eDMA & LPSPI
eDMA & LPSPI
panda_fei
How to configure eDMA and LPSPI to enable LPSPI to transmit and receive data over the eDMA?
可否提供一些例子,
Can you give us some examples?
THX
razva_tilimpea
That delay is caused by the high clock frequency used in your application. This behavior is expected because the IRQ handlers doesn't have enough time to re-fill the buffers.
You can easily convert your example to work with DMA:
1. In DMA component add 2 channels. Let's say that we use channel 0 and channel 1
2. Configure the LPSPI component to work with channels 0 an 1.
3. Configure DMA in your application:
  EDMA_DRV_Init(&dmaController1_State, &dmaController1_InitConfig0, edmaChnStateArray, edmaChnConfigArray, EDMA_CONFIGURED_CHANNELS_COUNT);
If you have problems on receiving side for master device please set SAMPLE bit from CFGR1. This issue will be fixed on our next release.
Razvan
panda_fei
thx
razva_tilimpea
Please check this thread: https://community.nxp.com/message/926395?commentID=926395#comment-926395.
Razvan
panda_fei
can not open the web
panda_fei
Unauthorized
This place or content does not exist or access to it is restricted. If you think this is a mistake, please contact your administrator or the person who directed you here.
