 4.335028] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.343924] VFS: Mounted root (ext4 filesystem) on device 179:130.
[ 4.359103] devtmpfs: mounted
[ 4.362502] Freeing unused kernel memory: 1280K
[ 4.681006] systemd[1]: systemd 237 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 4.703015] systemd[1]: Detected architecture arm64.
Welcome to NXP i.MX Release Distro 4.14-sumo (sumo)!
[ 4.726245] systemd[1]: Set hostname to <imx8qxpmek>.
[ 4.889114] systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 4.906279] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 5.097232] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.103955] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 5.120259] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.127645] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 5.144225] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.151146] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 5.173139] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 5.200275] systemd[1]: Reached target Host and Network Name Lookups.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Created slice System Slice.
[ OK ] Listening on Journal Audit Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Created slice system-getty.slice.
[ OK ] Listening on Syslog Socket.
[ OK ] Listening on Journal Socket.
Mounting Kernel Debug File System...
Starting Create list of required st…ce nodes for the current kernel...
Starting Setup Virtual Console...
Starting Load Kernel Modules...
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on Journal Socket (/dev/log).
Starting Journal Service...
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 5.421195] galcore: loading out-of-tree module taints kernel.
[ 5.438610] Galcore version 6.2.4.190076
Starting Remount Root and Kernel File Systems...
[ OK ] Listening on udev Kernel Socket.
[ 5.483525] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
Starting udev Coldplug all Devices...
Mounting Temporary Directory (/tmp)...
[ OK ] Reached target Paths.
[ OK ] Listening on Network Service Netlink Socket.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Slices.
Mounting Huge Pages File System...
Mounting POSIX Message Queue File System...
[ OK ] Mounted Kernel Debug File System.
[ OK ] Started Journal Service.
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Mounted Huge Pages File System.
[ OK ] Mounted POSIX Message Queue File System.
Starting Rebuild Hardware Database...
Starting Create System Users...
Mounting Kernel Configuration File System...
Starting Apply Kernel Variables...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Create System Users.
[ OK ] Mounted Kernel Configuration File System.
[ OK ] Started Apply Kernel Variables.
Starting Create Static Device Nodes in /dev...
[ 5.933720] systemd-journald[2225]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Containers.
Mounting /var/volatile...
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Rebuild Dynamic Linker Cache...
Starting Rebuild Journal Catalog...
Starting Create Volatile Files and Directories...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started Rebuild Journal Catalog.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started Rebuild Dynamic Linker Cache.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Rebuild Hardware Database.
Starting udev Kernel Device Manager...
Starting Update is Completed...
[ OK ] Started Update is Completed.
[ OK ] Started udev Kernel Device Manager.
Starting Start Psplash Boot Screen...
[ OK ] Reached target System Initialization.
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
Starting Console System Startup Logging...
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Started Daily rotation of log files.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started D-Bus System Message Bus.
[ 7.998201] [VPU Encoder] enable mu for core[0]
[ 8.011165] [VPU Encoder] vpu encoder core[0] firmware version is 1.2.2
Starting RPC Bind Service...
Starting Telephony service...
Starting System Logging Service...
Starting Connection service...
[ OK ] Started Job spooling tools.
[ OK ] Started Configuration for i.MX GPU (Former rc_gpu.S).
[ OK ] Started Periodic Command Scheduler.
Starting Login Service...
Starting Network Time Service (one-shot ntpdate mode)...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started TEE Supplicant.
Starting Network Service...
[ OK ] Started Start Psplash Boot Screen.
[ OK ] Started Console System Startup Logging.
[ OK ] Started RPC Bind Service.
[ OK ] Started System Logging Service.
[ OK ] Started Network Time Service (one-shot ntpdate mode).
[ OK ] Found device /dev/ttyLP0.
[ OK ] Started Network Service.
[ OK ] Started Telephony service.
[ OK ] Started Login Service.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Connection service.
Starting Hostname Service...
Starting WPA supplicant...
[ 8.748982] Atheros 8031 ethernet 5b040000.ethernet-1:00: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=5b040000.ethernet-1:00, irq=POLL)
[ 8.764374] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Starting Save/Restore Sound Card State...
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight…s of backlight:lvds_backlight@1...
[ 8.813215] fsl-amix 59840000.amix: MIXCLK: A started TDM1 is required for configuration propagation!
Starting Load/Save Screen Backlight…s of backlight:lvds_backlight@0...
Starting Rotate log files...
Starting Kernel Logging Service...
[ OK ] Started Updates psplash to basic.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started Load/Save Screen Backlight …ess of backlight:lvds_backlight@1.
[ OK ] Started Load/Save Screen Backlight …ess of backlight:lvds_backlight@0.
[ OK ] Started Rotate log files.
[ OK ] Started WPA supplicant.
[ OK ] Started Hostname Service.
[ OK ] Reached target Network.
[ OK ] Started Update psplash to network.
Starting Terminate Psplash Boot Screen...
Starting /etc/rc.local Compatibility...
Starting Permit User Sessions...
[ OK ] Started NFS status monitor for NFSv2/3 locking..
[ OK ] Reached target Sound Card.
[FAILED] Failed to start Terminate Psplash Boot Screen.
See 'systemctl status psplash-quit.service' for details.
[ OK ] Started /etc/rc.local Compatibility.
[ OK ] Started Permit User Sessions.
Starting Weston Wayland Compositor (on tty7)...
[ OK ] Started Serial Getty on ttyLP0.
[ OK ] Started Getty on tty1.
[ OK ] Started Weston Wayland Compositor (on tty7).
[ OK ] Created slice User Slice of root.
Starting User Manager for UID 0...
[ 9.398890] audit: type=1006 audit(1567766193.616:2): pid=3828 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[ OK ] Started Session c1 of user root.
[ OK ] Started Kernel Logging Service.
[ OK ] Started User Manager for UID 0.
Stopping User Manager for UID 0...
[ OK ] Stopped User Manager for UID 0.
[ OK ] Removed slice User Slice of root.
[ 10.320409] fsl-amix 59840000.amix: MIXCLK: A started TDM1 is required for configuration propagation!
[ 12.849172] fec 5b040000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.856994] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.888990] 8021q: 802.1Q VLAN Support v1.8
NXP i.MX Release Distro 4.14-sumo imx8qxpmek ttyLP0
imx8qxpmek login: rio oot
Last login: Fri Sep 6 10:36:33 UTC 2019 on tty7
[ 19.005457] audit: type=1006 audit(1567766203.224:3): pid=3844 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=2 res=1
root@imx8qxpmek:~#
root@imx8qxpmek:~#
root@imx8qxpmek:~# ifonf config -a
eth0 Link encap:Ethernet HWaddr 00:04:9f:05:ca:a6
inet addr:192.168.50.12 Bcast:192.168.50.255 Mask:255.255.255.0
inet6 addr: fe80::204:9fff:fe05:caa6/64 Scope:Link
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:105 errors:0 dropped:0 overruns:0 frame:0
TX packets:56 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:13725 (13.4 KiB) TX bytes:9089 (8.8 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:82 errors:0 dropped:0 overruns:0 frame:0
TX packets:82 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6220 (6.0 KiB) TX bytes:6220 (6.0 KiB)
root@imx8qxpmek:~# cat /proc/version
root@imx8qxpmek:~#
root@imx8qxpmek:~# cd /proc
root@imx8qxpmek:/proc# ls
1 19 2205 3614 3845 814 fb net
10 1901 2206 3616 3849 9 filesystems pagetypeinfo
1009 1902 2208 3632 3855 902 fs partitions
1010 1917 2216 3657 4 921 interrupts self
1049 1922 2219 3663 40 922 iomem slabinfo
1054 2 2220 3664 42 95 ioports softirqs
11 20 2225 3667 5 asound irq stat
1137 2018 2229 3681 50 bd71837 kallsyms swaps
12 2019 2237 3691 53 buddyinfo key-users sys
13 2032 2244 3703 578 bus keys sysrq-trigger
14 2055 23 3706 6 cgroups kmsg sysvipc
15 2057 24 3709 7 cmdline kpagecgroup thread-self
16 2060 25 3719 702 config.gz kpagecount timer_list
17 21 26 3745 703 consoles kpageflags tty
1758 2162 27 3754 705 cpuinfo loadavg uptime
1759 2165 28 3798 706 crypto locks version
18 2195 29 3808 707 device-tree meminfo vmallocinfo
1870 2197 3 3816 708 devices misc vmstat
1891 2198 30 3825 709 diskstats modules zoneinfo
1895 22 33 3826 711 driver mounts
1897 2204 3612 3844 8 execdomains mtd
root@imx8qxpmek:/proc# cat m cmdline
Aubineau_FAE
What are your u-boot environment variables?
Did you try with official baked images as I suggested?
V.
notify1forme
Hi, vincent.aubineau
Thank you for your helping me out
I solve the problem for CAN not detected.
Actually I download command named 'uuu uuu.auto' that makes me happy for CAN which is working well
Question 1.
Why do I get to fail to get the same condition without modification? 4.14.98_2.0.0_ga
=> I Just follow the rules written in documentation in yocto release.
petersonhou
How did you figure out detecting the can device? Thanks for you sharing
notify1forme
Hi, vincent.aubineau.
I've changed dtb file as you suggested "fsl-imx8qxp-mek.dtb" but I got messages continuously.
and I don't see a cursor at the end of booting. there are messages  circulated like it below
 [ 3.476049] imx-drm display-subsystem: master bind failed: -517
[ 3.504521] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.511173] [drm] No driver support for vblank timestamp query.
[ 3.517218] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.525456] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.532797] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.540174] imx-drm display-subsystem: failed to bind ldb@562210e0 (ops imx_ldb_ops): -517
[ 3.548614] imx-drm display-subsystem: master bind failed: -517
I always thankful to you for handling it sincerely.
U-Boot 2018.03-imx_v2018.03_4.14.98_2.0.0_ga+g87a19df5e4 (Aug 20 2019 - 07:50:46 +0000)
Board: iMX8QXP MEK
Boot: SD1
DRAM: 2.8 GiB
Loading Environment from MMC... OK
In: serial
Out: serial
Err: serial
BuildInfo:
- U-Boot 2018.03-imx_v2018.03_4.14.98_2.0.0_ga+g87a19df5e4
Net: eth0: ethernet@5b040000 [PRIME]
Warning: ethernet@5b050000 (eth1) using random MAC address - 9e:de:b3:b0:6e:13
Fastboot: Normal
Normal Boot
Hit any key to stop autoboot: 0
83068 bytes read in 17 ms (4.7 MiB/s)
Using Device Tree in place at 0000000083000000, end 000000008301747b
Disable intmux@37400000, resource id 289 not owned
Disable i2c@37230000, resource id 288 not owned
Disable i2c@5a810000, resource id 97 not owned
Disable can@5a8d0000, resource id 105 not owned
Disable can@5a8e0000, resource id 106 not owned
Disable flexspi@05d120000, resource id 237 not owned
/dma-controller@591F0000, 62444
/dma-controller@599F0000, 63332
/dma-controller@5a1f0000, 61568
Starting kernel ...
[ 0.000000] Linux version 4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 SMP PREEMPT Mon Au9
[ 0.000000] NUMA: NODE_DATA [mem 0x8bff78d80-0x8bff7ab7f]
[ 0.000000] percpu: Embedded 24 pages/cpu @ffff80083ff13000 s57624 r8192 d32488 u98304
[ 0.000000] Memory: 1749004K/2871296K available (13564K kernel code, 1692K rwdata, 6052K rodata, 1280K init, 434K bss, 139252K reserve)
[ 0.011329] Console: colour dummy device 80x25
[ 0.015505] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.025689] pid_max: default: 32768 minimum: 301
[ 0.030369] Security Framework initialized
[ 0.035655] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.043172] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.049916] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.056591] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.079770] ASID allocator initialised with 32768 entries
[ 0.092861] Hierarchical SRCU implementation.
[ 0.106300] *****Initialized MU
[ 0.109151] ***** imx8_init_pm_domains *****
[ 0.114561] CPU identified as i.MX8QXP, silicon rev 1.1
[ 0.121232] EFI services will not be available.
[ 0.133478] smp: Bringing up secondary CPUs ...
[ 0.166451] Detected VIPT I-cache on CPU1
[ 0.166482] GICv3: CPU1: found redistributor 1 region 0:0x0000000051b20000
[ 0.166516] CPU1: Booted secondary processor [410fd042]
[ 0.194475] Detected VIPT I-cache on CPU2
[ 0.194496] GICv3: CPU2: found redistributor 2 region 0:0x0000000051b40000
[ 0.194513] CPU2: Booted secondary processor [410fd042]
[ 0.222532] Detected VIPT I-cache on CPU3
[ 0.222550] GICv3: CPU3: found redistributor 3 region 0:0x0000000051b60000
[ 0.222567] CPU3: Booted secondary processor [410fd042]
[ 0.222627] smp: Brought up 1 node, 4 CPUs
[ 0.274609] SMP: Total of 4 processors activated.
[ 0.279296] CPU features: detected feature: GIC system register CPU interface
[ 0.286433] CPU features: detected feature: 32-bit EL0 Support
[ 0.292249] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.304631] CPU: All CPU(s) started at EL2
[ 0.308399] alternatives: patching kernel code
[ 0.313583] devtmpfs: initialized
[ 0.330476] random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
[ 0.339402] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.348858] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.378398] pinctrl core: initialized pinctrl subsystem
[ 0.385721] DMI not present or invalid.
[ 0.389627] NET: Registered protocol family 16
[ 0.397798] cpuidle: using governor menu
[ 0.402967] vdso: 2 pages (1 code @ ffff000008dc6000, 1 data @ ffff0000094f4000)
[ 0.410058] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.423037] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.429557] Serial: AMBA PL011 UART driver
[ 0.433491] imx rpmsg driver is registered.
[ 0.440095] MU and Power domains initialized
[ 0.444053] ***** imx8qxp_clocks_init *****
[ 0.522111] imx8qxp-pinctrl iomuxc: initialized IMX pinctrl driver
[ 0.557106] mxs_phy 5b100000.usbphy: 5b100000.usbphy supply phy-3p0 not found, using dummy regulator
[ 0.595756] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.626797] ACPI: Interpreter disabled.
[ 0.640170] vgaarb: loaded
[ 0.642882] SCSI subsystem initialized
[ 0.646788] usbcore: registered new interface driver usbfs
[ 0.652095] usbcore: registered new interface driver hub
[ 0.657341] usbcore: registered new device driver usb
[ 0.663100] usb_phy_generic usbphynop1: usbphynop1 supply vcc not found, using dummy regulator
[ 0.674925] i2c i2c-16: LPI2C adapter registered
[ 0.681898] i2c i2c-17: LPI2C adapter registered
[ 0.688158] i2c i2c-18: LPI2C adapter registered
[ 0.696354] media: Linux media interface: v0.10
[ 0.700615] Linux video capture interface: v2.00
[ 0.705321] pps_core: LinuxPPS API ver. 1 registered
[ 0.710108] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.719252] PTP clock support registered
[ 0.723513] EDAC MC: Ver: 3.0.0
[ 0.726614] dmi: Firmware registration failed.
[ 0.732298] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.742355] Advanced Linux Sound Architecture Driver Initialized.
[ 0.748823] Bluetooth: Core ver 2.22
[ 0.752086] NET: Registered protocol family 31
[ 0.756498] Bluetooth: HCI device and connection manager initialized
[ 0.762837] Bluetooth: HCI socket layer initialized
[ 0.767703] Bluetooth: L2CAP socket layer initialized
[ 0.772752] Bluetooth: SCO socket layer initialized
[ 0.778450] clocksource: Switched to clocksource arch_sys_counter
[ 0.784351] VFS: Disk quotas dquot_6.6.0
[ 0.788175] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.795129] pnp: PnP ACPI: disabled
[ 0.805153] NET: Registered protocol family 2
[ 0.809845] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.817119] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.824077] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.830418] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.836373] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.842912] NET: Registered protocol family 1
[ 0.847601] RPC: Registered named UNIX socket transport module.
[ 0.853189] RPC: Registered udp transport module.
[ 0.857874] RPC: Registered tcp transport module.
[ 0.862566] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.870268] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.878324] kvm [1]: 8-bit VMID
[ 0.882171] kvm [1]: GICv3: no GICV resource entry
[ 0.886635] kvm [1]: disabling GICv2 emulation
[ 0.891085] kvm [1]: GIC system register CPU interface enabled
[ 0.896961] kvm [1]: vgic interrupt IRQ1
[ 0.900885] kvm [1]: Hyp mode initialized successfully
[ 0.908672] audit: initializing netlink subsys (disabled)
[ 0.913859] audit: type=2000 audit(0.812:1): state=initialized audit_enabled=0 res=1
[ 0.914233] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[ 0.934764] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.941043] NFS: Registering the id_resolver key type
[ 0.945794] Key type id_resolver registered
[ 0.949944] Key type id_legacy registered
[ 0.953942] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.960760] jffs2: version 2.2. (NAND) 2001-2006 Red Hat, Inc.
[ 0.967373] 9p: Installing v9fs 9p2000 file system support
[ 0.977683] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.984801] io scheduler noop registered
[ 0.988822] io scheduler cfq registered (default)
[ 0.993411] io scheduler mq-deadline registered
[ 0.997875] io scheduler kyber registered
[ 1.028654] pwm-backlight lvds_backlight@0: lvds_backlight@0 supply power not found, using dummy regulator
[ 1.039774] pwm-backlight lvds_backlight@1: lvds_backlight@1 supply power not found, using dummy regulator
[ 1.059674] mxs-dma 5b810000.dma-apbh: initialized
[ 1.066830] Bus freq driver module loaded
[ 1.079599] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.089411] SuperH (H)SCI(F) driver initialized
[ 1.095131] msm_serial: driver initialized
[ 1.100554] 5a060000.serial: ttyLP0 at MMIO 0x5a060010 (irq = 52, base_baud = 5000000) is a FSL_LPUAR[ 1.111743] console [ttyLP0] ed
[ 1.111743] console [ttyLP0] enabled
[ 1.118784] bootconsole [lpuart32] disabled
[ 1.127495] fsl-lpuart 5a060000.serial: NO DMA tx channel, run at cpu mode
[ 1.134394] fsl-lpuart 5a060000.serial: NO DMA rx channel, run at cpu mode
[ 1.142288] 5a070000.serial: ttyLP1 at MMIO 0x5a070010 (irq = 53, base_baud = 5000000) is a FSL_LPUART
[ 1.153172] 5a080000.serial: ttyLP2 at MMIO 0x5a080010 (irq = 54, base_baud = 5000000) is a FSL_LPUART
[ 1.163360] imx8qxp-pinctrl iomuxc: pin_config_set op failed for pin 110
[ 1.170103] fsl-lpuart 5a090000.serial: Error applying setting, reverse things back
[ 1.178556] 5a090000.serial: ttyLP3 at MMIO 0x5a090010 (irq = 55, base_baud = 5000000) is a FSL_LPUART
[ 1.217681] imx8-dpr-channel 560d0000.dpr-channel: Linked as a consumer to 56040000.prg
[ 1.226211] imx8-dpr-channel 560e0000.dpr-channel: Linked as a consumer to 56050000.prg
[ 1.234270] imx8-dpr-channel 560e0000.dpr-channel: Linked as a consumer to 56040000.prg
[ 1.242827] imx8-dpr-channel 560f0000.dpr-channel: Linked as a consumer to 56060000.prg
[ 1.253410] imx8-dpr-channel 56100000.dpr-channel: Linked as a consumer to 56070000.prg
[ 1.261470] imx8-dpr-channel 56100000.dpr-channel: Linked as a consumer to 56080000.prg
[ 1.271991] imx8-dpr-channel 56110000.dpr-channel: Linked as a consumer to 56090000.prg
[ 1.280046] imx8-dpr-channel 56110000.dpr-channel: Linked as a consumer to 560a0000.prg
[ 1.290574] imx8-dpr-channel 56120000.dpr-channel: Linked as a consumer to 560b0000.prg
[ 1.298629] imx8-dpr-channel 56120000.dpr-channel: Linked as a consumer to 560c0000.prg
[ 1.310311] dpu-core 56180000.dpu: Linked as a consumer to 56100000.dpr-channel
[ 1.317704] dpu-core 56180000.dpu: Linked as a consumer to 56110000.dpr-channel
[ 1.325063] dpu-core 56180000.dpu: Linked as a consumer to 560f0000.dpr-channel
[ 1.332450] dpu-core 56180000.dpu: Linked as a consumer to 56120000.dpr-channel
[ 1.339802] dpu-core 56180000.dpu: Linked as a consumer to 56020000.pixel-combiner
[ 1.348222] dpu-core 56180000.dpu: driver probed
[ 1.357257] adv7511 17-003d: 17-003d supply avdd not found, using dummy regulator
[ 1.364823] adv7511 17-003d: 17-003d supply dvdd not found, using dummy regulator
[ 1.372361] adv7511 17-003d: 17-003d supply pvdd not found, using dummy regulator
[ 1.379915] adv7511 17-003d: 17-003d supply a2vdd not found, using dummy regulator
[ 1.387523] adv7511 17-003d: 17-003d supply v3p3 not found, using dummy regulator
[ 1.395050] adv7511 17-003d: 17-003d supply v1p2 not found, using dummy regulator
[ 1.403100] adv7511 17-003d: Probe failed. Remote port '/mipi_dsi_bridge@56228000' disabled
[ 1.411766] adv7511 18-003d: 18-003d supply avdd not found, using dummy regulator
[ 1.419394] adv7511 18-003d: 18-003d supply dvdd not found, using dummy regulator
[ 1.426927] adv7511 18-003d: 18-003d supply pvdd not found, using dummy regulator
[ 1.434466] adv7511 18-003d: 18-003d supply a2vdd not found, using dummy regulator
[ 1.442092] adv7511 18-003d: 18-003d supply v3p3 not found, using dummy regulator
[ 1.449627] adv7511 18-003d: 18-003d supply v1p2 not found, using dummy regulator
[ 1.457637] adv7511 18-003d: Probe failed. Remote port '/mipi_dsi_bridge@56248000' disabled
[ 1.473383] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.480029] [drm] No driver support for vblank timestamp query.
[ 1.486038] dpu-core 56180000.dpu: Linked as a consumer to 560d0000.dpr-channel
[ 1.493413] dpu-core 56180000.dpu: Linked as a consumer to 560e0000.dpr-channel
[ 1.500762] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 1.509215] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 1.516720] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 1.524092] imx-drm display-subsystem: failed to bind ldb@562210e0 (ops imx_ldb_ops): -517
[ 1.532561] imx-drm display-subsystem: master bind failed: -517
[ 1.546121] loop: module loaded
[ 1.555109] slram: not enough parameters.
[ 1.564414] libphy: Fixed MDIO Bus: probed
[ 1.568996] NXP PHY: loading NXP PHY driver: [autonomous mode]
[ 1.575061] tun: Universal TUN/TAP device driver, 1.6
[ 1.580334] CAN device driver interface
[ 1.588313] fec 5b040000.ethernet: 5b040000.ethernet supply phy not found, using dummy regulator
[ 1.597516] pps pps0: new PPS source ptp0
[ 1.606725] libphy: fec_enet_mii_bus: probed
[ 1.612017] fec 5b040000.ethernet eth0: registered PHC device 0
[ 1.619219] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.625075] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.631072] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 1.638057] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.643681] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 1.651526] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.658325] sky2: driver version 1.30
[ 1.667564] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.674128] ehci-pci: EHCI PCI platform driver
[ 1.678685] ehci-platform: EHCI generic platform driver
[ 1.684400] ehci-orion: EHCI orion driver
[ 1.688703] ehci-exynos: EHCI EXYNOS driver
[ 1.693148] ehci-msm: Qualcomm On-Chip EHCI Host Controller
[ 1.698956] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.705175] ohci-pci: OHCI PCI platform driver
[ 1.709712] ohci-platform: OHCI generic platform driver
[ 1.715272] ohci-exynos: OHCI EXYNOS driver
[ 1.720906] usbcore: registered new interface driver usb-storage
[ 1.726991] usbcore: registered new interface driver usb_ehset_test
[ 1.735435] usbmisc_imx 5b0d0200.usbmisc: 5b0d0200.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.749937] input: sc-powerkey as /devices/platform/sc-powerkey/input/input0
[ 1.760180] imx_sc_rtc rtc: rtc core: registered rtc as rtc0
[ 1.766669] i2c /dev entries driver
[ 1.774275] IR NEC protocol handler initialized
[ 1.778832] IR RC5(x/sz) protocol handler initialized
[ 1.783902] IR RC6 protocol handler initialized
[ 1.788447] IR JVC protocol handler initialized
[ 1.792995] IR Sony protocol handler initialized
[ 1.797620] IR SANYO protocol handler initialized
[ 1.802340] IR Sharp protocol handler initialized
[ 1.807056] IR MCE Keyboard/mouse protocol handler initialized
[ 1.812905] IR XMP protocol handler initialized
[ 1.827196] mxc-mipi-csi2 58227000.csi: mipi_csi2_probe
[ 1.853105] mxc-parallel-csi 58261000.pcsi: mxc_parallel_csi_probe probe successfully
[ 1.874608] max9286_mipi 16-006a: max9286_read_reg:read reg error: reg=1e
[ 1.881421] max9286 is not found, chip id reg 0x1e = 0xffffffff.
[ 1.888630] mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
[ 1.895059] mx8-img-md: Registered mxc_isi.1.capture as /dev/video1
[ 1.901483] mx8-img-md: Registered mxc_isi.2.capture as /dev/video2
[ 1.907897] mx8-img-md: Registered mxc_isi.3.capture as /dev/video3
[ 1.914320] mx8-img-md: Registered mxc_isi.4.capture as /dev/video4
[ 1.920731] mxc-isi 58140000.isi: register m2m device success
[ 1.926850] mxc-isi 58100000.isi: mxc_md_unregister_all unregister ISI channel[0]
[ 1.934472] mxc-isi 58110000.isi: mxc_md_unregister_all unregister ISI channel[1]
[ 1.942065] mxc-isi 58120000.isi: mxc_md_unregister_all unregister ISI channel[2]
[ 1.949670] mxc-isi 58130000.isi: mxc_md_unregister_all unregister ISI channel[3]
[ 1.957276] mxc-isi 58140000.isi: mxc_md_unregister_all unregister ISI channel[4]
[ 1.966779] mxc-jpeg 58400000.jpegdec: decoder device registered as /dev/video0 (81,0)
[ 1.976307] mxc-jpeg 58450000.jpegenc: encoder device registered as /dev/video1 (81,1)
[ 1.992654] Bluetooth: HCI UART driver ver 2.3
[ 1.997134] Bluetooth: HCI UART protocol H4 registered
[ 2.002282] Bluetooth: HCI UART protocol BCSP registered
[ 2.007610] Bluetooth: HCI UART protocol ATH3K registered
[ 2.013017] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.019513] Bluetooth: HCI UART protocol Broadcom registered
[ 2.025185] Bluetooth: HCI UART protocol QCA registered
[ 2.031779] sdhci: Secure Digital Host Controller Interface driver
[ 2.037986] sdhci: Copyright(c) Pierre Ossman
[ 2.042853] Synopsys Designware Multimedia Card Interface Driver
[ 2.051061] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.058927] mmc0: CQHCI version 5.10
[ 2.106473] mmc0: SDHCI controller on 5b010000.usdhc [5b010000.usdhc] using ADMA
[ 2.118885] mmc1: CQHCI version 5.10
[ 2.122607] sdhci-esdhc-imx 5b020000.usdhc: Got CD GPIO
[ 2.127866] sdhci-esdhc-imx 5b020000.usdhc: Got WP GPIO
[ 2.178600] mmc1: SDHCI controller on 5b020000.usdhc [5b020000.usdhc] using ADMA
[ 2.221470] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.221612] mmc0: new HS400 MMC card at address 0001
[ 2.232931] caam 31400000.caam: ERA source: device tree.
[ 2.233319] mmcblk0: mmc0:0001 R1J57L 29.1 GiB
[ 2.243402] mmcblk0boot0: mmc0:0001 R1J57L partition 1 8.00 MiB
[ 2.249805] caam algorithms registered in /proc/crypto
[ 2.249861] mmcblk0boot1: mmc0:0001 R1J57L partition 2 8.00 MiB
[ 2.261341] caam_jr 31430000.jr2: registering rng-caam
[ 2.261424] mmcblk0rpmb: mmc0:0001 R1J57L partition 3 4.00 MiB
[ 2.267100] caam 31400000.caam: caam pkc algorithms registered in /proc/crypto
[ 2.282711] platform caam_sm: blkkey_ex: 8 keystore units available
[ 2.289126] platform caam_sm: 64-bit clear key:
[ 2.293674] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.299367] platform caam_sm: 64-bit black key:
[ 2.303938] platform caam_sm: [0000] 15 eb bb 09 04 60 ce 94
[ 2.309620] platform caam_sm: [0008] 1d 4c 92 29 d2 b6 ba e7
[ 2.315292] platform caam_sm: 128-bit clear key:
[ 2.319930] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.325620] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.331300] platform caam_sm: 128-bit black key:
[ 2.336005] platform caam_sm: [0000] 76 47 c7 28 e8 ea 3d 64
[ 2.341685] platform caam_sm: [0008] f3 a8 c6 16 52 46 54 37
[ 2.347359] platform caam_sm: 192-bit clear key:
[ 2.352004] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.357701] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.363373] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.369043] platform caam_sm: 192-bit black key:
[ 2.373675] platform caam_sm: [0000] 8c d4 d6 51 cc 46 69 64
[ 2.379359] platform caam_sm: [0008] 1e 03 1d 26 63 d9 10 f8
[ 2.385049] platform caam_sm: [0016] 6f 37 34 d3 8b 7c 59 a5
[ 2.390741] platform caam_sm: [0024] 0e 64 74 f0 53 6e 1f 03
[ 2.396435] platform caam_sm: 256-bit clear key:
[ 2.401089] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.406785] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 2.412474] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 2.418175] platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
[ 2.423854] platform caam_sm: 256-bit black key:
[ 2.428507] platform caam_sm: [0000] f9 cb 77 f3 4a 41 65 ac
[ 2.434205] platform caam_sm: [0008] bb 4a de 7d f0 0b 59 8a
[ 2.439891] platform caam_sm: [0016] ea e3 99 9d ce b7 04 7c
[ 2.445573] platform caam_sm: [0024] bc de 10 41 9f 70 c4 3f
[ 2.446615] mmc1: new high speed SDHC card at address aaaa
[ 2.451254] platform caam_sm: 64-bit unwritten blob:
[ 2.457402] mmcblk1: mmc1:aaaa SA16G 14.8 GiB
[ 2.461722] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.471913] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.471915] mmcblk1: p1 p2
[ 2.480409] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.486093] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.491766] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.497443] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.503122] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.508806] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.514484] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.520161] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.525837] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.531512] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.537181] platform caam_sm: 128-bit unwritten blob:
[ 2.542249] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.547926] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.553604] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.559275] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.564949] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.570622] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.576293] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.581967] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.587641] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.593314] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.598985] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.604658] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.610329] platform caam_sm: 196-bit unwritten blob:
[ 2.615398] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.621068] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.626764] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.632444] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.638122] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.643797] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.649468] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.655141] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.660818] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.666487] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.672160] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.677835] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.683502] platform caam_sm: 256-bit unwritten blob:
[ 2.688572] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 2.694245] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 2.699916] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 2.705589] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 2.711264] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 2.716935] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 2.722608] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 2.728283] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.733956] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.739627] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.745300] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.750975] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.756758] platform caam_sm: 64-bit black key in blob:
[ 2.762004] platform caam_sm: [0000] d6 0d fc 43 9d d1 20 9b
[ 2.767682] platform caam_sm: [0008] 1b eb 2d d2 5d db 2f 88
[ 2.773352] platform caam_sm: [0016] bd 9e 35 f2 b5 93 cc 70
[ 2.779025] platform caam_sm: [0024] 26 d7 88 d3 84 96 eb a1
[ 2.784700] platform caam_sm: [0032] fb db 1f 6d 88 c3 02 0c
[ 2.790371] platform caam_sm: [0040] 35 81 10 f9 c7 1c f1 14
[ 2.796044] platform caam_sm: [0048] c6 53 11 61 b2 50 f5 5d
[ 2.801718] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 2.807393] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.813072] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.818746] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.824417] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.830089] platform caam_sm: 128-bit black key in blob:
[ 2.835420] platform caam_sm: [0000] 91 23 14 38 ef 10 82 22
[ 2.841088] platform caam_sm: [0008] 59 4c 83 39 6b 48 fb 1e
[ 2.846762] platform caam_sm: [0016] 06 0c df c3 16 21 02 3f
[ 2.852434] platform caam_sm: [0024] fc 68 c0 68 ef e5 82 35
[ 2.858107] platform caam_sm: [0032] 98 83 56 15 ef 2f 05 bb
[ 2.863780] platform caam_sm: [0040] 52 d2 f3 fd 4a 97 06 af
[ 2.869453] platform caam_sm: [0048] 63 89 63 a9 ec da ed 52
[ 2.875128] platform caam_sm: [0056] c0 22 63 16 11 76 c9 8d
[ 2.880799] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 2.886472] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.892147] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.897817] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.903487] platform caam_sm: 192-bit black key in blob:
[ 2.908820] platform caam_sm: [0000] 0f 4d d3 86 35 06 d4 97
[ 2.914489] platform caam_sm: [0008] ef cb 7c 74 03 d9 68 28
[ 2.920162] platform caam_sm: [0016] d8 57 90 75 66 d7 cb c0
[ 2.925837] platform caam_sm: [0024] a4 db 93 a9 32 f3 21 f3
[ 2.931508] platform caam_sm: [0032] 74 9b 4d eb f2 c9 cd 08
[ 2.937181] platform caam_sm: [0040] df 36 a0 eb 14 e6 77 31
[ 2.942856] platform caam_sm: [0048] 58 46 ad a5 ff 35 e6 a5
[ 2.948555] platform caam_sm: [0056] 91 0c 5a 0e ff a4 9d 00
[ 2.954229] platform caam_sm: [0064] 04 5f b1 d7 e9 6b 01 ef
[ 2.959899] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 2.965571] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 2.971244] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 2.976916] platform caam_sm: 256-bit black key in blob:
[ 2.982245] platform caam_sm: [0000] 0b 1b 6e b5 18 6d a4 60
[ 2.987916] platform caam_sm: [0008] ce da a9 13 04 9e 8b 75
[ 2.993589] platform caam_sm: [0016] 10 21 15 36 99 14 e0 01
[ 2.999264] platform caam_sm: [0024] 59 e2 15 23 f3 6a 98 02
[ 3.004935] platform caam_sm: [0032] 91 ef 59 cd ae 0e e2 cf
[ 3.010608] platform caam_sm: [0040] 7a 2e 04 89 1b bb 8e a5
[ 3.016283] platform caam_sm: [0048] fd 03 32 21 42 a1 17 ea
[ 3.021953] platform caam_sm: [0056] 9b b2 4c d7 9c ab ec 6d
[ 3.027629] platform caam_sm: [0064] 86 d4 4b 5c e8 a9 5c e3
[ 3.033308] platform caam_sm: [0072] 75 8f b4 e4 f3 e4 63 32
[ 3.038981] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.044654] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.050432] platform caam_sm: restored 64-bit black key:
[ 3.055761] platform caam_sm: [0000] 10 8a 32 30 53 24 eb a6
[ 3.061439] platform caam_sm: [0008] f1 26 1f 0b 9a 2e ef 94
[ 3.067114] platform caam_sm: restored 128-bit black key:
[ 3.072524] platform caam_sm: [0000] 76 47 c7 28 e8 ea 3d 64
[ 3.078196] platform caam_sm: [0008] f3 a8 c6 16 52 46 54 37
[ 3.083866] platform caam_sm: restored 192-bit black key:
[ 3.089281] platform caam_sm: [0000] 8c d4 d6 51 cc 46 69 64
[ 3.094955] platform caam_sm: [0008] 1e 03 1d 26 63 d9 10 f8
[ 3.100633] platform caam_sm: [0016] 34 79 d2 d1 6e 6c 42 25
[ 3.106309] platform caam_sm: [0024] ca a4 58 88 12 b3 69 5a
[ 3.111978] platform caam_sm: restored 256-bit black key:
[ 3.117396] platform caam_sm: [0000] f9 cb 77 f3 4a 41 65 ac
[ 3.123067] platform caam_sm: [0008] bb 4a de 7d f0 0b 59 8a
[ 3.128740] platform caam_sm: [0016] ea e3 99 9d ce b7 04 7c
[ 3.134413] platform caam_sm: [0024] bc de 10 41 9f 70 c4 3f
[ 3.141251] usbcore: registered new interface driver usbhid
[ 3.146855] usbhid: USB HID core driver
[ 3.156265] optee: probing for conduit method from DT.
[ 3.161750] optee: initialized driver
[ 3.168971] ***** imx8qm_acm_init *****
[ 3.205171] imx-cs42888 sound-cs42888: failed to find codec platform device
[ 3.212195] imx-cs42888: probe of sound-cs42888 failed with error -22
[ 3.219437] imx-wm8960 sound: failed to find codec platform device
[ 3.225660] imx-wm8960: probe of sound failed with error -22
[ 3.233589] imx-amix sound-amix-sai: DAI FE name:HiFi-AMIX-FE-sai@59820000
[ 3.240577] imx-amix sound-amix-sai: DAI FE name:HiFi-AMIX-FE-sai@59830000
[ 3.247923] imx-amix sound-amix-sai: snd-soc-dummy-dai <-> 59820000.sai mapping ok
[ 3.255589] imx-amix sound-amix-sai: snd-soc-dummy-dai <-> 59830000.sai mapping ok
[ 3.263218] imx-amix sound-amix-sai: snd-soc-dummy-dai <-> amix-0 mapping ok
[ 3.270325] imx-amix sound-amix-sai: snd-soc-dummy-dai <-> amix-1 mapping ok
[ 3.277408] imx-amix sound-amix-sai: ASoC: no DMI vendor name!
[ 3.286107] NET: Registered protocol family 26
[ 3.291153] NET: Registered protocol family 10
[ 3.296424] Segment Routing with IPv6
[ 3.300151] NET: Registered protocol family 17
[ 3.304617] can: controller area network core (rev 20170425 abi 9)
[ 3.310852] NET: Registered protocol family 29
[ 3.315314] can: raw protocol (rev 20170425)
[ 3.319595] can: broadcast manager protocol (rev 20170425 t)
[ 3.325276] can: netlink gateway (rev 20170425) max_hops=1
[ 3.330962] Bluetooth: RFCOMM TTY layer initialized
[ 3.335858] Bluetooth: RFCOMM socket layer initialized
[ 3.341022] Bluetooth: RFCOMM ver 1.11
[ 3.344786] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.350113] Bluetooth: BNEP filters: protocol multicast
[ 3.355357] Bluetooth: BNEP socket layer initialized
[ 3.360330] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.366267] Bluetooth: HIDP socket layer initialized
[ 3.371285] lib80211: common routines for IEEE802.11 drivers
[ 3.376996] 9pnet: Installing 9P2000 support
[ 3.381339] Key type dns_resolver registered
[ 3.386271] registered taskstats version 1
[ 3.406035] imx8_cpufreq_init: cluster 0 running at freq 1200 MHz, suspend freq 1200 MHz
[ 3.431970] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.438621] [drm] No driver support for vblank timestamp query.
[ 3.444660] imx-drm display-subsystem: bound imx-drm-dpu-bliteng.2 (ops dpu_bliteng_ops)
[ 3.452903] imx-drm display-subsystem: bound imx-dpu-crtc.0 (ops dpu_crtc_ops)
[ 3.460262] imx-drm display-subsystem: bound imx-dpu-crtc.1 (ops dpu_crtc_ops)
[ 3.467602] imx-drm display-subsystem: failed to bind ldb@562210e0 (ops imx_ldb_ops): -517
Aubineau_FAE
But what have you compiled exactly? To what I see your are booting a virtualized Linux. So the CAN FD is certainly in the Cortex-M4 partition.
So let restart from scratch.
standard pre-generated images
Can you please try our standard image:
i.MX Software | NXP
Download the image for the i.MX8X MEK board:
Then load it in the eMMC with a USB cable and UUU (Releases · NXPmicro/mfgtools · GitHub ), under Linux should be:
sudo ./uuu uuu.auto‍
Boot the board to see if it works.
Your generated image
Now you know our standard images works, rebuild your image:
bitbake -k fsl-image-validation-imx‍‍
in tmp/deploy/images/<your image name> use uuu once again to load it on your board thru USB.
If you want to load it in eMMC:
sudo ./uuu -b emmc_all imx-boot-imx8qxpmek-sd.bin-flash fsl-image-validation-imx-imx8qxpmek.sdcard.bz2/*‍‍
if you want to load it on a SD card:
sudo ./uuu -b sd_all imx-boot-imx8qxpmek-sd.bin-flash fsl-image-validation-imx-imx8qxpmek.sdcard.bz2/*‍‍
Test it and it should work like a charm.
Vincent
notify1forme
The result is the same as before, I don't' find any CAN device.
 #> ifconfg -a
notify1forme
As I understand that issue which is related to DUAL LVDS because of trying to bound dpu-crt.o and dpu-crt.1
but I have a daughterboard to monitor named  "IMX-LVDS-HDMI"
it makes the board failed as i see
How about your comment?
and What is the best solution to test?
VincentPark.
notify1forme
HI vincent.aubineau.
The messages made in the console was by "drivers/gpu/drm/drm_vblank_init.c"
int drm_vblank_init(struct drm_device *dev, unsigned int num_crtcs)
int ret = -ENOMEM;
unsigned int i;
spin_lock_init(&dev->vbl_lock);
spin_lock_init(&dev->vblank_time_lock);
DRM_INFO("Supports vblank timestamp caching Rev 2 (21.10.2013).\n");
/* Driver specific high-precision vblank timestamping supported? */
if (dev->driver->get_vblank_timestamp)
DRM_INFO("Driver supports precise vblank timestamp query.\n");
else
DRM_INFO("No driver support for vblank timestamp query.\n");
/* Must have precise timestamping for reliable vblank instant disable */
if (dev->vblank_disable_immediate && !dev->driver->get_vblank_timestamp) {
dev->vblank_disable_immediate = false;
DRM_INFO("Setting vblank_disable_immediate to false because "
"get_vblank_timestamp == NULL\n");
notify1forme
Here is the log message of B.L Which is the default of the released
printenv
auth_os=auth_cntr ${cntr_addr}
baudrate=115200
board_name=MEK
board_rev=iMX8QXP
boot_fdt=try
boot_os=booti ${loadaddr} - ${fdt_addr};
bootcmd=mmc dev ${mmcdev}; if mmc rescan; then if run loadbootscript; then run bootscript; else if test ${sec_boot} = yes; then if run loadcntr; then run mmcboot; else run netboot; fi; else if run loadimage; then run mmcboot; else run netboot; fi; fi; fi; else booti ${loadaddr} - ${fdt_addr}; fi
bootcmd_mfg=run mfgtool_args;if iminfo ${initrd_addr}; then if test ${tee} = yes; then bootm ${tee_addr} ${initrd_addr} ${fdt_addr}; else booti ${loadaddr} ${initrd_addr} ${fdt_addr}; fi; else echo "Run fastboot ..."; fastboot 0; fi;
bootdelay=3
bootscript=echo Running bootscript from mmc ...; source
cntr_addr=0x98000000
cntr_file=os_cntr_signed.bin
commit_atf=1cb68fa
commit_mkimage=dd023400
commit_scfw=f83a2bed
commit_secofw=92ef1143
console=ttyLP0
dom0fdt_file=fsl-imx8qxp-mek-dom0.dtb
earlycon=lpuart32,0x5a060000
emmc_dev=0
ethact=ethernet@5b040000
ethaddr=00:04:9f:05:ca:a6
ethprime=eth0
fastboot_dev=mmc1
fdt_addr=0x83000000
fdt_file=fsl-imx8qxp-mek-rpmsg.dtb
fdt_high=0xffffffffffffffff
fdtcontroladdr=85661208
image=Image
initrd_addr=0x83100000
initrd_high=0xffffffffffffffff
jh_mmcboot=setenv fdt_file fsl-imx8qxp-mek-root.dtb;setenv boot_os 'scu_rm dtb ${fdt_addr}; booti ${loadaddr} - ${fdt_addr};'; run mmcboot;
jh_netboot=setenv fdt_file fsl-imx8qxp-mek-root.dtb;setenv boot_os 'scu_rm dtb ${fdt_addr}; booti ${loadaddr} - ${fdt_addr};'; run netboot;
kboot=booti
loadaddr=0x80280000
loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};
loadcntr=fatload mmc ${mmcdev}:${mmcpart} ${cntr_addr} ${cntr_file}
loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}
loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}
loadm4image_0=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${m4_0_image}
m4_0_image=m4_0.bin
m4boot_0=run loadm4image_0; dcache flush; bootaux ${loadaddr} 0
mfgtool_args=setenv bootargs console=${console},${baudrate} rdinit=/linuxrc clk_ignore_unused
mmcargs=setenv bootargs console=${console},${baudrate} earlycon=${earlycon},${baudrate} root=${mmcroot}
mmcautodetect=yes
mmcboot=echo Booting from mmc ...; run mmcargs; if test ${sec_boot} = yes; then if run auth_os; then run boot_os; else echo ERR: failed to authenticate; fi; else if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if run loadfdt; then run boot_os; else echo WARN: Cannot load the DT; fi; else echo wait for boot; fi;fi;
mmcdev=1
mmcpart=1
mmcroot=/dev/mmcblk1p2 rootwait rw
netargs=setenv bootargs console=${console},${baudrate} earlycon=${earlycon},${baudrate} root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp
netboot=echo Booting from net ...; run netargs; if test ${ip_dyn} = yes; then setenv get_cmd dhcp; else setenv get_cmd tftp; fi; if test ${sec_boot} = yes; then ${get_cmd} ${cntr_addr} ${cntr_file}; if run auth_os; then run boot_os; else echo ERR: failed to authenticate; fi; else ${get_cmd} ${loadaddr} ${image}; if test ${boot_fdt} = yes || test ${boot_fdt} = try; then if ${get_cmd} ${fdt_addr} ${fdt_file}; then run boot_os; else echo WARN: Cannot load the DT; fi; else booti; fi;fi;
panel=NULL
script=boot.scr
sd_dev=1
sec_boot=no
soc_type=imx8qxp
xenboot_common=${get_cmd} ${loadaddr} xen;${get_cmd} ${fdt_addr} ${dom0fdt_file};${get_cmd} ${xenlinux_addr} ${image};fdt addr ${fdt_addr};fdt resize 256;fdt set /chosen/module@0 reg <0x00000000 ${xenlinux_addr} 0x00000000 0x${filesize}>; fdt set /chosen/module@0 bootargs "${bootargs} ${xenlinux_bootargs}"; setenv bootargs ${xenhyper_bootargs};booti ${loadaddr} - ${fdt_addr};
xenhyper_bootargs=console=dtuart dtuart=/serial@5a060000 dom0_mem=2048M dom0_max_vcpus=2 dom0_vcpus_pin=true
xenlinux_addr=0x92000000
xenlinux_bootargs=
xenlinux_console=hvc0 earlycon=xen
xenmmcboot=setenv get_cmd "fatload mmc ${mmcdev}:${mmcpart}";setenv console ${xenlinux_console};run mmcargs;run xenboot_common;
xennetboot=setenv get_cmd dhcp;setenv console ${xenlinux_console};run netargs;run xenboot_common;
Environment size: 4179/8188 bytes
Aubineau_FAE
Your DTB certainly does not contain FlexCAN, consequently you cannot see it.
But Are you using virtualization?
My env. variables:
=> printenv
baudrate=115200
board_name=MEK
board_rev=iMX8QXP
boot_fdt=try
bootdelay=3
cntr_addr=0x88000000
commit_atf=d6451cc
commit_mkimage=2cf091c0
commit_scfw=65afe5f6
commit_secofw=9d71fd5b
console=ttyLP0
emmc_dev=0
ethaddr=00:04:9f:05:57:6d
ethprime=eth0
fastboot_dev=mmc0
fdt_addr=0x83000000
fdt_file=fsl-imx8qxp-mek.dtb
fdtcontroladdr=fd68c308
image=Image
kboot=booti
loadaddr=0x80280000
m4_0_image=m4_0.bin
mmcautodetect=yes
mmcdev=0
mmcpart=1
mmcroot=/dev/mmcblk0p2 rootwait rw
panel=NULL
script=boot.scr
sd_dev=1
sec_boot=no
soc_type=imx8qxp
xenlinux_addr=0x85000000
xenlinux_bootargs=
Environment size: 4173/8188 bytes
Please in u-boot shell, try to change your device tree file:
setenv fdt_file 'fsl-imx8qxp-mek.dtb'
saveenv‍‍
V.
notify1forme
Hi VIncent. aubineau.
I'm trying to test CAN-FD[0..1] but failed to communicate with.
My circumstance is CPU B'd + Base B'd, So compiled the latest Linux Version 4.14.98_2.0.0_ga.
As I see To work with CAN-FDs, Just connect CPU BD + Base B'd and follow the rule you wrote.
But I can't see any can I/F when executing "ifconfig -a", also There is no dev file on /dev
How do I hand with?
Could you help me out?
VincentPark
Aubineau_FAE
Hi Vincent,
By chance I have compiled a 4.14.98_2.0.0_ga yesterday.
I can see the CAN in it:
root@imx8qxpmek:~# uname -a
Linux imx8qxpmek 4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c #1 SMP PREEMPT Fri Apr 26 08:56:40 UTC 2019 aarch64 aarch64 aarch64 GNU/Linux
root@imx8qxpmek:~# ifconfig -a
can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
 NOARP MTU:16 Metric:1
 RX packets:0 errors:0 dropped:0 overruns:0 frame:0
 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
 Interrupt:48
can1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
 Interrupt:49
eth0 Link encap:Ethernet HWaddr 00:04:9f:05:57:6d
 UP BROADCAST MULTICAST DYNAMIC MTU:1500 Metric:1
 RX packets:402 errors:0 dropped:0 overruns:0 frame:0
 TX packets:402 errors:0 dropped:0 overruns:0 carrier:0
 RX bytes:29260 (28.5 KiB) TX bytes:29260 (28.5 KiB)
root@imx8qxpmek:~#‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
What is your bitbake image? not sure it is in core-minimal.
On my side I use the validation:
Vincent
notify1forme
Hi FAE.
I am glad to hear about the testing of FD, Unfortunately, I didn't see any info which was related to CAN.
also, I run
I assembled like this below
CPU +BASEBOARD.
To debug I attached it. I hope that it's one of the clues to solve issue.
IS THERE AN OPTION TO BE MODIFIED FOR THE BOARD OR SOMETHING?
Linux imx8qxpmek 4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c #1 SMP PREEMPT Mon Aug 19 08:07:37 UTC 2019 aarch64 aarcx
inet addr:192.168.50.9 Bcast:192.168.50.255 Mask:255.255.255.0
RX packets:3845 errors:0 dropped:0 overruns:0 frame:0
TX packets:73 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:372349 (363.6 KiB) TX bytes:10999 (10.7 KiB)
RX packets:86 errors:0 dropped:0 overruns:0 frame:0
TX packets:86 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6592 (6.4 KiB) TX bytes:6592 (6.4 KiB)
Linux version 4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 SMP PREEMPT 9
root@imx8qxpmek:~#
Aubineau_FAE
in u-boot, which dtb do you use for Linux (do a printenv in u-boot)?
V.
joanxie
pls refer to the chapter 4.5 FlexCAN of enclosed file:
The FlexCAN on the i.MX 8QuadMax/8QuadXPlus supports CAN FD protocol.
chenchen_xi
Thanks.
I have referred the file.but i think it still need a BASE BOARD which contains a CAN transceiver.
Aubineau_FAE
Correct, you need a baseboard to have the CAN transceivers.
Vincent
Aubineau_FAE
chenchen_xi
Thanks a lot. Is the TJA1043 you mentioned in the BASE BOARD? and does it show can0 interface only when the BASE BOARD connected?
