Hi shinod AK,
Do you want to download the bootloader code to the chip? Or your chip already have the bootloader code, and you want to download the application code with bootloader?
As you know, the MK21FN1M0AVMC12 don't have the ROM bootloader, so if you want to download the bootloader code to the chip, you need to use the debugger to download it.
If you already download the flash bootloader in K21chip? Where did you get the flash bootloader code for K21, did you write it by yourself?
Please give me more details.
Kerry
