Does i.MX6 VPU can support H.264 encode and decode at the same time?
We hope to run h.264 enc/dec by gstreamer as following.
File H.264 720p60 -> H.264 decoder -> H.264 encoder 720p60 2Mbsp -> RTP-UDP
Device plan to use iMX6Quad (not QP).
Linux BSP Rev.: L3.10.53_1.1.0
But current our test, Frame rate of encode result goes to 54fsp.
Do you have any check point to keep frame rate to 60fsp?
Ishii.
