Error compiling apexCV related function on S32 design studio for vision
xuewong
Hi all,
I am trying to compile some example application on S32 design studio for vision 2.0 with orb feature extractor from apexcv. However, when i compile the function it always returns undefined reference error to all function in ACF_PROCESS. I make sure that the libacf.a is on the library linker list, so i can not really figure out other reason would caused this problem. Can anyone give me some suggestion on this issue?
The system i am compiling the code is Ubuntu 14.04.
Thanks you
jiri_kral
finally - with the Vision team help - I find out that you need to install gcc and g++ in version 4.9.3 . With this version can be apex2_orb_cv example successfully build on linux machine.
I put request that this limitation should be mentioned in the release notes.
Jiri
jiri_kral
thanks for report - I can reproduce your issue. I created JIRA ticket for S32DS Team.
I try to find out workaround - but not success yet. Only workaround is build the example on windows machine - the issue  is affecting only Linux environment.
Jiri
