how to migrate from codewarrior to DDC-I OpenArbor
dineshs
dineshs
chip part number MPC5676RRM , I am working in DDC-I OpenArbor IDE  (6.6.4.r80932) .
martin_kovar
we do not have any tool for project migration from CodeWarrior to DDC-I OpenArbor IDE, even this IDE is not NXP product, so I am not able to tell you where is the problem.
From my point of view, the best way for you is to contact DDCI support directly. Please see following link:
Software Trouble Report (STR) – DDC-I
Martin
dineshs
after migration I am getting following errors
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section .sbss lma 0x40009a18 adjusted to 0x4000ec18
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section .bss lma 0x40009a2c adjusted to 0x4000ec2c
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section .interp lma 0x4000ec18 adjusted to 0x400124d0
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section .dynsym lma 0x4000ec2c adjusted to 0x400124e1
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section .dynstr lma 0x4000ec2c adjusted to 0x400124e1
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section .hash lma 0x4000ec3c adjusted to 0x400124ef
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: section `.data' can't be allocated in segment 3
LOAD: .sbss .data .dynamic
BFD: D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5: The first section in the PT_DYNAMIC segment is not the .dynamic section
C:/DDC-I/usr/local/cross-compilers/gcc-4.6.1/bin/powerpc-motorola-elf-objcopy:D:/GSSW/GSS/output/powerpc-motorola-elf/diagnostic/stSTc4t5[.text]: Bad value
ZhangJennie
Please let us know what CodeWarrior version you work with and your chip part number. Thus we can contact the proper engineer to assist you.
Thanks.
Jennie
dineshs
chip part number MPC5676RRM , I am working in DDC-I OpenArbor IDE  (6.6.4.r80932) and  Code Warrior IDE version   5.9.0
ZhangJennie
Hi Dine,
What chip and what version of CW do you work with?
Jennie Zhang
