HW GPU Acceleration for X11
electone
Hello All,
I'm trying to enable vivante on userspace using the instructions from https://community.nxp.com/docs/DOC-330147?commentID=42866?sr=search&searchId=330ed732-8f0a-4064-83a3... but I am stuck on the "Adding HW GPU acceleration for X11" section. I am using a custom board based on imx6 sabresd. Currently using i.MX6DL SoC. I am using kernel version 4.1.15 and using Ubuntu 16.04.2 filesystem with xubuntu desktop environment.
On the ""./fastbuild.sh .... " command, I've encountered the first issue - missing the "swaprep.h" but fixed it using this patch.  The second issue is the DRI_1.10.4/scr directory missing, this directory can be found on the previous versions of  xserver-xorg-video-imx-viv, so I downloaded a later version xserver-xorg-video-imx-viv-3.0.35-4.0.0 and tried to copy its DRI_1.10.4 directory to the xserver-xorg-video-imx-viv-5.0.11.p7.4 and build it but still no luck.
Found some similar issues on this but there is no definite answer.
BR,
Elton
eltonreformado
I already solved this issue. Will provide solution later.
gilbertlee
Dear elton,
Could you let me know the solution for this issue?
I`ve tried to solve this ..many times, but I coulnd`t find..
Please help...
electone
Hello Gilbert,
Sorry for the late response.
I 'm still finishing the document.
Will send it to you once done.
Elton
gilbertlee
Hi elton,
It`s very wonderful news..
Thanks very much for your kindly answer.
I'll be waiting for your documents.
electone
Hello Gilbert,
There's a minor problem in Vivante, running glxgears -info freezes the
desktop.
Below are the instructions, if you find the solution of the error, please
let me know.
Elton
On Mon, Jul 17, 2017 at 11:07 AM, gilbertlee <[email protected]>
Bio_TICFSL
Hi Elton,
Glad to heard it works, I encourage you to create a new documentation about 4.1.15 and ubuntu 16.04 for the community.
regards
