More than three DAC.
simoneacciarito
Hi everybody. I need to use an MCU with more than three DACs. Can you tell me if there are MCUs in the Kinetis family with this requirement? Thanks in advance.
mjbcswitzerland
Specialist V
Simone
I don't think that there are more than 2 (12-bit DACs) in any of the Kinetis parts.
However, you can also use PWM outputs to generate DAC outputs (add an R/C filter to create the analogue signal)
Mark
PWM:
http://www.utasker.com/docs/uTasker/uTaskerHWTimers.PDF
ADC/DAC:
http://www.utasker.com/docs/uTasker/uTaskerADC.pdf
