LWIP: Latest version
saad_saeed
In the latest MCUexpressoSDK 2.5 the lwIP version used is 2.0.3. This version does not give support for DHCPv6 which is available in 2.1.0. What should I do this issue.
Kind Regards,
Saad.
Carlos_Mendoza
Hi Saad,
Could you tell us which MCU are you using?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
saad_saeed
I am using MCUXpresso IDE v10.3.0 [Build 2200] [2018-12-03] along with the latest SDK 2.5.0
danielchen
Hi saad
There is a plan to upgrade Lwip in next SDK release.  The target date maybe in Jun. 2019 .
You also can port it by yourself. Please refer to below links for more details.
https://www.nongnu.org/lwip/2_1_x/upgrading.html
https://www.nongnu.org/lwip/2_1_x/changelog.html
I hope it helps
danielchen
Hi Saad:
Currently lwip 2.1.0 is not supported in SDK. Let me check with the develop team whether they have a plan in the near future. I will update you when I have results.
