SPI in /dev not showing in imx6ul custom board
chandraevolute
Contributor V
Below is my SPI DT entries
&ecspi1 {
      fsl,spi-num-chipselects = <0>;
      pinctrl-names = "default";
      pinctrl-0 = <&pinctrl_ecspi1_1>;
      status = "okay";
      spidev@0 {
      compatible = "spidev";
      spi-max-frequency = <20000000>;
      reg = <0>;
                              pinctrl_ecspi1_1: ecspi1grp {
                                             fsl,pins = <
                                                            MX6UL_PAD_LCD_DATA22__ECSPI4_MOSI         0x100b1
                                                            MX6UL_PAD_LCD_DATA20__ECSPI4_SCLK    0x100b1
i have no chip selects as I am using single slave connnected to SPI.
My kernel version is Linux version 3.14.38-6UL_ga
below is the kernel log
gpmi-nand 1806000.gpmi-nand: driver registered.
spi_imx 2008000.ecspi: cannot get the TX DMA channel!
spi_imx 2008000.ecspi: dma setup error,use pio instead
spi_imx 2008000.ecspi: probed
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
2184200.usb supply vbus not found, using dummy regulator
ci_hdrc ci_hdrc.1: doesn't support host
ci_hdrc ci_hdrc.1: no supported roles
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
this is what I found when I searched spi after booting up.
imx6ulevk login: root
root@imx6ulevk:~# find / -name *spi*
/lib/udev/keymaps/acer-aspire_5920g
/lib/udev/keymaps/acer-aspire_5720
/lib/udev/keymaps/acer-aspire_6920
/lib/udev/keymaps/acer-aspire_8930
/sys/bus/spi
/sys/bus/spi/drivers/spidev
/sys/bus/platform/devices/2008000.ecspi
/sys/bus/platform/drivers/spi_gpio
/sys/bus/platform/drivers/spi_imx
/sys/bus/platform/drivers/spi_imx/2008000.ecspi
/sys/bus/platform/drivers/fsl_spi
/sys/bus/platform/drivers/fsl-quadspi
/sys/devices/soc0/soc.0/2000000.aips-bus/2000000.spba-bus/2008000.ecspi
/sys/class/spi_master
/sys/class/spidev
/sys/module/spidev
/proc/irq/63/2008000.ecspi
I am unable to find entry in my /dev folder
Is everything correct or do I need to modify any thing.
Labels (2)
Tags (2)
chandraevolute
Contributor V
got it worked
I changed chiselects from 0 to 1
&ecspi1 {
      fsl,spi-num-chipselects = <1>;
      status = "okay";
      spidev@0 {
      reg = <0>;
chandraevolute
Contributor V
got it worked
&ecspi1 {
      status = "okay";
      spidev@0 {
      reg = <0>;
