How to add custom cluster on JN5179?
bhavyamathukiya
Hi There,
I want to add custom cluster in HA profile in JN-AN-1216 IOT Control Bridge app for one of my customers' device. Can anyone know how to add support for the same?
limcb
If the end device/joining device already has the custom cluster, you could try to add the custom cluster by editing the *.zpscfg file using the IDE then recompile and try probing the end device's custom cluster for response.
You also probably need to edit some functions to handle the custom cluster.
bhavyamathukiya
Thanks Lim
