How to build fw_printenv and fw_setenv for LS1043ARDB LSDK1803?
jintong_yan
yipingwang
The commands fw_printenv and fw_setenv are integrated in the package u-boot-tools.
This package has already been included in "additional_packages_list" variable in configs/ubuntu/additional_packages_list_moderate, so fw_printenv and fw_setenv should be include in Ubuntu rootfs by default.
If you use tiny Ubuntu rootfs, please add "u-boot-tools" in the variable additional_packages_list in configs/ubuntu/additional_packages_list_tiny, then generate tiny Ubuntu rootfs with the following command.
$ flex-builder -i mkrfs -r ubuntu:tiny -a <arch>
In addition, on the target board you could run "apt-get install u-boot-tools" to install these commands, if you boot up the target board with Ubuntu rootfs filesystem.
TIC
